Staro 03.05.2008., 20:03   #31
Razer
Razer's Avatar
Postovi: 11,642
Dođem za pola sata, i opet me šokira sa slikom od 300kb+
Staro 03.05.2008., 22:34   #32
Shamanix
Shamanix's Avatar
Postovi: 870
Hmmm.. Zanimljivo..
Evo procesor na 3.4GHz, GPU score je cak veci nego kad je proc na 4GHz
Svidja mi se novi nacin ocjenjivanja, cini mi se najobjektivniji do sada i fino mozes vidjeti gdje ti je usko grlo..
Shamanix je offline   Reply With Quote
Staro 04.05.2008., 16:20   #33
nino
nino's Avatar
Postovi: 12,613
Booo, jel treba nes podesavat?
Edit: Grafa default, proc na 3,0, mema 1066.
Staro 04.05.2008., 16:21   #34
maX
maX's Avatar
Postovi: 7,326
to sve na defaultu ili? nekak mi se cini slab score...
edit: i sitno poboljsanje je bitno
Zadnje izmijenjeno od: maX. 04.05.2008. u 21:40.
Staro 04.05.2008., 22:33   #35
danc00
Why so serious
danc00's Avatar
Postovi: 3,417
Autor nino Pregled postova
Probaj stavit onaj hotfix za ati, dobiš podosta veći skor!
danc00 je offline   Reply With Quote
Staro 09.05.2008., 00:17   #36
Darude
DJ_Darude kicks ass...
Darude's Avatar
Lokacija: Virovitica
Postovi: 213
..:: Vlak je uvijek brži ::..
Darude je offline   Reply With Quote
Staro 23.05.2008., 16:42   #37
Razer
Razer's Avatar
Postovi: 11,642
Izašao manji update Vantagea:
3DMark Vantage Build 1.0.1 Hotfix
Changelog:
Hotfix For 3Dmark Vantage - Futuremarn have made changes in the product editions to better serve our customers. Off-line score is now available in the Advanced edition, and ad banners have been removed. Error messages have been improved, and various bugs have been fixed.
Note: The scores are NOT affected by this hotfix, and will remain compatible with build 1.0.0 scores.
If you have previously installed the 1.0.0 version of 3DMark Vantage, you can use the smaller Hotfix installer to update to version 1.0.1. Just follow the installation instructions on screen.
If you have not previously installed 3DMark Vantage, you need the full installer package. Run the installer, and follow the instructions on screen.
IMPORTANT: We recommend that you only install 3DMark Vantage using a user account that has Administrator rights on the machine. Installing 3DMark Vantage as a Standard User on Vista is not recommended. Cases where the user has Standard User rights only, and User Account Control (UAC) turned off are specifically not supported, and will not work.
If you have previously installed 3DMark Vantage with Standard User rights, and have any trouble installing the hotfix, please un-install 3DMark Vantage, and re-install using the full installer, using a user account that has Administrator rights on the system.
After the installation, 3DMark Vantage may ask you again for your serial key. Please enter it as previously.
The hotfix updates the following:
* Off-line score viewing is now available in the Advanced Edition.
* Score save / submit saved options are now available in the Advanced Edition.
* Ad banners have been removed from all editions.
* Added a "SEND ERROR" button to error messages; clicking this will send detailed error information to Futuremark for better bug tracking and fixing. No personally identifiable information will be sent or stored.
The hotfix fixes the following:
* An issue preventing valid serial key entry in some cases has been fixed.
* An issue causing "boost::filesystem::create_directory" error message after registration has been fixed.
* Added a check and error message for hardware that is not DX10 capable.
* Improved detection of supported resolutions so that CPU test minimum requirement (1280x1024) is now taken into account correctly.
* Fixed an issue where pressing the ESC key during CPU test loading screen, the user would be taken to a score view with score -1.
* The entire 3DMark Vantage application is now elevated to Administrator rights, rather than only the SystemInfo component. This will ensure more robust SystemInfo and benchmark functionality, and fixes the "pop-behind" elevation dialog.
* Fixed an issue that sometimes caused "WM_QUIT" error messages.
* Post-processing scale is now displayed correctly in the UI for the Extreme Preset.
* Fixed an issue that could cause resolution switches at test runtime.
Notes:The scores are NOT affected by this hotfix, and will remain compatible with build 1.0.0 scores.
Download
Staro 31.05.2008., 14:17   #38
Igneos79
Datum registracije: Mar 2008
Postovi: 328
Evo i moj scor, sa hotfixom instaliranim...nevjerojatno koliko mi je grafa slaba u odnosu na proc...
Igneos79 je offline   Reply With Quote
Staro 31.05.2008., 22:25   #39
Func
Func's Avatar
Postovi: 483
Nabavio konačno novi 3d čmark, Score: 14449
Q6600 @ 3.55/2x9800 GX2 Quad SLI stock, bez OC
Some say that he's Mac compatible, and that he once punched a horse to the floor. All we know is, he's called The ...
Func je offline   Reply With Quote
Staro 01.06.2008., 08:28   #40
Igneos79
Postovi: 328
Autor Func Pregled postova
Uh, ajde klokaj te grafe koliko idu, bas me zanima mozes li se pribliziti najbrzem po grafici....covjece, prvi test mi se vrti na 5 fpsa, a tebi na 42. Definitivno kupujem sebi jednu gt280 kad izadje....
Staro 01.06.2008., 20:05   #41
Func
Func's Avatar
Postovi: 483
Evo s laganim OC grafa 742/1048/1855. Neda mi se sad tražiti granicu za grafe, to ću za top listu. Score: 15117
Staro 01.06.2008., 20:08   #42
Razer
Razer's Avatar
Postovi: 11,642
Veći rezultat ćeš prije dobiti sa većim taktom procesora, ako je to moguće u tvom slučaju...
Staro 01.06.2008., 20:12   #43
Func
Func's Avatar
Postovi: 483
Autor Razer Pregled postova
Može nekak na 3.8, ali se zruši u occt-u nakon pola sata. Vjerojatno bi izdržao 3d čmark.
Staro 01.06.2008., 20:16   #44
Razer
Razer's Avatar
Postovi: 11,642
Vjerujem da bi bilo moguće.
Staro 01.06.2008., 21:17   #45
Func
Func's Avatar
Postovi: 483
Ovako, Q6600 na 3.8GHz, 2x9800GX2 na 742/1048/1855 Score: 16098. Nije baš neki pomak u odnosu na prijašnje rezultate, a to bi bio i neki maksimum. Moglo bi se možda još nabiti kojih 200, 300 marksa.
Staro 01.06.2008., 21:24   #46
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Pa s obzirom da je Vantage škrt sa bodovima, nije baš mal pomak
Staro 01.06.2008., 21:28   #47
Razer
Razer's Avatar
Postovi: 11,642
Na kojoj postavci to vrtiš? Performance?
Staro 01.06.2008., 21:29   #48
Func
Func's Avatar
Postovi: 483
Da, performance.
Staro 01.06.2008., 21:31   #49
Razer
Razer's Avatar
Postovi: 11,642
Koliki ti je rezultat na tim postavkama u 3DM06 u 1280?
Razmišljao sam da otvorim jedan thread (za '06) za one koji imaju SLI/CF, kako bi svi vrtili na nekoj većoj rezi tipa 16xx...
Staro 01.06.2008., 21:37   #50
Func
Func's Avatar
Postovi: 483
Negdje od 17 000 - 18 000 na 1280, sa procom na 3.55. Ne sječam se točno. Budem zvrtio, pa javim.
Na 1280: 18587, a na 1920: 18019. Stavio sam SS u 3DMark06 rezultati.
Zadnje izmijenjeno od: Func. 01.06.2008. u 22:25.
Staro 01.06.2008., 21:56   #51
Igneos79
Postovi: 328
Na Orbu se ne vidi koja marka su gpu ovog najjaceg rezultata. Zanima me kako je on dobio toliko veci skor? Voltmod?
Staro 01.06.2008., 21:57   #52
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
+ extremno hladenje
Staro 01.06.2008., 21:58   #53
Razer
Razer's Avatar
Postovi: 11,642
''Marka'' kartice u tom slučaju nema nikakve veze.
Taj rezultat je postignut žešćim OC-em (i modanjem, naravno) pri niskim temperaturama (čitaj: LN2).
Staro 02.06.2008., 14:19   #54
Igneos79
Postovi: 328
Off Topic:
Naletjeh na voltmod guide na netu, sve fino objasnjeno sa slikicama, pa mi je palo na pamet da se nisam davno uhvatio lemilice, a imam jednu ful malu, bas za te svrhe ....pa kad kupim novu karticu, moddati ovu staru. Sinoc se igrah sa nibitorom da vidim moze li se softverski. Prvo, vista 64 bit je problem, cak i sa iskljucenim driver signingom pri bootu, drugo, treba imati floppy, koji nemam. No dobro, mogao bih iskoristiti usb hdd za tu svrhu, samo ne znam gdje cu sa 120 giga podataka na njemu ....i trece, nibitor ne da da dizem voltazu vise od 1.3 V, pokazuje samo upitnik, a bogme niti da otkljucam jos koji pipeline...jedina korist je mogucnost mijenjanja tajminga memorije. No koliko je to pametno, ostaje upitno. Kaze neki lik na netu da se moze staviti bios od drugog prozvodjaca grafe i da je on postigao odlican uspjeh sa biosom od XFX XXX kartice. Naravno, radi se o 8800 GTS 320, za druge nisam citao.... Sto kazes, Razor? Jel pametno uopce se backati s tim?
Staro 02.06.2008., 22:40   #55
Razer
Razer's Avatar
Postovi: 11,642
Ne, nije pametno, tj nema potrebe. Preko BIOS-a nećeš uspjeti dići voltažu ili ''otključati'' shader jedinice na GTS 320/640 karticama.
Staro 02.06.2008., 23:55   #56
Igneos79
Postovi: 328
Evo, s novim drajverima....
Dojava: pise na orbu da je izasla novija verzija vantagea
Zadnje izmijenjeno od: Igneos79. 03.06.2008. u 00:38. Razlog: dojava
Staro 20.06.2008., 21:39   #57
vorda22
http://img517.imageshack.us/my.php?image=3dxr2.jpg
evo i jedan i drugi na istim postavkama...nikak do 20k na 06 :P
hm kak da stavim da se slika pokaze :S
Staro 25.06.2008., 19:13   #58
xPsycho
xPsycho's Avatar
Postovi: 964
evo i ja isprobao ovo cudo
mislim da nije lose s obzirom da grafa nije clockana
Zadnje izmijenjeno od: xPsycho. 25.06.2008. u 21:05.
xPsycho je offline   Reply With Quote
Staro 25.06.2008., 20:58   #59
2145
o.O
2145's Avatar
Postovi: 154
Autor xPsycho Pregled postova
To je s ovim novim physx driverima koji "varaju" na CPU testu ili?
Moj score sa 3870 (800/2400), 8.6 driveri i cpu na 3,1: 4540 bodova
ORB
2145 je offline   Reply With Quote
Staro 25.06.2008., 21:04   #60
xPsycho
xPsycho's Avatar
Postovi: 964
Autor 2145 Pregled postova
mrs izdajico
ma nije to varanje to je samo jedna dobra ideja od strane nvidie
