|  18.09.2004., 23:17 | #1 |
| Premium Datum registracije: Jun 2002 Lokacija: Tuh. Toplice
					Postovi: 327
				nForce2 cool patch
			 This patch will allow nForce2 chipset based motherboards with AMD cpus to use C2/C1 idle state (S2K bus disconnection and reduce idle/load temperatures by 1-10c degrees dnload: http://www.newgenerationorder.org/C2NGO.zip /edit evo meni pala sa 39 na 33-34, jel netko drugi isprobao mozda?
				__________________ Sempron 2800+ @ 2400 MHz/Epox 8KDA3i/ST passive/GEIL 2x512 MB/Enlight 300 W/9800 Pro/SB Live!/Seagate 320 GB/Pioneer 110D Zadnje izmijenjeno od: Lifo. 19.09.2004. u 04:41. |
|  19.09.2004., 10:25 | #2 |
| ... Datum registracije: Nov 2002 Lokacija: Zagreb
					Postovi: 1,950
				 | aha, i meni je opala tempa pa se nakon 5 min smrzo sistem |
|  19.09.2004., 13:09 | #4 |
| Premium Datum registracije: Sep 2002 Lokacija: Zagreb
					Postovi: 2,721
				 | nije se smrzo i pala za 5 stupnjeva. nije loše   edit: eto kad sam brzoplet, prvo je pala za 1 stupanj, kanije za 5, pa za 7, sad za 9!!! Ili ovaj patch sjebe sondu  ili je stvarno zakon.  A ja sam bio prebrz i prerano pisao pad temperature, trebao se on ohladiti. |
|  19.09.2004., 14:40 | #5 | |
					Postovi: 327
				 | Citiraj:
 Quote: 14 Processors with Half-Frequency Multipliers May Hang Upon Wake-up from Disconnect Products Affected: A4, A5, A6, A7, A9 Normal Specified Operation: The processor should reconnect to the system bus upon wake-up after a disconnect while in the C2 and C3 ACPI low-power states. Non-conformance:The processor uses a special circuit to wake up from a low-power state and reconnect to the system bus when the nominal operating frequency is generated with a half-frequency multiplier. This circuit is rarely observed to glitch when coming out of the C2 and C3 low-power states. Potential Effect on System: The system will hang. Suggested Workaround: Do not use the C2 or C3 ACPI states on processors that run at a nominal operating frequency generated with a half-frequency multiplier. This can be accomplished by having the BIOS not declare C2 or C3 support to the operating system in the Fixed ACPI Description Table (FADT). Resolution Status: Fix planned for a future revision. Also note that all Cx states only apply to the CPU, and no other part of the system. For Cx states to operate correctly, there **MUST** be BIOS support.
				__________________ Sempron 2800+ @ 2400 MHz/Epox 8KDA3i/ST passive/GEIL 2x512 MB/Enlight 300 W/9800 Pro/SB Live!/Seagate 320 GB/Pioneer 110D | |
|  19.09.2004., 15:51 | #8 | |||||||
| Premium Datum registracije: Jun 2004 Lokacija: Kaštela<->Varaždin
					Postovi: 178
				 | E LIFO, Sta si to stavia na silent boost (w/ Panaflo FBL08A12M)?
|  19.09.2004., 16:17 | #9 |
					Postovi: 327
				 | Ma to je originalni vent od silent boosta, samo ovako puno bolje zvuci, zar ne?
|  19.09.2004., 16:39 | #10 |
| hmhm...zzz svima... Datum registracije: Mar 2004 Lokacija: 21000 Split
					Postovi: 1,070
				 | Izgleda da je to i meni bilo uključeno
				__________________ moj zivot se mijenja... iz dana u dan ja kune neman  pozzz svima koju me znaju, a i onima koj ne   |
|  19.09.2004., 20:37 | #11 |
					Postovi: 1,070
				 | Sorry laga san smanjila mi se temp od 4-5 stupnjeva odlična stvarčica  thx
|  19.09.2004., 22:37 | #13 |
| Registered User Datum registracije: Jul 2004 Lokacija: Osijek
					Postovi: 756
				 | Evo kod mene je pala za 10°C , i sve radi OK,ali mi nije jasno dali samo piše da je temp. pala za toliko ili ju je stvarno skinuo za tih 10°,i kod dizanja Windowsa mi pokazuje 36°  i ako ju je doista skinuo za toliko skidam mu kapu  |
|  19.09.2004., 22:45 | #14 | |
| Premium Datum registracije: Mar 2004 Lokacija: Zagreb/Dubrava
					Postovi: 2,869
				 | Citiraj:
|  19.09.2004., 23:04 | #15 |
| Premium Datum registracije: Sep 2004 Lokacija: Mars
					Postovi: 64
				 | I meni je skinulo 5-6 stupnjeva.
				__________________ Athlon 64 3000+ -- Zalman 7000B-Cu -- DFI LanParty UT 250Gb -- 1*512 GEIL value DDR400 -- Sapphire 9800pro -- ZM80D-HP + vent-- Chieftec 360W -- Seagate 80GB -- ZamZung DVD-rom -- Chieftec MIDI Dragon -- Creative Megaworks 5.1-- 795DF -- MX510 -- DX9.0c -- XP pro SP1a -- |
|  20.09.2004., 00:17 | #16 |
| Premium Datum registracije: Sep 2003 Lokacija: Zagreb
					Postovi: 540
				 | meni je skinuo 7-8 stupnjeva  |
|  20.09.2004., 00:27 | #17 |
| Game Master Datum registracije: May 2004 Lokacija: Zagreb
					Postovi: 28
				Ne radi ?
			 Evo meni npr. nije nista snizio temperaturu. Ploca je NF7-S, idle je bio 46 stupnjeva i ostao 46 stupnjeva  a full load se takodjer nije promijenio 56 bio, 56 ostao. Pozdrav
				__________________ Abit NF7-S V2.0 with ZM-NB47J AMD Athlon XP-M 2500+ @ 210*11 (2310 MHz-a) 1.65V Thermalright SLK900A + 92mm Enermax @ potenciometar 2 x 256Mb Kingmax SuperRam DDR433 (8-3-3-2) Sapphire Radeon 9700np @ 360/620 with Zalman ZM80C-HP Seagate 160Gb 7200rpm 8MB S-ATA Antec SLK3700AMB + Fortron 350W LogiTech MX500 & LogiTech UltraX Flat Desktop Hyundai Q995 |
|  20.09.2004., 00:50 | #18 |
| Junior Member Datum registracije: May 2003 Lokacija: Zagreb
					Postovi: 3,205
				 | skino mi je skoro 10 stupnjeva. evo sad dok surfam npr. sto je zanemarivo opterecenje CPU-a. Normalno da pri full load-u ne moze skinuti nista. Evo dok surfam + svira winamp, cca 5stupnjeva manje.
				__________________ |
	|  26.09.2004., 23:52 | #19 |
| Premium Datum registracije: Nov 2003 Lokacija: Sisak
					Postovi: 1,127
				 | Ma svaka čast tim utilityjima, al koju korist imam ak mi je temp.' na full opterećenju ista. Mislim, koja je svrha snižavanja temp u neopterećnemom stanju proca? |
|  27.09.2004., 12:24 | #21 | |
					Postovi: 2,721
				 | Citiraj:
|  27.09.2004., 20:44 | #22 | |
| Moderator Datum registracije: Jun 2003 Lokacija: Kuća
					Postovi: 5,403
				Re: Ne radi ?
				__________________ | |
|  27.09.2004., 23:11 | #23 |
					Postovi: 756
				 | Vigor daj mi reci jer mi nije jasno kako je moguće da sa  Thermalright SLK900A + 92mm Enermax @ 1918rpm imaš 46°C idle, pa kod mene Athlon 2200@2250MHZ sa nekim kusrać Glacialtechom ima manje u idle. Kod tebe definitivno nešto nije kako treba,Mislim Thermalright SLK900A + 92mm Enermax @ 1918rpm šta da ti pričam.....???? |
|  27.09.2004., 23:37 | #24 |
					Postovi: 1,070
				 | tako i meni  na bartonu 2500@2200 200*11 temperatura mi je ideal sa nekin sranjen od 80kn negdi ok 36-39 a u full loadu se popenje do 50
