Datum registracije: Dec 2003
Lokacija: VŽ, Croatia
Postovi: 61
sapphire 9800Pro to XT ???
E, ovako, pročitao sam na nekim forumima da se ATI 9800Pro može lako promijeniti u 9800XT , ali samo ako ima r360 core. Pošto sam vlasnik te kartice, zainteresirao sam se za taj bios flash. Od flasha sam odustao kad sam u AIDI32 ugledao da imam r350 core. No, zatim sam naletio na ovu str. : http://forums.pcper.com/showthread.php?t=332242 gdje je jedan tip napisao sljedeće : "download / install Ati tool and somewhere under settings>misc theres a "dump bios" button. then go into the ati directory where you installed ati tool ( the dumped bios should be here ). then change the "bios.bin" to "bios.TXT". open it with notepad and it should say either R350 or R360 somewhere in the text. i used something like aida32 and it showed mine as a R350 but when i used the method in the link it said R360 and now i got a 9800pro flashed to XT. my instructions are kinda hard to understand just refer to the link ,lol. good luck " Napravio sam to sve po uputama i u tom biosu pronašao sljedeće R360 Hynix DDR 113-A18812-100 BIOS E ,sad, pitam ja vas kome vjerovati Aidi32 ili ati toolu ??? Vrijedi li riskirati ??? Unaprijed hvala |
#2 | |
Postovi: 391
Re: sapphire 9800Pro to XT ???
Malo procitaj, prvih 20 postova ili malo vise, pa ce ti biti sve jasno, vidjet ces kako drugima to prolazi pa ti probaj i usporedi. Pod temom ti se nalaze negdje linkovi za bios-e. LINK- http://forum.pcekspert.com/showthrea...0&pagenumber=1 LORD HELP HELP!!
Toshiba U400 - 1.86GHz, 3Gb, 250Gb, 13.3'' --- HP NX7300 - 1.66GHz, 2Gb, 80Gb, 15.4'' --- Intel Server Board, XEON 2.0GHz, 1Gb ECC, 2x18.1Gb 10000rpm raid, 3x250Gb. 2x320Gb, 1x120Gb |
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Tvoja je 100% R360. Samo flashash bios i to je to. Odi na http://forums.ocfaq.com za dodatne informacije
Postovi: 61
Prije nego krenem s flashanjem, znima me dal će ARCTIC COOLING, VGA silencer uspjeti dovoljno "ohladiti" novostvorenu 9800XT ??? |
