Staro 04.10.2007., 01:33   #121
Razer
Razer's Avatar
Postovi: 11,642
Interesantno...možda si potrefio neku lošu. Ja sam probao 3 komada i sve tri su išle na 630MHz za jezgru na stock naponu. Nikakva rušenja/smrzavanja se nisu dešavala. Ili da kažem iz konkretno mog primjera. Čip ide na 685MHz, a memorija nešto slabije jer je 512MB verzija - 1500MHz. Sve u svemu - IMHO - odlična kartica
Staro 04.10.2007., 01:51   #122
gunther
Postovi: 1,370
Moguce da sam naleti na slabiji primjerak
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 04.10.2007., 11:10   #123
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Jezgre se super klokaju na njima, jer deafoltno piče na većem taktu.
Samo gddr je bio problem...
Moram se ja malo potrudit i kloknut ih u crossfire. Ima netko iskustva u tome, to ako se kloka jedna odmah se digne takt i druge? Zapravo to razer zna sigurno...
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 26.08.2008., 22:27   #124
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
podizanje napona gpu-a na x1950gt
dakle zanima me dali postoje koji driveri za ati kartice ili možda nekakvi programi kojima bih mogao podići napon gpu-a i memorije na mojoj kartici?
jednom prilikom,instalirao sam omega drivere i ati tray tools i u overclocku sam imao opciju podizanja voltaže gpu-a i memorije, sad to više nikako nemrem dobit da radi, pa me zanima jel postoji koji drugi program preko kojeg bi takvo nešto bilo moguće?
D-I-A-B-L-O je offline   Reply With Quote
Staro 26.08.2008., 23:00   #125
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATT
Staro 26.08.2008., 23:23   #126
D-I-A-B-L-O
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Autor Jelc Pregled postova
ATT
ATT mi neće otvorit opciju dizanja napona, neznam zašto, možda nešto krivo radim??
ubijem hotkey poller prilikom instalacije,ništa, neubijem ga opet ništa, izludio sam već sa time, evo,sad na čistu instalaciju xp-a instaliram te iste omega drivere i opet pokušam i opet neće!
aj puknite nekakvu natuknicu šta treba napravit da to proradi
Staro 27.08.2008., 19:34   #127
D-I-A-B-L-O
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Šta nitko nezna kako osposobit att da mogu podizat voltažu??
Ako već nitko nezna za to, dali onda itko zna jel ima gdje kakav bios sa podignutim voltažana za memoriju i gpu??
Staro 27.08.2008., 21:31   #128
Jelc
Super Moderators
Postovi: 17,485
Ako si imao prije-moraš imat i sad...pogledaj pod one opcije overclocka (driver level i slično)
Staro 05.10.2008., 19:35   #129
Rufus1987
Lokacija: Vukovar
Postovi: 20
Peak Radeon x1950gt overclock?
Poz trebao bih par savjeta i imam par pitanja u vezi overclocka gore navedene grafe sad znam da ima onaj jedan programćić što istestira pa se moze s njim podizati taktovi itd sad pitanje je dokle bi išla s stock collerom sad je 500/1200mhz i koliko je pametno je clockati hvala unaprijed na odgovorima i ak moze link za te programćiće za overclock..
Rufus1987 je offline   Reply With Quote
Staro 05.10.2008., 19:41   #130
~Kaiser_Chief~
~Kaiser_Chief~'s Avatar
Lokacija: Zabok
Postovi: 1,189
Riva Turner
Ati Tool
itd...
a koliko bi isla zavisi o modelu... naravno da se isplati klokati je performanse rastu !
~Kaiser_Chief~ je offline   Reply With Quote
Staro 05.10.2008., 20:08   #131
Rufus1987
Lokacija: Vukovar
Postovi: 20
ej pokusao sam s ati toolom al bilo koju opciju da kliknem zacrni se monitor i nist se ne dogadja nekuzim
EDIT:nasao sam drugu verziju programa i sve on kao testira i dize taktove ali dodje na jedan dio gdje se pojave plavo bijele crte i stoji na tome već 20-tak min jel to normalno ili?
Zadnje izmijenjeno od: Rufus1987. 05.10.2008. u 20:25.
Staro 05.10.2008., 20:55   #132
Rufus1987
Lokacija: Vukovar
Postovi: 20
evo uspio sam dignuti core clock sa 500 na 650mhz makar mi je pokazao da mogu 700mhz ali memoriju kad pokusam kloknuti krene kao klokanje i monitor se zacrni nekuzim zašto moze pomoć?
Staro 05.10.2008., 21:13   #133
Razer
Razer's Avatar
Postovi: 11,642
Prebaci sa Low level na Driver level OC u opcijama programa.
Staro 08.10.2008., 22:43   #134
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
jako mi je zao zbog dizanja stare teme al nakon visesatnog guglanja mi nije nis jasnije kaj je to avivo tj kak bi ja to trebo spojit na svoju x1950gt?
imam onaj s-video to rca (crveni, zeleni i plavi) kabel i prek njega spojim komp s tvom(ustekam u crveni jer ak utekam u jedan od ova dva onda nema slike il je crno bijela). a sad sam dobio neku ideju da bi snimio nes s tva na komp(imam onaj scart izlaz(provjereno radi na burazovom cowon a2) al nemrem nikak dobit sliku na kompu...kak da ja to spojim i prek kojeg programa da radim?onaj avivo video converter oce samo convertat video,nigdi nema za capture(doduse uspio sam ga pokrenut samo iz ccc wizarda)...
ako je glupo pitanje ja se ispricavam al hebga,mozda sam i ja onda glup
njuskalo je offline   Reply With Quote
Staro 08.10.2008., 22:49   #135
domy_os
domy_os's Avatar
Postovi: 18,985
Uf, pomiješao si kruške, jabuke i šljive. Avivo, VIVO i HDTV su tri sasvim različita pojma. Ja sad nemam vremena tipkati što je što, ali Google sve zna.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 09.10.2008., 00:48   #136
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
oke,fala, skuzio sam da je razlika al kolko sam naso 1950 ima i vivo i avivo a sad kak bi trebalo spojit da ja mogu eventualno snimit nes s tva?
Staro 10.10.2008., 15:12   #137
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
ajde ljudi molim vas ako netko zna nek pomaga,kako i sto spojit te koji program koristit za snimit video s tva na x1950gt,vjerujem da ce isto radit i za hd2600xt jerbo bi i nju isto tako probo spojit?
Staro 10.10.2008., 15:34   #138
Jelc
Super Moderators
Postovi: 17,485
Isuse, pa sto puta smo već pričali o tome...možeš uvest signal sa fotića, kamere...za Tv ti treba video (VCR)
Dakle iz videa u VIVO grafe+kaj moraš sa videa dovest i zvuk na zvučnu.
Sve to pod uvjetom da imaš VIVO a ne samo Tv-OUT...
Staro 11.10.2008., 15:24   #139
crocro25
Lokacija: Sisak
Postovi: 589
iz iskustva....kako vam radi 1950 na 22incha monitorima pri mid range igrama tipa nfs carbon,godfather ili pak far cry 1 ?vise ili manje od 30fps
Prvo i zadnje upozorenje.
crocro25 je offline   Reply With Quote
Staro 11.10.2008., 15:45   #140
maX
maX's Avatar
Postovi: 7,326
Autor crocro25 Pregled postova
na nativnoj rezi ili?
mislim da se na nativnoj rezi bas i neces naigrat previse s tom grafom
Staro 11.10.2008., 16:14   #141
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Pitnje je ima li uopce T200 cip(VIVO) na kartici, uglavnom X1950GT taj chip nisu imale...
Staro 15.10.2008., 11:34   #142
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Autor Dizel Pregled postova
a kak da saznam dal moja ima il ne,osim ak nijedna nema...
a hd2600xt ima VIVO jel?
Staro 15.10.2008., 11:42   #143
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
HD serija NEMA VIVO, odjebali su ga cigani.
Ako imas Rage chip na kartici onda imas VIVO, uglavnom se nalazi izmedju 2 DVI-ja na PCB-u kartice, odmah iznad hladnjaka.
Staro 15.10.2008., 13:08   #144
Jelc
Super Moderators
Postovi: 17,485
Ne, zadnji model koji je imao VIVO je HD 2900XT, ostatak 2xxx serije ne (eventualno HD 2900 PRO)
Staro 13.05.2009., 15:16   #145
Lauscro1
Datum registracije: May 2009
Lokacija: split
Postovi: 1
Exclamation ATI radeon x1950gt Core temperature!
ej
imam ovu graficku karticu vec nekih godinu dana i pocela mi je radit velike probleme.Igrao sam Burnout Paradise The Ultimate Box i blokiralo mi je igru i izasla je neka poruka da mi je graf kartica presla"safe temperature" ili nes tako....pogledao sam preko ATI OVERDRiVE (current temp.) i necete mi vjerovat kolika je bila(103 c).......rekao sam prijatelju i on je mi nije vjerova(kao on kuzi sve te stvari)...skinuo sam pogram Riva tuner ili tako nesto i pogledao hardware monitoring......
80 c (na 100% duty cycle!!!)nije upaljena ni jedna igra.........
otvorio sam kuciste....malo se smanjila temp. ali svejedno...
molim vas da mi pomognete!!!
samo jos nesto igrao sam jos i Left 4 dead..96.65 c....
jos neke inf. iz riva tuner: core clock 499(ez upaljen igre)*
:memory clock 594
:ambient temp 56
Lauscro1 je offline   Reply With Quote
Staro 13.05.2009., 15:36   #146
Speedbreaker
Postovi: 545
Autor Lauscro1 Pregled postova
ej
:memory clock 594
:ambient temp 56
izvadi karticu i rastavi/počisti hladnjak.ako se prije nije pregrijavala vjerojatno se zaštopala od prašine.
Speedbreaker je offline   Reply With Quote
