#31 |
Bazinga
Lokacija: Križevci
Postovi: 3,932
#32 |
Lokacija: Poreč
Postovi: 69
Evo i konačnih službenih specifikacija ![]() System Requirements ________________________________________ Minimum Specifications • Windows XP/Vista. (if running Windows Vista SP1 is recommended) • DirectX 9.0c • Pentium D @ 3.0GHz or equivalent Athlon 64 X2 CPU • 1GB RAM • Graphics Card: GeForce 7800 / Radeon X1800 with 256 MB of VRAM • DirectX Compatible Sound Card • Dual Layer Compatible DVD-ROM Drive • 6 GB Hard Drive Space Recommended Specifications • Windows XP/Vista. (if running Windows Vista SP1 is recommended) • DirectX 9.0c • Intel Core 2 Duo @ 2.4Ghz or Athlon 64 X2 4200+ or better • 1.5GB RAM. • Graphics Card: GeForce 8800 or ATI Radeon HD 3800 series with 512 MB of VRAM or better • Sound Card: Creative Sound Blaster X-Fi Sound Card. • Dual Layer Compatible DVD-ROM Drive • 7 GB Hard Drive Space Other Requirements: Initial activation requires internet connection for Multiplayer; Onlineplay requires log-in to Games for Windows - LIVE; requires disc indrive to play (unlimited installations); software installationsrequired including Sony DADC SecuROM, Games for Windows - LIVE. TCP/IP mode (2-16 players) Requirements • Broadband internet connection required (512kbps+ recommended) • TCP/IP Network ________________________________________ Supported Graphics Cards ________________________________________ ATI Radeon x1800, x1900, x1950, HD2600, HD2900, HD3450, HD3650, HD3850, HD3870. HD4850, HD4870, HD4870X2 NVIDIA Geforce 7800, 7900, 7950, 8500, 8600, 8800, 9600, 9800, 9800GX2, GTX260, GTX280, GTX285, GTX295 ________________________________________ Supported Controllers ________________________________________ FUEL™ can be configured to use almost any PC controller, however werecommend the following controllers for the best game play experience: • Xbox 360 Controller for Windows Ima i najave u bugu: http://www.bug.hr/master/najave/ocek...one/94456.aspx btw, igra će biti Game of the Year ![]() ![]() |
#34 |
Lokacija: Poreč
Postovi: 69
#35 |
Lokacija: Chernobyl NPP
Postovi: 4,777
oavk izgleda super, al pre pre pre arkadno, daj pogledaj malo bolje gameplay video, vozila su zaljepljena na podlogu, skretanje užas, ne da hoču simulaciju, ali kaj je previše je jednostavno previše...a i malo me ta sloboda zabrinjava, tako govore da si biraš svoj put do cilja, a na svakom videu se tvrdo drže staze |
#37 |
Bazinga
Lokacija: Križevci
Postovi: 3,932
zivi bili pa vidjeli.ne treba sudit dok se ne proba.a kaj se tice ovih zahtjeva ocekivao sam da ce biti zahtjevnija
#40 |
overpowered
Postovi: 915
@Work HP Zbook15 @Home Acer 5020 |
#44 |
Postovi: 4,777
#50 |
Bazinga
Lokacija: Križevci
Postovi: 3,932
meni je igra baš ok.fora mi je kaj ima jako puno slobode.evo mali screenshot
#52 |
Lokacija: Poreč
Postovi: 69
#54 |
Lokacija: Poreč
Postovi: 69
Malo sam se ufurao u ovo slikanje pa mi je ispalo par screenshotova više nego planirano ![]() |
#55 |
P.E.B.K.A.C.
Postovi: 2,304
Ha ono kopija Motorstorma samo losija ![]() Uninstall nakon sat vremena ![]() Evo i Review: http://www.gametrailers.com/video/review-fuel/51627
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/ Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
#57 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,689
jel goni ko igricu prek sedmice? Naime tam gdje prvi put moram stisnut enter u onom ajmo rec pre-meniju moram stisnut space, a kad ono kakti autosejva pa se pojavi da moram opet stisnut enter ne lovi nista. Probao sam ustekat i gamepad ni tamo ne sljaka nista. |
#58 | |
Lokacija: Val
Postovi: 304
Nemam problema sa enter-om. |
