Staro 19.03.2009., 12:38   #1
maliking1
Postovi: 17
(riješeno) DMA i PIO
Zelim rijesit problem koji se mi vuce vec neko vrijeme, pa bih molioa,ako mi tko moze savjetovat?
Ovako. Na racunalu su dva identicna diska, svaki na svom IDE kanalu, a pored svakog tih diska stoji jos dvd-przilica. Osnovni podatki su slijedeci:
1.Disk-primary master
Maxtor 6Y060L0
Firmware version : YAR41BW0
Serial number : Y2NYAP8E
Capacity : 57.3 GB (~61.5 GB)
Buffer size : 2048 KB
Standard : ATA/ATAPI-7
Supported mode : UDMA Mode 6 (Ultra ATA/133)
Current mode : UDMA Mode 2 (Ultra ATA/33)
(U BIOS-u stoji: PIO 4, DMA 2 za primary master disk, dok za przilicu kao primary slave PIO 4, DMA 2
S.M.A.R.T : yes
48-bit Address : no
Read Look-Ahead : yes
Write Cache : yes
Host Protected Area : yes
Device Configuration Overlay : yes
Automatic Acoustic Management: yes
Power Management : yes
Advanced Power Management : yes
Power-up in Standby : no
Security Mode : yes
Firmware Upgradable : yes
Partition : 1
Drive letter : C:\
Label : GLAVNI
Capacity : 17665 MB
Usage : 31.43%
Type : NTFS
Bootable : Yes
Partition : 2
Drive letter : D:\
Label : FILMI
Capacity : 40970 MB
Usage : 56.97%
Type : NTFS
Bootable : No
2.Drugi disk-Secondary master
Maxtor 6Y060L0
Firmware version : YAR41VW0
Serial number : Y2R2RSKE
Current mode : UDMA Mode 5 (Ultra ATA/100)
(U BIOS-u stoji: PIO 4, DMA 5 za secondary master disk, dok za przilicu kao secondary slave PIO 4, DMA 4)
S.M.A.R.T : yes
48-bit Address : no
Write Cache : yes
Security Mode : yes
Partition : 1
Drive letter : E:\
Label : DARKECOV
Capacity : 17665 MB
Usage : 0.37%
Type : NTFS
Bootable : Yes
Partition : 2
Drive letter : F:\
Label : DARKO
Capacity : 40978 MB
Usage : 56.95%
Type : NTFS
Bootable : No
U device manangeru za Primary IDE chanel, di pise device usage-zasivljeno je, a za secondary IDE chanel pise device usage Use this device(enabled).
Zasto toliko opsirno pisem? Pa imam neki osjecah da tu lezi moj problem kod CPU Usage, koji se krece izmedju 85-100%. Nek napomenem da sam sve nepotrebne procese u cijelosti isklopil,HijackThis je svoje napravil, sve je u svezi toga sredjeno. Mozda je bas u tome bit problema kod mene?
U BIOS-u imam mogucnost to mjenjat, no iskreno, volio bih prvo cuti ljude koji se u to razumiju i tek onda caprkat po BIOS-u. Ujedno nek napisem da sam vec mjenjal one siroke kablove na IDE kanalima.Bitno mi nije uspjelo nista promjenit, pa sad
Izvinjavam se na poduzem postu,ali....
maliking1 je offline   Reply With Quote
Staro 19.03.2009., 12:52   #2
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Trebao bi ti i "1.Disk-primary master" raditi u UDMA Mode 5.Ako možeš namjesti u BIOS-u da radi u tome modu,ako i dalje bude mod 2 onda odspoji pržilicu koja je s njim na istom kablu pa vidi onda.I da li su ti jumperi dobro namješteni na svim uređajima?
Veki-os je online   Reply With Quote
Staro 19.03.2009., 13:10   #3
maliking1
Postovi: 17
Autor Veki-os Pregled postova
Jumperi su dobro namjesteni, a ja cu sada probat to kaj si napisal.Zajedanput iskreno hvala!
Staro 19.03.2009., 13:48   #4
maliking1
Postovi: 17
U BIOS-u sam stavil ono user define i s tim mi je bilo omoguceno stavit DMA na 5, no u device manangeru i dalje se pojavljuje DMA 2. Iskopcavsi przilicu s kabela jednostavno se disk izgubi (mislim na tvrdi), nema ga. Stavivsi natrag dvd, sve se opet normalno ucita. Izgleda da se mi sve vise komplicira
Jer kad iskopcam dvd (przilicu) u BIOS-u na postavkama User define ne mogu podesit brojeve za cylinder itd, jednostavno je zasivljeno.U slucaju da pa stavim na Auto, radi beskrajno dugo i izgubim strpljenje pa restartam. I sad kako dalje?
Staro 19.03.2009., 14:17   #5
Veki-os
Veki-os's Avatar
Postovi: 3,996
Otkopčaj opet pržilicu i taj kraj što je bio u pržilici ukopčaj u disk.Znači zamjeni položaje na kablu ali prvo probaj bez prže.
Staro 19.03.2009., 14:46   #6
maliking1
Postovi: 17
Ne pomaže.Sve ostaje isto. U BIOS-u u redu, dok winxp pokazuju kak sam vec napisal. Bi pomogla nova instalacija win?
Staro 19.03.2009., 14:51   #7
Veki-os
Veki-os's Avatar
Postovi: 3,996
Probaj deinstalirati taj kanal na kojem ti je taj disk u DMA 2 modu.
Onda restart i windowsi če ga sami opet instalirati,trebalo bi upaliti.
Staro 19.03.2009., 15:04   #8
maliking1
Postovi: 17
Ufufufufuf, vjerujem ti na rijec...,ak se ne javim za pol sata (usput po unuke u skolu),znaci ....
EDIT:
Ostaje isto, znaci na 2 DMA. Ako bih znao da nova instalacija donosi promenu, to bih uradio, no stvarno se mi neda sva ta sranja radit,ako to nece pomoci. Sad stvarno neznam.
Zadnje izmijenjeno od: domy_os. 19.03.2009. u 15:36.
Staro 19.03.2009., 15:36   #9
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor maliking1 Pregled postova
Da ti nemas mozda 40 pinski kabel na tom kanalu?
Igor Batinic
Staro 19.03.2009., 15:43   #10
maliking1
Postovi: 17
Sad sam stavil onaj pravi široki kabel i stavilo je na DMA 5, no CPU Usage jos uvjek se krece 70-90%.Sto bi jos moglo biti?
Staro 19.03.2009., 15:45   #11
maliking1
Postovi: 17
Autor Old Iggy Pregled postova
Bil je neki kabel koji je imal onak siroke trake, a sad sam stavil taj s gustim trakama, pa je stavilo na DMA5, ali CPU usage je jos uvjek grozan.
Staro 19.03.2009., 16:32   #12
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Daj navedi koji procesi gutaju toliko CPU-a.
Igor Batinic
Staro 19.03.2009., 18:33   #13
maliking1
Postovi: 17
Navek Opera (u prosjeku 70-80%) i explorer. Nijedan drugi proces ne zauzima nekaj posebnog.
Bio sam u trgovini i uzeo najnoviji taj kabel (onaj moj bio je malkice izmuckan), pa cu ga stavit gore navece kad odu svi spavat. Ujedno cu okrenut napajanje. Zasto? Pa napajanje lezi tocno iznad procesora i ja sam ga okrenuo tako da ventilator od napajanja puse direktno na procesor.Sad si mislim, mozda nije to dobro, pa cu ga okrenut i onda vidjet sto je?Najzanimljivije je to da ni Hijack this ne nadje nist posebno, ni Search...,NOD, ma stvarno zanimljivo. Ocito je nekaj hardverskog, bar ja tako mislim.
Mozda jos koja ideja prije nocnog popravka?
Evo od HijackThis:
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Opera\opera.exe
C:\Documents and Settings\Hajrudin\Desktop\HIJACK.EXE
O4 - HKUS\S-1-5-19\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [ShowDeskFix] regsvr32 /s /n /i:u shell32 (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [nltide_3] rundll32 advpack.dll,LaunchINFSectionEx nLite.inf,C,,4,N (User 'Default user')
Staro 19.03.2009., 20:05   #14
maliking1
Postovi: 17
E ovako. Sve sam isprobaval,iskopcal dvd pogone,menjal komplet kabele,pa na prvi,pa na drugi, pa okreni ovako-onako, stvarno kaj god mi je palo na pamet.Jedina stvar koja je iz svega toga izasla je ta da sam kantu usput ocistil i da su win stavili master prvi disk na DMA 5. Ostalo je sve ostalo isto, sto ce znacit ili stvarno neki skriven virus (jer ni NOD ni AVG nisu nasli nist pametno),trojan (trojan remover ne pronalazi nista)....
Jedino kaj mi pada napamet je mozda se procesor previse grije pa zbog toga dolazi do CPU usage u tako velikom postotku, nemam pojma. Kupit cu sutra onu pastu pa probat jos to.Ostalo pojma nemam.
Iskreno hvala svima koji ste predlozili dosta toga.
Staro 19.03.2009., 23:27   #15
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Daj pozatvaraj sve sto mozes pa onda vidi. Opera 80%?
Igor Batinic
Staro 20.03.2009., 06:42   #16
maliking1
Postovi: 17
To me cudi. Zasto Opera zauzima toliko?
Staro 20.03.2009., 07:46   #17
domy_os
domy_os's Avatar
Postovi: 18,862
Otvoren Dnevnik.hr? Ili neka druga stranica s Flashom?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 20.03.2009., 07:52   #18
maliking1
Postovi: 17
Autor domy_os Pregled postova
Ne.Uglavnom forumi u svezi satelitske tv,ali oni koliko znam ne trebaju taj flash.U biti je problem uistinu kad pokrenem Operu.Firefox ne,IE ne, samo Opera.Probat cu ju jos deinstalirat,pa jovo nanovo stavit.
Staro 20.03.2009., 09:21   #19
maliking1
Postovi: 17
Rijeseno.Kako?Deinstalacija Opere,sve nanovo stavljano (lozinke,stranice itd...),sada trosi isto kao IE ili Firefox.Ja zadovoljan,Vi zadovoljni,sve za 5. Najiskrenije hvala svima koji ste pomogli,bez Vas, kanta leti kroz prozor. Iskreno hvala!
