Postovi: 19,014
Catalyst 8.6
Evo i ova verzija je vani... ![]() Download: http://game.amd.com/us-en/drivers_catalyst.aspx Release Notes: https://a248.e.akamai.net/f/674/9206...ase_notes.html Citiram: Catalyst Install enhancement - No reboot required after Catalyst upgrade install This release of Catalyst™ introduces an enhancement to the Catalyst installer. Users are no longer required to reboot their system after Catalyst has finished installing (as long as the installation is an upgrade from a previous Catalyst install). Performance Improvements The following performance gains are noticed with this release of Catalyst™. * 3DMark Vantage:10 to 15% gains across all Radeon™ HD 3xxx and HD 2xxx products, with larger gains in specific cases. * Call of Duty 4: Performance increases across all Radeon™ HD 3xxx and HD 2xxx products, with gains as large as 35% in specific maps. * Call of Juarez DX10: Performance increases between 2 and 9% across all HD 3xxx and HD 2xxx products * Company of Heroes (DX10 version): Performance increases between 4 and 10% across HD 36xx and HD 34xx products. * Lost Planet (DX10 version): Performance increases by 1 or 2 fps across all HD 3xxx and HD 2xxx products, creating in some cases up to 20% increase. * Lost Planet (DX9 version): Performance increases between 2 and 20% across all HD 3xxx and HD 2xxx products * Prey OpenGL: 3-5% gains across HD 3xxx and HD 2xxx products. * Quake 4 OpenGL: Up to 8% increase across all HD 3xxx and HD 2xxx products. * Shadermark 2.1: Minor improvements across all HD 3xxx and HD 2xxx products, with the largest gains appearing on HD 3650 (up to 9%) * ViewPerf 10: Substantial performance improvements across several of the sub-tests, with the largest gains in ugnx (up to 55%), catia (up to 17%) and tcvis (up to 10%) across all of the HD 3xxx and HD 2xxx products.
Lokacija: N/A
Postovi: 773
ajde ako je ko isprobao javite kakvo je realno stanje, a ne ove marketinske finte iz release notea... da vidim da li cu se konacno maknuti sa 8.3... ![]() |
Postovi: 469
uninstaliraj 8.3, ocisti sve sa driver cleanerom i instaliraj ... ja uredno stavim nove drivere svaki puta kad izadju, imao sam problema samo sa 8.1 verzijom sve poslje su radile bez greske ... stavit cu danas kad dodjem doma s posla (oko 5 popodne) ovu novu 8.6 verziju pa javim kak je proslo ako netko vec prije ne instalira |
Postovi: 993
COd4 35% u određenim mapama ako je to istina ![]() |
#6 | |
Lokacija: N/A
Postovi: 773
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
#10 | |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
EDIT: Boogie, poslao sam ti PM.
"Everything with a heartbeat can knock you down" Zadnje izmijenjeno od: Vuco. 19.06.2008. u 17:28. |
Lokacija: Sarajevo-Mostar-Bugojno
Postovi: 227
Postovi: 469
instaliran 8.6 sve radi kako treba za sad, nema nikakvih problema, ne mjesaju se boje u firefoxu i nema kvadratica u lijevom gorenjem cosku monitora, promjenjen je welcome screen kad palite catalyst ![]() |
Postovi: 9,069
* Call of Duty 4: Performance increases across all Radeon™ HD 3xxx and HD 2xxx products, with gains as large as 35% in specific maps. Zbilja je tako. Overgrown, Backlot, Bog - osjetno poboljsanje.
___________ Just atha x |
Postovi: 8,687
instaliran 8.6 U GRIDu kod upaljenog 4xmaa boje na autu u meniju su izmiješane, a utrku uopće ne prikazuje. Kod isključenog maa, sve u redu u meniju, a u igri me izbaci nakon pola minute sa porukom "ATI VPU recover: gpu has recovered bla bla bla..." |
#20 |
Postovi: 9,069
#21 | |
Postovi: 8,687
Doduše grafa je OC-ana sa 825/900 na 855/955, možda i to uzrokuje kakve nestabilnosti iako mi je čudno jer drugdje je sve u redu... |
#22 |
Lokacija: Varazdin
Postovi: 253
Hm, prije ovih drivera sa novom grafom (3850 512) mi je u cod4 znalo tako zatrokati da mi se slika zaustavila na 2-3 sekunde, a sa njima je sad ok. Jedino na desktopu desni klik mi je prespor, cekam cca 3-5sec da se pojavi onaj prozorčić.
Pošteni trgovac: 17/17 |
#23 |
Postovi: 417
* Call of Duty 4: Performance increases across all Radeon™ HD 3xxx and HD 2xxx products, with gains as large as 35% in specific maps. bojim se da ti za 1600pro driveri ne mogu driveri puno pomoći ![]() . .. stavio i ove catalyste kao i sve prethodne redom i opet ne osjetim nikakvo bitno poboljšanje u igrama, ali ni pogoršanje, pa su valjda ok ![]() |
#25 |
Postovi: 763
Opa nadam se da je ono istina za CoD4 ![]() |
#27 |
Postovi: 34,109
Mogu se i sad skinuti posebno. Samo treba pažljivo čitati. Optional Downloads:
#28 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Bio sam tu i gledao, citao, ali kad su potrefili "super" kombinaciju boja... crveno na crnom a to k... ne vidim sta pise. Enivej, tnx. Ubuduce cu morat bit 2cm od monitora da mogu procitat bilo sta na toj glupoj stranici...
#29 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,007
O čemu ti briješ, pa to je najkontrastnija moguća kombinacija boja i sve se lijepo vidi |
#30 |
MadModerator
Lokacija: N/A
Postovi: 5,195
