Staro 15.10.2008., 21:37   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Catalyst 8.10
Evo, i službeni su vani
http://ati.amd.com/support/driver.HTML
New Features
This section provides information on new features found in this release of the Radeon™ Display Driver. These include the following:
See Catalyst Control Center™ Fan speed control
See Force Component Video Detection
This release of the ATI software driver version 8.54 introduces the ability for users to control the speed of the GPU fan when running in accelerated graphics.
This release allows users the option in Catalyst Control Center to force Component Video detection in the Display Options aspect. By selecting this option user are able to adjust the Component Video property settings (without a device being physically attached) allowing user to change format and frequency to a desired value. The selected values will be applied to the display once a component video display device get connected. The feature is applicable for all AMD products supporting Component Video.
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
Some video corruption might be noticed when playing certain Blu-ray titles. Further details can be found in topic number 737-38293
Disconnecting an HDMI display device during DVD playback may result in Windows Vista failing to respond. Further details can be found in topic number 737-38308
Flickering may occur on the primary display when two dual link displays are used. Further details can be found in topic number 737-38295
Playing some video file formats under Windows Media Player 11 can cause a time delay response. Further details can be found in topic number 737-38926.
City of Villains: Flashing observed in the game when super AA is enabled in Catalyst Control Center and the resolution is at 2560x1600. Further details can be found in topic number 737-38301
When desktop rotation enabled in OS:Vista Greek some text is cutoff in the default monitor.Further details can be found in topic number 737-38302
Performing an express un-install of the display driver on some ATI Radeon HD 48x0 series devices, may intermittently result in the display device failing to display an image. Further details can be found in topic number 737-38308
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
Catalyst Control Center Avivo Gamma control fails to function when playing a DVD using MS Windows Media Player or Cyberlink PowerDVD player. Further details can be found in topic number 737-28294
Opening Catalyst Control Center while playing back a HD/SD title with Cyberlink will cause display to go blank. Further details can be found in topic number 737-38305
Known Issues Under the Windows Vista Operating System
This section provides information on known issues that may be experienced under the Windows Vista operating system with the latest version of Catalyst™ . These include:
Some video can become corrupt after random seek using the Cyberlink player. Further details can be found in topic number 737-38297
Enabling Catalyst Control Center AA-4x and Filter-Edge detect settings can cause some video corruption in OpenGL applications. Further details can be found in topic number 737-38304
Known Issues Under the Windows XP Operating System
The following section provides a summary of open issues that may be experienced under the Windows XP operating system in the latest version of Catalyst™ . These include:
Color corruption can occur when playing some interlaced contents without having Catalyst Control Center installed. Further details can be found in topic number 737-38299
Installing the Catalyst™ Vista Software Driver
For further information and general help on software driver installation, game issues, and more, visit ATI Customer Care.
Installation information can be found at: ati.amd.com
AMD Customer Care
The AMD Customer Care website provides a high level of technical support and ease of navigation. The AMD Customer Care website provides accurate and up-to-date product support for optimum usability and performance. Technical issues are categorized and personalized to enhance user experience. The AMD Customer Care Website can be found at: support.ati.com
To view a known issue or find troubleshooting information, do the following:
Go to ati.amd.com. The AMD home page is displayed.
Click on Support & Drivers. The AMD Support and Drivers web page is displayed.
In the left hand pane, select Graphics Support.
In the top right corner of the Graphics Support page, enter the topic number or a general description of the issue you are experiencing within the search field.
In the Select Site field, select ATI.
Click the SEARCH symbol.
The information requested (if available) is displayed.
Catalyst™ Crew Driver Feedback
This driver release incorporates suggestions received through the Catalyst™ CREW Driver Feedback program. To provide us with your feedback, visit: Catalyst™ Crew Driver Feedback.
Staro 15.10.2008., 22:01   #2
edoo
1337
Lokacija: Slav. Brod
Postovi: 95
prije 1h skinio stare drivere i sad vidim nove i rade sve 5 thx na obavijesti
sad je lakse ak os podesiti si fan-ove
edoo je offline   Reply With Quote
Staro 15.10.2008., 22:12   #3
jurbAs
jurbAs's Avatar
Postovi: 2,582
pitanje koje pitam kakva je ta razlika izmedu onog sto se pojavilo na megauploadu?!
Staro 15.10.2008., 22:26   #4
edoo
1337
Postovi: 95
ja bar mislim da je ovo iz oficialnpog site zato
Staro 15.10.2008., 23:25   #5
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,274
Autor jurbAs Pregled postova
Vjerovatno je to isti drekec...
Staro 16.10.2008., 10:56   #6
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Isti su 100% kao i oni finalni prije 5 dana.
Liquid Snake je offline   Reply With Quote
Staro 16.10.2008., 12:59   #7
PuMa
PuMa's Avatar
Datum registracije: Jun 2004
Lokacija: croatia
Postovi: 63
da nista se nije promjenilo sto se tice podrske za fun control koji mi u biti ne znaci nista ali ja definitivno necu vise kupovati ati karticu jer me ovo jednostavno raspi*dilo kupio sam je cim je izasla i dao masnu lovu i sad ne daju podrsku ja im sve po redu eto.
koliko god sam bio na nvidiu ljut prvom prilikom se vracam na njih a sa moje strane to znaci atiu godisnje jedno 25-30 manje grafickih koliko ja sastavim ekipi kompjutera okolo znam da je to za njih nista ali barem pokazujem inicijativu .
svi vi pozivam vas na bojkot ATI-a
razlog katastrofalna podrska smece od drivera
eto i mene na intela
PuMa je offline   Reply With Quote
Staro 16.10.2008., 13:11   #8
Jelc
Super Moderators
Postovi: 17,485
Ne spamaj.
Ako ti ATI ne paše idi na Nvidiu, ko ti brani...Fan speed control je koliko znam samo za 4xxx seriju.
Osim toga-ko te tjero uzimat X2, sad imaš grafu koja puno troši, grije se, bučna je dozlaboga i popušila je na vrijednosti skroz-naskroz
Staro 16.10.2008., 13:14   #9
Pippincro
Pippincro's Avatar
Postovi: 616
hm Puma, oke
Driveri isti kao i oni leakani, jedino me zacudjuje mali release note. Fixevi i performanse izostavljeni u ovoj verziji drivera? 8.10 = 8.9 + fan control i opengl podrska?
Pippincro je offline   Reply With Quote
Staro 16.10.2008., 13:37   #10
ShAd0w_dAnCeR
ShAd0w_dAnCeR's Avatar
Lokacija: BJ/ZG
Postovi: 539
nije isto, barem mislim... skinuo sam jucer (!) one sa megauploada i kada sam stavio custom install tamo je bilo i el os installirat tv wonder i jos neke gluposti koje ne znam sta su... bilo kako bilo, u ovoj ofišl su vjerojatno samo taj install "sredili"...
ShAd0w_dAnCeR je offline   Reply With Quote
Staro 16.10.2008., 14:07   #11
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Eh, kad budu dodali fan control za HD3800 seriju instalirat cu ove drivere, dotada sve radi super na 8.9 releasu u CF-u
Staro 16.10.2008., 14:18   #12
Jelc
Super Moderators
Postovi: 17,485
Autor Dizel Pregled postova
Ne radi ATT kad je CF?
Staro 16.10.2008., 14:31   #13
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Radi, ali ATT ne podrzava 2 kartice, vidi samo primarnu. Dakle, imam kontrolu samo primarnog adaptera u ATT-u, sekundarnog "ne vidi".
Staro 16.10.2008., 14:34   #14
Jelc
Super Moderators
Postovi: 17,485
Ah, ja mislio da su to sredili...
Staro 16.10.2008., 14:49   #15
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,001
Ovo stvarno nije u redu, ja kupio ULTIMATE verziju 3870-ice i sad nemam podršku za fan control?
Staro 16.10.2008., 15:09   #16
Jelc
Super Moderators
Postovi: 17,485
Matori, ne spamaj...odi igraj Conana Varvarina...
Staro 16.10.2008., 15:18   #17
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,001
Autor Jelc Pregled postova
Ja nikad ne griješim kod kupovine hardvera i softvera, i eto priznajem da je AOC iznimka koja potvrđuje pravilo
Zato je tu Warhammer online.
A što se tiče on-topica, evo:
http://forum.pcekspert.com/showthread.php?t=123151
Staro 16.10.2008., 17:34   #18
nino
nino's Avatar
Postovi: 12,600
.....Osim toga-ko te tjero uzimat X2, sad imaš grafu koja puno troši, grije se, bučna je dozlaboga i popušila je na vrijednosti skroz-naskroz
Da, a ja bio prisiljen dati liku moju 3870X2 i dobijem od njega na ruke ovo Jos me pitao da nadoplati, ja reko "Ma netreba, sve ok"
Staro 21.10.2008., 16:50   #19
Atrax
Atrax's Avatar
Postovi: 553
Thumbs down
Opet me izbacuje iz CoD4 MP.....
Vraćam se na 8.9........
Atrax je offline   Reply With Quote
Staro 21.10.2008., 20:15   #20
stopalo9
stopalo9's Avatar
Postovi: 763
Autor Atrax Pregled postova
kod mene upravo suprotno
stopalo9 je offline   Reply With Quote
Staro 21.10.2008., 21:37   #21
Atrax
Atrax's Avatar
Postovi: 553
Autor stopalo9 Pregled postova
stavio sam ovaj FC2 hotfix, za sad super radi, vidit ćemo kolko će dugo
Staro 25.10.2008., 14:07   #22
Jakesevic
Truth is out there!
Jakesevic's Avatar
Datum registracije: Aug 2003
Postovi: 496
Imam 2600 mobility i vistu i preko onog moddera sam stavio ove drivere 8.10, ali vidim po slikama da ljudi imaju o ccc onu opciju ati overdrive i jos gpu nesto,ja nemam. Jel to zbog tog sto je ovo mobile kartica ili?
"Covjek je star koliko i zena koju osjeca!" C.Sheen
Jakesevic je offline   Reply With Quote
Staro 26.10.2008., 14:07   #23
E4300
E...jedno pitanje
kaj je to ati WDM driver? stalno to instaliravam a neznam kaj je to zapravo?! tnx
Staro 26.10.2008., 16:20   #24
Roberto
Roberto's Avatar
Postovi: 2,636
Autor E4300 Pregled postova
E...jedno pitanje
Znači da je MS approved:
Windows Driver Model (WDM)
Staro 26.10.2008., 16:39   #25
Jelc
Super Moderators
Postovi: 17,485
Ma ne, to je onak-generalno...u ovom slučaju bi bilo "The WDM driver is a series of drivers used to enable the capture and TV tuner features on VIVO boards, and the All-In-Wonder™ series of cards produced by Advanced Micro Devices Inc."
