Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 18.02.2009., 15:18   #1
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
BFG GeForce GTX 295 H20
BFG GeForce GTX 295 H20 review by Guru3d
''normal desktop usage: With a proper liquid-cooling setup at idle you can expect a temperature of below 35~40 degrees C (104 degrees F).
stress: once we push the GPU to 100%, the temperatures remain low and settle at 45-50 Degrees C (122 degrees F). Fantastic to see. Bear in mind that the final temperatures are highly dependant on your liquid cooling setup and environment. In a hot summer, your coolant temperature can be slightly warmer as well, thus so will your GPU temperature.
Anyway, that is impressive cooling right there.''
Staro 18.02.2009., 15:38   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
bome, ne lažu
Staro 18.02.2009., 16:57   #3
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
da, odlicne temperature, mocan komad bakra nema sta...
Staro 19.02.2009., 01:08   #4
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
mocna mu je i cijena
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 19.02.2009., 07:49   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
zato je nisam ni napisao na newsima
Staro 19.02.2009., 18:08   #6
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Ma ok, grafička je zvijer, ali 729$??
Ono, prestrašno....
D-I-A-B-L-O je offline   Reply With Quote
Staro 19.02.2009., 23:33   #7
Rebbit
Postovi: 662
ali je grafa trenutno najjaca na trzistu koliko sam upoznat...
ipak 896x2 i proc na 1.2ghz sa ramima na gigahercu....
tesko koja grafa to moze pruzit
nek sam isti kao on, ma nek sam isti ko stari moj, dok zivot juri, ja cu lagano....
Lenovo Thinkpad T14
Logitech MX Master 2S
Logitech MX Keys
Galaxy S23+
Rebbit je offline   Reply With Quote
Staro 20.02.2009., 08:07   #8
Pippincro
Pippincro's Avatar
Postovi: 616
Autor Nikola K. Pregled postova
jel to znaci onda da ja imam cpu od 8ghz ?
Pippincro je offline   Reply With Quote
Staro 20.02.2009., 09:12   #9
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
heboteled, pa ja imam onda 14400 MHz proc! đizs, nisam ni znao!
Staro 20.02.2009., 09:34   #10
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Hebote, pa svaki dan otkrivate nešt novo
Jel vam mogu bit prijatelj?
Mislim, dva frenda sa 22 GHz
blaa
Staro 20.02.2009., 09:38   #11
Pippincro
Pippincro's Avatar
Postovi: 616
hehe, mislim da cemo dobiti neki kartoncek, ali samo da objasnim Nikola K. radi cega ovakve reakcije:
gpu frekvencija nije 1.2ghz, vec 600mhz po jezgri (ako si vec zbrojio radne taktove jezgre, radi cega nisi i kolicinu vrama i frekvenciju meme? hm, naravno da to nebi bilo tocno..).
Tako da jeste - to je najmocnije graficko rjesenje trenutno, ali je po mom ukusu previse ovisno o driverima i softwareskoj podrsci. A cijena je paprena, ali netko ce i to kupiti
Staro 20.02.2009., 13:12   #12
Rebbit
Postovi: 662
sad sam ga usro i odma se svi belje.. .ehheheh.. a dobro ajd nek im bude...
al ustvrdili smo da je najjaca i da ce i to netko kupit...
usprkos sprdanjima na moj račun...
Lenovo Thinkpad T14
Logitech MX Keys
Galaxy S23+
Staro 20.02.2009., 13:35   #13
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
ma to je bio dobronamjerni 'belj', sori!
da, grafa je skupa, ali bez obzira na cijenu temperature su predobre, i kupovati ce se sigurno... da nam je omjer placa i cijena hardwera kao kod amera vec bi se setao po ulici s majcom na kojoj pise 'da, ja imam x58, i7 965 i quad sli gtx 295'...
btw, na EK waterblocks za EK-FC295 GTX pise: 'Due to high demand, we will be able to ship within 3-5 days after ordering the block.'
to ti sve govori
Staro 23.02.2009., 19:20   #14
Big Guy
RPG player
Postovi: 1,574
@bluefluid
ja sam mislio da idu samo 2 gtx 295 u sli, da tri sli i više nije moguće sa tom grafom
ili je to nešto novo ?
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 23.02.2009., 21:38   #15
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
sta pricas ti? upisi u google quad sli ak ti nesto nije jasno
Staro 25.02.2009., 23:46   #16
Big Guy
RPG player
Postovi: 1,574
ja sam mislio da je tri sli 3 grafe, a quad sli 4 grafe na matičnoj
a izgleda da se dvije gtx 295 zovu quad sli zato jer su gtx 295 po dvije kartice skupa
izgleda da smo oba bili u pravu
Staro 26.02.2009., 00:36   #17
Rebbit
Postovi: 662
Autor Big Guy Pregled postova
3way ti je kao sto si rekao 3 sli grafe..
quad sli ti je 2 grafe x2.. tipa 3870 x2 i 3870x2 u sli ti je quad sli...
dobro si rekao... za gtx295
Lenovo Thinkpad T14
Logitech MX Keys
Galaxy S23+
Staro 26.02.2009., 09:08   #18
Big Guy
RPG player
Postovi: 1,574
quad sli ne mogu biti dvije 3870x2 grafe (sli je nvidia ), ali kužim što želiš reći
http://www.tweaktown.com/popImg.php?img=485cfz_07l.JPG
evo, quad CFX sa 4 hd4850
i nakon pola sata google-anja, da nebi bilo da sam nešto izostavio, nisam nigdje našao da nvidia ima 4 grafe na jednoj ploči
Staro 26.02.2009., 10:09   #19
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
SLI (iliti scalable link interface) je nvidijina licencirana tehnoligija kada se uparuju dvije ili vise grafickih kartica (samo nvidija, naravno). Kako do serije 8 nije bilo rijesenja da se spoji vise od dvije kartice sam izraz 'sli' je oznacavao dvije grafe u jednom polju. No pojavom 8800ultra kartica i ploca sa 3 pci-ex utora sa 680i chipsetom je omoguceno staviti do 3 grafe, sto se onda naziva '3way sli'. Nakon izlaska 9800gx2 kartica, omoguceno je i njihovo uparivanje, sto se onda naziva 'quad sli' (kasnije i za stariji 7950gx2), iz ocitog razloga sto su 7950gx2, 9800gx2 i gtx295 dva gpu-a na dva odvojena pcb-a
Crossfire je atijeva licencirana tehnologija kojom se omogucuje spajanje do 4 radeon graficke kartice. Problem je sto do izlaska Spider platforme nije bilo moguce upariti vise radeona, pa se pod pojmom 'crossfire' podrazumijeva samo 2 radeona, nakon cega je uveden pojam 'crossfireX' koji oznacava 3 ili 4 radeona (on obuhvaca sve moguce kombinacije, npr 3x 4850, ili 4x 3870, ili 4870x2 + 4850 itd.)
Staro 26.02.2009., 12:11   #20
Wolverine
Wolverine's Avatar
Postovi: 12,425
SLI /3Way SLI /QSLI se ne odnosi na broj kartica u polju nego na broj GPU-ova u polju.
Dakle kako jedna GTX295 već ima dva GPU-a ona je sama po sebi hardverski SLI, njih dvije zajedno daju 4 GPU-a pa shodno tome i ime QuadSLI
Ista je stvar i sa ATI-jem
CrossFire je polje od dva GPU-a
CrossFireX je polje od tri ili četiri GPU-a u polju
Dakle nema veze imaš li u polju npr 3x HD4870 ili HD4870X2 + HD4870 -> to je CFX sa tri GPU-a
Ide ti sve bolje i bolje
prvo zbrajaš taktove, sad već i guraš ATI GPU u SLI....
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 26.02.2009., 12:38   #21
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,848
kad smo kod ovog se može upogonit, kako se kaže, neka bude hexa sli 3xgtx 295???tj 6 gpu-a.
Staro 26.02.2009., 12:41   #22
Wolverine
Wolverine's Avatar
Postovi: 12,425
ne iz dva razloga
1. fizički ne možeš spojit tri GTX295 pošto svaka ima samo jedan SLI konektor a ne dva kao npr GTX285
2. ne postoje driveri tj podrška za tako nešto
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 26.02.2009., 13:24   #23
Postovi: 7,568
Gigabyte LGA 775 ploča iz doba 965P i 975X čipseta i 4x 7800GT u (ovom slučaju) softverskom SLi polju.
Staro 26.02.2009., 15:21   #24
Rebbit
Postovi: 662
sad sam i ja vidio sta sam napiso.. lol...
bas sam blesav...
Lenovo Thinkpad T14
Logitech MX Keys
Galaxy S23+
Staro 26.02.2009., 16:16   #25
Big Guy
RPG player
Postovi: 1,574
@Wolverine
aha, ta sitnica
thnx na info
@McG
izgleda da je lakše naći dok znaš točno što tražiš
izgleda da nije bilo isplativo kad se nije održalo
