Staro 26.09.2008., 01:57   #1
rodney
only fool, not a horse
rodney's Avatar
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,281
(riješeno) Informaticka nepismenost (vezano uz foldere)
ovaj informaticki nepismeni iz naslova sam ja osobno..
nesto mi se stilto komp i ja kliknuo par puta manijacki,
i sad mi kad otvorim my computer ili bilo koji folder to zgleda ovak:
ja bi ono gore sto neznam kak se zove htio nazad.
googlo bih ali neznam kak se to zove. toolbar ili nes tak?
pomagajte, kak se to pali?
rodney je offline   Reply With Quote
Staro 26.09.2008., 02:12   #2
DiSc-jOcKeY
Postovi: 173
Autor rodney Pregled postova
Desni klik na my computer>> Arrange icons>> by type , Ponovo desni klik >> Arrange icons >> Show in groups.
DiSc-jOcKeY je offline   Reply With Quote
Staro 26.09.2008., 03:11   #3
rodney
rodney's Avatar
Lokacija: near zgb
Postovi: 1,281
bojim se da me nisi razumio, fali mi ono di je back, forward, adress......
jbg-a znam da "ja bi ono gore sto neznam kak se zove htio nazad." i nije
neki opis.
znaci ovo ovdje mi fali:
zrezo sam neku sliku s neta...
Staro 26.09.2008., 03:16   #4
Func
Func's Avatar
Postovi: 483
Pod folder options bi trebalo biti negdje. Na visti sam, pa ne mogu točno reći.
EDIT:
Probaj ovo:
If I recall from quite a few years ago there should be what looks like a verticle handle either to the left or the right of the word Address. Move your cursor (pointer) over that handle till it turns into a 2 sided arrow then hold your left mouse button down and try dragging to the right or downwards untill the Address bar appears the release the left mouse button.
link na topic
http://forums.cnet.com/5208-6121_102...sageID=2854165
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ...
Func je offline   Reply With Quote
Staro 26.09.2008., 03:40   #5
rodney
rodney's Avatar
Lokacija: near zgb
Postovi: 1,281
to je za internet explorer, meni se ovo dogodilo u my computer....
pod folder options nisam nasao. vjerojatno jer neznam kako se to zove.
ali nije nista od onoga sto sam razumio i/ili probao tamo na view u folder options
Staro 26.09.2008., 03:57   #6
Func
Func's Avatar
Postovi: 483
Staro 26.09.2008., 04:51   #7
Shaper
Shaper's Avatar
Postovi: 92
View/toolbars/standard buttons i address bar
Shaper je offline   Reply With Quote
Staro 26.09.2008., 04:56   #8
Func
Func's Avatar
Postovi: 483
Autor Shaper Pregled postova
Tj. alt+v, pošto ne vidi view.
Staro 26.09.2008., 14:23   #9
rodney
rodney's Avatar
Lokacija: near zgb
Postovi: 1,281
Autor Func Pregled postova
ovo je pomoglo. hvala.
alt + v isto nije htjelo, samo bi dao onaj zvuk ko error...
nego je da je problem rjesen, ali rjesen je tako da sam morao brisat neke gluposti po registry-u, kako je do toga uopce doslo? jesam mogao ja to uneredit sa par nekontroliranih tipki?
