Lokacija: Dubrovnik
Postovi: 2,583
Prime95
Nova verzija Prime95 ne donosi nista novo naspram 25.5 verzije no ipak su ispravljeni neki bugovi... Changelog:
Linux - Download Linux 64-bit - Download Windows 64-bit - Download Mac OS X - Download |
Lokacija: Malaysia
Postovi: 96
Prime95v.25.8
Prime95v.25.8 build 1 (32-bit) 1) Bug fixed in smart affinity on hyperthreaded CPUs. 2) Bug fixed in setting a thread priority other than 1. 3) Off-by-one-bit bug fixed in the benchmarking of trial factoring.
Need a Gigabyte latest BIOS? GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2) G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1) Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD, Corsair Hydro-H50 (MX-2) Gigabyte Superb 720W,Windows 7 SP1 |
Lokacija: Malaysia
Postovi: 96
Prime95v.25.8 build 3 (32bit) Prime95v.25.8 build 3 (64bit) 1) Bug fixed in smart affinity on hyperthreaded CPUs. 2) Bug fixed in setting a thread priority other than 1. 3) Off-by-one-bit bug fixed in the benchmarking of trial factoring. 4) In rare case an infinite loop could occur when the computer ID in the spool file did not match the current computer ID. 5) The "days between checkin" value now has a range of 1 to 7 days. In version 24, the range was 1 to 60 days with a default of 28 days. 6) Fixed bug where switching users on a Windows machine caused computer GUIDs to be erroneously regenerated. You may need to suffer through one more regenerated GUID before the fix takes effect. 7) A bug where some low memory situations on a multi-core machine resulted in one or more worker threads sat idle has been fixed. 8) A crash bug doing 61 and 62 bit trial factoring on P
Lokacija: Malaysia
Postovi: 96
Lokacija: Malaysia
Postovi: 96
Lokacija: Malaysia
Postovi: 96
Lokacija: Malaysia
Postovi: 96
Lokacija: Malaysia
Postovi: 96
ODUZIMAM VAM RIJEČ
Postovi: 13,580
Prime95
Ovak, stavio sam prime95 da provjerim stabilnost novog kompa, i odmah na početku torture testa (blend test) dobim slijedeće za worker 1,2,3 http://slike.hr/slike/p/prime95_cbcde.jpg zanima me sad, pošto sam prvi puta pokretao prime95 i neznam ubiti što znači ovo ''worker stopped'' pa ako mi netko stručniji može reći dal je sve u redu, ili nije konfiguracija sastrane ![]() |
konjpjukter
Postovi: 934
nije |
ODUZIMAM VAM RIJEČ
Postovi: 13,580
ok, u čemu je problem, nešto neispravno ili što? edit: nakon restarta kompa, pokrenuo sam opet prime i sad već pola sata nije našao nikakav error ni na jednoj jezgri, ne kužim ali eto :S ipak je na prvom našao http://slike.hr/slike/p/prime95a_1e5c8.jpg ![]() Zadnje izmijenjeno od: mamutarka. 18.04.2010. u 18:20. |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
a glle ako ti komp radi normalno u svakodnevnim aplikacijama onda zaboravi na prime. primjera radi dok sam imao amd-a (prije cca 5god) on nije prolazio prime duze od sat vremena nikad, ali se nikad nije srusio ili nesto takvog.
#14 | |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Procesor može biti satima stabilan u prajmanju i onda ti rukne kod kodiranja audia u mpeg2 konverziji...imao isti slučaj sa jednim P4 prije dosta godina. |
#16 |
Postovi: 3,794
meni da ne radi prime95 ok, tj da mi nalazi errore, ja bih se zabrinuo. jer platio sam proc koji mora biti 100% ispravan, a ne samo na svakodnevnim aplikacijama. sto ako cu htjet za mjesec dva pokrenut neku specificnu aplikaciju pa mi pocne smrzavati komp ili bacati bluescreen?! @m4mut: provjeri napajanje, da nije ono krivo za takvo ponasanje... |
#18 |
Lokacija: Malaysia
Postovi: 96
Prime95v.26.1 build 1(32bit) ftp://mersenne.org/gimps/test_v26_32.zip Prime95v.26.1 build 1(64bit) ftp://mersenne.org/gimps/test_v26_64.zip Test version.
#19 |
Lokacija: Malaysia
Postovi: 96
Prime95v.26.2 build 1(32bit) ftp://mersenne.org/gimps/p95v262.zip Prime95v.26.2 build 1(64bit) ftp://mersenne.org/gimps/p64v262.zip From the included whatsnew.txt file: 1) Faster FFTs for most SSE2-capable CPU architectures. 2) More FFT lengths supported. 3) Some of the new, faster FFTs don't let us do as much error checking on each iteration. If you don't want to lose this error checking, choose "SUM(INPUTS) error checking" from the Options menu. This will slow down your tests by about 2-5%. 4) When a possible hardware error occurs during a test, the error message would likely scroll off the screen unnoticed. Now, all future progress updates to the screen will be followed by a message containing a count of the errors that have occurred during the test. 5) Worker Windows now stagger their starts. This improves timings for some CPUs and operating systems. See undoc.txt to control this feature.
#23 |
Datum registracije: Jan 2011
Postovi: 18
Prime95 - prvi susret
Eto nakon što sam sastavil napokon komp, skinul sam sa neta prime95 i pokrenul test i asrock oc tuner da vidim temeprature. E sad pročital sam malo po netu i otprilike skužil kak to radi, ali eto molim malu pomoć da me upoznate sa time, kako to ide i sve ostalo. evo jedna slika, dakle sve je stock, sad neznam dal su t oke temperature ili? ![]() ![]() ![]() ![]() ![]() |
#25 |
Postovi: 18
da piše 45, ne nije blend nego je onaj prvi gore koji kao anjviše opterećuje procesor. i sad sam skinul CPU-Z i zanima me jedna stvar, tako je i u biosima, ram je G.Skill Ripyaws 1333mHz a ovdje mi piše da kuca na 667mHz ![]() http://valid.canardpc.com/show_oc.php?id=1615395 isto i za grafičku da je core na 399mHz, je to oke, ili sam ja očito neš krivo napravil? |
#26 | |
#27 |
Postovi: 18
oke, zahvaljujem na informacija, sad me samo još zanima onaj OC tab koji je u biosima, tj. mogu clockati cpu i grafiku po postocima u koracima od 5%, dakle mogu svaki put za 5% dignuti i onda porenem prime95 na nekoliko sati da vidim jeli sve oke? |
#28 |
Lokacija: Malaysia
Postovi: 96
Prime95 v26.5 Build 2 ftp://mersenne.org/gimps/p95v265.zip ftp://mersenne.org/gimps/p64v265.zip 1) Minor bug fixes. 2) Starting in build 2, P-1 work will display the chance of finding a factor. The worktodo.txt line must include how_far_factored using the new syntax: Pminus1=k,b,n,c,B1,B2[,how_far_factored][,B2_start][,"factors"]
#29 |
Lokacija: Malaysia
Postovi: 96
Prime95 v26.5 Build 3 ftp://mersenne.org/gimps/p95v265.zip ftp://mersenne.org/gimps/p64v265.zip Starting with build 3, at startup the program tries to determine which hyperthreaded logical CPUs comprise one physical CPU. If this isn't working properly, see the AffinityScramble2 setting in undoc.txt. The previous version's AffinityScramble setting is no longer supported!
