#1891 |
Postovi: 1,431
puno hvala ![]() |
#1892 |
1oo1 NooB
Postovi: 1,306
NP ![]()
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. |
#1893 |
Postovi: 1,431
prebacio me tip u 2 minute, sad je bolje, hvala jos jednom mm ![]() ![]() ![]() <table class="datatable" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td width="170">Uptime:</td><td colspan="3">0 days, 0:03:14</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Modulation:</td><td colspan="3">G.992.1 Annex B</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Bandwidth (Up/Down) [kbps/kbps]:</td><td colspan="3">692 / 6.887</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Data Transferred (Sent/Received) [MB/MB]:</td><td colspan="3">12,07 / 38,68</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Output Power (Up/Down) [dBm]:</td><td colspan="3">13,0 / 19,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Line Attenuation (Up/Down) [dB]:</td><td colspan="3">27,0 / 28,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">SN Margin (Up/Down) [dB]:</td><td colspan="3">7,0 / 7,5</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Vendor ID (Local/Remote):</td><td colspan="3">TMMB / BDCM</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Framing (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Signal (Local/Remote):</td><td colspan="3">3 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Power (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Link (Remote):</td><td colspan="3">0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Error Seconds (Local/Remote):</td><td colspan="3">8 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">FEC Errors (Up/Down):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">CRC Errors (Up/Down):</td><td colspan="3">2 / 1</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">HEC Errors (Up/Down):</td><td colspan="3">0 / 1</td></tr></tbody></table> |
#1894 |
Honda Prelude 2.0i driver
Lokacija: Zagreb Dubrava
Postovi: 1,128
evo ovak izgleda moja parica: imam skoro identičnu ateunaciju i jadan sn margin ali errora skoro da i nemam a uptime mi ne pukne po 10 dana stvarno rock solid veza a parica je realno loša prije sam bio na 6 mbit (iste vrijednosti)i pucala mi je veza svakih 2-3 sata neznam kaj se moralo dogodit da je veza sada tako stabilna zato sam izvukao zaključak da je možda do dslamova...nisam baš neki znalac al neznam kaj bi drugo moglo bit , pa ak neko ima kakvu ideju...? <table class="datatable" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td width="170">Uptime:</td><td colspan="3">5 days, 4:11:12</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Modulation:</td><td colspan="3">G.992.1 Annex B</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Bandwidth (Up/Down) [kbps/kbps]:</td><td colspan="3">899 / 6.887</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Data Transferred (Sent/Received) [GB/GB]:</td><td colspan="3">21,56 / 47,15</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Output Power (Up/Down) [dBm]:</td><td colspan="3">12,5 / 19,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Line Attenuation (Up/Down) [dB]:</td><td colspan="3">17,5 / 27,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">SN Margin (Up/Down) [dB]:</td><td colspan="3">20,0 / 7,5</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Vendor ID (Local/Remote):</td><td colspan="3">TMMB / BDCM</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Framing (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Signal (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Power (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Link (Remote):</td><td colspan="3">0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Error Seconds (Local/Remote):</td><td colspan="3">261 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">FEC Errors (Up/Down):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">CRC Errors (Up/Down):</td><td colspan="3">0 / 310</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">HEC Errors (Up/Down):</td><td colspan="3">0 / 106</td></tr></tbody></table>
#1895 | |
lar~
Postovi: 1,557
@tomifish2002, imas puno srece Trenutno ti se parica drzi iz nekog razloga (mozda su slozili profil koji se drzi na samo 7,5dB) i budi sretan |
#1896 |
Postovi: 1,128
hm , to mi se čini nerealno tak da ču i dalje ostati pri tome da situacija ima nekave veze sa kapacitetom amisa u mom kvartu , nešto su nadograđivali očito
#1897 |
Lokacija: agram
Postovi: 108
Ok ljudi, kako sam bio napisao promjenili su mi modulaciju ali ovo postaje naporno već malo stoga da pitam da li mi vidite nekakvo riješenje situacije ili način da sredim stvari ili kod sebe ili da zovem službu amisovu jer malko su mi preveliki skokovi u vezi da bi mogo bit miran: Stats: Link Information <table class="datatable" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td> </td><td width="30"></td><td width="220"></td><td width="50"></td></tr> <tr><td width="170">Uptime:</td><td colspan="3">1 day, 18:40:53</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Modulation:</td><td colspan="3">G.992.1 Annex B</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Bandwidth (Up/Down) [kbps/kbps]:</td><td colspan="3">899 / 8.826</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Data Transferred (Sent/Received) [GB/MB]:</td><td colspan="3">5,30 / 796,72</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Output Power (Up/Down) [dBm]:</td><td colspan="3">12,5 / 19,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Line Attenuation (Up/Down) [dB]:</td><td colspan="3">12,5 / 19,5</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">SN Margin (Up/Down) [dB]:</td><td colspan="3">20,0 / 8,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Vendor ID (Local/Remote):</td><td colspan="3">TMMB / BDCM</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Framing (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Signal (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Power (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Link (Remote):</td><td colspan="3">0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Error Seconds (Local/Remote):</td><td colspan="3">3 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">FEC Errors (Up/Down):</td><td colspan="3">0 / 1.920</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">CRC Errors (Up/Down):</td><td colspan="3">0 / 3</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">HEC Errors (Up/Down):</td><td colspan="3">0 / 1</td></tr></tbody></table>eh sad slikice sa speedtesta: Zg1 | zg2 ![]() mbr |mau ![]() nrbg |prs ![]()
Ak-khan-du NEX -------------------------------------------------- Let them die a violent death! |
#1898 |
Lokacija: Zagreb, Dubrava
Postovi: 502
ovo su moji detalji pa recite sta ne valja. <table class="datatable" width="100%" cellpadding="0" cellspacing="0"><tbody><tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Uptime:</td><td colspan="3">0 days, 9:57:59</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Modulation:</td><td colspan="3">G.992.1 Annex B</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Bandwidth (Up/Down) [kbps/kbps]:</td><td colspan="3">899 / 4.880</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Data Transferred (Sent/Received) [MB/GB]:</td><td colspan="3">648,45 / 4,39</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Output Power (Up/Down) [dBm]:</td><td colspan="3">13,0 / 19,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Line Attenuation (Up/Down) [dB]:</td><td colspan="3">31,5 / 35,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">SN Margin (Up/Down) [dB]:</td><td colspan="3">10,0 / 15,5</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Vendor ID (Local/Remote):</td><td colspan="3">TMMB / BDCM</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Framing (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Signal (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Power (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Link (Remote):</td><td colspan="3">0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Error Seconds (Local/Remote):</td><td colspan="3">4.786 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">FEC Errors (Up/Down):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">CRC Errors (Up/Down):</td><td colspan="3">0 / 1.903</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">HEC Errors (Up/Down):</td><td colspan="3">0 / 1.473</td></tr> </tbody></table> <script type="text/javascript">generateTasks()</script><hr> |
#1900 |
1oo1 NooB
Postovi: 1,306
#1901 |
Postovi: 683
Mozete li moju procijeniti ![]() <table class="datatable" width="100%" cellpadding="0" cellspacing="0"><tbody><tr> <td width="170">Uptime:</td> <td colspan="3">1 day, 22:06:25</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Modulation:</td> <td colspan="3">G.992.5 annex B</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Bandwidth (Up/Down) [kbps/kbps]:</td> <td colspan="3">767 / 3.071</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Data Transferred (Sent/Received) [MB/GB]:</td> <td colspan="3">405,65 / 5,36</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Output Power (Up/Down) [dBm]:</td> <td colspan="3">11,5 / 19,5</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Line Attenuation (Up/Down) [dB]:</td> <td colspan="3">9,5 / 14,5</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">SN Margin (Up/Down) [dB]:</td> <td colspan="3">20,0 / 31,0</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Vendor ID (Local/Remote):</td> <td colspan="3">TMMB / BDCM</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Loss of Framing (Local/Remote):</td> <td colspan="3">0 / 0</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Loss of Signal (Local/Remote):</td> <td colspan="3">0 / 0</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Loss of Power (Local/Remote):</td> <td colspan="3">0 / 0</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Loss of Link (Remote):</td> <td colspan="3">0</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">Error Seconds (Local/Remote):</td> <td colspan="3">3 / 0</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">FEC Errors (Up/Down):</td> <td colspan="3">0 / 0</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">CRC Errors (Up/Down):</td> <td colspan="3">4 / 605</td></tr> <tr> <td colspan="4" height="7"> </td></tr> <tr> <td width="170">HEC Errors (Up/Down):</td> <td colspan="3">350 / 222</td></tr></tbody></table> |
#1902 | |
1oo1 NooB
Postovi: 1,306
Malo se hvalimo ha? ![]() PS za slučaj da ne znaš - dobra parica!
#1903 | |
Postovi: 1,128
ateunacija je dost velika ali je sn margin stvarno dobar a broj errora je zanemariv , frendovi mi imaju milijune errora i niš se ne kuži kod surfanja i igranja
#1904 | |
upgrading...
Lokacija: Zagreb->G.Dubrava
Postovi: 438
a ako nista ne osjeti, mislim da ga bas nije briga kaj mu tu pise =) |
#1905 |
Postovi: 683
hm...fala, a zasto mi se spojio na 767/3MBit nešto ak sam uzeo 384/2MBit -a? |
#1906 |
Postovi: 1,128
zato jer amiši časte...
#1908 |
Postovi: 230
#1909 |
Postovi: 502
Zadnje izmijenjeno od: Litra. 10.09.2008. u 02:56. |
#1910 |
Lokacija: agram
Postovi: 108
#1911 |
Postovi: 15
Jao... Pa sječam se da je prije godinu dana bilo dovoljno da samo spojim svoj router u amisov, namjestim PPPoE i ugasim i upalim thompsona, ali sada ne želi pa sam pomislio da sam posenilio ![]() A i glupo mi je to da ih moram radi toga zvat... pa možda nakon testiranja poželim vratiti router mod pa ću ih opet morat zvat... samo kompliciraju ![]() |
#1912 |
lar~
Postovi: 1,557
#1913 | |
Postovi: 230
#1914 |
upgrading...
Postovi: 438
#1916 |
Uptime 99.99%
Postovi: 2,638
Pih vec sam mislio da se netko zali, postalo je dosadno u ovom topicu. ![]() Evo da ja napisem brzina USA > amis je pushiona.
#1917 |
Postovi: 1,128
amis je toliko dobar da su ljudi ostali bez riječi ![]()
#1918 |
Chipokemon
Postovi: 339
dobar je ![]() ALI, uvijek ima ali po meni moglo bi i bolje, bilo bi pametno i lijepo da oni sada već lagano počnu kopati po zagrebu tak da se pripreme za VDSL, jer sadašnja infrastruktura (parice), rastuće brzine i još iptv (kada krene) ne idu baš zajedno, a i ja bih osobno volio upload od 1mpbs za male pare ![]()
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment. -It`s what Jesus would do. |
#1920 |
1oo1 NooB
Postovi: 1,306
