Staro 13.08.2008., 11:54   #1
Func
Func's Avatar
Postovi: 483
Shared folder problem
Ovako. Mreža radi najnormalnije. Mogu pristupiti public folderu i remote desktop također radi. Problem se javlja kada hoću pristupiti sharing folderu.
Jedan kom je Vista Ultimate 64, drugi Vista Ultimate x86. Prčkao sam po firewallu, nije do toga. Za premision sam stavio Everyone i sve na alow.
U Network and Sharing Center mi je uključeno Network and Discovery i File sharing. Ostalo je na off. Također mreža je na privete. Postavke su indentične na jednom i drugom kompu.
Ima ko kakvu ideju?
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ...
Func je offline   Reply With Quote
Staro 13.08.2008., 12:44   #2
thopok
Lokacija: Splity
Postovi: 3,003
Check the permissions of the file or folder the file is saved in. Here's how:
1. Right-click the file or folder, and then click Properties.
2. Click the Security tab.
3. Under Group or user names, click your name to see the permissions you have.
To open a file, you need to have read permission.
Troubleshoot "access denied" when opening files or folders
Staro 13.08.2008., 16:53   #3
Func
Func's Avatar
Postovi: 483
Probao sam, neće.
Staro 13.08.2008., 20:15   #4
Joke
N00B
Joke's Avatar
Postovi: 3,886
Local security policy-->Local polices-->Security options-->i pod Network security:LAN Manager authencitacion level-->postavi "Send LM & NTLM - use NTLMv2 session security if negotiated"...
@Func koji je firewall u pitanju od windowsa ili?Ako je neki dodatni FW sta si stavljao provaj ga privremeno ugasitmpodesi sve opcije prema ovome http://forum.pcekspert.com/showpost....24&postcount=4 i ukljuci u visti ovu opciju Administartive tools-->Local security policy-->Local polices-->Security options-->i pod Network security:LAN Manager authencitacion level-->postavi "Send LM & NTLM - use NTLMv2 session security if negotiated"...
IE6
Linux is Not Windows
Staro 13.08.2008., 23:09   #5
Func
Func's Avatar
Postovi: 483
windows firewal, moram ga imati uključenog zbog reamote desktopa. Stvio sam natrag vistu 64, pa budem sutra javio da li radi. @thopok, @Joke hvala na savjetima.
Staro 15.08.2008., 12:04   #6
Func
Func's Avatar
Postovi: 483
Stavio natrag vistu x64 i sve radi normalno. Svejedno bi ju stavio nevezano za ovaj problem, zato što mi 32bit-na prepoznaje samo 2GB RAM-a.
