Staro 03.02.2009., 21:13   #61
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Bilo bi dosta offtopičarenja
Staro 04.02.2009., 16:48   #62
afterburner
afterburner's Avatar
Lokacija: USA/Split
Postovi: 525
Da li itko zna kako iskljucit onaj CrossfireX logo koji mi se nekim cudom pojavio nakon instalacije novih drivera?? Mislim na onaj u gornjem desnom kutu sta se pojavi u igrama.
U Catalystu nema nikakve opcije za to iskljucit..bar je ja ne vidim..
Ps imam HD 3870X2 i vistu
afterburner je offline   Reply With Quote
Staro 04.02.2009., 17:22   #63
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Rade bez problema na windows xp 32-bit, vista 32-bit, windows 7 32-bit te windows 7 64-bit(barem meni).
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 04.02.2009., 21:15   #64
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Autor afterburner Pregled postova
Ja imam 4870x2 ali mislim da bi opcije tribale biti iste...
Kao prvo imas pravo sto se tice Catalysta, tamo neces naci tu opciju ali mozes priko ikone. Znaci ukljuci opciju da se ikona prikaze pa
ovako: desni klik na ikonu -> 1. po redu gpu -> CrossFireX Settings -> Show CrossFireX status icon. To iskljuci i nemas problema
Staro 04.02.2009., 21:29   #65
d^_^b
d^_^b's Avatar
Lokacija: Sarajevo
Postovi: 474
Ovaj vikend cu da reinstaliram Windowse. Pa bih nakon reinstalacije instalirao ove nove drivere.
Netko mi je rekao da moram flashati bios i obaviti jos neke gluposti kako bi mi sve radilo kako treba nakon instalacije drivera? Je li to istina ili mogu samo instalirati drivere na svjeze Windowse i furati dalje bez problema?
d^_^b je offline   Reply With Quote
Staro 04.02.2009., 21:35   #66
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Autor d^_^b Pregled postova
Cekaj, ti to ozbiljno mislis? Pa naravno da ne trebas flashati bios prije instalacije drivera. Kad instaliras windowse instaliraj i nove drivere i to je to, nikakav flash
Staro 04.02.2009., 21:40   #67
d^_^b
d^_^b's Avatar
Lokacija: Sarajevo
Postovi: 474
Ozbiljno
Danas ja jaranu kazem da sam vidio na netu nove drivere za grafu. Veli on meni kako on to nikada nece instalirati jer je to jako komplicirano zbog toga sto moras flashati biose i obaviti jos neke zajebancije.
Ja sam sumnjao u to, ali ipak sam pitao - bolje pitati nego skitati....
Vozdra, hvala...
Staro 05.02.2009., 15:47   #68
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Hehe, flashati bios nakon instalacije drivera... lol
ma kakvo flashanje, samo ti inst nove drivere i stvar je rjesena
Staro 06.02.2009., 09:17   #69
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Ozbiljno
Vozdra, hvala...
Jaran ti nije bas informaticki pismen!
TV: LG 7450
GAMEPAD: XBOX One
Staro 07.02.2009., 21:18   #70
DavidCroBBB
Neka vide da nas ima...
DavidCroBBB's Avatar
Lokacija: LijepaNaša
Postovi: 42
hm... nakon sto sam instalirao nove drivere ne zeli se otvorit Catalyst Control Centar u procesima vidim kako se pocne "vrtiti" ccc.exe ali nakon cca 10s se makne i nista ... (reinstalacija nije pomogla)
zna netko u cemu je problem?
Bez reklama u sigu :-)
[/U]
DavidCroBBB je offline   Reply With Quote
Staro 07.02.2009., 23:08   #71
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Autor DavidCroBBB Pregled postova
Hmm, nisam siguran.. Probaj napraviti uninstall pa s driver cleanerom sve pocisti. Prije same instalacije drivera updateaj net-framework... To je sve sto mi trenutno pada na pamet.
Staro 09.02.2009., 18:58   #72
DavidCroBBB
Postovi: 42
Autor Sn4k3 Pregled postova
sve je to napravljeno 2 puta
[/U]
Staro 09.02.2009., 23:15   #73
kaiserrex
kaiserrex's Avatar
Lokacija: TERRA INKOGNITO
Postovi: 208
Radeon HD4850 stucanje u nekim igrama
Pozdrav!
Naime prije nekoliko dana sam kupio u Ve-mil-u Gainward Radeon HD4850 graficku karticu,
jer mi je zastarjela Nvidia Geforce 7600GT jednostavno preslaba za novije i atraktivne naslove.
Naravno uzbudjen kupnjom odmah sam instalirao nevedenu graficku karticu u sistem i instalirao najnovije Catalyst 9.1 drivere.
Cisto iz znatizelje za perfomansama globalno hvaljene ATI-jeve kartice pokrenuo sam igru "Mirrors Edge".
Podesio sam postavke na nativnu rezoluciju monitora ( 1680x1050 ) sa najvisim postavkama
i ukljucenim 4x Antialiasing-om i ukljucenim V-sync-om.
I zaista perfomanse su ocaravajuce, no primjetno je neugodno 1. sekundno zastajkivanje vrtnje grafike.
Pokusao sam i sa drugom igrom "Left4Dead", no takodjer se javlja stucanje grafike.
Promjena drivera na 8.12 nije donjela pozitivan ucinak.
Problemi se javljaju kod gore navedenih igara,
dok kod "Far Cry 2", "Fallout 3", "PES09", " Tomb Raider - Underworld" sve radi odlicno.
Gumb "Moj Komp" ce vam reci o kakvoj se konfiguraciji radi.
Svaki komentar je pozeljan!
Hvala!
kaiserrex je offline   Reply With Quote
Staro 09.02.2009., 23:20   #74
Big Guy
RPG player
Postovi: 1,574
probaj smanjiti postavke kao aa i af
grafa je dobra ali ipak ne može sve vrtjeti na max
probaj staviti patcheve na igre
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 09.02.2009., 23:21   #75
Metamphetamine
Flaccitra
Metamphetamine's Avatar
Lokacija: Vinkovci
Postovi: 276
Kod Mirrors Edge isključi u opcijama physx, a u left 4 dead "multicore rendering".
Metamphetamine je offline   Reply With Quote
Staro 09.02.2009., 23:36   #76
kaiserrex
kaiserrex's Avatar
Postovi: 208
Autor Big Guy Pregled postova
Autor Metamphetamine Pregled postova
1. Na LOW postavkam stuca, igra je patch-ana ( Graficka je dovoljno jaka, frame-ovi su dovoljni za glatko igranje, no ipak stuca )
2. physx je iskljucen
3. Znam za dual core probleme kod ove igre ( rjesit cu to kad uhvatim vremena )
Staro 09.02.2009., 23:48   #77
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
driveri, sistem? kakvo je stanje sa tim, cime si micao stare drivere? jel os ok, koliko star, jesi formatirao pa stavljao novo kad si promijenio grafu?
inace osobno preferiram svjez os, pogotovo kod mijenjanja graficke kartice. cesto naletim na neodobravanja, ismijavanja i negodovanja prijedlogom, ali onda barem znas da zeza nesto sa driverima (naravno, ako zeza, a nije mi se dogodilo da nesto ne radi kako treba). jer jako tesko da je do sistema, kad je nov, jel.
inace, fulao si podforum. mislim da je ovo puno prikladnije softverskim problemima, jer je 99% problem u driverima.
Staro 10.02.2009., 00:08   #78
kaiserrex
kaiserrex's Avatar
Postovi: 208
Autor Burko Pregled postova
Naveo sam verzije drivera koje sam koristio.
Drivere sam micao Driver Sweeper-om.
OS je i vise nego O.K., star je negdje oko 6. mj., odrzavan, mazen i pazen.
Mislim da za to nema potrebe, mjenjao sam vise grafi na instaliranim sustavima i nikad problemi.
Staro 10.02.2009., 00:25   #79
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Najbolje rješenje kad ništa neće je podići windowse. Simple
Staro 10.02.2009., 01:32   #80
Burko
Burko's Avatar
Postovi: 2,317
Autor -POP- Pregled postova
bas ovo napisano, pogotovo ako ocito nesto zeza. ne kuzim kako je to postala tolika tlaka ljudima, ja formatiram, instaliram xp, potrpam drivere/programe/igre u manje od dva sada. a da je sistem mazen i pazen maximalno sto se moze, opet nece raditi bolje i brze nego svjezi sistem.
mislim, ako ti zeza u dvije igre, ocito nesto negdje zeza. dakle, moja preporuka je format/install.
Staro 10.02.2009., 02:31   #81
kaiserrex
kaiserrex's Avatar
Postovi: 208
Eto malcice se igrao sa driverima, deinstalaciojm istih, i instalaciojm,
izgleda da su neke datoteke ostale pri deinstalaciji 9.1 drivera,
mada je driver sweeper reko da je sve cisto,
pokretanjem istog u Safe mode-u se pokazalo da tome nije tako,
nova instalacija 8.12 drivera brise probleme u prvom postu,
sad se sve glatko vrti, poglavito Mirrors Edge..
Staro 10.02.2009., 14:11   #82
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,275
Da, nema smisla šamarati mrtvog majmuna
Staro 14.02.2009., 13:17   #83
agm7007
noise freak
agm7007's Avatar
Postovi: 323
Catalyst profil load pri dizanju Windowsa?
Zna netko kak namjestiti da se određeni profile u Catalystu loada kod startupa Windowsa? Tam u opcijama ne nalazim to, samo nešto za hotkeyeve i sl...
Ukratko, imam dva windows profila (korisnika), jedan za HTPC, a drugi za main PC, pa želim u Catalystu složiti da mi se kod startupa HTPC profila loada Catalyst profil sa postavkama rezolucije za plazmu, a kod profila za main PC da mi se loadaju postavke za monitor. Koji je najlakši način za to izvesti?
EDIT: nvm, rješio sam. Jednostavno rješenje - treba kliknuti na desktop shortcut u postavkama profila u Catalystu i onda taj shortcut staviti u startup folder.
Zadnje izmijenjeno od: agm7007. 15.02.2009. u 19:05.
agm7007 je offline   Reply With Quote
