Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst 8.11
New Features This section provides information on new features found in this release of the Radeon™ Display Driver. These include the following: • ATI CrossFireX™ Enhancements • HydraVision Support for Windows XP • New Display Enhancements • Performance Improvements ATI CrossFireX™ Enhancements This release of ATI Catalyst™ enables users to verify whether an application is running in ATI CrossFireX™ mode. The new option found in the ATI Catalyst™ Control Center system tray, will allow users to verify whether a Direct3D or OpenGL application is running in ATI CrossFireX™ mode. (The “ATI Cross- FireX” logo will be shown on screen when the application is running). HydraVision Support for Windows XP This release of ATI Catalyst™ introduces HydraVision support for the ATI Catalyst ™ Control Center under Windows XP. HydraVision enables users to more efficiently organize multiple applications across single or multiple displays. Highlights include: • HydraGrid – A new feature found in HydraVision that divides the Windows desktop into user definable areas. This helps users to more easily move and organize multiple applications. • HydraVision Hotkeys – The ATI Catalyst™ Control Center Hotkey Manager can assist users to quickly setup and define their HydraVision specific hotkey commands. • HydraVision Virtual Desktops – Users can configure up to 9 different virtual desktops. This enables users to manage and group multiple applications across each user defined desktop. Application positions, desktop associations and display settings can be saved for every virtual desktop. • HydraVision Wizard – Using the ATI Catalyst™ Control Center Wizard, users can configure their HyrdaVision settings with ease. Resolved Issues for the Windows XP Operating System This section provides information on resolved issues in this release of the ATICatalyst™ Software Suite for Windows XP. These include: • “Lower Resolution” message displayed when attempting to play HD content using winDVD • Running certain OpenGL applications may intermittently cause the system to stop responding • Some desktop corruption may be noticed when playing standard definition video while exiting full screen DOS • Overlay rotation failing under Windows XP • Hot unplugging the secondary device with Clone Mode enabled may cause video playback instability • With Clone Mode and Overlay Theater Mode enabled some video playback may fail to render properly • Some corruption may be noticed during video playback on Cyberlink winDVD7 and rotate desktop • Midway “Stranglehold” may become New Display Enhancements This release of ATI Catalyst™ Linux introduces support for display scaling to resize the display devices that support TV timings (480i/p, 720p, 1080i, 1080p) through either digital (DVI or HDMI) or analog (component) interfaces. Performance Improvements The following performance gains are noticed with this release of Catalyst™ FarCry 2 – performance gains of 3 to 10% for Single card mode and 8 to 14% in Crossfire mode, with some specific configurations showing even greater improvements. Performance gains were noticed on all Radeon HD4xxx and Radeon HD3xxx products. S.T.A.L.K.E.R.: Clear Sky – performance gains of 6 to 18% in single card settings and 10 to 30% in CrossfireX mode. Performance gains were noticed on all Radeon HD04xxx and Radeon HD3xxx products. http://ati.amd.com/support/driver.HTML
Postovi: 993
Lijepo, popravili su performanse i 3xxx verzije |
Lokacija: Novska
Postovi: 2,452
Ocistio sam stare drivere i ccc sa driver cleanerom. Nakon instalacije novih drivera, ne mogu uc u CCC. Prijavi mi da novi CCC nema basic view nego samo advanced view. Kada kliknem na advanced nista se ne dogodi. |
Postovi: 19,024
Više nema GART i South Bridge drivera u paketu ili ja nešto krivo gledam? ![]()
Postovi: 1,030
Performanse nikakve nisam primjetio u FarCry 2, barem ne po FarCry 2 benchmarku. Dapače, pred kraj benchmarka imam veće rupe u grafu, tj. minimalni FPS mi je sada 16, a na 8.10. driverima bio je 19.
Everything is sooooo slow... Why? Oh, why? |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Počistio sa Driver Sweeperom pa stavio,ok zasad (Far Cry2,HL2 - Orangebox, ETQW,UT3,WoW,Fifa09) |
#14 | ||
Super Moderators
Postovi: 17,485
i dan-dva nakon na drugoj temi: Citiraj:
Lokacija: Cakovec
Postovi: 84
8.11 driver i i overclock?!
Imao sam dosad 8.10, i tamo sam lijepo s riva tunerom oc-ao kako sam htio, sve super (vista 64bit), i sad stavio 8.11 i kitaaa! Nemrem OCat nigdje! AMD GPU TOOL, ATI Tool, Riva Tuner, Power nesto.. U svakom programu stavim neku frekvu, applayam i on vrati na staru :s S overdriveom sam sad OCao, al to nije dosta..jer ide vise nego mi on dopusta :s Pokusao sam stavit opet 8.10 drivere, unistalirao 8.11, cak sam i pocistio s driver cleanerom, ali dok se driveri instaliraju i restartam komp ne radi.. 60Hz osvjezenje, bez ccc-a i sve u k***u. Tak da sam sad na 8.11 opet, al bez OC-a. Rjesenje neko? O.o hvala |
#17 |
Postovi: 177
#18 | |
Flaccitra
Lokacija: Vinkovci
Postovi: 276
#20 |
Lokacija: Petrinja
Postovi: 904
Na bugu pise da ce u verziji 8.12, serija hd4*** dobiti podrsku za "ati stream" i da ce u ccc ukljuciti avivo converter koji koristi stream procesore sa grafičke za dekodiranje,kodiranje videa!!! |
#22 |
Super Moderators
Postovi: 17,485
#25 | |
Postovi: 616
Oc granice u samom ccc-u neces moci promijeniti, ali kakve taktove postavis tamo ti ce ti vrijediti za 3d mode, a u 2d ce se vracati na tvornicke 2d postavke. |
#28 | |
Datum registracije: Jun 2004
Postovi: 3,996
Prouči ove linkove da sad ja ne pišem opet sve što je napisano tamo ![]() http://forum.pcekspert.com/showthread.php?t=118175 http://www.xtremesystems.org/forums/...d.php?t=197219 |
#29 | |
Postovi: 616
normalno da moze, ali on je pitao dal to moze iz ccc, bez prckanja po biosu ![]() Od tamo nemoze, jer je lokirano na odredjenu vrijednost. E sad, drugim biosom i preko rive se moze (te drugih alata), a za ccc bi se u teoriji moglo kada rucno editiras profile koje si kreirao preko ccc-a (tamo mozes sloziti i 2d/3d profile, ali ih rucno palis) i tamo forsiras druge vrijednosti, medjutim opet ce ovisiti o biosu i kakve su tamo vrijednosti slozene. |
#30 |
Lokacija: Petrinja
Postovi: 904
a da jednostavno koristis att?? Tamo mozes stavit i na 1THz core clock!!! |
