		#181 |
			Datum registracije: Oct 2001
				Lokacija: Vinkovci
					Postovi: 5,231
		 probao, meni radi ali cini se da to grafa uopce ne detektira kao 3d ili koji vec k jer je vent ostao na defaultu i zagrijala se u 3PM dok si rekao keks. i da, nije donut niti dlakavo nego ovo da, gpu mem test mi javlja toliko errora da bi ocekvao da mi graficka uopce ne radi. Nadam se da je rijec o beta problemima jer tesko bi spavao uza sve te errore koje ne mogu reklamirati jer grafa radi potpuno ispravno ![]()  |
		#183 |
				Lokacija: Malaysia
					Postovi: 96
		 OCCTPT3.0.0.b06 Changelog : * GPU temp properly recognized and saved * 64 bits OS detected automatically : if 32 bits : no 64 bits mode (obviously), if 64 bits : 64 bits Linpack & Power supply test by default * Computers with more than 2GB of memory are now properly recognized with Linpack and Power supply tests - couldn't test with vista64 though * Adding/removing temps doesn't reset other lines in the monitoring panel * Custom Sensor 2 name for Voltages is properly saved/loaded. * Default res is now 1024x768
	Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1  |
		#184 |
				Lokacija: Malaysia
					Postovi: 96
			Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1 Zadnje izmijenjeno od: stasio. 26.11.2008. u 05:18.  |
		#185 |
			 Bannija :D
				Lokacija: Sisak
					Postovi: 1,098
		 Meni zadnja verzija radi sve osim GPU memtesta, ali ljudi moji što ovo zagrijava grafičku LOL Do sada mi još nije prešla 70°c al na ovom čudu ode na 85°c pa i više, hebesh ti PCS+ i zerotherm, brijem da večeras gore ide dobri stari S1+ 2X120 scythe slipstream. Doduše zerotherm mi je lockan na nekih 20-30% vrtnje i neželi se brže zavrtit al neda mi se zezat sa servisom, tek sam piknu grafu u komp, prelijen sam opet ostajat bez nje ![]()  |
		#186 |
				Lokacija: Lille, France
					Postovi: 44
		 Hey guys, long time no see  ![]() I came here to warn you about the new beta, but it seems somebody else already did   Thanks stasio !I have to warn you about one thing though (the new version will include a HUGE warning of some sorts) : the power supply test is HARDCORE and could very well mean the death of your power supply. Tests shows that OCCT Power supply demands 20% to 30% more power than Crysis or 3dmark on dual-cores... and 50% more on quad-cores ! So be warned if you've got a no-name power supply (or "cheap" brands such as LC Power, heden), as OCCT already killed a few of those (they sported a 550W label, they didn't take the test with a dual-core and a HD4850 or such graphic cards). Be warned ! Oh, and there's still something missing with the current version : there're no profile for OCCT GPU at the moment. That means SLI people have to create it manually. Next version should be able to create it automatically for Nvidia, and i have yet to get my hands on an ATI card to get a look into it. Have fun boys, and thanks for your support !  |
		#187 |
					Postovi: 11,642
		 Great job Tetedeiench, looking forward to the final version  ![]()  |
		#188 |
					Postovi: 44
		 I want to burn stasio once at least  ![]() OCCT PT 3.0.0.b08 OUT ! Changelog :
 http://www.ocbase.com/download.php?fileext=beta  |
		#190 |
			 Bannija :D
				Lokacija: Sisak
					Postovi: 1,098
		 Nego imam pitanjce. Pomoću čega ova zadnja verzija occt-a mjeri temp procesora? Naim NAPOKON sam uspio iskemijat i probit barijeru od 2.9GHz na svom procu, i sad je trenutno bio testiran na 3.0GHz, s tim što me nakon 10 minuta baca van i u logu mi ispiše da je cpu too hot. Temparatura mi dođe do nekih 56-57 i neide dalje, u occt-u je nariktan shutdown na 80, kako je on doša do te temparature ako ja imam 20 i kusur supnjeva manje?? Komp nije nestabilan, malo sam sad probavao grid i fallout3, sve radi normalno, čak imam i pokoji fps više, ali muči me to. Temparature pratim sa smartguardianom (inače dfi-jev alat, ali ova ploča je rebrandirani dfi,čak ima i lanparty oznaku na sebi) i pcwizardom i oboje pokazuju identično, u occt-u sam poštelao da mi sa tih istih senzora prikazuje cpu temp. Probao bih ići dalje sa dizanjem, a neznam šta da radim, neznam jel bi bilo pametno povisit limit u occt-u pa ručno nadgledat temparature preko pcwizarda i guardiana, cooler je zalman cnps 9500, tako da mislim da se nebi smio moći pregirjat obzirom da su voltaže nedirnute. Testirao sam normalno i linpack modom.  |
		#191 |
				Lokacija: Zagreb, Tresnjevka
					Postovi: 9,505
		 OCCT PT 3.0.0.b10 OUT ! Changelog : * Linpack test has been updated, and is now much harder on core i7s. * DirectX 9 version is detected and if not recent enough, the tab is disabled and you've got an error message * Cuda is detected the same way (but incomplete, as it reports OK on GeForce 7s, and yu need GeForce 8 or more to run it). * OCCT won't enter the crazy mode anymore if you click the on and off buttons ni a loop * Core number detection improved (but there's still a bug going on there, sometimes OCCT detects only 3 cores out of 4, 1 instead of 2...) * Graph size option has disappeared (unused) * A new option has appeared "Generate graphs", checked by default. Guess what it does if unchecked... it won't generate graphs ! * Due to a few power supply deaths, the Power Supply test bears a warning the first time you click on it. * The GPU test now works in fullscreen mode with ATI crossfire cards, and the window can be moved to another screen without crashing * The window position is now saved and restored upon startup. * The aboutbox now has the correct design * The bottom of the main form now has the right design (shape, size, color). http://www.ocbase.com/OpenBeta/OCCTPT3.0.0.b10.zip @ Diablo Pa trebalo bi mjeriti sa onime što si odabrao.
	"Everything with a heartbeat can knock you down"  |
		#192 |
				Lokacija: Malaysia
					Postovi: 96
		 Mozete skinuti samo beta 08. Ima nekih problema sa beta 09 i 10.
		#193 |
			 Bannija :D
				Lokacija: Sisak
					Postovi: 1,098
		 Heh,znam i ja da bi trebao, ali iz nekog razloga mi na temp. 20'C nižoj od one koju prikazuje prekida test zbog navodno previsoke temparature proca. Probat ću danas popodne skinut zadnju verziju pa da vidim hoće li se i na njoj dešavat isto.  |
		#194 |
					Postovi: 9,505
		 Beta 12 Download Changelog : * Several graphical glitches were fixed * the Linpack test is now working again * The OCCT test has been updated - check it out * the GPU test now correctly works on Crossfire configurations and SLI config too (SLI needs a profile) * A few warnings were changed (just made more explicit, really)
		#195 |
				Lokacija: Malaysia
					Postovi: 96
		 OCCT 3.0.0.beta 14 * The linpack test now works with 32 bits OS with more than 2GB of Memory * OCCT's way of remembering window position as been changed for some people for which it didn't worked
		#196 |
					Postovi: 44
		 Happy to see that everything is still posted to this board. I hope i'll be able to reach stable stage by the end of this year, but due to necessary translation delays, i probably won't ![]() Stay tuned though ![]()  |
		#197 |
				Lokacija: Malaysia
					Postovi: 96
		 OCCT 3.0.0 beta 16 Changelog : * The linpack test is now working again with XP32 with more than 2GB of memory * the TAB key now works everywhere, and the order has been fixed * The Temperature line is drawed in front of the CPU Usage line, in the graphs. This leads to better visibility of the graphs.
		#198 |
				Lokacija: Malaysia
					Postovi: 96
		 OCCT 3.0.0 beta 17 Changelog : * The OCCT Test is now executed in a separate process (this is done to open the way for the "one core not detected" bugfix). * The OCCT GUI will now report on which core the error occured in the OCCT Test. * The files "ThreadX.txt" aren't generated anymore (the previous point removes all need for them). * The way translations are handled is now brand new and much, much more easy to update for me * If the Linpack test refuses to start, OCCT will now lower the memory utilisation until a successfull start. You may see a small delay in launching the Linpack test, but it is usually less than a second in the worst case. * The field showing the test duration is now always updated, depending on the test selected. Try to select "custom" and change the duration, you'll quickly see what i mean.
		#199 |
				Lokacija: Metkovic
					Postovi: 13
				OCCT problem
			Bok ekipa, evo testirao sam svoj clockani e8500 na 3,8ghz i kad sam ga testirao na OCCT nakon 45min javlja mi se ova poruka, dali je to vezano za moj komp ili za software. Molim pomoć Hvala! http://www.imagesforme.com/show.php/...0107182906.png  |
		#201 |
			 In the ghetto
					Postovi: 1,943
		 Ili nek proba neku stariju verziju...
	AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor  |
		#202 |
					Postovi: 9,505
		 Ili probaj sa npr. IntelBurnTestom koji isto koristi Linpack za testiranje CPU-a. Ovo ti može biti radi svega, od samog OCCT-a do Windowsa/proca. Uostalom, n4d44 ti je dobro rekao. Smanji takt pa vidi jel će opet ili ne javiti taj error.
		#203 | |
			 FORD Fix Or Repair Daily
					Postovi: 872
		#205 |
				Lokacija: Malaysia
					Postovi: 96
		 OCCT 3.0.0 beta 22 Changelog : * The OCCT Test now executes as a separate process * The bug known as "-1 core detected" is gone * Monitoring/system info engine updated * Linpack 32 bits test now works with systems with more than 4GB of memory - max mem considered is 1.44GB (universal value) * The power supply test now works everywhere as well * GPU:Memtest has been GREATLY updated : 6 thorough tests have been implemented, and they are EXACTLY the same as Memtest86+. One pass is takes much, much longer though (i'd say about 10 minutes). But the efficiency is now much better. Remember, you need a geforce 8 or later cards.
		#206 |
				Lokacija: Malaysia
					Postovi: 96
		 OCCT 3.0.0 Final Changelog (Since 2.0.1) : MAJOR FEATURES * OCCT's main UI has been completly revamped * Graphs now shows a 2nd line showing the CPU usage / FPS during the test. * CPU usage is now instantaneous instead of an average since the start of the test * OCCT now has 5 different tests. The descriptions are at the end of the changelog USER INTERFACE * Entirely revamped - now based on tabs, and completly modular * Now has a small help module - just move your mouse around OCCT's window, you'll see MONITORING * The built-in engine has been updated - lots of new hardware are now supported * Alot of bugs are fixed, included the famous "3 cores out of 4 detected" GRAPHS * Graphs now shows a second line showing the CPU usage/FPS during the test * A legend explains everything * The test configuration is now entirely present in the graph's subtitles TESTS DESCRIPTION CPU:OCCT * The original, inherited from previous versions of OCCT * Now Core i7 compatible * Optimized CPU:LINPACK * The very same as IntelBurnTest, based on a test provided by Intel * It will make your CPU hotter than never ! * 32 and 64 bits support GPU:3D * Home-made test written in Direct3d that will make your GPU really hot - this test is similar to ATITool and Furmark (thanks to Furmark and JegX for his support and for the aborted partnership ) * Will make your graphic card real hot - especially the GPU * Has an error detection mode similar to ATITool * SLI and Crossfire support (Just enable Fullscreen mode !) GPU:Memtest * Again, Home-made test written in CUDA that'll launch a MemTest86 or MemTest86+ like test on your Graphic card memory and report any error found * Requires a Nvidia Graphic Card, and a GeForce 8 or Higher ! Power Supply * Dedicated to power supplies - it'll launch GPU:3D and CPU:LINPACK at the same time to load your power supply. BEWARE, THIS TEST IS REALLY DEMANDING ! * WARNING, DO NOT USE THIS TEST WITH NO-NAME POWER SUPPLY, AS A FEW DEATHS HAVE ALREADY BEEN REPORTED ! * This tests demands 30 to 40% more power than crysis on a quad-core system with an SLI graphic system installed...
		#208 |
				Lokacija: Malaysia
					Postovi: 96
		 OCCT 3.0.1 Changelog (Since 3.0.0) : GPU:MEMTEST * Now compatible with GeForce cards with more than 512MB under Vista (A Cuda bugs was encountered, but i found a workaround) * Now 4 times faster (thanks to a switch to Cuda 2.1 which came with bugfixes in the SDK - new prerequisites though) * The test cannot be run on GeForce 7 or lower anymore MONITORING * OCCT now saves monitoring sensor based on sensor names when available, not on position in a list. Thus, when a sensor disappear, OCCT configuration is preserved * Engine has been updated - new CPU support,... * the maximpum CPU temp can now be set at a temp higher than 99°C (before, it could be done, but it was reset upon reloading OCCT at 80°C) TRANSLATION * Arabic and Romanian support have been added * Italian have been updated OCCT REQUIREMENTS * Up-to-date DirectX9 (Under Vista, DirectX 10 and 9 are updated separatly) for GPU:3D and Power Supply * Nvidia Drivers 181.22 or later for GPU:MEMTEST (Now based on CUDA 2.1,as several critical bugs have been fixed in this release). ![]()
		#209 |
				Lokacija: Malaysia
					Postovi: 96
		#210 |
					Postovi: 60
		 Evo nakon duzeg vremana izasla je nova verzija occt http://www.ocbase.com/perestroika_en/index.php?Download ![]() Zadnje izmijenjeno od: mis. 05.11.2011. u 01:57.  |
