Staro 16.04.2008., 22:46   #1
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Stigao 8.4
http://game.amd.com/us-en/drivers_ca...=xp/radeonx-xp
https://a248.e.akamai.net/f/674/9206...ase_notes.html
Da ne kopipejstam gomilu teksta
Ništa spektakularno ovaj put, izgleda
Staro 16.04.2008., 23:00   #2
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
izasla je 8.4 i za linux
danij3l je offline   Reply With Quote
Staro 16.04.2008., 23:02   #3
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Evo da se malo ispravim, nije baš da nisu ništa radili, ova verzija je 10MB manja!
Staro 16.04.2008., 23:24   #4
Hektor
Postovi: 82
Preuzeo još jučer preko Windows update servisa.
Hektor je offline   Reply With Quote
Staro 16.04.2008., 23:36   #5
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Autor Hektor Pregled postova
Blago tebi, meni nudi 8.1 tamo
Staro 17.04.2008., 01:04   #6
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
Company of Heroes: Setting the in-game options to maximum levels no longer results in the game exiting to the desktop after the game has completed loading. Further details can be found in topic number 737-32600
Crysis: Setting the Catalyst™ Control Center->Advanced View->3D->Standard Settings to Optimal Quality and having certain in game option settings no longer results in the game failing to render properly. Further details can be found in topic number 737-33395
Doom 3: Setting the in game options to Ultra Quality and the screen size to 1600x1200 no longer results in the image next to the text failing to be rendered. Further details can be found in topic number 737-32603
Hellgate: London: Flickering is no longer noticed when quitting and then relaunching the game when the in-game setting are set to their maximum levels. Further details can be found in topic number 737-32604
Lost Planet: Setting AA to either 4x or 8x no longer results in the game failing to respond. Further details can be found in topic number 737-28492
Tabula Rasa: Setting the graphics option to enable Deferred Lighting and Dynamic Shadows no longer results in corruption being displayed. Further details can be found in topic number 737-32597
Tomb Raider Anniversary: Performance improvements are now noticed when playing the game with CrossFire™ enabled. Further details can be found in topic number 737-32598
Playing a game that uses the Unreal Engine 3.0 no longer results in AA setting not having any effect on the game when CrossFire is enabled. Further details can be found in topic number 737-33384
The Windows Vista operating system no longer fails to respond when running the Auto-tune utility found in the Catalyst™ Control Center OverDrive™ option. Further details can be found in topic number 737-30584
Using the pound key (#) as the first character in the user name no longer results in an error when installing the Catalyst™ Control Center. Further details can be found in topic number 737-31578
The color depth no longer changes to 8 bpp when enabling or disabling CrossFire™ for the first time. Further details can be found in topic number 737-31580
Display corruption is no longer noticed when enabling CrossFire™ on a system containing an ATI Radeon™ X1900/1950 series of product when the display resolution is set to 1600x1200 70Hz and running a 3D application in full screen mode. Further details can be found in topic number 737-31582
Connecting a TV as a secondary display device no longer results in extended desktop mode failing to become active. Further details can be found in topic number 737-32659
Flashes of white lines are no longer noticed when quickly moving windows around the Vista desktop. Further details can be found in topic number 737-32660
Momentary flicker is no longer noticed when rotating the display device. Further details can be found in topic number 737-32661
Hot plugging an HDMI display device to a system running Windows Vista (32 or 64 bit version) no longer results in the HDMI display device being detected as a DTV (DVI) device. Further details can be found in topic number 737-32593
The signal on HDTV TV is no longer displayed as 480p60 after setting the format to 576i25/576p50 in clone mode. Further details can be found in topic number 737-32662
A warning message no longer fails to appear when using an inappropriate DVI-HDMI adapter. Further details can be found in topic number 737-32596
Attempting to perform a silent install of the display driver on a system running Traditional Chinese version of Windows Vista no longer results in an error message being displayed and the display drivers failing to be installed. Further details can be found in topic number 737-32601
Catalyst™ Control Center->Display Properties->Settings tab->Advanced: The adapter information is no longer displayed as ATI Display Adapter instead of the actual product name. Further details can be found in topic number 737-32602
Enabling extended desktop mode followed by swapping the primary and secondary display devices no longer results in all running applications to be displayed on the primary display device. Further details can be found in topic number 737-32607
Enabling or disabling CrossFire no longer results in the HydraGrid settings failing to be retained. This issue may also be experienced under the Windows XP and Windows XP Professional x64 Edition operating systems. Further details can be found in topic number 737-32609
Exiting a full screen D3D application no longer results in some of the other running applications failing to retain their current HydarGrid location. This issue may also be experienced under the Windows XP and Windows XP Professional x64 Edition operating systems. Further details can be found in topic number 737-32612
An incorrect message is no longer displayed when resuming from an S3 state when extended desktop mode is enabled. Further details can be found in topic number 737-33374
Enabling Overlay Theatre Mode while a movie is playing no longer results in the secondary display device displaying a black screen when extended desk mode is enabled. Further details can be found in topic number 737-33375
Connecting a secondary display device and setting the display resolution to 1280x800 or greater no longer results in corruption being noticed when attempting to enable extended desktop mode. Further details can be found in topic number 737-33376
Playing a Blu-ray or HD DVD title using the Cyberlink PowerDVD 7.3 no longer results in an error message being displayed. Further details can be found in topic number 737-33377
Using MCE to view TV no longer results in the Vista operating system (32 bit version) failing to respond when resuming from an S3 state. Further details can be found in topic number 737-33378
Intermittent corruption when switching between an LCD display device and an HDMI TV no longer occurs. Further details can be found in topic number 737-33379
Connecting an HDMI display device no longer results in an extra longer time being noticed when attempting to switch between the LCD display device and the HDMI display device. Further details can be found in topic number 737-33382
Corruption is no longer noticed on the Windows Vista desktop when playing a DVD title when using the Windows Media Player. Further details can be found in topic number 737-33383
Connecting an HDTV using the HDMI port on a system containing an ATI Radeon™ HD 3100/3200 series of product no longer results the LCD display device failing when hot-unplugging the HDTV. Further details can be found in topic number 737-33384
Staro 17.04.2008., 01:04   #7
Jelc
Super Moderators
Postovi: 17,485
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
3DMark05/06: A performance drop is no longer noticed when running the benchmark under Windows XP. Further details can be found in topic number 737-33497
Setting the language option to any supported language other than English no longer results in the Help file for Configure and Diagnostics failing to appear. Further details can be found in topic number 737-32605
Setting the language option to Russian for the Catalyst™ Control Center no longer results in some text being cropped for the secondary display device in the display properties. Further details can be found in topic number 737-32663
Setting the language option to German for the Catalyst™ Control Center no longer results in some translation errors being noticed through-out the Catalyst™ Control Center. Further details can be found in topic number 737-32664
Setting the language option to French for the Catalyst™ Control Center no longer results in some translation errors being noticed through-out the Catalyst™ Control Center. Further details can be found in topic number 737-32665
Connecting a CRT and TV and enabling either clone mode or extended desktop no longer results in Overlay Theater Mode failing on the secondary display device when attempting to change the TV format to D/PAL. Further details can be found in topic number 737-32606
Catalyst™ Control Center->3D: AA options are no longer missing on certain system configurations. This issue may also have been experienced under the Windows Vista and XP Professional x64 Edition operating systems. Further details can be found in topic number 737-33400
The Apply button no longer fails to become disabled when changing the display resolution on a system with extended desktop mode enabled and the secondary display device having a different color scheme. This issue may also have been experienced under the Windows Vista and XP Professional x64 Edition operating systems. Further details can be found in topic number 737-33401
Setting the language option to French for the Catalyst™ Control Center no longer results in cropped text being noticed within the Catalyst™ Control Center. This issue may also have been experienced under the Windows Vista and XP Professional x64 Edition operating systems. Further details can be found in topic number 737-33402
The display device no longer displays a green image when launching the Catalyst™ Control Center when PowerDVD is running. Further details can be found in topic number 737-33405
The Windows XP operating system no longer fails to respond when switching between user profiles. Further details can be found in topic number 737-33414
Staro 17.04.2008., 17:30   #8
CPU
Varanje na tržnici
Lokacija: Zabok
Postovi: 214
Izbačen se steam.
moglo bi se zaključiti da si više nisu dobri pa bi u buduće vrijeme moglo biti više problema s driverima i igrama koje radi valve,ali opet nemora biti...
Ili još gore što bi se moglo događati je da više neće budnlirati igre od valve-a što se meni nikako ne sviđa.Ovo mi se nikako ne čini dobar potez.
CPU je offline   Reply With Quote
Staro 17.04.2008., 23:55   #9
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
sad to dolazi s nvidia driverima, ocito su valvu ponudili bolje uvjete (ili ih ucijenili necim )
Staro 18.04.2008., 11:50   #10
Atrax
Atrax's Avatar
Postovi: 553
Question
meni nikad ne nudi catalys na updejtu. vistu koristim sad, al ni na xp-u nije nudio.
jedino one updejtane hdmi drivere i takve stvari za ati, al catalyst nikad.
imam jedno pitanje, malo je OT pa se ispričavam unaprijed, zašto u dxdiag-u piše dx 10 a ne 10.1 kod verzije dx-a?
znači imam vistu, sp1 i drivere nove.
nije da patim na to,tak mi je svejedno, al sam baš išo vidit kad sam sp1 intalirao.
mislim da sam negdje našo članak da u biti ni sp1 ne koristi dx 10.1 neg da će kasnije tek dolazit updejtovi za dx koji će dić to onda na 10.1.
možda lupam gluposti, al mislim da sam pročito to negdje tak, ili nešto slično.
ak sam zabrijo, don't me
Atrax je offline   Reply With Quote
Staro 19.04.2008., 09:13   #11
CPU
Varanje na tržnici
Lokacija: Zabok
Postovi: 214
Zabrijao si.
http://ati.amd.com/developer/demos/rhd3000.html
Samo malo prođi po stranici i može se dosta toga zaključiti.(netreba biti lumen)
Staro 19.04.2008., 13:35   #12
Atrax
Atrax's Avatar
Postovi: 553
Talking
Autor CPU Pregled postova
Zabrijao si.
a znaš šta je najzanimljivije u svemu tome, instalirao sam taj demo čim sam vistu stavio. i nakon što sam pročitao da je potrebna vista i dx10.1 za pokrenut to, i nakon što sm uspio to pokrenut i odigrat, bilo je jako teško zaključit da vista koristi dx10.1
my bad
Staro 19.04.2008., 15:28   #13
Deepdiver
opet sam sjebo kompjuter
Deepdiver's Avatar
Datum registracije: Apr 2008
Lokacija: Dubrovnik
Postovi: 30
ej ljudi, ja imam Ati radeonku HD 3870x2 i catalyst 08.1 što se dobije na cd-u s njome.
Hoću li dobiti što na preformansama ili čemu korisnome ako instaliram noviji catalyst?
kao ovaj 8.4, a neki mi preporučuju 8.3. što vi mislite? naravno Windows XP professional imam.
Deepdiver je offline   Reply With Quote
Staro 20.04.2008., 00:19   #14
Jelc
Super Moderators
Postovi: 17,485
Autor Deepdiver Pregled postova
Instaliraj pa vidi
Ako ti nisu dobri uvjek se možeš vratiti na stare...
Instalirao si ove:
http://game.amd.com/us-en/drivers_ca.../integrated-xp
i ovo:
http://game.amd.com/us-en/drivers_ca...adeonxavivo-xp
Zadnje izmijenjeno od: Jelc. 20.04.2008. u 00:39.
Staro 20.04.2008., 16:49   #15
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Instalirao sam maloprije upravo..čisto neka glupa navika da uvijek stavim up-to-date drivere..igram Crysis dosta online,pa čisto nekih sitnica radi..textura,pucanja itd..
Sve štima odlično zasad na CoD4,Crysis SP,MP..NFS Carbon,NBA08,FiFa08..tako da mogu samo preporučiti vlasnicima 3870tki..
Što se tiče nekog konkretnog bencha,dobio sam na moj komp 11379 marka06, što je nekakav pomak od 70tak markova naspram 8.3 drivere,znači zanemarivo ali čini mi se čisto subjektivno,da je frame-rate nešto stabilniji..odnosno da dropovi više nisu tako česti..
Zasad sve štima..više bi trebalo zabrinjavati AGP usere njihova situacija,tj. da li su sredili stabilnost..nego nas na PCI-E..mali su pomaci..ovo je stvar čisto neke glupe navike..imho,nema od 8.1 - 8.4 neke razlike..pa čak i od 7.9...
Al eto..up-to-date..
Staro 20.04.2008., 17:36   #16
windfucker
Potvrđujem zapaženo...same here
Staro 21.04.2008., 08:00   #17
LouisCyphere
LouisCyphere's Avatar
Lokacija: Sl.Brod
Postovi: 270
Imam velikih problema što se tiče 8.4 u Crysisu na visti 64.
Čim krenem igrati slika samo stanre zvuk ide dalje. Probao sam staviti 8.2 i onda mogu igrati jedno 15-30 min, ali se isto dogodi.
8.1 mi ne želi instalirati kao ni 8.3.
Što još da pokušam? HELP!
Grafa je 3870 peak.
Who is General Failure and why is he reading my disk?
LouisCyphere je offline   Reply With Quote
Staro 21.04.2008., 08:33   #18
Postovi: 34,016
Autor LouisCyphere Pregled postova
1. maknut Vistu
2. maknut Vistu
Staro 21.04.2008., 08:57   #19
LouisCyphere
Lokacija: Sl.Brod
Postovi: 270
Navečer ću ju maknuti, staviti ću opet xp 64. Samo mislim da nije do Viste. Barem ne ovaj put.
Staro 21.04.2008., 11:35   #20
Mljac
Mljac's Avatar
Datum registracije: Feb 2003
Lokacija: Zaprešić/Laduč
Postovi: 460
Već sa 8.3 nisam imao nikakvih problema, ostao sam na XP-u, fala bogu.
8.4 mi se stvarno čini nekako fluidniji, nema nekih pomaka u špicama fps-a, ali su zato padovi čini mi se manji.
Ono kaj meni nije jasno je da mikromekani može cijeli svijet karat sa tim poluproizvodom od Viste.
Imaš hardver za dx 10.1 a moraš ostat na 9.0!
Mljac je offline   Reply With Quote
Staro 22.04.2008., 00:52   #21
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
a ne znam, vista je u kurcu zbog vise stvari ali evo neki dan je stavio (SP1 naravno) i jos je nisam maknio. to nesto govori jer prije SP1 nikada nije izdrzala na stroju vise od 12 sati
konacno radi vidljivo brze, fluidnije. sucelje vise nije onako sporo i sredili su one idiotarije da ponekad moram vijati pixel da bi stisnio 'beno dugme, kao da igram neku staru avanturu. driveri su ok za sve koliko sam vidio do sada.
naravno morao sam ugasiti UAC i te budalastine, izludile su me
da se razumijemo, ne propagiram je. vjerovatno ce opet uskoro odletjeti s kante. ali ocito je da se ipak trude nesto popraviti. to sto ce biti potreban jos jedan SP2 da bude upotrebljiva kao i XP...to je druga stvar
Staro 22.04.2008., 03:40   #22
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Autor greg SE Pregled postova
Tko si ti i sto si napravio sa Gregom?
Ha gle. Vista je bolja sa SP1, al jos je to debelo lose, da bi opravdalo prelazak.
EDIT: sad tek skuzio da je 8.4 tema, a ne vista review. Neka ostane reply, a modovi neka pobrisu ako misle da nije uredu.
Staro 26.04.2008., 23:33   #23
manowar3
Datum registracije: Mar 2008
Lokacija: SAS
Postovi: 20
Jeli snimio netko ove cataliste za HD2600XT? ako je, ima li ikakvih problema (zaista bi me čudilo da nema, stoga se stvarno potrudite da me uvjerite da nema)
manowar3 je offline   Reply With Quote
Staro 27.04.2008., 00:54   #24
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Autor manowar3 Pregled postova
O čemu ti to? Ja sam promijenio sve dosad od 7.6 do 8.4, nikad nikakvih problema
Staro 27.04.2008., 01:13   #25
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
@sagregator - nemoj biti tako povrsan, moramo se SVI fizicki i spiritualno posvetiti tom nasemu konacnom zivotnom cilju - ujeravanju gospodina manowar3 da updejta drivere.
Staro 27.04.2008., 01:17   #26
nino
nino's Avatar
Postovi: 12,613
Eo i ja se pridruzujem uvjeravanju. Zovite i Fleksa.
Staro 27.04.2008., 01:28   #27
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Autor nino Pregled postova
Zovite i Fleksa.
Hare Hare Krišna !
Staro 27.04.2008., 23:43   #28
manowar3
Lokacija: SAS
Postovi: 20
nije mi jasno zašto svi ovde moraju doslovno shvatit sve što napišem i zašto nitko na forumu nezna za nimalo zajebancije. Sa catalistima sam uvik ima problema, od 7.1-8.3, kao što su promjenute boje u firefoxu i nekakvi erori od ccc-a,nemogućnost otvaranja ccc-a...itd. i još jedna stvar. ja sam pitao za hd2600xt a ti pričaš kako na tvojoj 3870 nema nikakvih problema
Staro 27.04.2008., 23:46   #29
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Ne vidim da je itko spominjao 3870
Staro 27.04.2008., 23:58   #30
domis
Lokacija: Hrvatistan
Postovi: 4,165
ma lik se gubi
btw. ako ti sad sve radi...nema bas potrebe da updejtas drajvere...uostalom, ak bi ih htel updejtat, nebi nas spitaval
