		#31 |
			 Beskorisna bitanga...
				Lokacija: Sesvete (Zg)
					Postovi: 6,956
		 Razlike su normalne i neizbježne, ako nema problema s CPUom nema razloga oko toga se brinuti čak niti ako je razlika veća od 10C jer uvjek može biti jedna od sondi - neispravna...
	-- Have a nice day...  |
		#32 |
			 LateralusX
					Postovi: 1,788
		 Download: Core Temp 0.99.2 Code:
	Version 0.99.2 - 18th August, 2008 - Fix: Start with Windows option was broken in 0.99.1. - Fix: Default color for the second system tray icon is invisible with WinXP blue theme. - Fix: Save screenshot function would create a corrupted BMP in some viewing software. - Fix: Nehalem does not report VID like earlier CPUs. VID field now disabled for Nehalem. - Fix: Incorrect 65nm Turion X2 code name detection. - Fix: Potential bug of improper K10 and up recognition. - Fix: Enabling distance to Tj.Max with "Highest temp." for system tray would show the largest distance to Tj.Max instead of smallest. - Fix: Vendor ID and Device ID values were reversed in the register dump file. - Fix: 3/4 temperatures logged for Phenom X3/X4 instead of 1. - Add: Support for Core Temp plugins. (Still in beta phase and not in GUI yet). - Add: Full support for AMD's Puma platform CPUs (in previous version reffered to as Griffin). - Add: Initial support for 45nm AMD processors. - Add: Update K8 and K10 recognition code to support all currently known CPUs. - Add: Default TDP detection for Nehalem. - Add: On the fly CPU speed detection. - Add: Close to system tray option. - Change: Log file is now produced in CSV format - easily import your logs into Excel. - Change: Logging interval is now in Seconds instead of miliseconds. - Change: Default logging interval is now 10 seconds. - Change: Logging is now off by default.  |
		#33 |
			 LateralusX
					Postovi: 1,788
		 sad sam testirao novi plugin sustav, odlicna stvar, sad bilo koja 3rd party aplikacija moze koritstiti ocitavanje temp    iako vec ima aplikacija koje to rade (npr. Everest), coretemp ima tu predonost sto je trosi iznimno malo resursa npr. vec ima widget za sidebar:  |
		#34 |
			 tha pilot
					Postovi: 647
		 Imam E8200 sa stock coolerom i razlika između prve i druge jezgre je dosta velika. U Everestu i Coretempu u IDLE-u pokazuje: prva jezgra 47°C, druga 38°C. Imam li ja razloga za brigu da mi nije sjeo dobro cooler ili je mozda do necega drugoga ili je to normalno za taj proc? Unaprijed hvala  |
		#35 | |
					Postovi: 652
		#38 |
			 LateralusX
					Postovi: 1,788
		 Download: Core Temp 0.99.3 Code:
	Version 0.99.3 - 22th August, 2008 - Add: Correct TjMax values for 45nm Core 2 series, according to this document. - Fix: When TjMax = 0 (undefined) "Delta to Tjunction" was not added to the temperature string.  |
		#39 |
				Lokacija: Malaysia
					Postovi: 96
	Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1  |
		#41 |
			 Six Blade Knife
					Postovi: 292
		 System information).
- Add: Thermal protection mechanism. (Look at Options menu, changed from 0.99.5.20 beta)
- Add: Support for the latest AMD and Intel CPUs.
- Add: Mini mode for GUI. (Double click anywhere to switch between modes)
- Add: Per core temperature offset adjustment. (Look at Options menu)
- Add: Screenshots are now taken in the lossless but very compact PNG format.
- Add: User defined text colors for main Window. (Options --> Settings)
- Add: Show high/low temperatures. (Press F6 or the Tools menu to reset values)
- Add: On/Off switch for G15 applet in Tools menu.
- Add: Running several instances of Core Temp is now possible (enable in Settings).
- Change: Temp turns Orange when temperature is over TControl, and Red when CPU is thottling/critical.
- Change: Reorganized menu.
- Change: TjMax for mobile Atom processors changed to 90C.
- Change: "Lion" codename for AMD Turion was changed to "Griffin".
- Change: Completely dropped support for older Windows NT OS, Windows XP or up is required.
                Core Temp 0.99.5.26:  32-bit   64-bit
	Code:
	Version 0.99.5.26 - 3rd August, 2009 - Fix: Incorrect clock speeds reported on some systems. - Fix: At startup Core Temp shows 0 (?) or 21 (?) on AMD K8 series. - Fix: Turion MK series recognition was wrong. - Fix: Properly detect Atom and Core i7 engineering samples. - Fix: Tri-Core AMD CPUs incorrectly shown as having only 2 cores and 2 threads in 64bit Core Temp binary. - Fix: System tray text was off center. - Fix: Penryn (mobile Core 2) processors reported as having 85C TjMax instead of 90C. - Fix: Settings window would open centered, and sometimes out of the desktop area. - Fix: System tray icon very small in Windows 2000/XP/2003. - Fix: AMD Athlon X2 4x50e series detected as 3x50e. - Fix: Using a negative offset on AMD systems results in "42949672xx°C" being displayed. - Fix: Add support for Mobile Athlon 64 X2 TK-xx series and Turion 64 MK-xx series. - Fix: Workaround added for when Core Temp fails to find supported CPUs on Phenom based systems. - Fix: PROCHOT signal from Intel CPUs was not picked up correctly. - Fix: Core Temp would start out of the desktop area, and the main Window couldn't be seen/accessed. - Fix: False overheating warning on AMD systems. - Fix: False readings of over 200C° on AMD systems. - Fix: High/low temperatures would be reversed when "Show distance to TjMax" was enabled. - Fix: Clicking "Defaults" button in settings would enable logging when it should be disabled by default. - Fix: 23xx and 83xx series AMD Opterons recognized as 83xx and 23xx respectively. - Fix: System tray icons appear incorrectly on AMD K10 and newer CPUs. - Fix: "Show highest temp of each CPU" systemtray icon configuration sometimes reports duplicate readings. - Fix: G15 applet did not work after resuming from Sleep/Suspend. - Add: Completely new code for processor speed detection. - Add: A comprehensive processor information window (F3 or Tools --> System information). - Add: Thermal protection mechanism. (Look at Options menu, changed from 0.99.5.20 beta) - Add: Support for the latest AMD and Intel CPUs. - Add: Mini mode for GUI. (Double click anywhere to switch between modes) - Add: Per core temperature offset adjustment. (Look at Options menu) - Add: Screenshots are now taken in the lossless but very compact PNG format. - Add: User defined text colors for main Window. (Options --> Settings) - Add: Show high/low temperatures. (Press F6 or the Tools menu to reset values) - Add: On/Off switch for G15 applet in Tools menu. - Add: Running several instances of Core Temp is now possible (enable in Settings). - Change: Temp turns Orange when temperature is over TControl, and Red when CPU is thottling/critical. - Change: Reorganized menu. - Change: TjMax for mobile Atom processors changed to 90C. - Change: "Lion" codename for AMD Turion was changed to "Griffin". - Change: Completely dropped support for older Windows NT OS, Windows XP or up is required.  |
		#43 |
				Lokacija: Malaysia
					Postovi: 96
		 Core Temp 0.99.6 http://www.alcpu.com/CoreTemp/CoreTemp32.zip http://www.alcpu.com/CoreTemp/CoreTemp64.zip - Add: Support for new and upcoming Intel and AMD processors. - Add: Better recognition of AMD dual/tri core unlocked CPUs. - Add: Optional 24 hour display on G15 LCD. - Fix: Platform field blank for newer AMD CPUs. - Fix: Some K8 CPUs were unknown or recognized incorrectly. - Fix: Overheat protection "Activate at specified temperature" problems were fixed. - Fix: Overheat detection does not show a Balloon Tip when user specified temperature value is set. - Fix: Temperature displays a negative value when core temperature reaches over TjMax (Intel). - Fix: Intel W3500 series Xeons recognized with Core i7 model numbers (ie W3520 shown as Xeon 920) - Fix: In certain cases Core 2 Duo T5500 was recognized as a T5450. - Fix: G15 LCD display is no longer always-on-top after coming out of sleep or hibernation. - Fix: G15 won't display 0.0000v in case VID readings are not supported by the CPU. - Fix: In some cases, at Windows startup systemtray icons would not appear. - Change: Windows XP SP2 or higher is now required. - Change: Completely new processor frequency detection algorithm. (for Core 2 generation and newer only) - Change: Remove "APICID" from main window as it has very little use.
		#44 |
				Lokacija: Malaysia
					Postovi: 96
		 Version 0.99.6.1 - 8th May, 2010 http://www.alcpu.com/CoreTemp/CoreTemp32.zip http://www.alcpu.com/CoreTemp/CoreTemp64.zip - Add: Support for new and upcoming Intel and AMD processors. - Add: Better recognition of AMD dual/tri core unlocked CPUs. - Add: Optional 24 hour display on G15 LCD. - Known issues: Intel processor speed detection displays extremely high numbers.
		#45 |
				Lokacija: Malaysia
					Postovi: 96
		 Core Temp 0.99.6.2 beta http://www.alcpu.com/CoreTemp/CoreTemp32Beta2.rar http://www.alcpu.com/CoreTemp/CoreTemp64Beta2.rar -Fix frequencies , including Turbo mode
		#46 |
				Lokacija: Malaysia
					Postovi: 96
		#48 |
				Lokacija: Malaysia
					Postovi: 96
		 Core Temp 0.99.7.1 http://www.alcpu.com/CoreTemp/CoreTemp32.zip http://www.alcpu.com/CoreTemp/CoreTemp64.zip - New: Implemented Windows 7 taskbar button features. (Under the Options menu) - New: Clock modulation detection for Intel processors. - New: Proper support the Phenom II X6 and Athlon L100 series. - New: Support for the E3000 Celeron series. - New: Displays the processor's manufacturing process. (Lithography) - Fix: Intel frequency detection. - Fix: Frequency doesn't update after exiting from Sleep or Hibernation. (Intel) - Fix: Reading and logging intervals in Settings can't be changed. - Fix: Minor Intel processor recognition issues. - Fix: On some systems the System Information window would flood the screen with errors. - Fix: G15 plugin restarts after resuming from sleep even if it was previously disabled from the menu. - Fix: Overheating protection on AMD processors bug. - Update: Rearranged the main GUI and added new information. - Update: Added missing Intel Socket names.
			Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1 Zadnje izmijenjeno od: stasio. 27.06.2010. u 17:07.  |
		#49 |
			Datum registracije: Aug 2008
				Lokacija: Moj dom Krapina
					Postovi: 246
		 Core Temp 0.99.7.3
		#50 |
				Lokacija: Malaysia
					Postovi: 96
		 Core Temp 0.99.7.7 http://www.alcpu.com/CoreTemp/CoreTemp32.zip http://www.alcpu.com/CoreTemp/CoreTemp64.zip - New: Core Temp FAQ is now available online, see About Core Temp dialog. - New: System tray icons for CPU speed and CPU load - see System Tray setup under Options. - New: Support for the latest mobile AMD processors. - Fix: Multiple "Fail" messages when the computer exits sleep or plugged into/unplugged from power (laptops). - Fix: Several mobile Intel processor recognition issues. - Fix: When disabling Windows 7 Taskbar feature with Cycle mode, icons still continue to cycle. - Fix: Windows 7 Taskbar settings UI bug. - Update: "Start with Windows" function in Vista and 7 now works on a per-user basis. - Update: Change the time and date layout of the log file name to YYYY-MM-DD HH-MM-SS. - Update: All of the readings logged are now numeric only. - Update: In single instance mode, the previous instance will be brought to the screen. - Known issue: Core Temp may stop responding for a period of time or completely lockup on some systems when switching between power supplies (wall/battery) or exiting sleep/hibernation mode.
