Lokacija: ZgB
Postovi: 158
![]() Tu je stranica i guide kako da podesim ruter i radi se o tamo navedenom routeru ( http://www-uk.linksys.com/servlet/Sa...#versiondetail ), ali kada upisem u browser 192.168.0.1/advanced ili samo 192.168.0.1, on mi nista ne pronade ? Kako znaci da udem u router i namjestim postavke?? |
Lokacija: Splity
Postovi: 3,003
I am not able to access the Phone Adapter’s Web-based Utility Setup page. User Guide |
Postovi: 206
run --> cmd pa izvrsi ipconfig. sto ti pise pod default gateway? -->
odi na start --> run --> cmd pa izvrsi ipconfig. sto ti pise pod default gateway?
walk the talk |
Lokacija: ZgB
Postovi: 158
U tom i je problem pise mi 0.0.0.0 a nemogu promjenit zato jer mi u properties od mreze pa pod Iv4 nema toga di bi trebo gateway upisat i onaj subnet mask i to? Zadnje izmijenjeno od: kiwwy. 18.01.2009. u 14:34. |
Postovi: 206
daj posalji sve sto ti ispise naredba ipconfig /all
walk the talk |
Lokacija: ZgB
Postovi: 158
Microsoft Windows [Version 6.0.6001] Copyright (c) 2006 Microsoft Corporation. All rights reserved. C:\Users\Bruno>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : Bruno-PC Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Mixed IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No PPP adapter Broadband Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Broadband Connection Physical Address. . . . . . . . . : DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 213.147.102.52(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.255 Default Gateway . . . . . . . . . : 0.0.0.0 DNS Servers . . . . . . . . . . . : 213.147.96.3 213.147.96.4 NetBIOS over Tcpip. . . . . . . . : Disabled Ethernet adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/1000 PL Network Connection Physical Address. . . . . . . . . : 00-19-D1-E1-3B-5F DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::f9d9:7aee:7a88:37e2%10(Preferred) Autoconfiguration IPv4 Address. . : 169.254.55.226(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.0.0 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS over Tcpip. . . . . . . . : Enabled Tunnel adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 12: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 02-00-54-55-4E-01 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 17: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : isatap.{6001FF96-FEF8-4EC6-BE05-FF879F6AF 444} Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 18: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4 Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 19: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft 6to4 Adapter #3 Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2002:d593:6634::d593:6634(Preferred) Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301 DNS Servers . . . . . . . . . . . : 213.147.96.3 213.147.96.4 NetBIOS over Tcpip. . . . . . . . : Disabled C:\Users\Bruno> |
Postovi: 23,502
Opet Vista sme * e, probaj isključit TCP/IP v6 i onda manualno podesit TCP/IP v4 |
Lokacija: HRVATSKA, Slavonski Brod
Postovi: 35
Uhh , pa moras postaviti rucno IP adresu svoje mrezne kartice preko koje se mislis zakaciti na router. Jer ocito ti je na router-u iskljucen DHCP. IP adresa tvog racunala recimo moze biti 192.168.0.10, jer ti racunalo mora biti u istom range-u IP adresa koju koristi router po default-u dakle u ranngu 192.168.0.2-254, 1 ti je vec zauzet za sam router. Kod postavki Primary DNS-a i Default Gataway-a upisujes 192.168.0.1
Nisam za EU. Globalizacija je navece zlo koje je do sada snaslo nas planet ! Na forumu sam da ako nekome mogu pomoci, a ne voditi sulude beskonacne rasprave tipa ciji je veci i tko je bolji tehnicar! |
Lokacija: ZgB
Postovi: 158
Postovi: 35
Ocito koristis koliko vidim po ipconfig/all ispisu PPPoE konekciju kreiranu na racunalu. U tom slucaju kada postavis static IP LAN konekcije da bi pristupio routeru nemas vezu s internetom, dok ne vratis na prijasnje postavke. Najme dok koristis PPPoE konekciju na racunalu tvoj router ustvari ne radi kao router vec kao DSL modem, dokle god u routeru ne kreiras DSL vezu i prebacis da radi u router modu, sto znaci da ce se tvoj router vezati na internet a sva racunala prikljucenena bilo LAN ili WLAN vezom na njega ce automatski sva biti vezana istovremeno na internet bez bilo kakvog uspostavljana posebne veze na racunalima (za mene apsolutno puno bolja varijanta nego primitivno uspostavljanje veze preko PPPoE konekcije na samom racunalu, jer u tom slucaju imas router koji ustvari nista od svojih mogucnosti ne cini osim sto koristi DSL modem) Dakle prvi korak ako mislis ista na routeru mjenjati da posavis svoju LAN vezu da mu mozes pristupiti preko web browser-a. Evo ovdje naputka kako ces promjeniti svoj IP na static IP i ostale postavke mreze tu ces vidjeti i gdje mjenjas DNS i Gateway. Osobno ne koristim Vistu i nemam ju na niti jedom svom racunalu instaliranu pa ti nazalost video clip s tocnim postupkom korak po korak ne mogu snimiti kako inace na poslu to profesionalno odradjujem kod supportiranja. To configure a DNS client for static IP address
#12 | |
Lokacija: ZgB
Postovi: 158
Subnet mask Defaul getaway to se vidi na slici iznad znaci problem je to kaj ja to nemogu upisat da mogu vec bi sredio ![]() Jel zna tko? |
Postovi: 206
Za pocetak...vidim da si isao desnom tipkom misa na Broadband Connection. Tu neces naci Subnet Mask i Default Gateway. Trebas ici na Local Area Network! Tu ces naci za upisati Subnet Mask i Default Gateway. E sad mi reci... Koji uredaj ti imas?? Prema ovome sto si postao imas Phone Adaptor With Router, Model no SPA2102. Da li je to tocno? Ako imas taj uredaj reci mi da li imas kabel spojen izmedu zutog porta od rutera i LAN porta od kompjutera? Imas li sto spojeno na crveni port? Sto? Kamo ide drugi kraj kabla?
walk the talk |
#14 | |
I'm nightrider
Lokacija: Bjelovar
Postovi: 718
vjerovatno si zato i kupio drugi router, zato što tipkaš ip adrese u konekciju s kojom se spajaš na net a ne u local area connection, i naravno da ti tak ne radi net ![]() uglavnom, nemaš subnet i gateway jer ih cijelo vrijeme tražiš na krivom mjestu... hjoooj, na poslu se svakodnevno susrećem s ovakvim "problemima" ![]() dakle, pogle šta ti čoek napiso start, control panel, network and internet, network and sharing centre, manage network connections (to ti je u izborniku s lijeve strane)... i sad, ono bitno, ono što cijelo vrijeme radiš pogrešno, desni klik na LOCAL AREA CONNECTION.... dakle, ne na onaj broadband pppoe, nego na... LOCAL AREA CONNECTION ev još jednom, da slučajno ne kažeš da nisi dobro vidio LOCAL AREA CONNECTION i još jednom LOCAL AREA CONNECTION ![]() sad tu dvoklik na internet protocol ipv4 (ali pazi da ne makneš kvačicu, dakle, kvačica ostaje) i upišeš one brojeve koje ti čovjek spomenuo... i ak slučajno napišeš da opet nema gejtveja i sabnet maske... ostavi se tog, zovi nekog lokalnog pc guru-a koji će ti to poklikat i spojit te na net prije neg ti stigneš popušit pljugu.... sorry...al morao sam ![]() ![]() |
#15 | |
Lokacija: ZgB
Postovi: 158
Nista, zapravo hvala ti darQ jel inace nebih nikad shvatio ![]() ![]() I da nisam kupio drugi router ovaj sam dobio s metronetom!! Citiraj:
U novom stanu sam i onda imam sve zice iz svih soba kroz zid. One sve vode u jednu rupu iznad vrata. Tamo su sve ukopcane u neki Konig adapter i onda zica od tog cjelog adaptera ide u taj linksys u Ethernet utor. Ako to sto pomaze da znate. |
#16 |
Postovi: 206
Odgovori mi na pitanja koja sam ti postavio
walk the talk |
#19 | |
Postovi: 206
EDIT: Zasto je ovo pitanje? Kamo uopce ide drugi kraj kabela koji ti je spojen u komp?
walk the talk |
#20 |
Postovi: 279
Probaj ovako ... upiši u Local Area Connection potrebne adrese i dns-eve. Broadbend konekciju nemoj koristiti, odnosno budi disconnected dok radiš cijeli ovaj postupak koji čitaš. Nakon upisanih brojeva u Localu, dupli klik na mozillu ili sto vec koristiš, pa unesi adresu routera i malo pričekaj da uđeš u konfigurator. Nakon postavljanja postavki u routeru i reboota istog trebao bi biti spojen i tek onda ce se ipconfig promjenjeniti. |
#21 |
Lokacija: ZgB
Postovi: 158
Kabel koji mi je spojen u komp u jedini utor gdje stane ( valjda je LAN ) ide znaci prvo u taj adapter Konig koji omogucuje spajanje svi kompjutera u router, a poslje njega ( kroz njega ) u Ethernet utor na linksysu neznam kako da bolje objasnim! EDIT: Evo slike ipconfiga s zgasenim broadbend connection i upisanim 192... u mozzili ![]() |
#22 |
Postovi: 206
Probaj u Internet Exploreru.
walk the talk |
#25 | |
Postovi: 337
Ako je router 192.168.0.1 onda ip adresa mora biti minimalno 192.168.0.2, a ako je router 192.168.1.1 onda je ip adresa 192.168.1.2 Ti si stavio 33 na ss-u, znači 192.168.0.33 bi trebalo raditi u kombinaciji sa 192.168.0.1 za gateway i dns (dns-u možeš ostavit i ove vanjske ip adrese od metroneta) Kad promjeniš postavke otvori cmd i upiši ping 192.168.0.1, ako ima reply otvori firefox i upiši 192.168.0.1 i dalje se logiraš pa što već želiš promijeniti... Zadnje izmijenjeno od: Cele303. 20.01.2009. u 01:08. Razlog: tipfeler |
#26 |
Postovi: 206
PA u ovoj zadnjoj slici se vidi da je ruter 192.168.1.1. Vjerovatno kad sa PPoE netko pristupi ruteru on ne moze u browseru ucitati 192.168.1.1 EDIT: brijes da je on sam upisao gateway...a moze bit
walk the talk |
#27 |
Lokacija: ZgB
Postovi: 158
Evo ipak bi trebalo ici 192.168.0.1 ali kada to stavim isto na radi ![]() Kada sad upisem dok sam connectan na broadbnd connection ping 192.168.0.33 dobim ovo Pinging 192.168.0.33 with 32 bytes of data: Reply from 192.168.0.33: bytes=32 time<1ms TTL=128 Reply from 192.168.0.33: bytes=32 time<1ms TTL=128 Reply from 192.168.0.33: bytes=32 time<1ms TTL=128 Reply from 192.168.0.33: bytes=32 time<1ms TTL=128 Ping statistics for 192.168.0.33: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 0ms, Maximum = 0ms, Average = 0ms Pod ipconfig/all pod local area connection pise sve kak sam stavio ali pod broadbend opet pise gateway 0.0.0.0 i neki drugi ip. Mislim da se nece nis promjenit ako ukopcam u lan ali probat cu poslje kad cu moc ( u user guidu pise da se connecta u ethernet ) |
#28 |
Postovi: 206
A zasto uopce zelis pristupiti ruteru? sto bi mjenjao?...ovako kako si poceo, nest ces jos shebat.
walk the talk |
#30 |
Postovi: 206
hmhm...zelis imati static ip kad si na internetu? zasto?
walk the talk |
