Staro 18.09.2004., 22:17   #1
Lifo
Datum registracije: Jun 2002
Lokacija: Tuh. Toplice
Postovi: 327
nForce2 cool patch
This patch will allow nForce2 chipset based motherboards with AMD cpus
to use C2/C1 idle state (S2K bus disconnection and reduce idle/load
temperatures by 1-10c degrees
dnload:
http://www.newgenerationorder.org/C2NGO.zip
/edit
evo meni pala sa 39 na 33-34, jel netko drugi isprobao mozda?
Sempron 2800+ @ 2400 MHz/Epox 8KDA3i/ST passive/GEIL 2x512 MB/Enlight 300 W/9800 Pro/SB Live!/Seagate 320 GB/Pioneer 110D
Zadnje izmijenjeno od: Lifo. 19.09.2004. u 03:41.
Lifo je offline   Reply With Quote
Staro 19.09.2004., 09:25   #2
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
aha, i meni je opala tempa pa se nakon 5 min smrzo sistem
Veky je offline   Reply With Quote
Staro 19.09.2004., 10:10   #3
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
Meni je možda 1c opala temp. I nije se smrzo sistem.
Staro 19.09.2004., 12:09   #4
Elven
Elven's Avatar
Datum registracije: Sep 2002
Postovi: 2,721
nije se smrzo i pala za 5 stupnjeva. nije loše
edit: eto kad sam brzoplet, prvo je pala za 1 stupanj, kanije za 5, pa za 7, sad za 9!!! Ili ovaj patch sjebe sondu ili je stvarno zakon. A ja sam bio prebrz i prerano pisao pad temperature, trebao se on ohladiti.
Staro 19.09.2004., 13:40   #5
Lifo
Postovi: 327
This is normally disabled due to the following issue that's noted in AMD's errata pages:
Quote:
14 Processors with Half-Frequency Multipliers May Hang Upon Wake-up from Disconnect
Products Affected: A4, A5, A6, A7, A9
Normal Specified Operation: The processor should reconnect to the system bus upon wake-up after a disconnect while in the C2 and C3 ACPI low-power states.
Non-conformance:The processor uses a special circuit to wake up from a low-power state and reconnect to the system bus when the nominal operating frequency is generated with a half-frequency multiplier. This circuit is rarely observed to glitch when coming out of the C2 and C3 low-power states.
Potential Effect on System: The system will hang.
Suggested Workaround: Do not use the C2 or C3 ACPI states on processors that run at a nominal operating frequency generated with a half-frequency multiplier. This can be accomplished by having the BIOS not declare C2 or C3 support to the operating system in the Fixed ACPI Description Table (FADT).
Resolution Status: Fix planned for a future revision.
Also note that all Cx states only apply to the CPU, and no other part of the system. For Cx states to operate correctly, there **MUST** be BIOS support.
Staro 19.09.2004., 14:01   #6
Freek
Freek's Avatar
Postovi: 2,869
To je ista stvar kao i AMD Soft Cooler,koji mi skine nekih 6-7c.
Staro 19.09.2004., 14:28   #7
spawn
spawn's Avatar
Postovi: 8,355
Meni ne skida nista jer mi je ta opcija izgleda vec ukljucena u bios-u. To bi trebala biti ona opcija CPU DISCONNECT : ENABLED
Staro 19.09.2004., 14:51   #8
Saeta
Saeta's Avatar
Datum registracije: Jun 2004
Lokacija: Kaštela<->Varaždin
Postovi: 178
E LIFO,
Sta si to stavia na silent boost (w/ Panaflo FBL08A12M)?
Untitled Document
DFI Lanparty Rev. B ( TicTac Bios)
Leadtek 6600GT @ 561/1153
AMD Athlon - M 2600+@2525Mhz ( 240*10.5, 1.85V )
Water Cooled by Dr.Ice
HDD 80GB WDD
Enermax 350W
Corsair CMX512-3200C2 rev. 1.1 (2 2 2 9, 3.2V)
Samsung 19" 957DF
Saeta je offline   Reply With Quote
Staro 19.09.2004., 15:17   #9
Lifo
Postovi: 327
Ma to je originalni vent od silent boosta, samo ovako puno bolje zvuci, zar ne?
Staro 19.09.2004., 15:39   #10
maky-st
hmhm...zzz svima...
maky-st's Avatar
Lokacija: 21000 Split
Postovi: 1,070
Izgleda da je to i meni bilo uključeno
Staro 19.09.2004., 19:37   #11
maky-st
hmhm...zzz svima...
maky-st's Avatar
Postovi: 1,070
Sorry laga san smanjila mi se temp od 4-5 stupnjeva odlična stvarčica thx
Staro 19.09.2004., 19:51   #12
Freek
Freek's Avatar
Postovi: 2,869
Meni AMD Soft cooler skine 7-8c. u IDLE.
Staro 19.09.2004., 21:37   #13
Jablan
Jablan's Avatar
Datum registracije: Jul 2004
Lokacija: ZG/Njemacka
Postovi: 756
Evo kod mene je pala za 10°C , i sve radi OK,ali mi nije jasno dali samo piše da je temp. pala za toliko ili ju je stvarno skinuo za tih 10°,i kod dizanja Windowsa mi pokazuje 36° i ako ju je doista skinuo za toliko skidam mu kapu
Jablan je offline   Reply With Quote
Staro 19.09.2004., 21:45   #14
Freek
Freek's Avatar
Postovi: 2,869
Da skien ti ju za toliko.
Staro 19.09.2004., 22:04   #15
Mr.Bean
Mr.Bean's Avatar
Datum registracije: Sep 2004
Lokacija: Mars
Postovi: 64
I meni je skinulo 5-6 stupnjeva.
Athlon 64 3000+ -- Zalman 7000B-Cu -- DFI LanParty UT 250Gb -- 1*512 GEIL value DDR400 -- Sapphire 9800pro -- ZM80D-HP + vent-- Chieftec 360W -- Seagate 80GB -- ZamZung DVD-rom -- Chieftec MIDI Dragon -- Creative Megaworks 5.1-- 795DF -- MX510 -- DX9.0c -- XP pro SP1a --
Mr.Bean je offline   Reply With Quote
Staro 19.09.2004., 23:17   #16
Overvide
Postovi: 537
meni je skinuo 7-8 stupnjeva
Overvide je offline   Reply With Quote
Staro 19.09.2004., 23:27   #17
Vigor
Game Master
Vigor's Avatar
Postovi: 28
Ne radi ?
Evo meni npr. nije nista snizio temperaturu.
Ploca je NF7-S, idle je bio 46 stupnjeva i ostao 46 stupnjeva a full load se takodjer nije promijenio 56 bio, 56 ostao.
Pozdrav
Abit NF7-S V2.0 with ZM-NB47J
AMD Athlon XP-M 2500+ @ 210*11 (2310 MHz-a) 1.65V
Thermalright SLK900A + 92mm Enermax @ potenciometar
2 x 256Mb Kingmax SuperRam DDR433 (8-3-3-2)
Sapphire Radeon 9700np @ 360/620 with Zalman ZM80C-HP
Seagate 160Gb 7200rpm 8MB S-ATA
Antec SLK3700AMB + Fortron 350W
LogiTech MX500 & LogiTech UltraX Flat Desktop
Hyundai Q995
Vigor je offline   Reply With Quote
Staro 19.09.2004., 23:50   #18
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
skino mi je skoro 10 stupnjeva. evo sad dok surfam npr. sto je zanemarivo opterecenje CPU-a. Normalno da pri full load-u ne moze skinuti nista.
Evo dok surfam + svira winamp, cca 5stupnjeva manje.
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 26.09.2004., 22:52   #19
Roller
Lokacija: Sisak
Postovi: 1,127
Ma svaka čast tim utilityjima, al koju korist imam ak mi je temp.' na full opterećenju ista. Mislim, koja je svrha snižavanja temp u neopterećnemom stanju proca?
Roller je offline   Reply With Quote
Staro 26.09.2004., 22:56   #20
Freek
Freek's Avatar
Postovi: 2,869
pa umjesto da mi bude 40c u IDLE od mi bude 33c.
Zašto bi mibio 40c ako može 33c.Veoma jednostavna LOGIKA.
Staro 27.09.2004., 11:24   #21
Elven
Elven's Avatar
Postovi: 2,721
većina korisnika ipak računalo koristi za zadatke koji ne opterećuju previše proc. Sigurno je bolje za procesor da radi 8 sati dnevno na 40 nego na 50 stupnjeva.
Staro 27.09.2004., 19:44   #22
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,398
Re: Ne radi ?
Pozdrav
Mi izgleda smrdimo, pa nam se nije temperatura spustila. Kak je bila tak mi je i ostala.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Amdejac je online   Reply With Quote
Staro 27.09.2004., 22:11   #23
Jablan
Jablan's Avatar
Postovi: 756
Vigor daj mi reci jer mi nije jasno kako je moguće da sa
Thermalright SLK900A + 92mm Enermax @ 1918rpm imaš 46°C idle, pa kod mene Athlon 2200@2250MHZ sa nekim kusrać Glacialtechom ima manje u idle. Kod tebe definitivno nešto nije kako treba,Mislim Thermalright SLK900A + 92mm Enermax @ 1918rpm šta da ti pričam.....????
Staro 27.09.2004., 22:37   #24
maky-st
hmhm...zzz svima...
maky-st's Avatar
Postovi: 1,070
tako i meni na bartonu 2500@2200 200*11 temperatura mi je ideal sa nekin sranjen od 80kn negdi ok 36-39 a u full loadu se popenje do 50
