Staro 12.08.2004., 21:35   #1
ljekra
ljekra's Avatar
Datum registracije: Dec 2003
Postovi: 391
Zanimljiv firmware za korisnike DVD-RW Pioneer 107D
Flash se pokrece iz windowsa, odnosno command prompt-a u windowsima! Archiva je selfextract, tako da ju mozete otpakirati u vec navedeni direktorij! U DRIVE-u NEMOJTE DRZATI NIKAKAV CD-e RADI SIGURNOSTI....
PROBAO SAM SVE TRAXDATA -DVD-ima I TOCNO JE TO STO SU I NAVELI! RADI!
Pokrenete run upisete cmd, odete u direktorij u kojem ste raspakirali file-ove (unutar command prompa!) i upisete: DVRFlash -vf X: R7100007.116 R7100107.116
s time da X oznacava na kojem se drive-u nalazi vas dvd-rw unutar windowsa (my computer)! npr. Ja imam C: i D: kao dva diska, a E: mi je dvd-rw, znaci upisem umjesto X:-a, E:
Kad se flasha nemojte nista dirati, ali apsolutno nista, dok se nezavrsi flash-anje! Napisat ce vam nakraju da je sve OK!
Download
Release Notes:
This firmware was used succesfully to burn *QUALITY* 4x +/-R
media at 6x and 8x speed and *QUALITY* 2x -RW media at 4x.
Patched: o RPC-1 (Region Free):
Remember, patching your drive to region free is only half
the job. A region free drive will not turn your system
region free by itself. For more info, please read
http://forum.rpc1.org/viewtopic.php?t=239
o 12xRip (Unlimited ripping speed):
The official firmware from Pioneer limits the ripping
speed on video discs. This limitation has been removed.
12x is only the maximum THEORETICAL speed that the drive
can achieve, but not the sustained speed you are likely to
get when ripping. Most DVD's will start ripping around 2x
to 4x and end up around 8x or 10x. THIS is normal.
o nx4all : All *workable* speeds for all media!
This firmware allows you to select ALL burning speeds on
ALL media. The official firmware from Pioneer only allows
a limited set of Pioneer approved media to use these
specific speeds but this patch removes that limitation. It
should NOT alter the write strategies for approved media
however.
PROPER BURN OF NON APPROVED MEDIA IS NOT GUARANTEED!
Not patched: - Bitsetting ("Burn on -R media instead, people!!!")
- nx4all on +RW media. For the reason behind that, see:
http://forum.rpc1.org/viewtopic.php?p=108571
Tests showed that burning +RW media at higher speed than
the manufacturer recommended was a bad idea - ACCEPT IT!
Toshiba U400 - 1.86GHz, 3Gb, 250Gb, 13.3''
HP NX7300 - 1.66GHz, 2Gb, 80Gb, 15.4''
Intel Server Board, XEON 2.0GHz, 1Gb ECC, 2x18.1Gb 10000rpm raid, 3x250Gb. 2x320Gb, 1x120Gb
ljekra je offline   Reply With Quote
Staro 13.08.2004., 01:56   #2
ćiber_manija
CyberSky
ćiber_manija's Avatar
Datum registracije: Feb 2004
Lokacija: Jastrebarsko
Postovi: 1,168
Ovo nikad nisam radio.
Jel moguće sj****at uređaj ako se ne napravi nešto dobro.
Što točno donosi novi firmware,nisam baš skužio do kraja?
The šuma...
Staro 13.08.2004., 23:32   #3
ljekra
ljekra's Avatar
Postovi: 391
Ovako rizik uvijek postoji, ali nevidim neki razlog da bi se moglo nesto zeznut, ako se radi kako je opisano!
Ja sam flash-ao dvije i nije bilo nikakvog problema!
A sto se tice firmware-a i sto donosi, uh mnogo toga al nabrojat cu najbitnije!
1. Kvalitetnije dvd-e medije koji su na 2x i 4x moguce je prziti na 6x ili 8x! isprobao sa 4x traxdatom i przi bez greske na 8x!
2. Tako mozes i 2x DVD-RW medije prziti na 4X!
3.Orginal firmware od pioneera ogranicava ripanje dvd video-a na 8x-10x, a sa ovim mozes na 12x!
4. Omogucava citanje dvd dual layer medija!
itd.......
Staro 14.08.2004., 11:57   #4
ćiber_manija
CyberSky
Postovi: 1,168
Onda je rizik vrlo mali nasprem kaj donosi ovaj. Isnstaliro i radi
The šuma...
Zadnje izmijenjeno od: ćiber_manija. 14.08.2004. u 16:42.
