Staro 08.05.2009., 16:51   #1
Postovi: 7,568
GPUTool
TechPowerUP has released the GPUTool Community Technology Preview 1 which helps you detect the information of video cards.
This first public Community Technology Preview is released to show you which way the development is going and to get feedback about possible new features.
Expect a lot of bugs and broken features.
GUI / Interface
Q: What is the (1:0:0) behind my card in the drop down?
A: The location on the bus, every device gets a unique location.
Rendering
Q: Why is there no movement in the render test?
A: In order to detect artifacts, GPUTool compares two subsequent images. If there was movement the images wouldn't match. Movement will not create a higher load anyway.
Tools like OCCT and Furmark do not actively scan for errors so there can be movement.
General
Q: Feature X doesn't work.
A: That was expected for such an early release. Make a bug report in the forum, maybe it gets fixed.
Q: Will you integrated GPU-Z in GPUTool or GPUTool in GPU-Z.
A: No, that's not planned.
Q: When can I expect a next/beta/final release?
A: When it's done.
Q: Which cards will be supported?
A: Unknown at this time. I am aiming for something like newer than GeForce 6, HD 3xxx. Intel/S3/Matrox unknown and low priority.
Download i službeni forum
Staro 08.05.2009., 16:58   #2
Melani
Lokacija: doma
Postovi: 964
Čini mi se da su se probudili iz zimskog sna.
Odlična vijest.
Posebno mi se sviđa ovo "Voltages".
Kad dođu do prve dosta stabilne verzije,ak nebudu stavili language support onda ću prevesti i ovo na hrvatski
Melani je offline   Reply With Quote
Staro 08.05.2009., 17:24   #3
panisher20
panisher20's Avatar
Postovi: 939
tool je predobar, bolji meni od rive
panisher20 je offline   Reply With Quote
Staro 08.05.2009., 18:04   #4
alengrosevic
alengrosevic's Avatar
Postovi: 3,779
tool definitivno ima potencijala. vidi se da ekipa na tehpowerup-u ne miruje
alengrosevic je online   Reply With Quote
Staro 08.05.2009., 21:16   #5
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Bit ce ovo jako ljep tool nakon nekog vremena dok se poslože kockice.
Staro 08.05.2009., 23:53   #6
j0Z
Datum registracije: Apr 2009
Postovi: 28
svida mi se programcic svaka cast za up samo da ga srede
j0Z je offline   Reply With Quote
Staro 09.05.2009., 00:01   #7
stopalo9
stopalo9's Avatar
Postovi: 763
Tool je prva liga
stopalo9 je offline   Reply With Quote
Staro 09.05.2009., 23:17   #8
Melani
Lokacija: doma
Postovi: 964
Pohvala isprobao x1950 ne radi
8800 ultra odlično radi našao max clockove i radi stabilno na postavkama kakve je našao
Staro 10.05.2009., 01:40   #9
Baja 001
Baja 001's Avatar
Postovi: 7,504
Kako sam trenutno na GMA nije mi potreban tool, ali ima jako puno potencijala jedva čekam da upogonim 9800GT s njim
