Staro 14.05.2009., 16:41   #451
SuzukyVstrom
Nije Suzuky nego Suzuki
SuzukyVstrom's Avatar
Datum registracije: May 2009
Lokacija: Sisak
Postovi: 60
:9 , evo narucio iz HG spota http://www.hgspot.hr/Article.aspx?aid=160911
<- 10 godina garancije , nakon 2 i pol godine riknula mi POW 8800gts za koju sam dao 3.500kn(jamstvo 12 mjeseci) , imam trenutno samo za cooler !
Kupit cu i rame , koje da uzmem , DDR2 !?
SuzukyVstrom je offline   Reply With Quote
Staro 14.05.2009., 16:44   #452
3NCORE
NePremium clan
3NCORE's Avatar
Lokacija: Dubrava,Zagreb
Postovi: 215
Autor DraŽ Pregled postova
Pa odkad mushkin proizvodi grafičke kartice muljatoru!
Od 10.01.2008 ako te bas zanima
3NCORE je offline   Reply With Quote
Staro 14.05.2009., 16:49   #453
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
To stvarno nisam znao jer ih nigdje dosad još nisam nigjde vidio! Ispričavam se
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 14.05.2009., 17:06   #454
3NCORE
NePremium clan
3NCORE's Avatar
Postovi: 215
Ma ja isto slucajno naletio,prva im je bila 8800GT.
Staro 14.05.2009., 17:34   #455
SnakePriest
Lokacija: Zagreb,Rudeš
Postovi: 197
Autor SuzukyVstrom Pregled postova
Pozdrav svima
AMD 64 x2 4600+ , radi na : 2411MHz , 1.150 V , 40 C Temp.
Maticna je ASUS M2N-E Chipset nVidia nForce570 SLI
Rami rade na 399MHz :1gb 800MHz 240pin TRANSCEND
1gb 800MHz PC 6400 TWISTER TWINMOS
2x 1gb kingmax 800 MHz
Pa me vrlo jednostavno zanima sto je potrebno napraviti sa memorijom i maticnom u vezi oc i na koliko MHz treba oc procesor .
Stize mi je nova graficka Mushkin GTX260 OCII Ultimate FX.
HVALA !
vecina ljudi dobije razlicite rezultate...sve ovisi o maticnoj,napajanju,ramovima itd.
SnakePriest je offline   Reply With Quote
Staro 14.05.2009., 19:29   #456
SuzukyVstrom
Lokacija: Sisak
Postovi: 60
Dali netko ima AMD Athlon 64 X2 7750+ (Black Edition) ; na koliko ga je oc sa originalnim ili
novim hladnjakom .. *?
HVALA
Zadnje izmijenjeno od: SuzukyVstrom. 15.05.2009. u 00:23.
Staro 18.05.2009., 15:29   #457
maX
maX's Avatar
Postovi: 7,326
Staro 19.05.2009., 10:34   #458
honored
Lokacija: virje
Postovi: 154
evo mene muci mali problemcic imam amd 6000+ windsor (1,400v),gigabyte 790x -ds4 i 2x1 gb kingston hyperx 667 MHz.. i spustim memoriju i multi da vidim koliko ide fsb i ide dosta nisam dosao do kraja, i jucer sam se cjeli dan mucio i nisam uspio dici proc vise od 3250mhz da radi kolko tolko stabilno temperatura je u idleu 40-43 c a u loadu 60-65, i sad konacno me zanima dali je to maximum proca ili sam negdje pogresio??
honored je offline   Reply With Quote
Staro 19.05.2009., 12:45   #459
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,403
Autor honored Pregled postova
Koliki napon si dao procu?
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Amdejac je online   Reply With Quote
Staro 19.05.2009., 14:39   #460
honored
Lokacija: virje
Postovi: 154
pa pise ti 1,400 ali overvolta pa je 1,42v
Staro 28.05.2009., 12:15   #461
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
O/C Brisbanea ?
Konfiguracija je pod Moj Komp. Trenutno stanje je 250 x 9,5 = cca 2375MHz, memorija prema CPU-Z-u 940MHz, makar u BIOS-u pise 1000Mhz, HT Link radi na 995MHz sa 4x mnoziteljem.
Napon CPU-a sam stavio na 1,275V, i dodatnim dizanjem FSB-a mi ne zeli bootat u Windoze. Probao sam dici napon na mojoj ploci maksimalnih 1,300V no i dalje ne zeli bootati u Windoze. Jel to moze biti plafon moje ploce ili mogu jos nesto probati? Jer znam da ovaj procesor moze vise...
rams je offline   Reply With Quote
Staro 28.05.2009., 12:35   #462
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
A da memoriju malo probaš smanjit preko djelitelja ? Čisto da vidiš da li te ona koči.
Zašto nisi temu stavio u ovaj već postojeći topic ?
Staro 28.05.2009., 12:38   #463
rams
80286
rams's Avatar
Postovi: 1,724
Moj bed, nisam inace cesto pod O/C forumom pa zaboravih da ima taj thread, premjesti ondje ako hoces topic.
Probat cu smanjit RAM pa vidit hoce sljakat.
Staro 29.05.2009., 00:16   #464
rams
80286
rams's Avatar
Postovi: 1,724
Cini se da je stvar bila u RAMU, hvala Vuci na savjetu.
Evo SS sa trenutnim stanjem:
Ovako sljaka stabilno (Orthos jos uvijek vrti...), na FSB 290 MHz se upali i radi, ali se Orthos srusi, a na vise se ne zeli bootati do kraja. Moglo bi biti da je tu kraj ploci, ili pak mome O/C iskustvu
Staro 29.05.2009., 12:48   #465
Vuco
Vuco's Avatar
Postovi: 9,505
Ploču izbaciš kao moguću kočnicu tako da digneš HTT na 300 ili više preko Clockgena (znači programom iz Windowsa, koji nema veze sa BIOS-om koji te možda ograničava). Sa Clockgenom polako diži i nemoj se čuditi ako ti se koji puta smrzne stvar. Ili ako ima neki Gigabyte-ov program, Easytune il kako god već.
A ako je proc, onda digneš sitno napon pa vidiš jel do njega ili nije.
Staro 29.05.2009., 20:19   #466
rams
80286
rams's Avatar
Postovi: 1,724
Napon proca je vec na, na mojoj ploci maksimalnih, 1,3V tako da tu nema puno mrdanja. A i sa ovim rezultatom sam sasvim zadovoljan tako da necu vise cackat. I moram priznat da se razlika u radu fino osjeti izmedju 1,9GHz i 2,7GHz
Staro 30.05.2009., 17:45   #467
sinn69
sinn69's Avatar
Lokacija: ZGB
Postovi: 29
Comp uredno sve radi i prolazi testove,boota ali kad ga ugasim i ohladi se cca pola sata vise nece bootati isprve vec eventualno iz drugog ili treceg pokusaja.
zna li netko u cemu je problem
na 3,1Ghz 240x13 boota hladan iz prve , na 3,2Ghz 247x13 hladan se ne boota,kad je topli onda moze
ovo su postavke na kojima hladan ne boota
http://valid.canardpc.com/show_oc.php?id=576477
sinn69 je offline   Reply With Quote
Staro 30.05.2009., 19:44   #468
rams
80286
rams's Avatar
Postovi: 1,724
Jes pokusavao dizati napon CPU-a ?; ako nisi pokusaj za jedan korak podici napon pa vidi hoce raditi.
Staro 30.05.2009., 21:16   #469
sinn69
sinn69's Avatar
Lokacija: ZGB
Postovi: 29
Autor rams Pregled postova
Napon je na max koliko da ploca 1,35V
Staro 09.06.2009., 13:59   #470
BeroVK
Lokacija: Vinkovci
Postovi: 780
BeroVK je offline   Reply With Quote
Staro 09.06.2009., 14:42   #471
Thorax
Doomster
Thorax's Avatar
Datum registracije: Mar 2008
Lokacija: Kraj Donji
Postovi: 400
Autor BeroVK Pregled postova
Odličan clock
Jel to stabilno ili? Mislim voltaža uopće nije velika za 3.4...
Thorax je offline   Reply With Quote
Staro 09.06.2009., 15:02   #472
Vuco
Vuco's Avatar
Postovi: 9,505
Pa bome 1.57V nije niti malo. x2 se na tom naponu grije jako.
Staro 09.06.2009., 15:05   #473
Thorax
Doomster
Thorax's Avatar
Postovi: 400
Ups, da nije malo... Ja uopće nisam gledao AIBooster nego CPU-Z... a on pokazuje 1.424 V
Staro 09.06.2009., 17:43   #474
BeroVK
Lokacija: Vinkovci
Postovi: 780
laze asusov program voltaza u biosu je na V1.45
Stabilnost nisam istestiro, za vikend cu ga detaljnije proradit
Staro 13.06.2009., 17:53   #475
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Grrr, nakon današnjeg dana, mislim da definitivno prelazim na intel....
Jučer sam frendu stavljao pentiuma E6300 i reko aj da vidimo šta se može s njime napravit, i iz zajebancije puknem ja 350X10, i 1,29v i mali pali iz prve, occt linpack stabilno 1h temparatura oko 72°c, +-2.
Danas reko idem opet probat ovog mog nagovorit da radi stabilno na 3,2 i nema teoretske teorije, pumpao sam voltažu do 1,53 i ništa, nakon 2-3 minute occt-a pada kao kruška, 3.0 ide na stock naponu, 3.1 ide na 1.39v ali već 3.2 nema teorije.
Pošto se igram samo multijem (BE), dali bi imalo ikakve veze da dodam malo soka memoriji,nb-u i sb-u?
D-I-A-B-L-O je offline   Reply With Quote
Staro 13.06.2009., 19:24   #476
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
probaj sve opcije ne košta te ništa...
boris87 je offline   Reply With Quote
Staro 13.06.2009., 20:44   #477
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Autor D-I-A-B-L-O Pregled postova
e s kojim naponom tebi radi tvoj na 3.0?
mene zanima na kojoj frekv bi moj radio stabilno?nisam bas neki expert u tome.pa bi mi svaki savjet dobro dosao.hvala
Staro 14.06.2009., 01:19   #478
BeroVK
Lokacija: Vinkovci
Postovi: 780
Meni za 3ghz stock voltaza, 3.4ghz V1.48
Staro 14.06.2009., 02:22   #479
D-I-A-B-L-O
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Alaaa, ja 3,4 nemogu ni sanjat
Na 3.0 i meni ide na stock, ali mi je već 3,1 max bez obzira na sve, toliko o black editionu
Nisam imao volje danas još isprobat sa jačim voltažama za memoriju, nb i sb, da sam ga ikako uspio natjerat na barem 3,2 možda bi se odlučio cijeli dan zezat s time, ovako kad mi nakon 3 sata mučenja nije htjeo proći occt duže od 2 minute, odustao sam od svega i vratio na 3.0 i stock voltaže.
Bero, tvoj nije BE?
Staro 14.06.2009., 13:24   #480
BeroVK
Lokacija: Vinkovci
Postovi: 780
Moj nije BE obican je, a jesi siguran da ploca nije kriva?
