Staro 10.05.2004., 13:37   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
R300 Ruby Rap v1
Evo-nije dugo trebalo čekati
Za gledanje novog X800 dema trebate samo skinuti:
http://www.users.on.net/triforce/ruby/r300rubyrap.zip
i kratke upute:
http://www.users.on.net/triforce/ruby/r300readme.txt
System Requirements
Minimum:
128 MB Video Memory
512 MB System Memory
Recommended:
256 MB Video Memory
768 MB System Memory
Notes
This should work for all 128 MB Radeon 9500 and above cards.
A 128 MB card is REQUIRED! It will NOT run on 64 MB cards.
If you have a 128 MB card, you should have your AGP aperture size set to 256 MB. You should also change
resolution to 640x480 and multisampleType to 1 in Sushi.ini.
You 'really' need more than 512 MB of memory to run this other wise speed will probably be terrible, if it runs
at all.
Make sure your Antialiasing Settings in your Control Panel is set to Application
To decrease the size of the shaders so they would work on R300 class card, certain effects are now gone.
These include Depth of Field and many specular highlights. A future version may attempt to put these back in."
I da, demo je tu:
http://www.ati.com/developer/demos/rx800.html
130 mega.
Uživajte, nude patch je već u izradi
Staro 10.05.2004., 17:55   #2
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
upravo skidam pa ćemo da vidimo kak to zgleda
pinsla je offline   Reply With Quote
Staro 10.05.2004., 20:50   #3
pinsla
pinsla's Avatar
Postovi: 1,860
eto skinuo odgledao i zgleda ok
no ipak nije to ono pravo vjerojatno zgleda daleko bolje na x800 a to ćemo malo pričekati da i to vidimo nadam se da neću čekat predugo
baj d vej ne pokrećite bez skoro pa gige rama jer svapa inače i to opako
Staro 10.05.2004., 23:03   #4
Jelc
Super Moderators
Postovi: 17,485
Jesi dao grafi 256MB u BIOS-u kako traži?
Ja bum dobil demo sutra-prekosutra, a veli tip da to nije zadnja verzija wrappera, napravio je i da se može gledati i na FX-icama.
Samo je na njima sp-oro
Staro 11.05.2004., 00:10   #5
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
ma ja bum radje skinul video demo. jel ionak nemrem na svojoj vidjeti field depth kaj me najvise zanima. potraziti cu high resolutio filmek i uzivati. BTW Jelc ak nagavis demo daj bumo se nasli samo da vidim kak ce stekati na mojoj grafi.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 11.05.2004., 02:52   #6
pinsla
pinsla's Avatar
Postovi: 1,860
ma ne bi ni to pomoglo jer je u stroju bilo sam 512 megi a to je premalo
baj d vej nekak mi je čudno kaj se na fx-icama to sporo vrti a tebi??
Staro 11.05.2004., 13:39   #7
Jelc
Super Moderators
Postovi: 17,485
Jeeee...da se čovjek zamisli:burn:
A šupci iz Nvidie još ni nisu dali svoj demo u javnost, a baš lijepo izgleda...
Da ne bi bilo ko i zadnji put-da se brže vrtio na ATI-ju
Ma bilo je još dobrih wrappera i rendera po netu, sam kaj škvadra ne zna za to...npr. oko 150 mega OGL ATI render za UT, mrak izgleda...brz....
Još da mi je nekaj brže a ne 56k...
Staro 11.05.2004., 14:41   #8
ćiber_manija
CyberSky
ćiber_manija's Avatar
Datum registracije: Feb 2004
Lokacija: Jastrebarsko
Postovi: 1,168
Evo ja sam skinuo taj demo ali neznam di to treba iskopirati,pročito sam readme i dalje neznam
The šuma...
Staro 11.05.2004., 17:11   #9
Jelc
Super Moderators
Postovi: 17,485
A možda je autor mislo na-
Installation
Extract r300rubyrap.zip (with directories) to the "ATI Demos\DoubleCross" directory and you are done.
Staro 11.05.2004., 17:24   #10
pinsla
pinsla's Avatar
Postovi: 1,860
A čuj ak najdeš neke tak zanimljive stvari sam me upozori budemo se snašli
Staro 12.05.2004., 00:24   #11
Jelc
Super Moderators
Postovi: 17,485
A kaj bu ti GL render za UT kad samo pičiš po autekima i trkama?
Staro 12.05.2004., 01:40   #12
pinsla
pinsla's Avatar
Postovi: 1,860
a čuj ja sam znatiželjan kak kaj radi pogotovo na atijevkama
a i ne mora bit samo za UT bilo kakvi demoi i slično zna bit na netu super stvari sam kaj ja u zadnje vreme nemam baš vremena to poiskat
a kaj se tiče auteka ma pusti fakat ne znam kad sam nekaj zadnji put igral nema se cajta
al sa zato danas skinuo GTR press demo i zgleda fenomenalno
Staro 13.05.2004., 13:46   #13
ßellerophon
Sannin
ßellerophon's Avatar
Datum registracije: Jun 2003
Postovi: 1,568
ovaj... skinio sam mpeg ruby i snimka trokaje...
pa koliko je to zahtjevno???
YES - BUT /
Staro 13.05.2004., 15:12   #14
ozren
PC Ekspert
ozren's Avatar
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
Ruby demo je meni totalno bezveze... neovisno jel na X800 ili na romobilu...
Nissan GT-R Black Edition
ozren je offline   Reply With Quote
Staro 13.05.2004., 17:34   #15
Jelc
Super Moderators
Postovi: 17,485
Pa bar je vani ak ništ drugo
Onu njihovu sirenu nisam još našao za skidanje...
I nije bio topic hvalospjev o tom demu nego o mogućnosti pokretanja istog na starijem hardwareu
Staro 13.05.2004., 21:35   #16
pinsla
pinsla's Avatar
Postovi: 1,860
meni je odličan barem ono kaj sam vidio gde nisu svi efekti uključeni ali bih ga volio vidjet na x800
Staro 13.05.2004., 22:40   #17
Jelc
Super Moderators
Postovi: 17,485
Evo-probao i ja maloprije, ide fino
I bogme je velika razlika u brzini kad se grafi da 256 MB u BIOS-u.
Mislim-nije demo loš, ali da su ga mogli i bolje napraviti jesu...
Ona eksplozija je ko da je žaba prdnula
Dakle-kad se stavi 256 MB ide brže, tak i piše u uputstvu.
Bar je tak na mojoj 9800 NP flashanoj u PRO i na kraju silovanoj XT BIOS-om
Jadna grafa...
Staro 14.05.2004., 01:02   #18
pinsla
pinsla's Avatar
Postovi: 1,860
Jadna grafa...
ma čekaj dok ga vidiš na x800 to je čist nekaj drugo mislim eksplozija
Staro 15.05.2004., 13:35   #19
ßellerophon
Sannin
Postovi: 1,568
istina... -kad ce past cijene memorija pocinjem ozbiljno razmisljat o kupnji jos jedno 512mb....
YES - BUT /
