#1651 |
Postovi: 87
Danas ujutro sam poslao mejl i dobio odgovor, s tim da je mejl isti osim ovog dijela: Stoga, kao ulog u uspješnu dugotrajnu suradnju, tijekom srpnja povećat ćemo Vam (ovisno o kvaliteti Vaše parice) brzinu korištenja naše usluge na brzinu do 4Mbps, a po cijeni koju ste ugovorom odabrali. Nadam se da to nece bit krajem mjeseca ![]() |
#1652 |
bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Ma biti ce ti za 2 dana cca ....
#1653 | |
Postovi: 15
Jesam li ja jedini koji ne zna kako doči do ovih podataka gore ? ![]() |
#1654 |
1oo1 NooB
Postovi: 1,306
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. |
#1656 | |
Postovi: 15
Hvala.Eto što kaže moj "details" <table class="datatable" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td width="170">Modulation:</td><td colspan="3">G.992.1 Annex B</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Bandwidth (Up/Down) [kbps/kbps]:</td><td colspan="3">899 / 4.880</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Data Transferred (Sent/Received) [MB/MB]:</td><td colspan="3">457,03 / 28,30</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Output Power (Up/Down) [dBm]:</td><td colspan="3">13,0 / 13,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Line Attenuation (Up/Down) [dB]:</td><td colspan="3">7,0 / 11,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">SN Margin (Up/Down) [dB]:</td><td colspan="3">26,0 / 20,0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Vendor ID (Local/Remote):</td><td colspan="3">TMMB / BDCM</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Framing (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Signal (Local/Remote):</td><td colspan="3">2 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Power (Local/Remote):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Loss of Link (Remote):</td><td colspan="3">0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">Error Seconds (Local/Remote):</td><td colspan="3">38 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">FEC Errors (Up/Down):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">CRC Errors (Up/Down):</td><td colspan="3">0 / 0</td></tr> <tr><td colspan="4" height="7"> </td></tr> <tr><td width="170">HEC Errors (Up/Down):</td><td colspan="3">0 / 0</td></tr></tbody></table> |
#1657 |
Postovi: 2,723
Došao kući prije 2h i Amis ne radi. Radi ping prema carnetu i par naših stranica (tipa HGSpot). Isto, Ping prema Amisu prolazi, i bit će da je link iz Amisa prema dalje u banani. Eno, morao sam laptop upalit pa na HSDPA/UMTS... Ima još ili je to samo meni?
MMA Zadnje izmijenjeno od: Sa_Stilom. 04.07.2008. u 21:32. |
#1658 |
Postovi: 144
Pisem ovo sa moba, wnw usluga. Amis ne radi ni meni, ali pazi www.isvu.hr radi (Bono nemoj se smijati) |
#1659 |
Postovi: 2,723
sve sto ima neku vezu s Carnetom radi... Jel ko uspio dobit Korisničku? Prvi put sam slušao muziku 11min, pa odustao, a sad odmah izbaci kad pokušam nazvati korisničku. Dali itko ima info što se događa?
MMA |
#1660 |
Uptime 99.99%
Postovi: 2,761
Evo sad radi, izgleda da im je pukao link iz hr prema sloveniji. Zato sam inzistirao na CIX-u bar su radile stranice od clanica CIX-a, kad im se ovako nesto dogodi. Ja sam probao zvati i svaki puta je bilo zauzeto znaci da su iskljucili telefone, vrlo profesionalno nema sta. To je kod T-coma zgodni detalj samo naprave glasovnu poruku da imaju problema sa linkom i to je to, a ne se ovako skrivati. EDIT: evo pise na newsima da im je nepoznati pocinitelj namjerno presjekao kabel, sta god to znacilo. |
#1661 |
Postovi: 2,660
I ja sam uzaludno pokušavao dobiti SZK. Kod mene nije bilo neta negdje od 18:30 do 22:40. Ne znam zbog čega ali nikaj nije radilo na netu... Bit će da smo s ovim mailovima za povećanje brzine syebali amis ![]()
#1663 |
Postovi: 144
Jos jedan kojem ne radi. |
#1664 |
Postovi: 2,723
Radilo mi je oko 23.30h na 10min i onda ništa. Evo jutros i dalje ne radi a korisničku ne mogu dobit, jer se ne žele javiti. Sada mi ne radi ni ping na carnet.... jedino pingam amis.hr
MMA |
#1666 |
Postovi: 144
Ja ni preko wlana, osim susjedovog, ali ne znam wep key |
#1667 | |
bycod
Postovi: 6,699
""od jucer od 18h nemam interneta, svaki pokusaj zvanja szk zavrsavao je odjebom ili ti zauzetim tonom. jucer u 22h sam nazvao szk i cekao prvo 17minuta sa mobitelom (jer sa fiksnim telefonom bi se odma veza prekinula) i onda u 23h 46minuta sa fiksnoga telefona. ja neam pojma kakvih vi problema imate al nabijem na kurac vasu sluzbu za korisnike jer kakvi god problemi bili bilo bi jebeno uredu bar se javiti na telefon da se zna sta je. ali ne lakse se nejaviti na telefon da nebude greske zvao sam i 0800 50 10 i 062 100105.""
#1668 |
Postovi: 2,723
Ono što mi je smiješno da su oni nesposobni ukoliko se sranje dogodi u petak... Kreteni jesu i to teški... Nebi niš ni rekao na njihovu podršku koja je da ne kažem kakva, da im barem onda na webu stoji neki note, ili nešto tipa "SEMAFOR"...
MMA Zadnje izmijenjeno od: Sa_Stilom. 05.07.2008. u 14:29. |
#1669 |
Postovi: 2,723
Ev Raadiiiii! PSM!!! ![]()
MMA |
#1671 |
1oo1 NooB
Postovi: 1,306
Ja jučer (oko 14:00) igram COD2 online i dobijem connection interupt. Pogledam ASE ono svi serveri down, pogledam firefox - ne može na home page - probam restartat modem a ono ne mogu se više spojit. Nazovem odma SZK pitam čovjeka da li im je pao net on veli samo malo i 10 sec kasnije mi veli da mora provjerit i da će me nazvat. Ja več kužim da im je opet pao link prema deželi ali je čovjeku u SZK trebalo sat vremena da me nazove i veli da imaju tehnički problem (ne zna točno kojih ) i da će me nazvat kad proradi - velim ja OK ne treba me zvat bum več videl kad bu net proradil.Danas upalim komp oko 12h i sve radi - velim dobro samo jedan dan nije radio ali da imam posao vezan za net svega bi bilo uključujuči moj odlazak u Buzin da im malo.....![]() Jedini svijetli trenutak - danas oko pol dva nazove me Danijela ( ) da provjeri dal je sve u redu - velim ja sve pet ![]() Sad sam se sjetio da dok sam igrao COD2 nešto mi je bilo čudno - ono velim svi čiteri na serveru - ubijaju me prije nego me vide, pogibam od bombi kojih nema , meni treba skladište municije da ubijem nekog - pogledam ping - 35ms ![]() Uglavnom kao da mi je igra kasnila 2-3 sekunde - valjda je u tom trenutku rikavao polagano net..................
#1672 |
Hejter
Postovi: 6,521
Dugo nije radilo , sad srecom opet radi , zvao sam i bio ful nabrijan ali covjek mi se javio me se dojmio u svom poniznom nastupu i nisam imao srca napasti ga , pa on sa tim ima veze isto kao i blagajnik na ini sa cijenom benge , nadam se da vise necu biti problema bar danas i sutra dok nesto ne obavim preko neta ![]() |
#1673 |
Postovi: 171
Ma sad radi, ali sam se naživcirao s njihovom SZK. Zanimljiv način kako se rješiti navale ljudi, iskopčat telefon ![]() E da o kakvom vi povećanju brzine pričate? To ovo kaj su dizali samo adsl ili ima nekaj i s 2u1 uslugom? |
#1674 |
upgrading...
Lokacija: Zagreb->G.Dubrava
Postovi: 438
meni nije radilo od jucer navecer, barem do 13:00, ali se nisam ni trudio zvati szk jer sam isao iz kuce i nadao se da ce sve rjesiti dok se vratim, i sad radi, bolje im je, osjecam se ko paraliziran kad dodjem doma a net ne radi ![]() |
#1675 |
Postovi: 2,723
the same... A jesmo ovisnici o internetu ![]()
MMA |
#1676 |
Postovi: 171
#1677 |
Postovi: 2,723
Zato ja imam lap i VMC al yebga, s VMC nemrem halat CSS ![]()
MMA |
#1678 |
bycod
Postovi: 6,699
ma meni je puko film kad su "iskopcali" telefone szk mislim kakav je to odnos da nisam danas isao raditi otisao bi do buzina onak rekreativno.... kuzim moze biti milijun problema al zato postoji szk da sere kak ce sve rijesiti brzo i to... uglavnom veliki minus za njih sa tim potezom....
#1679 |
Postovi: 171
#1680 |
1oo1 NooB
Postovi: 1,306
