#1981 |
Postovi: 6
Rebellion : Puno ti hvala na korisnim savjetima! edit: Zvao ja Amis i zamolio da me prebace na 6db i prebacili me i nije pomoglo. Ne mogu reci da je imalo pomoglo čak isto je kao i prije, možda čak i malo lošije ali teško je to reći. Ovo su novi statsi danas ujutro (lijevo novo, desno ono što je bilo 17.10.2008): Link Information <table class="datatable" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td> </td><td width="30"> </td><td width="220"> </td><td width="50"> </td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Uptime:</td><td colspan="3">0 days, 10:13:25</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Modulation:</td><td colspan="3">G.992.1 Annex B</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Bandwidth (Up/Down) [kbps/kbps]:</td><td colspan="3">899 / 4.880</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Data Transferred (Sent/Received) [MB/GB]:</td><td colspan="3">90,56 / 1,36</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Output Power (Up/Down) [dBm]:</td><td colspan="3">13,0 / 19,0 --- 12,5 / 19,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Line Attenuation (Up/Down) [dB]:</td><td colspan="3">22,0 / 33,0 --- 22,5 / 33,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">SN Margin (Up/Down) [dB]:</td><td colspan="3">18,0 / 19,0 --- 17,0 / 17,5</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Vendor ID (Local/Remote):</td><td colspan="3">TMMB / BDCM</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Framing (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Signal (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Power (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Link (Remote):</td><td colspan="3">0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Error Seconds (Local/Remote):</td><td colspan="3">89 / 0 ------- 3.171 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">FEC Errors (Up/Down):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">CRC Errors (Up/Down):</td><td colspan="3">0 / 91</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">HEC Errors (Up/Down):</td><td colspan="3">0 / 36</td></tr></tbody></table>E super, šta sada? Koliko vidim sada su se još približili sn i output i to valjda nije dobro... Opet povećao se SN pa je to ok i malo smanjio LIne Attenuation pa je i to ok, samo problem ostaje... BTW isčupao sam žice i povezao telefonski dolazni sa ADSLom onako žica na žicu i nije pomoglo baš, sada je kabel još kraći.... Ima li još ideja šta sada da ih tražim konkretno ili da pustim njih da isprobavaju? hvala! Zadnje izmijenjeno od: Hisoka. 04.11.2008. u 13:59. |
#1982 |
Postovi: 23
Amis
Zanima me amis 2u1 usluga i to paket do 24Mbps. Htio bih saznati od korisnika te brzine, kolika im je stvarna brzina na www.speedtest.net , i ako bi mogli da mi sliku testiranja poslaju ovdje u temi. Trenutno koristim maxadsl 8Mbps/512kbps i kod testiranja mi je stvarna brzina 6850kbps/420kbps. |
#1983 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ako kod T-Coma ne uspjevas dobiti 8Mbit download (ne po tom shitty speedtestu, vec mislim na "pravi" download) onda ne mozes ocekivati da ces dobiti ista brzu vezu i kod Amisa.
#1985 | ||||
Killer of your Dreams
Lokacija: Final Digit of the Rainbow
Postovi: 107
2) koristenje resursa je poprilicno, vece nego kod BitDefendera uz manju djelotvornost 3) konfigurabilnost je zadovoljavajuca, svaka komponenta se moze posebno iskljuciti, iako nije 100% user friendly sucelje, no buduci da Amis daje podrsku za SigSustav, mozes nazvat korisnicku i trazit pomoc oko svih detalja. SS nije freeware nego je stvarno poklonjena licenca Ne bih nikako savjetovao koristiti ga uz neki drugi AV/anti-spyware/firewall zbog potrosnje resursa i stabilnosti sustava. Predstavlja najbolje rjesenje ako vam je bitnije imati legalan antivirus, a ne zelite placati cca. 50€ i vise godisnje za AV. S druge strane, i po sigurnosti i po koristenju resursa ne moze konkurirati Kasperskom (broj 1) i BitDefenderu (broj 2 AV). Sto se tice novog Nortona, mozda je smanjena potrosnja resursa, no i dalje ostaje za vidjet kakav je algoritam (jel unaprijedjen) za prepoznavanje virusa, jer iz iskustva znam da Norton, NOD32, avast i AVG ne detektiraju neke maleware koje Kaspersky i BitDefender s lakocom preveniraju, cak bih mozda prije preporucio SigSustav/F-secure nego Nortona (2008), NOD, avast i AVG. Top 10 antivirusa godine sa sazetkom funkcija Citiraj:
![]() Isprika MadBoy-u, al samo da covjek procjeni treba li koristiti poklon licencu od Amisa Citiraj:
Koliko vidim, puno je manje errora na parici i malo bolje stanje sa signalom. Jedino jos sto ostaje pitanje gubi li se vise signal na putu od centrale ili na samim kucnim instalacijama. Ako je ovo drugo po srijedi, mislim da mozes trazit da ti Amisov tehnicar to rijesi, samo to ce ic na tvoj trosak. (teoretski naplatit ce ti izmedju 50 i 300kn, ovisno kolko ce radit oko instalacija). Ako zelis to, napomeni im, jer ako znaju da je do tvojih instalacija problem, prije ce ti izac tehnicar ako kazes da si spreman platit pomoc. Citiraj:
Upozorenje - kod Amisa u rout modu neces moc prec 18Mbps na paketu od 24Mbps zbog starog software na Thomson Speedtouchu! Upload je 768kbps u tom slucaju, malo se smanji dok se koristi tel linija (jer nema splittera, pa), no maks upload koji mozes ostvariti kod Amisa je do 1Mbps, i bit ces na ADSL2+, sto ti ne odgovara ako ti je bitan ping. Zadnje izmijenjeno od: Rebellion. 04.11.2008. u 20:03. |
#1986 |
Postovi: 6
Ako je ovo drugo po srijedi, mislim da mozes trazit da ti Amisov tehnicar to rijesi, samo to ce ic na tvoj trosak. (teoretski naplatit ce ti izmedju 50 i 300kn, ovisno kolko ce radit oko instalacija). Ako zelis to, napomeni im, jer ako znaju da je do tvojih instalacija problem, prije ce ti izac tehnicar ako kazes da si spreman platit pomoc. Hm... Da sada navecer je malo bolje nego jučer navečer. Nabavio sam CAT5 kabel , sve isčupao, isčupao viška utičnice koje sam imao, žice spojio iz zida sa na CAT5 kablom (30 cm kabel) (zalemio) i to u router i sada je malo bolje. Hm ako ih ja pozovem , šta on meni može napraviti više nego sam ja napravio, mislim sumljam da će mi provlačiti nove žice jel? Šta će on to magično napraviti? Ujutro sam gledao i nemam PLa ni malo. E sad netko je napisao (ti mislim) da jedino šta ja mogu je smanjiti dužinu kabla a situaciju oko DSLAMa i ostalog se mogu slikati. Da u biti kada ljudi nahrupe navečer dolazi do izražaja moja ne tako savršena parica ako sam dobro skužio. Gle ne bi ništa rekao da prije nisam bio x godina na HTu i u žitovu možda imao ukupno 20 PLa (sada ih imam toliko u 5 minuta), mislim sumljam da se netko popišao na moju paricu pa sada ima lošiji signal nego prije, e to mene živcira.... edit: E da baš gledam ove HEC errors, i piše da se one dešavaju kada moja parica ne može isfurati link, možda je na HTu prije sve radilo jer sam imao 2mb/s a sada imam 4 sa Amisom, pa je povećanje brzine uzrokovalo prolbmee kod većeg opterećenja dslama... Zadnje izmijenjeno od: Hisoka. 05.11.2008. u 15:29. |
#1987 |
Postovi: 23
AMIS !!!!
Ovako, Igram Counter Strike 1.6 Steam, i ping mi je na njemackim serverima od 30-45. Sve sta me zanima je da imam ping ispod 20ms, bas radi toga razloga bih uzeo amis, jer gledam kompice koji imaju amis i koji igraju igre preko net-a, ping im je relativno niski, ispod 30ms. Bas zato me zanima amis 2u1 do 24 mbps. Rekli su mi u amisu da ako uzmem paket od 24 mbps, i ako nisam imao nikakve osjetljivije padove u vezi za t-com (daju 8mbps, a ja imam stvarnu 6.8Mbps. znaci nije puno) ne bi rebao ni imati kod amisa kod paketa od 24 bps, jer bi oni prema meni slali 24Mbps, a sada je pitanje kolko bih ja dobio, sto mislim da je oko 18Mbps - 21Mbps |
#1988 | |
Postovi: 6
Kako ? http://www.kitz.co.uk/adsl/frogstats.php Ako sada nemaš 8 nego manje nekako sumnjam da ćeš dogurati puno više... Pošalji nam statistiku sada na 8.... |
#1989 | |
Postovi: 23
DIAGNOSTIKA
Upstream : noise margin upstream: 25 db output power downstream: 14 db attenuation upstream: 13 db carrier load: number of bits per symbol(tone) tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 23 tone 32- 63: 45 66 66 67 77 77 76 66 66 66 54 43 21 00 00 00 tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Downstrean: noise margin downstream: 21 db output power upstream: 12 db attenuation downstream: 24 db carrier load: number of bits per symbol(tone) tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tone 64- 95: 00 00 01 34 46 68 65 89 77 87 89 98 94 38 43 30 tone 96-127: 53 87 87 84 28 44 68 78 88 88 48 88 76 88 88 87 tone 128-159: 66 78 58 67 67 67 67 66 76 76 57 77 67 77 77 77 tone 160-191: 66 77 75 77 76 46 66 77 67 57 66 77 66 77 77 56 tone 192-223: 67 76 67 76 75 74 77 77 67 66 57 76 36 66 76 66 tone 224-255: 56 76 66 66 56 55 65 65 56 65 64 67 56 65 66 65 tone 256-287: 76 56 66 77 77 77 77 67 76 77 77 77 77 77 76 77 tone 288-319: 76 67 77 77 76 77 77 77 77 76 77 76 77 77 67 57 tone 320-351: 77 77 67 65 65 55 56 55 55 56 36 56 66 65 66 45 tone 352-383: 46 66 64 56 35 46 46 65 65 65 55 55 25 55 44 45 tone 384-415: 24 55 55 24 45 44 44 43 54 54 34 32 24 44 32 44 tone 416-447: 44 34 44 34 34 44 44 44 34 42 44 44 44 22 22 22 tone 448-479: 22 22 22 22 22 22 22 22 22 22 22 22 22 11 11 11 tone 480-511: 11 11 11 11 01 00 00 00 00 00 00 00 00 00 00 00 Evo, i kolko bih mogao Mbps imati okvirno ako uzmem brzinu do 24Mbps |
#1990 |
Datum registracije: Feb 2003
Postovi: 1,556
uskoro sa bneta (mistral 2Mbps/384kbps) koji plaćam 145 kn, prelazim na Amis, onaj paket sa 6Mbps/768 kbps + tel sa đabe spikanjem unutar fiksne u HR za 168 kn.....dakle, odnos brzine i cijene je više nego jasan...zanima me koliko se drži ping na adsl-u u odnosu na kablovsku (kod koje je dosta stabilan)? koje su prave brzine u odnosu na deklarirane? pretpostavljam isto nešto niže u stvarnosti...koliko niže, kako piče torenti, stabilnost veze, jel puca često i sl.....uzeo bi Amis u novoj zgradi u španskom kod oranica...molim vaša iskustva |
#1991 | |
Uptime 99.99%
Postovi: 2,768
#1992 |
Postovi: 1,556
#1994 | |||
Postovi: 107
Tako je otprilike i sa signalom, tebi je max parice vjerojatno blizu brzine kojoj koristis, tj nije bash najbolja, pa kad vise ljudi na tvojoj centrali koristi net, ti, da slikovito kazemo, "dobivas mrvice". Sto si spomenio zamjenu zica - tj kucnih instalacija, moguce je da ce ti tehnicar iz Amisa to napravit na tvoj trosak kao sto rekoh. No, prva stvar koju jos mozes napravit jest da ti tehnicar provjeri stanje na kucnom razvodu, tj na prvoj razvodnoj kutiji od tvoje kuce. Znam x situacija gdje ljudi imaju realnih 2mbps, a kad padne kisa, ni telefon im ne radi, tako da se isplati provjerit kutiju. (tko zna kada i kako su spajane zice u kutiji ako je starija kuca). Inace, razlike u samim zicama kojima je parica provedena su male, no varijacije stvaraju razlike u kvaliteti spojeva, razvodnim kutijama i slicno. Citiraj:
No, ne bih ti preporucio brzinu preko 8Mbps, jer ces vrlo vjerojatno biti na adsl2+ (sto ti ne odgovara zbog pinga), jer u praksi se kod svih parica preko 8Mbps uvijek stavlja adsl2+. Sto ce tice pinga na stranim serverima, na amisu ce ti biti bolji ping prema austrijskim i slovenskim serverima zvog izlaznog linka, a zbog veceg upstreama moguce cak i prema njemackim serverima, nego sto ti je na t-comu, iako teoretski t-com ima prednost jer je t-comov izlazni link preko njemacke, a amisov preko austrije. Citiraj:
Pucanje veza upravo o tome ovisi, ogranicenja na torrente kao promet nema! Upload je u odnsu na download veci nego kod t-coma. To su prednosti u tvom slucaju ![]() Ovako, ja imam na 2u1 na 4Mbps/768kbps ovakvu situaciju: Modulation: G.992.1 Annex B Bandwidth (Up/Down) [kbps/kbps]: 899 / 4.880 Data Transferred (Sent/Received) [GB/GB]: 28,93 / 16,89 Output Power (Up/Down) [dBm]: 12,5 / 9,0 Line Attenuation (Up/Down) [dB]: 4,0 / 4,5 SN Margin (Up/Down) [dB]: 27,0 / 23,5 a na t-comu na 8Mbps/512kbps ovakvu: Modulation: G.992.5 annex B Bandwidth (Up/Down) [kbps/kbps]: 507 / 7.999 Data Transferred (Sent/Received) [GB/GB]: 2,28 / 6,21 Output Power (Up/Down) [dBm]: 13,0 / 0,0 Line Attenuation (Up/Down) [dB]: 3,0 / 2,0 SN Margin (Up/Down) [dB]: 30,5 / 29,0 Iz nekog razloga me neki t-comov tehnicar na centrali nedavno prebacio na adsl2+(G.992.5), iako sam im svaki put kad sam ih zvao govorio da iz razloga sto mi bitniji ping nego brzina mora biti adsl (G.992.1). Preporuka svima koji su na amisu, a igraju Counter strike 1.6 (trenutno samo za one koji nemaju steam zbog novog steam update-a, prije je bio za sve server, cim izadju esteamation i semi-steam patchevi za linux servere na novom protocolu 48, moci ce se ponovno i steamom uc na server) je server 85.10.63.74:27018 (Prior of Sion CS1.6 II). Server je na adslu koji je gore naveden (na amisu naravno; ) , ping ce vam biti ispod 30ms. Isti ping ce biti i vecini koji su u HR, a nisu na t-comu, jer Amis, Bnet, CARNet, H1, Metronet/Vodatel i Optima (tj gotovo svi alternativni ISP-ovi osim t-comovog iskona) imaju interni komunikacijski link, tj komunikacija sa serverom ne ide preko medjunarodnog linka kao kad ste na t-comu a igrate na serveru koji je na amisu (i obrnuto) vec postoji direktna veza izmedju 2 linka (skraceni put da tako kazemo) sto odmah rezultira i manjim pingom. Inace, za sve informacije vezano za server, moj mail je tomba@priorofsion.com, a msn: tomba2k@hotmail.com Inace, ovo je 1 od 2 HR servera registrirana na gametracker na kojem ima igraca. pregled igraca na serveru drugi je venera na magic telecomu, no tracerout sa amisa ne daje bash sjajne rezultate iako je server na stalnoj vezi a ne adslu: Tracing route to www.mtnet.hr [193.19.220.150] over a maximum of 30 hops: 1 36 ms 100 ms 99 ms 192.168.2.1 2 19 ms 34 ms 12 ms zagreb1.amis.net [194.146.109.209] 3 42 ms 56 ms 55 ms zagreb2-ge-0-0-0-1.amis.net [194.146.109.1] 4 21 ms 15 ms 15 ms 212.18.41.5 5 21 ms 64 ms 55 ms vienna1-te-2-1.amis.net [212.18.41.154] 6 61 ms 57 ms 57 ms 213.248.72.105 7 77 ms 51 ms 55 ms 213.248.104.186 8 21 ms 42 ms 66 ms 213.147.96.109 9 * * * Request timed out. 10 * * * Request timed out. 11 75 ms 54 ms 56 ms 213.147.111.26 12 26 ms 24 ms 24 ms 193.19.220.150 (btw, tracrout nije sa 2u1 usluge, nego sa paketa prometa preko amisa, a brzine preko t-coma, tako da me ne pitate kako je adresa gatewaya 192.168.2.1; ) Zadnje izmijenjeno od: Rebellion. 24.11.2008. u 13:11. |
#1995 |
Postovi: 144
Ima li Amis neke probleme? Jednostavno mi je promet stao. Pokusao sam uci u ruter, nisam mogao. Jednom ugasio modem, ruter proradio. Kasnije se opet isto desilo i restartao sa "rupicom" 2x i oba puta dodje do lampice DSL i dalje nece. Jel mi jedino preostaje SZK ili je to do neke vise sile? Hvala! |
#1998 |
Postovi: 144
Poziv u szk i ponovni (4-5) restart ''rupicasti'' je rijesio stvar. Na koliko dugo, vidjet cemo ![]() Hvala svima koji ste mi ukazali na to da nije do Amisa |
#2001 |
Postovi: 144
Aha, na to mislih ![]() |
#2002 | |
Postovi: 107
Kad drzis cackalicu u rupici, to nije "rupicasti restart", nego reset, cime dobivas isti efekt kao kad formatiras disk na kompu i reinstaliras win - znaci sve postavke, port forwarding i sve ostalo se brise!!! RESET najcesce nije porteban, a prilicno je normalno da ti internet ne radi nakon RESETA, jer to ovisi o tome jeli modem pokupio password za net sa DSLAMa! NEMOJTE resetirati modem bez potrebe! Kada vam radi telefon a ne radi net, ako ne gori internet lampica, prvo probate uci u modem (192.168.1.254) i spojiti se na net, jer ako niste spojeni na net, to nije ni do amisa ni do routera - kao da pokusavate voziti auto a niste ga upalili! Ako ne mozete uci u modem (router zapravo), prvo ga pokusajte ugasiti/upaliti. Cekajte da vam proradi telefon i onda ponovo pokusajte uci u konfigurator modema (192.168.1.254). Tek ako ni tada ne mozete, onda vam je nuzan RESET preko rupice jer tada je problem do modema! Nakon sto jednom RESETIRATE modem, nemojte ga 10x nakon toga resetirati (tako mozete i pokvariti modem btw), nego pricakajte da vam proradi telefon (buduci da nakon reseta modem ponovo downloada postavke ovo traje duze nego RESTART tj gasenje/paljenje modema). Kad vam proradi telefon, ako ne proradi odmah i net, onda udjite na 192.168.1.254, pa se rucno spojite na net, vidjet cete jeli vam lozinka upisana ili ne, kao i poruku zasto se modem sam nije spojio na net. Ako vam lozinka nije upisana, mozete do mile volje RESETIRATI router dok se ne pokvari, ali on se nece sam spojit na net. Ne ocekujte da adsl oprema bude inteligenta, ona samo radi zadano, ne moze razmisljati umjesto vas! ![]() |
#2003 |
Postovi: 6
Rebelion hvala ti opet. Nego par dana nakon svog post-a sam zvao korisničku da kažem da se tvari nisu baš nešto previše poboljšale pa da li bi mogli još šta probati ovo ono. Tip mi je rekao da je to max , da oni ne mogu više ništa ovako nabrzaka, da imam veliko gušenje na vezi bla bla. Ja rekoh a niš ako je to maximum onda je maksimum i bok. Btw. molio sam da me prebace na 2mbs i signal se pojačao dosta ali gušenje ostlao isto naravno , malo poboljšanje. I 2 dana nakon tog razgovora igram ja navečer kada PL-a najviše i čudno mi je nekako mi više ne šteka , svfe ok. Pogledam netgraph ravan bez crvenila. Rekoh doobro valjda se zalomilo. Sutra isto ok, dan iza sve ok. Uglavnom štogod da su napravili su to sredili nekako?!?! |
#2004 |
Inquisitor DeathWatch
Lokacija: Zagreb-Rijeka
Postovi: 918
ja mogu reci da onih par djecjih bolesti zbog kojih sam zvao korisnicku podrsku su mi rjesili u roku keks i bili su iznimno ljubazni. kad sam selio Router sa jednog mjesta u stanu na drugo, pa sam ga iskljucio na par sati. Zvali me iz tehnicke podrske na mob , dali je sve u redu da se linija prekinula, dali trebam pomoc..... Uglavnom ja sam jako zadovoljna musterija i sirim dalje reklamu zbog dobre usluge. Amis Keep up the good Work.
#2005 |
Lokacija: n/a
Postovi: 900
Mmm da, nisam ni vidla taj reset button, daklem ni koristila ga nisam niti sam znala da postoji lol. Router palim i gasim na stranici ili na on/off switchu, lately nemam annoying prekida veze, telefon valjda radi lol, ne koristim ga baš. Pitanje, jesu li svi Thomsonovci koji dolaze u Amisovom 2u1 WL-podesivi? |
#2006 |
Postovi: 918
Moji kvart je taman postao dostupan, tako da je ovaj router sta sam dobio bio sa W-lan za 1kn u nekoj akciji. Thomson Speedtouch 780 A inace neznam koji su router dijelili.
#2008 | ||
Postovi: 107
![]() Inace, normalno je da je stanje bolje (ping i PL) na manjoj brzini. Citiraj:
Kao sto je Filip rekao, imas routere sa i bez WLAN, na ST780WL imas WL i mozes konfigurirat ime WLAN mreze, tip zastite, lozinku, kanal i nacin rada (ljudi ojima je losiji singal nek koriste 802.11b, oni kojima je dobar neg stave 802.11g) Inace, ne mozes koristiti WDS funkciju na WL koju 780WL ima podrzanu, al vecina ljudi to ni ne koristi. (iako bi dobro dosla onima sa debelim zidovima u kuci xD ) |
#2009 |
Postovi: 2,723
Dali ima još netko na Amisu da je uzeo do 24Mbit? Evo, ja sam uzeo i imao sam dosta problema, naime, parica je bila jedva vukla 8Mbita na ADSL2+ modulaciji, s puno errora i podosta velikim pingom. I prije nego li sam odustao od povećanja s 4Mbits na išta veće, napravio sam sljedeće: Napravio sam jedan mali "trik"... koji dosta znači... Naime, isčupao sam utičnicu iz zida, kabel do modema koji je dug 5m (a do routera ima 2m) skratio na 2m i zalemio direktno na žice iz zida. I dobio, extra 4Mbita/s na downloadu i 384kbita/s na uploadu, te ping snizio za 8-10ms. Uz to FEC errors smanjio za 98-99% Sad to izgleda ovako: (slika 5KB) ![]() A ovako izgleda FULL download: (slika 9KB) ![]() Prilično zadovoljan, skinem 700MB za cca 8-9 min ![]()
MMA |
#2010 |
Postovi: 144
Nesto mi ocito nije u redu sa modemom. Zvali me ili ne, da utvrde jel' stvar od jutra bolja (nije, pred par minuta mi se opet veza totalno prekinula. Jedino je paljenje/gasenje modema na onaj gumb pomoglo, ali koliko dugo....), zovem ih i pokusat cu se dogovoriti za novi modem. P.S. Ne moram ni spominjati da mi se modem danas 5-6 puta sam od sebe restartao, aaaaa |
