Postovi: 69
Mozilla Firefox šteka sve u 16!
Prije tri dana firefox 3.0 je poceo zahebati.Stranice koje je normalno otvarao, normalne stranice poput novina, ne otvara nego javlja: Failed to Connect Firefox can't establish a connection to the server at Though the site seems valid, the browser was unable to establish a connection. Could the site be temporarily unavailable? Try again later. Are you unable to browse other sites? Check the computer's network connection. Is your computer or network protected by a firewall or proxy? Incorrect settings can interfere with Web browsing. .....kad otvori strašno šteka,mail od 200kb učitava više od 10 min,dok sam na netu zna se pojaviti nakon nekog vremena poruka: Connection Interrupted The connection to the server was reset while the page was loading. The network link was interrupted while negotiating a connection. Please try again. ......uglavnom,internet je odjedanput počeo jako štekati! Imam t-comov žični modem,adsl,ekipa iz tcoma kaže da je kod njih sve ok,nije ništa novo instalirano niti obrisano,firewall nemam-isključen.....pregledao sam ga NODom koji je našao WIN32/PRCVIEW.....spybotom S&D,ad-awareom,wise registry cleaner,cccleaner,super anti-spywareom, SmitfraudFixom,tune up utilities.....i sve ok i jednostavno ne znam zašto me internet zeza!?? Hvala svima koji pokušaju s bilo čim pomoći! ![]() Evo,kad sam se pokušao registrirati na forum opet je bacio poruku: Content Encoding Error The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression. Please contact the website owners to inform them of this problem. .....i onda je poslije primio kad sam kliknuo resend! ![]() ![]() |
Postovi: 34,112
Da li ti cijeli net šteka ili samo kad pokušaš FF-om? Ako šteka cijeli net, probaj s drugim routerom.
Postovi: 69
Za google chrome moram imati SP2,a to sad baš i ne mogu..... A nije da mi baš cijeli net šteka.....izgleda ko da je zagušen.....ne vjerujem da je router....ne znam... Hvala! |
N00B
Postovi: 3,886
@Naftaš jesu li IP,gateway DNS itd. na automatic postavljeni?Mislim da tebi zezaju tu DNS-ovi pa postavi manualno i u windowsima i u routeru pa vidi ima li poboljsanja.. |
#7 | ||
Postovi: 69
e kad bi ja to znao di,kako,šta...... ![]() al sam saznao da je,točno prije nego što je net počeo štekati,moj "dragi" brat ugasio komp kad mu se smrznuo! pretpostavljam da je upravo to poremetilo neke "tvorničke postavke"! a firefox 3.0 imam čim je izašao i sve je za 5 radilo tako da ne vjerujem da šteka zbog instalacija il nečeg sličnoga. Citiraj:
da,imam 512 al to mi je čist ok radilo do prije tri dana,radi čist ok već 3 godine,ne bi rekao da odjedanput ima rama veze...... ![]() i skužio sam da mi download ide ok,dok mi upload (ne)ide PREEEEEESPORO! EDIT BY MOD: Počni koristiti EDIT i MULTI-QUOTE tipke, a ne ostavljati više postova za redom. http://forum.pcekspert.com/showthread.php?t=29105 Zadnje izmijenjeno od: domy_os. 07.09.2008. u 14:14. |
#8 | |
N00B
Postovi: 3,886
Postovi: 69
evo ovo je na brzinu....poslije budem u profilu ![]() AMD Sepron 3000 processor+1800 Mhz, 64-bit AMD Athlon GEIL 512 RAM,DDR 400 BULK,128 cache NVIDIA GeForce FX 5500,256 MB,128 BIT Windows xp 120 HD,SEAGATE,BARRACUDA NVIDIA nForce Networking Controller - Packet Scheduler Miniport AsRock NVIDIA NFORCE3,2*DDR 400-1*AGP/8X/1.5GB...... Siemens USB ADSL A-100-I LAN Modem - Packet Scheduler Ak sam šta zaboravio pitaj.... EDIT: The web site does not support encryption for the page you are viewing.....to piše za sajtove koje ne može otvoriti.....random su sajtovi,nisu neki određeni! Mislim da ću ga ![]() ![]() ![]() ![]() EDIT BY MOD: Počni koristiti EDIT i MULTI-QUOTE tipke, a ne ostavljati više postova za redom. http://forum.pcekspert.com/showthread.php?t=29105 Zadnje izmijenjeno od: domy_os. 07.09.2008. u 14:15. |
Postovi: 19,018
Kažeš da je NOD nešto našao, ali je li to i obrisao? Lijepo updateaj NOD i namjesti ga ovako: ![]() Ponovi skeniranje i vidi je li može obrisati sve što nađe. Zatim skini VundoFix i njime isto skeniraj. Ako ti verzija 7 ne radi kako treba, skini 6.5.10. Ostale koji predlažu korištenje Google Chrome ili druge alternative molim da se ne javljaju jer to nije rješenje problema.
Postovi: 69
Ispričavam se za više postova,neće se ponoviti. Prvi put kad sam skenirao nodom ono što je našao je obrisao,jednu stvar nije obrisao (sumnjam da je to uzrok štekanja neta) ni sad kad sam postavio navedene postavke...... File F:\System Volume Information\_restore{B16D39F5-A613-451A-BFB4-8A9EE9738C87}\RP1\A0000309.exe is infected with application Win32/PrcView. The file can be deleted. It is strongly recommended that you back up any crucial data before you proceed. Našao sam ovu t-com stranicu http://www.t-com.hr/privatni/kzona/p...reske_wlan.asp (žično spajanje na router) i na ovoj četvrtoj slici ja nemam microsoft client net.....nego PPP over ethernet protocol (drugo je sve isto) I dolje na kraju se spominje pinganje koje mora biti Ping statistics for 192.168.1.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss).....a ja kad pingam preko carneta imam sent=4,recived=0, lost=100% ![]() ne znam uopće u čemu bi mogao biti problem jer nisam ništa radio što inače ne radim..... A što se tiče VundoFix to ne mogu skinuti jer mi na svakoj stranici s koje pokušam download firefox izbacuje onu obavijest iz prvog posta,tj.da se ne može spojiti. Upload ne mogu uopće izmjeriti. hvala svima! |
Postovi: 19,018
A kako ti je spojen modem? Preko USB-a ili UTP-a?
Zadnje izmijenjeno od: domy_os. 06.11.2011. u 15:54. |
Postovi: 69
usb ide iz routera u komp a modem ima 3 izlaza iz utp-a. istina,od telefonske utičnice do modema ima 10-ak metara kabla,ali on nije oštećen,i vjerojatno ne bi mogao nikako na net. VundoFix nije ništa našao.... |
Postovi: 19,018
Idemo ovako, spoji prvo neki drugi komp na taj modem pa vidi kako na njemu radi. Ako ga nemaš, prespoji modem na UTP, bootaj neku live distribuciju Linuxa i probaj njime. Nakon toga, ovisno o tvom odgovoru, ćemo vidjeti što dalje.
Lokacija: Samobor, HR
Postovi: 1,615
Može HijackThis log, nekako obožavam te logove ![]() Aj skini: http://www.download.com/Trend-Micro-...-10227353.html Instaliraj i preimenuj datoteku HijackThis.exe u Nesto.exe, pokreni, napravi log i copy-pastaj tu ![]() Pa da vidimo jel ima kaj ili nema, pa cemo dalje... |
#16 |
Postovi: 69
A komp drugi nemam....budem odnio komp i modem frendu,koji zna to malo bolje od mene, pa ćemo probati razne kombinacije. Hvala na pomoći , pa javim kak je prošlo. |
#17 | |
Postovi: 69
C:\WINDOWS\system32\csrss.exe C:\WINDOWS\system32\winlogon.exe C:\WINDOWS\system32\services.exe C:\WINDOWS\system32\lsass.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\Explorer.EXE C:\WINDOWS\system32\spoolsv.exe C:\Program Files\Netropa\Multimedia Keyboard\nhksrv.exe C:\Program Files\Eset\nod32krn.exe C:\WINDOWS\System32\nvsvc32.exe C:\Program Files\Spyware Doctor\sdhelp.exe C:\WINDOWS\System32\wdfmgr.exe D:\tipkovnica i mis 2\SetPoint\SetPoint.exe C:\Program Files\Common Files\Logitech\khalshared\KHALMNPR.EXE C:\Program Files\Mozilla Firefox\firefox.exe C:\WINDOWS\System32\svchost.exe C:\Program Files\Internet Explorer\Iexplore.exe C:\Program Files\Trend Micro\HijackThis\HijackThis.exe C:\WINDOWS\System32\wbem\wmiprvse.exe R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page = R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = T-Com Internet Explorer R3 - URLSearchHook: (no name) - {BC4FFE41-DE9F-46fa-B455-AAD49B9F9938} - (no file) O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll O2 - BHO: PCTools Site Guard - {5C8B2A36-3DB1-42A4-A3CB-D426709BBFEB} - C:\PROGRA~1\SPYWAR~1\tools\iesdsg.dll O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll O2 - BHO: PCTools Browser Monitor - {B56A7D7D-6927-48C8-A975-17DF180C71AC} - C:\PROGRA~1\SPYWAR~1\tools\iesdpb.dll O2 - BHO: EpsonToolBandKicker Class - {E99421FB-68DD-40F0-B4AC-B7027CAE2F1A} - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll O3 - Toolbar: EPSON Web-To-Page - {EE5D279F-081B-4404-994D-C6B60AAEBA6D} - C:\Program Files\EPSON\EPSON Web-To-Page\EPSON Web-To-Page.dll O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx O4 - HKLM\..\Run: [Logitech Hardware Abstraction Layer] KHALMNPR.EXE O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup O4 - HKLM\..\Run: [Kernel and Hardware Abstraction Layer] KHALMNPR.EXE O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'LOCAL SERVICE') O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'NETWORK SERVICE') O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM') O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user') O4 - Global Startup: Logitech SetPoint.lnk = ? O8 - Extra context menu item: &ICQ Toolbar Search - res://C:\Program Files\ICQToolbar\toolbaru.dll/SEARCH.HTML O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll O9 - Extra button: Spyware Doctor - {2D663D1A-8670-49D9-A1A5-4C56B4E14E84} - C:\PROGRA~1\SPYWAR~1\tools\iesdpb.dll O9 - Extra button: ICQ Lite - {B863453A-26C3-4e1f-A54D-A2CD196348E9} - C:\WINDOWS\System32\shdocvw.dll O9 - Extra 'Tools' menuitem: ICQ Lite - {B863453A-26C3-4e1f-A54D-A2CD196348E9} - C:\WINDOWS\System32\shdocvw.dll O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll O9 - Extra button: ICQ6 - {E59EB121-F339-4851-A3BA-FE49C35617C2} - C:\Program Files\ICQ6\ICQ.exe O9 - Extra 'Tools' menuitem: ICQ6 - {E59EB121-F339-4851-A3BA-FE49C35617C2} - C:\Program Files\ICQ6\ICQ.exe O9 - Extra button: T-Com - {6A6620C6-6F7C-4C6F-B270-28187829C86D} - C:\WINDOWS\System32\shdocvw.dll (HKCU) ostatak ne mogu uopće poslati! ![]() |
#18 |
Postovi: 69
......to je ostatak.....ispričavam se jedino sam ga tako uspio poslati. ![]() O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsu...?1134415209060 O17 - HKLM\System\CCS\Services\Tcpip\..\{D1E6F8E0-7EC6-466E-B667-52CD595D1962}: NameServer = 195.29.149.197 195.29.149.196 O18 - Protocol: bwfile-8876480 - {9462A756-7B47-47BC-8C80-C34B9B80B32B} - D:\tipkovnica i mis 2\Desktop Messenger\8876480\Program\GAPlugProtocol-8876480.dll O20 - Winlogon Notify: !SASWinLogon - F:\super anri spyware\SASWINLO.DLL O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe O23 - Service: Netropa NHK Server (nhksrv) - Unknown owner - C:\Program Files\Netropa\Multimedia Keyboard\nhksrv.exe O23 - Service: NOD32 Kernel Service (NOD32krn) - Eset - C:\Program Files\Eset\nod32krn.exe O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe O23 - Service: Sandra Data Service (SandraDataSrv) - SiSoftware - D:\SiSoftware Sandra Lite 2005.SR3\RpcDataSrv.exe O23 - Service: Sandra Service (SandraTheSrv) - SiSoftware - D:\SiSoftware Sandra Lite 2005.SR3\RpcSandraSrv.exe O23 - Service: PC Tools Spyware Doctor (SDhelper) - PC Tools Research Pty Ltd - C:\Program Files\Spyware Doctor\sdhelp.exe O23 - Service: TuneUp Drive Defrag Service (TuneUp.Defrag) - TuneUp Software GmbH - C:\WINDOWS\System32\TuneUpDefragService.exe |
#19 |
Postovi: 19,018
Mogao si to staviti i kao prilog...
#20 |
Postovi: 69
#23 | |
Postovi: 69
komp je izvrćen sa svim i svačim i sve je ok.... e kad bi znao šta me muči.... ![]() Ako je nešto u vezi modema,routera i toga dijela pa zar ne bi onda uopće mogao na internet!? Primjetio sam da mi prilikom povezivanja na internet javlja dvije greške: error 633 i error 692 .....i kad sam proguglao saznao sam da bi trebao reinstalirati modem,tj.drivere. Zadnje izmijenjeno od: naftaš. 08.09.2008. u 20:11. |
