Staro 12.08.2009., 03:54   #661
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,770
Autor Dizel Pregled postova
Za mene je taj MSI uvijek bila kirvajska firma za sabane koji padaju na farbice i reklamice sa bombarderima i raketlinima na kutijama
mozda i jesu malo kicave kutije, ali bez obzira MSI je zna izbaciti kvalitetne a cijenom pristupacne ploce.. Za bombardere i circu-pipe nemam sto reci
Ovaj Lucid Hydra chip stvarno izgleda zanimljivo.. Sam koncept pruza krajnjim korisnicima vise slobode u odabiru komponenti (citaj grafulja)..
Edit: Btw, svidja mi se ovaj Core i7-870
Zadnje izmijenjeno od: Sn4k3. 12.08.2009. u 04:22.
Sn4k3 je online   Reply With Quote
Staro 17.08.2009., 17:14   #662
Postovi: 7,568
nVidia nForce MCP99 za LGA-1156 procesore
Fresh reports suggest that nVidia indeed has a chipset product lineup planned for Q1 2010, that supports socket LGA-1156 processors, codenamed MCP99. In addition to this, nVidia will also serve up two new LGA-775 chipsets, codenamed MCP85 and MCP89. What's common to all these chipsets is that they embed an integrated graphics processor (IGP). Some of these chipsets feature a 64-bit wide memory channel dedicated to the IGP's memory needs, apart from the 128-bit wide (dual-channel) system memory controller, on the LGA-775 platform. The dedicated memory channel allows the IGP to match entry-level graphics cards in terms of performance, without eating into the system memory. We predict this will be implemented in the same way AMD 780G, 785G and 790GX does, with dedicated memory chips present onboard. The LGA-775 compatible ones will further feature dual-channel DDR3-1333 standard supportive memory controllers for system memory. The MGPU will be named inside the GeForce 200M series.
Izvor: techPowerUp
Staro 19.08.2009., 01:30   #663
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
ASRock P55 Deluxe Bundles SATA III Addon-Card
'upcoming P55 Deluxe advertises SATA III support, and packs a tiny, half-height card that uses PCI-Express (2.0?) x1 interface. At the heart of it is a Marvell 88SE9123 SATA III controller'
Izvor:techpowerup;OCWorkbench
ASUS Prepares First LGA-1156 Workstation Motherboard
'The ASUS P7P55 WS SuperComputer builds on the features of its socket LGA-1366 cousins, by offering as many as five PCI-Express 2.0 x16 slots, a massive 16+3 phase CPU VRM, support for DDR3-2133 by overclocking, and the latest multi-GPU standards support.'
Izvor: techpowerup;XFastest
Staro 19.08.2009., 02:43   #664
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Isprika sto nisam u toku al jel nije trebalo bit da su samo i5 1156 socket.Koliko vidim ovaj i7-860 je i7 a scoket 1156 ? kak to?
jel moze netko objasnit su klasifikaciju ?
Staro 19.08.2009., 03:46   #665
Postovi: 7,568
Pa imaš sve objašnjeno na prethodnim stranicama i linkovima koji su postani. Osim toga i diljem neta je stvarno brdo meterijala o Intelovoj novoj shemi imenovanja.
Staro 19.08.2009., 11:48   #666
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Staro 19.08.2009., 16:18   #667
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
thx skuzio sam sad. Al su sjeb*** sto su ova dva i7 modela ubacili na 1156 socket pa je malo zbunjujuce.
Staro 19.08.2009., 23:22   #668
Postovi: 7,568
Staro 20.08.2009., 00:08   #669
aski
Je suis Schumi
aski's Avatar
Postovi: 1,526
Socket 1156 heatsinks have taken the middle ground with a spacing of 75mm, while Socket 1366 heatsinks use a 80×80mm hole spacing, and 775 mounting is 72mm apart.
Ajde nek vise i to cudo krene
Di sam stao?
Staro 20.08.2009., 00:35   #670
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
O bože, pa ja ne vjerujem.
Heatsinkovi sa i7-ice neće moći bez dodatnih mounting kitova na i5?
Fail
Foxconn je na Bloodrageu napravio odličan posao, ima rupe i za 775 i za i7
Ploča je srednja žalost ali ajde bar nešto
blaa
Staro 20.08.2009., 01:35   #671
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Jos jedno glupo pitanje al me zanima : zasto novi nehalemi imaju "pinove" i s druge strane procesore , ove uz rub ? btw ovaj i5 je super stvarcica samo da ne bude preskup
Staro 20.08.2009., 02:19   #672
Postovi: 7,568
32nm Clarkdale i Havendale Preview - prijevod je koma, ali sve se skuži.
Staro 20.08.2009., 16:07   #673
Postovi: 7,568
Asus Maximus III Gene LGA-1156 ploča
The newest entry into ASUS' already huge lineup of socket LGA-1156 motherboards based on the Intel P55 chipset, is the new Republic of Gamers Maximus III Gene. Unlike the Maximus III Formula, this one is based on the micro-ATX form-factor, with four expansion slots in all, to spare. The LGA-1156 socket is powered by a high-grade 10-phase digital PWM circuit. It is wired to four DDR3 DIMM slots for dual-channel memory. With two PCI-Express 2.0 x16 slots (electically dual x8 when both populated) wired to the CPU, the board utilizes the feature-set of the P55 PCH completely. An open-ended PCI-E x4 is located between the two x16 slots, and a legacy PCI slot below. Connectivity includes gigabit Ethernet, Firewire, USB, eSATA, and 8-channel ASUS SupremeFX X-Fi, implemented in the same way as on Rampage II Gene and Maximus II Gene. The ASUS Maximus III Gene motherboard is expected to start selling by the end of this month, its pricing is yet to be known.
Izvor: techPowerUp
Staro 21.08.2009., 15:57   #674
Postovi: 7,568
Asus TUF Series Sabertooth i55
Here's our Asus LGA-1156, Intel P55 motherboard for the day: TUF Series Sabertooth i55. As a short history lesson, Asus' TUF series motherboards was touted as a parallel to its Republic of Gamers (ROG) series, and was unveiled back in March as the "Marine cool" design, although no products made it to the market. The selling points of TUF series is unparalleled durability and next-generation motherboard components, including "breakthrough innovations in materials--ceramic and metal--for exceptional Cooling". Here's hoping this one does. The Sabertooth i55 comes across as fairly mid-range within the P55 motherboard lineup, as far as features go, but banks heavily on design innovations.
For starters, the CPU is powered by a 12+2 phase VRM, while the four DDR3 DIMM slots rely on a 2-phase VRM. For the greater part of its features, the Intel P55 chipset pitches in. Additional storage controllers provide extra SATA ports, supporting Asus DriveXpert technology. Expansion slots include two PCI-E 2.0 x16 (arrange as x8, x8 in SLi and CrossFireX), two PCI-E x1, and two PCI. Here's where the unique features start: metal heatsinks with ceramic coating that boosts surface area by 50% for better heat dissipation. On the components front, it features durable "TUF-branded" MOSFETs, and capacitors. The DDR3 DIMM slots lack retention clips on one end, a feature implemented by Asus with several recent motherboards, that makes sure the clips don't interfere with installed graphics cards. Although there's adequate clearance on this board, it is utilised by providing a placeholder for a fan dedicated to memory cooling. In a short presentation, Asus describes its innovations. There's no word on its availability and pricing.
Izvor: techPowerUp
Staro 21.08.2009., 16:17   #675
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ajme kako stancaju modele ne bi li nas nabrijali na superarhitekturu...
Keramika, metal, jos samo fali da je oblozena kamenom vunom iz Rockwoola ne bi li se nasjelo da je to nesto najfinije i rucni rad
Staro 21.08.2009., 17:58   #676
Pantera-N
Pantera-N's Avatar
Lokacija: In front of the monitor
Postovi: 1,593
mene cijena zanima.. a ne keramika
Pantera-N je offline   Reply With Quote
Staro 21.08.2009., 18:14   #677
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,770
Normalno cijena igra veliku ulogu, ali neka tih "keramika" i ostalih inovacija..
Staro 21.08.2009., 23:29   #678
Postovi: 7,568
How Much Does it Cost to Build a P55 Motherboard?
The pressure is on the motherboard makers to deliver affordable P55 solutions. Without affordable motherboards, Lynnfield will fail - so Intel and end users are both expecting a healthy supply of ~$100 motherboards. As I’m about to show you, doing so is quite difficult. The socket itself costs a couple of dollars, but even that is significantly more than LGA-775. The bulk of the 1156 socket isn’t the cost of the device, but rather the licensing fee that has to be paid to Intel for each socket. I’ve heard numbers approaching $7 per socket, per board once you include the licensing fees. As volumes go up, the price per socket will go down, but for smaller manufacturers this is a tough pill to swallow. It’s far easier to build an expensive motherboard than it is to build a cheaper one.
If you start at $40 for the motherboard, you’ll need to add another $10 for a 6-layer PCB. A 6-layer PCB is necessary if you want to run SLi at this point, otherwise you can get by with a cheaper $5 4-layer PCB. Mentioning SLi also requires validation and support from nVidia. That’s $30 up front plus an average of $5 per motherboard. P55 motherboards will have a range of 4 to 24-phase power delivery circuitry. Each phase costs about $2 in components although the high end motherboards with high quality MOSFETs/chokes/capacitors will reach $3 per phase.
The power connectors, switches, LEDs, I/O back panel and other components on the motherboard cost anywhere between $8 and $15 depending on the type of motherboard. What about those fancy copper heatpipes and elaborate heatsinks? They start at $6 and go as high as $25 for the really high end motherboards. While we'll definitely see P55 motherboards hit the $100 price point, it's worth realizing how difficult that is to do. As P55 matures, these costs will fall (particularly the chipset) but initially it's going to be a tough race to the bottom.
Izvor: AnandTech
Staro 22.08.2009., 00:27   #679
Pantera-N
Pantera-N's Avatar
Postovi: 1,593
kad uopče možemo očekivati P55 ploče i i5? Tenutno sam u postupku nabavljanja quada, pa me zanima jel mi se isplati čekat...ako cijena bude tu negdje
Staro 22.08.2009., 00:36   #680
Postovi: 7,568
Sljedeći mjesec stižu nove ploče i procesori.
Staro 22.08.2009., 00:53   #681
Pantera-N
Pantera-N's Avatar
Postovi: 1,593
Possible Core i3, i5, i7 Prices Leaked
http://www.tomshardware.com/news/Cor...ices,8448.html
al samo 4MB cache za i5?
Staro 22.08.2009., 01:12   #682
Postovi: 7,568
Ma Tom's je koma ko i obično. Quad-core Core i5 procesori imaju 8MB L3 cahea, a dual-core Core i3 i i5 imaju 4MB ili 3MB u slučaju novog Pentium G6950 modela.
Staro 22.08.2009., 14:55   #683
Pantera-N
Pantera-N's Avatar
Postovi: 1,593
piše po netu da bude quad i5 oko $200, znači kod nas minimum 1500+ kn plus matična koja neče biti ispod 1000kn u početku predstavljanja. Ipak je novi socket. Nekako mi je neisplativo to. Mislim da ču ja sad na Q9400
jedino pozitivno da budu sad cijene c2d i postoječih quada pale....nadam se...
Staro 22.08.2009., 16:25   #684
Postovi: 7,568
Neisplativost ovisi od čoveka do čoveka i o namjeni. Da kupujem novo, tj. da prelazim s ovog kaj sad imam na nekaj novo, kupil bi LGA-1156 mašinu prije nego LGA-1366 ili LGA-775. Em LGA-1156 podržava puno veći asortiman procesora nego LGA-1366, em performanse nisu tolko lošije u odnosu na punokrvne Nehalem modele, em se ovi noviji ipak malo manje griju i troše. Sve u svemu, LGA-1156 bude na ovaj ili onaj način našel svoje kupce.
Staro 22.08.2009., 16:40   #685
Pantera-N
Pantera-N's Avatar
Postovi: 1,593
Autor McG Pregled postova
pa niko nije rekao kontra, naravno da s vremenom bude prevladao LGA1156, isto kako je prije nekoliko godina prevladao 775. Tjek evolucije
ja sam samo komentirao da kako u početku, kao i uvijek, bude 1156 (i CPU i mbo) bude neisplativ, tj preskup. Trebat če dva do tri mjeseca da se sabiliziraju cijene i dok proizvođači izbace jeftinije verzije P55 čipseta (ili nekog drugog).
Staro 22.08.2009., 16:45   #686
Postovi: 7,568
No i ja sam se samo nadovezal na tvoj komentar neisplativosti, jer se to (za neisplativost) zna otkad su prvi put objavljene cijene novih ploča i procesora. Zato velim da sva ta neisplativost ovisi od čoveka do čoveka. Nekom je neisplativo, a neko jedva čeka da npr. Q6600 ili kaj slično zamijeni za novi Core i5-750. Bez obzira na neisplativnost, ne bude ni prvi ni zadnji put da se novi (i relativno skupi) procesori i ploče pokupuju čim stignu u dućane.
Autor Pantera-N Pregled postova
Mislim da ću ja sad na Q9400
Kaj ne bi ti bila bolja opcija da prodaš 5000+ X2 i kupiš Phenom II 810 ili novi Athlon II 620 (ili neki drugi iz 600 serije)?
Staro 22.08.2009., 16:50   #687
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,859
Evo npr, meni ne pada napamet baš da zbog nekih 20% performasni prelazim na i5/7 derivate, nema mi smisla...
Kad sam kupovo procesor taman sam si reko da je to kao što su mnogi na ovom forumu spominjali zalog za budućnost, a sumnjam da je na 3.6GHz slabiji od i5 derivata na 2.6 npr... I ako je, neka je, ja ću imat quad i dalje
Spoiler alert!
Staro 22.08.2009., 16:54   #688
Postovi: 7,568
Nisam ni rekel da ti ili neko drugi treba preći s C2Q na Core i5, tj. LGA-1156, ali kad je stigel Core i7 bilo je na ovom podforumu itekak ljudi koji su prešli s brutalnih C2Q mašina na novi Nehalem.
Isti slučaj bude i u ovoj ili onoj mjeri s LGA-1156. Odvrti si pokoju stariju temu, da vidiš s kakvih se sve konfiguracija prelazilo na Nehalem.
Staro 22.08.2009., 16:59   #689
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,859
Ma to mi nikad neće bit jasno, taman da i zarađujem bijesne novce u ovo recesijsko vrijeme, radije bih si novce ostavio na računu nego mijenjao nešto što je odlično za nešto hiper dobro... Al oke, tak nekome nije isto jasno zašto imam vodeno hlađenje i zašto stalno rastavim komp. Iz gušta... i ne može mi nitko pomoć, može samo koja osoba ženskog spola bit ljubomorna
Spoiler alert!
Staro 22.08.2009., 17:21   #690
Pantera-N
Pantera-N's Avatar
Postovi: 1,593
pa...ne!!!
Nisam baš previše zadovoljan sa ovim AMD-om, a pošto mislim tako i onako kupovat novu ploču, bolje da odmah prelazim na quada. To što je 775 na zalasku, ne muči me to. Nemam namjeru mjenjat nešto godinu / dvije kad kupim, a onda budu pak toplu vodu izmišljali.
