Staro 01.09.2008., 10:58   #1
LuxZg
Postovi: 512
RivaTuner 2.10 - podrška za 48xx kartice
Unwinder objavio da je beta GOTOVA!
http://forums.guru3d.com/showpost.ph...1&postcount=91
I već možete novu verziju skinuti sa homepagea - http://www.guru3d.com/index.php?page=rivatuner
Dodana je podrška za 48xx kartice na RV770 chipu, i Catalyste 8.5-8.8
- Now almost all RivaTuner's features including overclocking, low-level fan control and hardware monitoring are fully available on AMD RADEON HD 48x0 series display adapters.
Please take a note that currently RivaTuner doesn't support direct access to generic I2C bus and flashrom on RV770 GPUs, so generic I2C bus access based features (e.g. RADEON HD 4870 X2 fan control and monitoring) and VGA BIOS image dumping features are currently not available.
- Updated bundled RivaTunerStatisticsServer v2.8.0 utility
-Added support for serial VID encoding mode for VT1165 voltage regulators to provide proper voltage regulator output monitoring on AMD RADEON HD 4870 and GeForce GTX 260 / 280 series display adapters.
Pa evo, krenite sa testiranjem i isprobavanjem, i javite kako radi - pogotovo na ("problematičnoj") Visti x64! Ja imam još nekih 6h dok ne stignem doma..
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise
LuxZg je offline   Reply With Quote
Staro 20.11.2008., 21:55   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Staro 20.11.2008., 22:08   #3
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,551
I radi ko zmaj ...plus sto ovi novi 180.48 driver imaju podrsku za namjestanje venta na 9800 gtx+ i ja hepi
Staro 21.11.2008., 14:11   #4
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Imam problem, sa ni jednov RivaTuner verzijom nisam imal problema, al sad sam stavil nove drivere za graf. pa sam stavil i rivu 2.20. I nikak mi ne radi, kod pokretanja stalno isto mi javlja, tj ovo:
Imam Vistu x64!
danc00 je offline   Reply With Quote
Staro 21.11.2008., 21:48   #5
~Kaiser_Chief~
~Kaiser_Chief~'s Avatar
Lokacija: Zabok
Postovi: 1,189
probaj runat kao administrator!
~Kaiser_Chief~ je offline   Reply With Quote
Staro 21.11.2008., 21:51   #6
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
hvala na prijedlog, al to sam prvo napravil....
Staro 22.11.2008., 15:51   #7
sipe
sipe's Avatar
Postovi: 993
Autor danc00 Pregled postova
Si instalirao signed driver za x64? ponudi ti to tijekom instalacije
sipe je offline   Reply With Quote
Staro 23.11.2008., 02:44   #8
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
I u tome mislim da je problem, normalno sam to instaliraval sa prijašnjim verzijama, al sad mi jednostavno neče, nemogu odabrat riva.exe ko program za pokretanje ti drivera za x64, al dobro, riješil sam to u biosima, a i radi mi 2.11, tak da je riješeno na drugi način, možda bude još nekom tak pa javi kak je to riješil!
