Staro 08.03.2009., 00:31   #91
žile
žile's Avatar
Postovi: 3,074
Pa sigurno da je to jedna od najvažnijih stavki na koje treba obratiti pozornost,ali više shadera igra isto važnu ulogu.
žile je offline   Reply With Quote
Staro 25.03.2009., 18:18   #92
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
GPU-Z 0.3.3
Staro 25.03.2009., 21:08   #93
Wolverine
Wolverine's Avatar
Postovi: 12,425
su sredili da kuži 55nm G92 da si ekipica sa 9800GTX+/GTS250 ne čupa kosu i ide reklamirat krivi čip na svojim eNdivijama
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 01.05.2009., 15:23   #94
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
  • Fixed RV740 Bugs: ROP count, shader count, real-time core clock, BIOS dump size
  • Fixed number of transistors on RV790
  • Fixed BIOS reading on RV790
  • NVIDIA driver version is returned correctly on Windows 7
  • GPU-Z should work again on Windows 2000 without PSAPI.DLL
  • Added voltage reading support for HD 4890
  • Fixed default clock reading on ATI cards that have default clock < boot clock
  • Fixed GM45 to be 65 nm and DX 10.0
  • Added release date for GTX 275
  • Fixed GT 130M to be 55 nm and added its release date
GPU-Z v0.3.4
Sultan je offline   Reply With Quote
Staro 24.09.2009., 15:52   #95
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
GPU-Z 0.3.5
TechPowerUp today released version 0.3.5 of the GPU-Z graphics subsystem information and monitoring utility. GPU-Z provides information on the computer's installed graphics hardware, and provides real-time updates on their parameters such as clock-speeds, temperatures, voltages, and fan-speeds. Version 0.3.5 makes the utility geared up for the newest graphics processors from AMD, its Radeon HD 5800 series, along with improved support for NVIDIA FX5500, 9400 GT, G73, GTS 240, GT 140, FX 1800, GT 120 (Apple), FX 380, FX 350, GTX 295 Single PCB, Quadro CX, FX 5800, FX 4800, FX 3800, GTX 180M, GTX 260M, FX 2700M, G 110M, GT 120M, GT 220M, FX 1700M, G 105M, MCP79MX. GPU-Z can now also detect the embedded GPU on some Intel socket LGA-1156 processors. Support is also added for some of AMD's newest Radeon HD 4700 series GPUs and HD 4650 AGP, M92, M96, M98. A concise list of other notable changes is as follows:
Added clock reading for Intel i910, i915, i945, 946
Added support for DDR3 detection on G9x
Added monitoring support for RV7xx based mobile chips
Voltage controller "slaves" are now called "phases"
Fixed BIOS parsing on some newer HD 4870 cards
Added voltage monitoring support for MSI N275GTX Lightning
Staro 14.10.2009., 23:19   #96
e1ectra_one
Creepshow
e1ectra_one's Avatar
Postovi: 417
TechPowerUp GPU-Z 0.3.6
Today TechPowerUp presents version 0.3.6 of GPU-Z, our graphics sub-system diagnostic utility that provides information on the computer's installed graphics hardware, their various specifications, and provides real-time updates on their parameters such as clock-speeds, temperatures, voltages, and fan-speeds. The utility is backed by our overclock validation system, and an extensive video-card BIOS database. This release brings with it a few important changes that improve compatibility with the latest graphics processors, and enhance usability.
To begin with, GPU-Z introduces an infotip feature that makes understanding graphics hardware easier. Hovering the mouse over an information field shows concise information related to that field. Along with polished support for ATI Radeon HD 5850, and HD 5700 series, version 0.3.6 introduces preliminary support for AMD's newer GPUs. Also introduced is support for several of NVIDIA's GeForce 100 and 200 series GPUs, and some Tesla GPGPU processors. A number of stability issues have also been fixed.
Added Infotips, they can be turned off in the system menu
Added preliminary support for ATI Radeon HD 5900 (Hemlock), HD 5600 (Cedar), HD 5300 (Redwood)
Added full support for HD 5850, HD 5770, HD 5750
GPU-Z no longer crashes on ATI ULPS enabled CrossFire configurations
Fillrate Pixel, Fillrate Texel, Memory Bandwidth will now correctly recalculate when clocks change
Bus Interface, ATI shader count is now periodically refreshed
Added support for HD 5850 voltages
Second voltage on HD 5870 correctly named VDDCI
ATI clock reading code fixed
Fixed default clock reading on HD 5850
Added Mutex to avoid collisions on long I2C operations
Added basic detection for a lot of NVIDIA card fakes
Added detection for ATI FireGL V7600, M92, RS880
Added detection for NVIDIA GT 130, 9600 GE, Tesla C1060, G 220, GT 220, NVS 3100, GTS 160 M, NVS 160M, NVS 150M, G105M, GT 240M, G105M, G210M, G310M, ION LE
Fixed die size and transistor count on G72 M
e1ectra_one je offline   Reply With Quote
Staro 14.10.2009., 23:49   #97
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Cool
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 23.12.2009., 13:07   #98
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
0.3.8
* Added framework for translations in GPU-Z
* Added sensors to monitor GPU load percentages on NVIDIA
* Fixed startup on Windows 2000 (DLL not found)
* Improved detection/added sensors for ATI M86
* Fixed several NVAPI crashes
* Fixed crash when PhysX not available
* GPU-Z can now be set in its system menu to be always on top of other windows
Download
Staro 24.02.2010., 10:50   #99
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
  • Added localized tooltips in the languages: AM, AR, BG, CN, DE, FA, FR, IT, PT, RS, RU, TR, UA. Default language is your system language, you can change this setting in the system menu of GPU-Z.
  • Added support for ATI HD 5830, HD 5770, HD 5750, HD 5670, HD 5570, HD 5450, HD 4860, HD 4750, Mobility HD 3430, M97, Mobile HD 5850, 5730, 5650, 5470 (Broadway, Madison and Park)
  • Added support for NVIDIA GeForce 6200A, GTS 250, 9800S, 205, 310, GT 320, GT 240, GTS 360M, 230M, 330M, 240M, G105M, Quadro NVS170M, G210M, GTS 250M, future MCP, more ION variants.
  • Added support for Intel GMA500, Clarkdale, Arrandale
  • Added detection for variants of NVIDIA NV41, G94, G98, ATI RV350, RV370, R480, RV515. Most of them used on fake cards relabeled to NVIDIA 9x00 series.
  • Improved default clock BIOS parsing on NVIDIA
  • Fix for incorrect default clocks on HD 5000 Series
  • Fixed incorrect real-time clock monitoring on some HD 5000 cards
  • Added more accurate real-time clock monitoring function for NVIDIA
  • Improved OpenCL detection on ATI R700, RV790, all HD 5000 cards
  • Added temp. monitoring support for some Intel IGPs
  • Improvements to CUDA detection
  • Removed memory chip input fields from VGA BIOS Upload
GPU-Z v0.3.9
Staro 27.03.2010., 23:11   #100
Jelc
Super Moderators
Postovi: 17,485
GPU-Z v0.40
Added support for NVIDIA GeForce GTX 470 and GTX 480
Added voltage monitoring for HD 5750, 5830, 5870 Lightning
Added support for Intel Pineview
Fixed double memory clock reading on NVIDIA w/ GDDR5 (real clock is now displayed)
Fixed rounding errors in RV7xx and Evergreen fan monitoring code
Added tooltip translations for Albanian and Chinese Traditional
Memory bandwidth calculation uses GB now instead of GiB
Added new hardware giveaway tab in cooperation with ASUS
http://www.techpowerup.com/118512/Te..._Giveaway.html
Staro 07.04.2010., 17:29   #101
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
  • Fixed an issue on all NVIDIA cards that would sometimes cause them to lose fan control when GPU-Z is running. Please don't run pre-0.4.2 and 0.4.2 at the same time, this might result in incorrect readings in the 0.4.2 window.
  • Fixed system crash on MSI HD 5830 TwinFrozr II
  • Validation upload now uses Unicode for entered name
  • Reverted memory bandwidth calculation introduced in last version. It introduces too much confusion, we will go with what all companies use in their marketing material, even though we believe it is not correct. Using power of 10 again now, 1 GB/s = 1,000,000,000 Bytes per Second.
GPU-Z v0.4.2
Staro 21.05.2010., 13:43   #102
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
  • Added full voltage controller monitoring for GeForce GTX 480
  • Added real-time clock monitoring for GF100
  • Added detection for vendor GALAXY
  • Complete revamp of voltage controller architecture. Adds voltage monitoring for many ATI & NVIDIA cards and generic monitoring method for NVIDIA cards via driver.
  • Added support for >4 GB memory on NVIDIA
  • Fixed memory clock reading on some HD 5670 cards
  • Fixed thermal sensor count on some ATI Evergreen models
  • Fixed incorrect default clock reading on some ATI Evergreen models
  • Added detection for NVIDIA GTX 465, GT 320M GT 335M, ION variant, GT 340, Tesla C2050, Tesla M2050, GTX 285M, GT 325M, Quadro FX 880M, Quadro FX 1800M
  • Added detection for ATI HD 5570, Mobility 4550, Mobility 5870, HD 4250, HD 4290, FirePro V7750
  • Added detection for Intel GMA 3150
  • Added fix for ADT7473 coldbug (GTX 480) via commandline parameter /fixcoldbug
  • Added OCP adjustment for CHL8266 (GTX 480). Use it via command line parameter /chl8266ocp without parameter to query, with numeric value seperated by space to set. This is a permanent change that will not be reverted by powering down the system.
  • Added languages Hungarian and Spanish
  • Updated languages French, Italian, Russian
GPU-Z v0.4.3
Staro 01.07.2010., 17:44   #103
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
  • Added support for NVIDIA GeForce GTX 460, GT 330, GT 315, GT216 based ION
  • Added support for AMD HD 5670 (Juniper), Mobility HD 5430, Mobility 4200, Mobility 4100
  • Added PowerColor hardware giveaway
  • Added die size measurement for NVIDIA GF100
  • Added option to GPU-Z's system menu to show temperatures in °F
  • Fix for BIOS reading on ATI
  • Fixed decimal points in ADT7473 reading
  • Fixed crash on GeForce 8300 IGP
  • Added clock monitoring for RS780 variants
  • Improved clock monitoring for ATI R6xx architecture
GPU-Z v0.4.4
Staro 19.08.2010., 15:47   #104
Razer
Razer's Avatar
Postovi: 11,642
GPU-Z 0.4.5
Changelog:
Fixed shader count on NVIDIA GTX 460, added die size & transistors
Fixed ROP count on AMD Redwood
Added support for ATI FirePro V7800, ATI IGP 320M, ATI FireGL X1, ATI HD 4200 variants
Added launch on Windows startup function accessible via system menu and supporting UAC
Autoupdater will not check for update when no Internet connection detected
Fixed browser not starting correctly from autoupdater
Screenshot detection that promotes GPU-Z's own screenshot upload feature
Sensor data collection limited to 6 hours of data per sensor (~250 KB)
Shortened Clevo PCI vendor name
Download
Staro 02.09.2010., 21:26   #105
Jelc
Super Moderators
Postovi: 17,485
GPU-Z 0.4.6
Latest Changes
- Added MSI hardware giveaway
- Fixed temperature readings getting stuck on ADT7473 sensor (GTX 400 cards)
- Fixed broken BIOS reading on all cards
- General improvements to Intel support, still far from perfect
- Added support for ATI FirePro V8750
- Added support for GeForce GTS 455, GTS 450, GT 440, GTX 430, GTX 420, GT 330, GT218 based ION, GTX 470M, GTX 460M, GTX 445M, GTX 435M, GTX 425M, GTX 420M, GTX 415M, GeForce 310M
http://www.techpowerup.com/gpuz/
Staro 04.11.2010., 17:29   #106
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Here are the winners of the MSI TechPowerUp GPU-Z Hardware Giveaway, for the month of October 2010. panning across September and October, the contests gives six lucky winners some epic graphics hardware from MSI. This is the closing month of the contest. The winners for this month are:
  • Kamil from the Czech Republic, wins MSI R5870 Lightning
  • Thomas from Denmark, wins MSI N460GTX HAWK
  • Damir from Croatia, wins MSI R5770 HAWK
Congratulations to the winners. MSI will contact them directly and arrange for the shipping of the prizes. TechPowerUp would like to thank the nice people at MSI for making the giveaway possible, we will return with more such awesome giveaways to the GPU-Z community.
Čestitam 'rvatu. Ako je netko odavde, slobodno neka se javi
fran123456 je offline   Reply With Quote
Staro 03.12.2010., 15:28   #107
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,280
Added support for GeForce GTX 570, GTX 460 SE
Added support for PCI-Express 3.0
Added PowerColor Giveaway
Added Colorfire PCI vendor ID
Added detection for AMD Radeon HD 6310, HD 6370
Fixed BIOS >64k reading on GF110
Added GT215 based GT 220
Fixed TMU count on GF104
Improved default clock reading on GeForce GTX 580
Better error handling for memory type detection code
http://www.techpowerup.com/downloads...PU-Z.0.4.9.exe
Staro 27.12.2010., 14:17   #108
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
  • Added full support for Radeon HD 6950 and HD 6970
  • Fixed TMU/Texture Fillrate rounding error on NVIDIA cards
  • Improved voltage monitoring support for GTX 570
  • Workaround for ATI OpenCL driver crashing GPU-Z on systems with NVIDIA cards
  • Fixed crash when driver version could not be read
  • Fixed crash when splash screen interrupted by message box
GPU-Z v0.5.0
Staro 25.01.2011., 17:37   #109
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
  • Added support for NVIDIA GTX 560 Ti, 480M, 485M
  • Added transistors and die size for 460M, 445M, 435M
  • Added release date for 6800 GT, 6600 GT, 6600, 6200, 8800 GTX, 8800 GTS, 8800 Ultra, 8600 GTS, 8500 GT, 8800 GS, 9600 GSO, 8800 GT, GTS 250, GT 440
  • Added preliminary support for AMD Zacate and Ontario APUs
  • Found a new way to disable NVIDIA's power limiter
  • Added support for GTX 570 and GTX 560 to power limit disable function, the parameter is now called /GTX500OCP
  • Fixed crash in sensors panel
  • Acer PCI vendor now using a shorter text that fits the field width
  • Added CHL8214 & CHL8226 support for AMD Barts and Cayman
  • Improved the automatic update check to run completely in the background and only appear when an update is available (manual update check is unchanged)
GPU-Z v0.5.1
Staro 21.03.2011., 14:54   #110
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
TechPowerUp GPU-Z 0.5.2 Released
TechPowerUp today released version 0.5.2 of GPU-Z, our popular graphics hardware information and diagnostic utility that gives you information about the installed graphics hardware in your computer, and lets you monitor various parameters such as clock speeds, temperatures, fan speeds, and voltages, all in real-time. GPU-Z is also backed by our overclock validation system and video card BIOS database. Version 0.5.2 adds support for new GPUs, improved support for known GPUs, and a timely dose of stability improvements.
To begin with, GPU-Z 0.5.2 can now detect AMD Radeon HD 6990, NVIDIA GeForce GTX 590, GTX 550 Ti, GTX 560 Ti; improved support for GTX 570, and Intel "Sandy Bridge" processor-embedded graphics. The CHL8228 VRM controller found on some Radeon HD 6900 series cards is supported. There's improved OpenCL support detection for AMD/ATI GPUs, and improved driver-based monitoring support for AMD/ATI GPUs in general. A number of stability/reliability fixes were introduced.
DOWNLOAD: TechPowerUp GPU-Z 0.5.2
The changelog for GPU-Z 0.5.2 follows:
  • Added support for NVIDIA GT 440, GTX 550, GTX 560, GTX 570, GTX 590
  • Added support for AMD HD 6990
  • Added detection support for more Sandy Bridge IGPs
  • Fixed ROP count on ATI Madison
  • Improved OpenCL detection for ATI
  • Added CHL8228 voltage controller support for Cayman Pro and XT
  • Improved driver based voltage monitoring support for ATI cards
  • Added startup parameter /card followed by the adapter index, starts with 1.
  • Several crash and stability fixes
http://www.techpowerup.com/142583/Te...-Released.html
C L O W N I N G A R O U N D
Staro 11.04.2011., 08:14   #111
Doink the Clown
Postovi: 6,214
TechPowerUp GPU-Z v0.5.3 Released
TechPowerUp today releases the latest version of GPU-Z, our popular graphics subsystem information, diagnostic, and monitoring utility. Version 0.5.3 comes with a timely dose of support for new GPUs, and stability fixes. To begin with, GPU-Z now supports recently released GPUs such as AMD Radeon HD 6790, AMD FirePro V5800, NVIDIA GeForce GT 555M, GTX 540M, G315M, Quadro FX 600, FX 2800M, Quadro 4000; a trio of new voltage controllers are supported, including VT1556, uP6266, uP6218; and added capability to show sensors in TechPowerUp OSD Server (upcoming software). Several stability and reliability updates were also made.
DOWNLOAD: TechPowerUp GPU-Z v0.5.3
A list of changes follows.
  • Added support for AMD Radeon HD 6790, FirePro V5800
  • Added support for GeForce GT 555M, GTX 540M, G315M, Quadro FX 600, FX 2800M, Quadro 4000
  • Fixed GeForce GTX 590 release date
  • Added support for voltage controllers VT1556, uP6266, uP6218
  • Added VDDCI measurement on CHL8228 based ATI cards
  • Added capability to show sensors in TechPowerUp OSD Server
  • Fixed several crashes and resource leaks
http://www.techpowerup.com/143770/Te...-Released.html
Staro 03.05.2011., 19:30   #112
Doink the Clown
Postovi: 6,214
TechPowerUp Releases GPU-Z ROG Edition v0.5.3
TechPowerUp in association with ASUSTek, today unveiled a special Republic of Gamers (ROG) edition of GPU-Z, our popular graphics hardware information, diagnostic, and monitoring utility. GPU-Z gives you a quick glance on the graphics hardware installed in your machine, and lets you monitor its vital stats such as clock-speeds, fan-speeds, voltages, and even fine details such as graphics memory usage on supported GPUs. The new GPU-Z ROG Edition is based on GPU-Z version 0.5.3, and includes a vast database of discrete GPUs.
GPU-Z is backed by our expansive video card BIOS database, and Overclock Validation system, making up for a nifty, portable application that is every GPU overclocker's companion. TechPowerUp is happy to be associated with one of the most renowned brands in the PC enthusiast industry, ASUS Republic of Gamers. ASUS Republic of Gamers is a fine selection of enthusiast motherboards and graphics cards from one of the biggest names in the hardware industry.
Staro 29.06.2011., 15:13   #113
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,280
TechPowerUp GPU-Z v0.5.4
Considerably improved startup time on ATI cards, faster on NVIDIA, too
Improved rendering on high-DPI screens
Fixed ROP count reading on AMD Radeon HD 6790, Turks & Whistler
Fixed sensor count on Caicos, Whistler, Turks
Fixed OpenCL detection on some NVIDIA drivers
Memory size reading support for AMD Fusion GPUs
Added die size and transistor count for GF108, GF114, Turks, Caicos
Added detection for more Intel Sandy Bridge GPUs
Added detection for variants of GT 220, GTS 450
Added detection for faked cards based on GTS 250, 9600 GT, NV41M
Added detection for GeForce GTX 560 non-Ti, GT 520, GF116 based GTS 450, GT 550M, GeForce 315, GeForce 405, Quadro 2000 & 6000
Added detection for GeForce GTX 560M, GT 555M, GT 550M, GTX 540M, GT 525M, GT 520M, GTX 415M, GT 410M, Quadro 1000M, NVS 4200M
Added detection for GT218 based ION 2 / 9300 GS / 8400 GS / 405 / NVS 300
Added detection for HD 6750, HD 6770, HD 6850M, HD 6970M, HD 6670M, HD 6650M, HD 6330M, FirePro 2260
DOWNLOAD
DOWNLOAD ROG EDITION
Staro 01.09.2011., 22:44   #114
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
TechPowerUp GPU-Z 0.5.5 Released
TechPowerUp today announced the latest version of GPU-Z, the graphics hardware information and diagnostic utility trusted by the PC enthusiast community at large. Version 0.5.5 comes with support for the latest graphics processors, makes the interface a little more accessible to users, and improves stability and reliability.
To begin with, GPU-Z 0.5.5 adds full support for AMD A-Series accelerated processing units (the Radeon GPU component embedded in them), a load of new and lesser-known GPUs from NVIDIA including GeForce GT 560 Ti OEM, GT 545, GT 530, GeForce GTX 580M, GT 555M, GeForce 520MX, GT 520M, 410M, 305M, Quadro 5000, Quadro 4000M, Quadro 400; from AMD including Radeon HD 6290, Radeon E6760 & E4690, FirePro V8800, FirePro V3700, FirePro 2460 (FireMV); and the recently launched ASUS ROG MARS II, which probably got Santa's inbox flooded by now.
GPU-Z 0.5.5 packs a much-demanded UI improvement, in systems with multiple graphics processors it remembers the GPU it was monitoring when it was last closed, and restores it. This helps overclockers with multiple GPUs, or enthusiasts using the Lucid Virtu platform, as GPU-Z will start up with monitoring the discrete GPU which you were monitoring, and not the Sandy Bridge IGP.The Stream Processor count for AMD "Blackcomb" (AMD Cayman GPU in MXM boards), BIOS version reading for NVIDIA GPUs is also improved.
With this version, PowerColor has teamed up with us once again, to bring you a stunning new Giveaway.
Zanimljiv Giveaway u suradnji sa PowerColor.
It's that time again, when bagging some rad graphics hardware is as easy as showing off your PC tuning skills and filling up a form in GPU-Z 0.5.5. PowerColor is back on board with us, and this time what we're giving away will come with the bragging rights of being perhaps the only people in the world to have it! Presenting, PowerColor and TechPowerUp Pimp my Rig Contest 2011!
You stand to win a rare, one of its kind PowerColor dual Radeon HD 6970 X2 prototype, which is designed by its makers to be one of the fastest, most tweakable graphics cards. There's just one prototype on the planet that's fully finished for the consumer, and you stand to win it! All you have to do is get the lowest possible 3DMark 03 score in default settings (of 3DMark), submit the validation link of your feat along with other details in the "PowerColor Giveaway" tab of GPU-Z 0.5.5. That's right, you don't need the fastest hardware to win this contest, just your skills.
That's not all! You can still leave things to Lady Luck. From the pool of valid entries, we will randomly pick one person, who will bag an awesome new PowerColor Radeon HD 6870 X2 dual-GPU graphics card! So there's simply no reason not to try!
Malo sam čitao HardOCP forum i vidim da će se trebati dobro potruditi za dobiti najmanji score. Stvarno ljudi imaju svašta po svojim ormarima i ladicama.
Kod mene tu negdje leži neki P2 na 433MHz i Riva TNT2, ali izgleda da ne može zavrtiti 3DMark 03.
Download GPU-Z.
cccp je offline   Reply With Quote
Staro 01.09.2011., 23:55   #115
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
bas me zanima da li pretpotopna integrirana VIA sa nekim ~80MHz AMDom (valjda, ako se dobro sjecam) moze tjerati 3dmark. XP znam da moze progutat, to je testirano.
ili zblekat sve to na ISA graficku, naravno PCI? slatke nedoumice..........
Staro 02.09.2011., 00:01   #116
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Neće ići.
http://www.futuremark.com/products/3dmark03/minreq/
DirectX 9 compatible graphics adapter that has 32MB of memory and is fully DirectX 7 compliant
Spoiler alert!
Staro 02.09.2011., 00:14   #117
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
Autor Burko Pregled postova
Ovisi koja grafička kartica na tom sučelju. Ako podržava barem DX6, išlo bi sa 3DMark-om '99. Svi noviji 2000/2001 pa nadalje zahtjevaju DX7 podršku.
timmy je offline   Reply With Quote
Staro 02.09.2011., 09:25   #118
Burko
Burko's Avatar
Postovi: 2,317
thnx obojici, nazalost otisao sam na futuremark stranice i sam i vidio sistem za 3dmark03 . nema veze, mozda neka stara drlja od grafickih koje imam moze potjerat dx7, ako nadem vremena...........
Staro 02.09.2011., 09:34   #119
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Nema beda.
Ja imam idealnu konfu, s370 P3 866, gf2mx400 32MB i još neki 10GB spori disk
Još ak će to biti prejako imam celera na 533, još jednog p3 na 733...
Može link na thread na HardOCP forum cccp?
Spoiler alert!
Staro 02.09.2011., 11:46   #120
Baja 001
Baja 001's Avatar
Postovi: 7,504
Nema beda.
I mene zanima, iman Celer 700, 128 SDRAMa i MX440/FX5200. AKo triba ide i downclock.
