Staro 18.07.2004., 01:28   #1
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Cudno,mozda i nije...help
evo, recimo da sam prilicno neiskusan u OCu, ovo su podaci mog kompa:
------CPU------
CPU ID : 681
CPU IDEx : 781
Revision : B0
Model : AMD Athlon(tm) XP 2400+
Codename : Thoroughbred
Technology : 0.13µ
----CHIPSET-----
General Information :
NorthBridge : nVidia nForce
SouthBridge : nForce HUB Interface
NorthBridge Information :
Architecture : Northbridge
Manufacturer : nVidia
Revision : B2
Front Side Bus Speed : 146.8 MHz
Bus Speed : 293.5 MHz (DDR)
HyperTransport Frequency : 400 MHz
APIC Information :
Version : 1.01
Maximum Interrupts : 24
IRQ Handler enabled : No
Device Capabilities :
I/O Access : No
Memory Access : Yes
Bus Master Capable : Yes
Special Cycle Recognition : No
Memory Write & Invalidate : No
VGA Palette Snoop : No
Parity Error Response : No
Cycle Wait : No
System Error Line : No
Fast Back-to-Back : No
Detects Parity Errors : No
User Defined Format : No
PCI 66Mhz Bus Support : Yes
New Capability List : Yes
PCI Support : AGP
PCI Support : Hyper-Transport
-----MBO----
Product : WinFast nVIDIA
Version : Unspecified
Serial Number : Unspecified
Support MP : No
Chassis Information :
Manufacturer : Unspecified
Type : Desktop
Asset : Unspecified
Slots Information :
Slot PCI : Available (32-bit) 5.0v
Slot PCI : In Use (32-bit) 5.0v
Slot AGP : Available (32-bit) 5.0v
External Connectors :
Serial 16450 Compatible : DB-9 male
Parallel ECP/EPP : DB25 female
Keyboard : PS/2
Mouse : PS/2
Internal Connectors :
PRIMARY IDE : On Board IDE
SECONDARY IDE : On Board IDE
FDD : On Board Floppy
EEPROM Information :
Type : EEPROM Specific
Address : 0x57
----RAM----
A0 (RAS 0) : 128 (Single Bank) -
A1 (RAS 2) : 128 (Single Bank) -
A2 : Empty
Memory Controller Information :
Memory Controller : Standard, EDO
Number of connectors : 3
Max. Module Size : 32 MB
Max. Memory Size : 96 MB
Supported Speed : 70ns, 60ns
Supported Voltages : 5v
Error Detection Method : 8-bit Parity
Error Correction Capability : Unspecified
Current/Supported Interleave : 1-way/1-way
Chipset Information :
Type : DDR-SDRAM PC0
Channels : Dual
ECC Diagnostic : No
RAS to CAS (tRCD) : 3 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 7 clocks
e sad, ako bi itko mogao pomoci, u CPU info pise da je Athlon XP 2400+, ali to je zato sto sam digao fsb na 146 mhz(13.5x146=1981mhz), postupak sam obavio tako da sam postupno dizao fsb bez dizanja napona jezgre, dok se komp nije htjro upaliti sto se desilo na 149mhz fsb, izvadio sam bateriju i vratio nazad te stavio na zadlju frekvu na kojoj radi, dakle 146/147mhz, ali sada neznam jel zbog toga sto sam resetiro bios...jer se temp proca nije digla prakticki nista,igram recimo neku igru 5-10min i komp se resetira,nakon reseta kad se pali cuje se zvuk harda kako se pali, ne vidim razlog zasto bi hard crko..odnosno ugasio se,dali mozda zbog napajanja koje je btw Codegen 300W(doslo s kucistem), moze li mi netko pomoci, dati savjet ili tako nesto.....
hvala, peace
rams je offline   Reply With Quote
Staro 18.07.2004., 04:01   #2
hrca
...(=_o)...
hrca's Avatar
Lokacija: Osijek/Đakovo
Postovi: 401
Jel ti imaš Athlona 2200+ po defaultu?
Moj takav radi na 160 FSB bez dizanja napona proca i memorije ,kod mog frenda se komp resetira nakon 15-ak minuta igranja igrica i to bez da je komp nabrijavan,mislim da mu je nešto s hladnjakom jel mu se tada temp. penju preko 60 što je nenormalno
hrca je offline   Reply With Quote
Staro 18.07.2004., 11:28   #3
miato
(°_°)
miato's Avatar
Postovi: 3,249
Re: Cudno,mozda i nije...help
vrlo vjerojatno
Staro 18.07.2004., 16:23   #4
rams
80286
rams's Avatar
Postovi: 1,724
da, po defaultu je 2200+, ali radi na 133mhz fsb po defaultu i tako radi ko urica, hladnjak mi je GlacialTech Igloo nesto, ne pretjerano dobar, ali temp proca neide skoro nista gore, nakon dva-tri sata igranja se digne na nekih 50-55°C sto opet nije previse+kuciste je otvoreno,
ploca je Leadtek Winfast K7N415DA, to mi Pcwizard nije mogo procitat pa evo da napisem..
Staro 18.07.2004., 19:29   #5
hrca
...(=_o)...
hrca's Avatar
Postovi: 401
Moje napajanje isto CODAGEN 300 W,pa ne znam jel to ,jel to temp. od 50-55 na 2200+ ili 2400+ mislim da ti je to malo prevelika temp. ,moj na 2200+ radi na max 45,
tvoja ploča ima O.T.S.(CPU Over Temperature Shutdown) pa ti je možda nisko postavljena granica pa ga sruši ako je to nemoj je previše dizat jer inače , de napiši koju memoriju imaš i koliki je napon
Staro 18.07.2004., 21:06   #6
rams
80286
rams's Avatar
Postovi: 1,724
eo igro sam NFSU 2 sata i temp proca je bila 52C u biosu(ne clockan), nije se cuo hard ali je grafa prokuhala(probo rukom, vrela..),
napone nisam diro, napon RAMa je 2.48V i nisam potuno sigran ali mislim da je neki no-name 256mb na 266mhz, a napon proca je 1.6V
OTS je naredjen na 70°C i nemoze vise za gasenje, ali proc nikad nije bio tako vruc tako da je nesto drugo(ram,napajanje,grafa...)
Staro 19.07.2004., 02:24   #7
hrca
...(=_o)...
hrca's Avatar
Postovi: 401
Instaliraj Overclock Speed Gear II to trebaš imat na CD-u od matične to ti je njihov program za oveclock ,imaš sve pa tak da tamo možeš pratit temp. samo nemoj previše eksperimentirat jer bi nešto moglo zagorit, pretpostavljam da igraš igrice s integriranom grafičkom pa tak da je to s vrelom grafom normalno jer nema nikakav hladnjak na sebi,tak je i kod mene
Napajanje može zajebavat al mislim da ti je do RAM-a ,
ta memorija mi ne izgleda kao da je sposobna za neki veći OC,
kod mene nije htio upalit komp na FSB od 166 (kod SAMSUNG DDR 333 memorije) sve dok nisam podigo voltažu memorije s 2.6V na 2.7V i dok nisam podigo napon procu na nekih 1.65
tako da bi i ti trebo ostavit množitlj na 13.5 i povećat voltažu memorije na 2.6V a ako tad ne uspije onda i malo dić voltažu proca(OBAVEZNO PRATI TEMPERATURE PROCESORA I MEMORIJE) ,al kod tebe ne valja previše mrdat po voltaži jer su ti po defaultu velike temp. procesora,prije svega najbolje da pročitaš Kovin članak o Overclocku procesora i memorije pa će ti sve biti puno jasnije
Staro 19.07.2004., 21:26   #8
rams
80286
rams's Avatar
Postovi: 1,724
grafa nije integrirana a inace je MX440 64mb, dakle srot do jaja ali me sluzi no nije to tema, ima mali aktivni cooler na GPU a na memorijama nista, i dapace mi je cudno zasto se tako jako grije, ali sto je tu je,
procitao sam Kovine clanke prije nego sam isao clockat i procu nisam htjeo dirat voltacu vec samo fsb bas zbog toga sto je temp malo veca,a sto se tice memorije, ja nemam u biosu postavke tRAS i sve ostalo, nego imam
Memory Timing : Agressive i Optimal(to asm stavio na agrresive jer se maaalo poboljsaju performanse)
CAS Latency Override: Auto i 2 i 2.5to mi je na auto, probao sam staviti na 2 ali mi padnu performanse
te Memory Frequency: Auto/266/200, to mi je isto na auto, ali memorija ionako radi na 266mhz pa onda nemoram to mjenjat(valjda)
zasad onda necu previse clockat dok nesredim neko bolje hladjenje i napajanje
peace
Staro 19.07.2004., 21:47   #9
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
KAJ?? Ne! OC se radi iz BIOS a ne iz nekavih programčića.
Za temperaturu MOtherboard Monitor.
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 20.07.2004., 00:16   #10
hrca
...(=_o)...
hrca's Avatar
Postovi: 401
Dobro,dobro mozda sam se krivo izrazio znam da se OC radi iz Biosa al mislio sam na grafičku koja je integrirana pa se iz tog programa može dić frekva...jel je spominjo vrelu grafu itd.
Moja preporuka je da uzme bolju matičnu i memoriju i naravno hlađenje jer s ovim komponentama neće baš puno dobit,zarr nee
Staro 20.07.2004., 01:46   #11
rams
80286
rams's Avatar
Postovi: 1,724
da, sam bed je sto u Motherboard Monitoru nema moje maticne, no sad nekih 200kn ide na modding kucista(sad sam presto lemit tu jednu LEDicu hehe, kak dobro svjetli plava LED) pa se moram malo zrtvovat sto se tice performanski kompa, a onda ide skupljanje love za djelove bolje
hvala svima za odgovore
Staro 20.07.2004., 02:06   #12
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
kak nema ledatekice???
Grunf je moj idol!
Staro 20.07.2004., 16:29   #13
rams
80286
rams's Avatar
Postovi: 1,724
ma ima Leadtek ali nema moj model odnosno K7N415DA, a hardware monitor mi nece radit
Staro 21.07.2004., 00:06   #14
rams
80286
rams's Avatar
Postovi: 1,724
blah malo sam nesiguran...pa je bolje prvo pitat,
trazio sam noviju verziju biosa ali nigdje nema za 415DA, cak n na sluzbenim Leadekovim stranicama, ima samo za 420DA, e sad, jel da flasham bios ili ne, cak su i upute koje se dobiju s plocom skoro potpuno iste za te dve ploce pa ja mislim da je to dobar BIOS, samo moram iz DOSa pokrenit exe fajl
Staro 21.07.2004., 18:49   #15
Toncek
member
Toncek's Avatar
Lokacija: Dalmacija
Postovi: 758
Neeeeeeeee, ni u ludilu.....male su sanse da ti uspije... Ne igraj se jer bi mogao ostat bez ploce....
Toncek je offline   Reply With Quote
Staro 21.07.2004., 18:59   #16
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Ne budeš ostao bez ploče ali si budeš zakomplicirao život 100%. U čem je razlika u te dvije ploče? SATA kontroler, više USB portova, mrežna kratica? Ak se zajebe stvar moraš nači nekoga s reprogramatorom i voljnog da ti to odradi za neku sumu novaca itd...NE!
tor je online   Reply With Quote
Staro 21.07.2004., 19:41   #17
Toncek
member
Toncek's Avatar
Lokacija: Dalmacija
Postovi: 758
Ko da je ostao bez ploce, jer za novce koje bi potrosio mogao bi kupit polovnu maticnu....
Staro 21.07.2004., 22:40   #18
rams
80286
rams's Avatar
Postovi: 1,724
uf necu onda...fala.....evo malo sam testiro sa Prime95, torture test je radio 1,5 sat i temp proca je bila 52C stalno,
zanima me sto mislite o ove tri ploce,odnosno koju je bolje da kupim jer imam bas tak para negdi a mislim da nisu lose:
MBO EPOX 8RDA3I, nForce2 Ultra 400 SPP+MCP, DDR, zvuk, LAN, socket A
ili
MB Albatron KX18D Pro, Socket A, NVIDIA nForce2 Ultra400 SPP+MCP, FSB 400/333, UDMA133, Adjustable CPU and AGP frequency by 1 MHz increment, Adjustable Vcore, VAGP, Vmemory, 6PCI, AGP8x, 3DDR (Dual Channel, 400/333MHz), 6 channel sound, USB 2.0, nForce2 MCP 10/100 Ethernet LAN, ATX NOVO!
ili
MB Soltek 75FRN2-L, Socket A, NVIDIA nForce2 Ultra400 SPP+MCP, FSB 400/333, UDMA133, 5PCI, AGP8x, 3DDR (Dual Channel, 400/333MHz), 6 channel sound, USB 2.0, ATX
ja mislim da je Albatrononova mama bolja, ali mozda netko ima iskustva???, cijene sve tri su oko 500-550 kna
Staro 24.07.2004., 23:59   #19
rams
80286
rams's Avatar
Postovi: 1,724
proslo tri dana a nitko ne odgovara....schr
aj pliizzz...jel valja koja od ove tri ploce ili nesto drugo
peace
Staro 25.07.2004., 00:58   #20
Mailman
Mailman's Avatar
Postovi: 1,606
Mailman je offline   Reply With Quote
Staro 25.07.2004., 01:25   #21
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
imam....zadovoljan!preporuka...premda bi ti bilo bolje zašparat još malo i ubost 8rda3+!
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
Staro 25.07.2004., 01:29   #22
rams
80286
rams's Avatar
Postovi: 1,724
e fala, ma kupit cu ja nju, samo mi je vazno da ima sve postavke za memoriju, i to sve da mogu fino clockat, a dalje sparam ili za bolje hladenje svega u kompu, ili bolju graficku, al to jos budem vidio, prvo maticna
evo malo detaljnije o toj
Specifications for EP-8RDA3i:
• Socket A Supporting 200/266/333/400MHz FSB AMD Processors
• NVidia NForce2 SPP / MCP Chipset
• 1 Floppy drive controller - 2 serial ports - parallel port
• AGP 8x for 1.5v graphics cards, 5 PCI slots
• 2 standard IDE ports for ATA-133, backwards compatible with ATA-100/66
• 3 DDR SDRAM banks for Maximum 3 GB memory DDR333/400
Dual Channel DDR400 memory support for increased performance (backward compatible)
• 4 USB 2.0 ports, 4 extra by optional USB back-panel cables
• Multiphase power solution for increased stability, including 12v supply adaptation for CPU
• Onboard sound, 6 channel CMedia C9739a Audio Supports Digital SPDIF and software AC-3
• Standard ATX format 305mm x 245mm x 40mm, ATX Size
• Onboard 10/100 LAN
kupujem!!!
Staro 25.07.2004., 01:35   #23
Mailman
Mailman's Avatar
Postovi: 1,606
Novije revizije imaju Realtekov alc650/655 zvuk....
