Staro 15.12.2008., 20:20   #1
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,948
DMA-driver error, CRC error
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2.11.2004 12:54:32
NT-SPTI used
Nero Version: 7.5.7.0
Internal Version: 7, 5, 7, 0
Recorder: <LITE-ON DVDRW SHM-165S6S>Version: QS02 - HA 1 TA 0 - 7.5.7.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <LITE-ON DVDRW SHM-165S6S>Version: QS02 - HA 1 TA 0 - 7.5.7.0
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW SHM-165S6S nvata Port 1 ID 2 DMA: Off
DiskPeripheral : ST3250620AS nvata Port 2 ID 0 DMA: Off
DiskPeripheral : SAMSUNG HD501LJ nvata Port 2 ID 2 DMA: Off
CdRomPeripheral : DY2417I GSB206D 2.0B afh7bk1y Port 3 ID 0 DMA: Off
CdRomPeripheral : DY2417I GSB206D 2.0B afh7bk1y Port 3 ID 1 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW SHM-165S6S F: CDRom0
DY2417I GSB206D G: CDRom1
DY2417I GSB206D H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095528kB)
Free physical memory: 961MB (984412kB)
Memory in use : 53 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.12.2008
UDF/ISO compilation
18:27:01 #1 Text 0 File SCSIPassThrough.cpp, Line 583
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
18:27:02 #2 Phase 112 File dlgbrnst.cpp, Line 1746
DVD-Video files reallocation started
18:27:02 #3 Phase 114 File dlgbrnst.cpp, Line 1746
DVD-Video files reallocation completed (no file modified)
18:27:02 #4 Text 0 File Isodoc.cpp, Line 6508
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:27:02 #5 Phase 111 File dlgbrnst.cpp, Line 1746
DVD-Video files sorted
18:27:02 #6 ISO9660GEN -11 File Geniso.cpp, Line 3313
First writeable address = 0 (0x00000000)
18:27:02 #7 ISO9660GEN -11 File Geniso.cpp, Line 3313
18:27:02 #8 Text 0 File Burncd.cpp, Line 3435
Turn on Disc-At-Once, using DVD media
18:27:02 #9 Text 0 File DlgWaitCD.cpp, Line 301
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1820543 (404:33.68, 3555MB)
18:27:02 #10 Text 0 File DlgWaitCD.cpp, Line 313
Write in overburning mode: NO (enabled: CD)
18:27:02 #11 Text 0 File DlgWaitCD.cpp, Line 2863
Recorder: LITE-ON DVDRW SHM-165S6S, Media type: DVD-R
Disc Manufacturer: MCC 03 - RG20
Disc Application Code: 64, Disc Physical Code: 193
18:27:02 #12 Text 0 File DlgWaitCD.cpp, Line 485
>>> Protocol of DlgWaitCD activities: <<<
18:27:02 #13 Text 0 File ThreadedTransferInterface.cpp, Line 820
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1820544 (1820544) = #1820544/404:33.69
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1820544 blocks [Main]
18:27:02 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1033
Prepare recorder [LITE-ON DVDRW SHM-165S6S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3728474112, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 1820544 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1820544 | 0 | 0x00
1820544 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
18:27:02 #15 Text 0 File SCSIPassThrough.cpp, Line 41
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
18:27:02 #16 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
18:27:02 #17 Text 0 File Burncd.cpp, Line 4262
Cache writing successful.
18:27:02 #18 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
18:27:02 #19 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 12x (16.620 KB/s)
18:27:02 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2730
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:27:02 #21 Text 0 File DVDR.cpp, Line 3026
Recording mode: Sequential Recording Mode
18:27:02 #22 Text 0 File DVDR.cpp, Line 3182
Start write address at LBA 0
DVD high compatibility mode: Yes
18:27:02 #23 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
18:27:57 #24 Text 0 File Cdrdrv.cpp, Line 1290
18:27:57.296 - F: LITE-ON DVDRW SHM-165S6S : Queue again later
18:28:17 #25 SPTI -1502 File SCSIPassThrough.cpp, Line 293
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1502)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 05 C0 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 00 08 03
Buffer x064d5a00: Len x10000
0x00 00 01 BA 44 00 26 AB 75 C7 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 00 0D 75 FC CC DC 3A 4B 57
0x53 EC CD 4A C6 E9 2A AE B3 D4 81 13 7D 55 FC 07
18:28:17 #26 CDR -1502 File Writer.cpp, Line 278
18:28:17 #27 Text 0 File DVDR.cpp, Line 3402
EndDAO: Last written address was 1471
18:30:01 #28 Phase 38 File dlgbrnst.cpp, Line 1746
Burn process failed at 12x (16.620 KB/s)
18:30:01 #29 Text 0 File Cdrdrv.cpp, Line 10459
DriveLocker: UnLockVolume completed
18:30:01 #30 Text 0 File SCSIPassThrough.cpp, Line 583
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 8.3.2007 0:51:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 8.3.2007 0:51:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Gugla san, uglavnom mi izbacuje probleme sa Master/slave koje ja neman, jer je pržilica sata, model DVDRW SHM-165S6S.
Do jučer je radila, a danas više ništa ne mogu spržit, ovaj error pukne oko 10% nebitno šta pržija i nebitno na kakav medij pržija... Proba 2 Nero verzije...
Koji joj je k. I ima li ko kakvu pametnu prije nego šta je razvalim od susjedni zid, jer od svih komponenata u i oko kante, najveće probleme mi stvara jebena pržilica od 200 kn....
Evo i kompletan log
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Use Inquiry : 1
15.12.2008
UDF/ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet : FALSE
DAO infos:
MCN: ""
DAO layout:
Sense Code: 0x08
Sense Qual: 0x03
Existing drivers:
Registry Keys:
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 15.12.2008., 22:14   #2
Postovi: 23,561
Ako ti se da zafrkavat, rastavi, očisti leću i vrati nazad. Ako pomogne dobro, ako ne štemaj zid s njom i ubaci novu.
Staro 15.12.2008., 22:19   #3
Mr.Ex.President
Torrent freek
Postovi: 3,948
Autor Nikky Pregled postova
To ću i napravit.
Nakon 4,5 potrođenih DVDa odjednom počne radit, al iznad 4x neće.
1,2,4x sprži ok i kvaliteta je ok kao da je sve ok, sve iznad 4x javi error ili sprži tako da nije čitljivo
WTF
Uglavnon, whatever, kupit ću novu i miran san, ova mi je pojela puno živaca (korisnici koji su češće na ovom dijelu foruma će se možda i sjetit svih pizdarija)
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
