Propali Amigaš
Lokacija: Nin
Postovi: 7,000
Stigao 8.4
http://game.amd.com/us-en/drivers_ca...=xp/radeonx-xp https://a248.e.akamai.net/f/674/9206...ase_notes.html Da ne kopipejstam gomilu teksta ![]() Ništa spektakularno ovaj put, izgleda |
Lokacija: NA
Postovi: 2,620
izasla je 8.4 i za linux |
Postovi: 82
Preuzeo još jučer preko Windows update servisa. |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Resolved Issues for the Windows Vista Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include: Company of Heroes: Setting the in-game options to maximum levels no longer results in the game exiting to the desktop after the game has completed loading. Further details can be found in topic number 737-32600 Crysis: Setting the Catalyst™ Control Center->Advanced View->3D->Standard Settings to Optimal Quality and having certain in game option settings no longer results in the game failing to render properly. Further details can be found in topic number 737-33395 Doom 3: Setting the in game options to Ultra Quality and the screen size to 1600x1200 no longer results in the image next to the text failing to be rendered. Further details can be found in topic number 737-32603 Hellgate: London: Flickering is no longer noticed when quitting and then relaunching the game when the in-game setting are set to their maximum levels. Further details can be found in topic number 737-32604 Lost Planet: Setting AA to either 4x or 8x no longer results in the game failing to respond. Further details can be found in topic number 737-28492 Tabula Rasa: Setting the graphics option to enable Deferred Lighting and Dynamic Shadows no longer results in corruption being displayed. Further details can be found in topic number 737-32597 Tomb Raider Anniversary: Performance improvements are now noticed when playing the game with CrossFire™ enabled. Further details can be found in topic number 737-32598 Playing a game that uses the Unreal Engine 3.0 no longer results in AA setting not having any effect on the game when CrossFire is enabled. Further details can be found in topic number 737-33384 The Windows Vista operating system no longer fails to respond when running the Auto-tune utility found in the Catalyst™ Control Center OverDrive™ option. Further details can be found in topic number 737-30584 Using the pound key (#) as the first character in the user name no longer results in an error when installing the Catalyst™ Control Center. Further details can be found in topic number 737-31578 The color depth no longer changes to 8 bpp when enabling or disabling CrossFire™ for the first time. Further details can be found in topic number 737-31580 Display corruption is no longer noticed when enabling CrossFire™ on a system containing an ATI Radeon™ X1900/1950 series of product when the display resolution is set to 1600x1200 70Hz and running a 3D application in full screen mode. Further details can be found in topic number 737-31582 Connecting a TV as a secondary display device no longer results in extended desktop mode failing to become active. Further details can be found in topic number 737-32659 Flashes of white lines are no longer noticed when quickly moving windows around the Vista desktop. Further details can be found in topic number 737-32660 Momentary flicker is no longer noticed when rotating the display device. Further details can be found in topic number 737-32661 Hot plugging an HDMI display device to a system running Windows Vista (32 or 64 bit version) no longer results in the HDMI display device being detected as a DTV (DVI) device. Further details can be found in topic number 737-32593 The signal on HDTV TV is no longer displayed as 480p60 after setting the format to 576i25/576p50 in clone mode. Further details can be found in topic number 737-32662 A warning message no longer fails to appear when using an inappropriate DVI-HDMI adapter. Further details can be found in topic number 737-32596 Attempting to perform a silent install of the display driver on a system running Traditional Chinese version of Windows Vista no longer results in an error message being displayed and the display drivers failing to be installed. Further details can be found in topic number 737-32601 Catalyst™ Control Center->Display Properties->Settings tab->Advanced: The adapter information is no longer displayed as ATI Display Adapter instead of the actual product name. Further details can be found in topic number 737-32602 Enabling extended desktop mode followed by swapping the primary and secondary display devices no longer results in all running applications to be displayed on the primary display device. Further details can be found in topic number 737-32607 Enabling or disabling CrossFire no longer results in the HydraGrid settings failing to be retained. This issue may also be experienced under the Windows XP and Windows XP Professional x64 Edition operating systems. Further details can be found in topic number 737-32609 Exiting a full screen D3D application no longer results in some of the other running applications failing to retain their current HydarGrid location. This issue may also be experienced under the Windows XP and Windows XP Professional x64 Edition operating systems. Further details can be found in topic number 737-32612 An incorrect message is no longer displayed when resuming from an S3 state when extended desktop mode is enabled. Further details can be found in topic number 737-33374 Enabling Overlay Theatre Mode while a movie is playing no longer results in the secondary display device displaying a black screen when extended desk mode is enabled. Further details can be found in topic number 737-33375 Connecting a secondary display device and setting the display resolution to 1280x800 or greater no longer results in corruption being noticed when attempting to enable extended desktop mode. Further details can be found in topic number 737-33376 Playing a Blu-ray or HD DVD title using the Cyberlink PowerDVD 7.3 no longer results in an error message being displayed. Further details can be found in topic number 737-33377 Using MCE to view TV no longer results in the Vista operating system (32 bit version) failing to respond when resuming from an S3 state. Further details can be found in topic number 737-33378 Intermittent corruption when switching between an LCD display device and an HDMI TV no longer occurs. Further details can be found in topic number 737-33379 Connecting an HDMI display device no longer results in an extra longer time being noticed when attempting to switch between the LCD display device and the HDMI display device. Further details can be found in topic number 737-33382 Corruption is no longer noticed on the Windows Vista desktop when playing a DVD title when using the Windows Media Player. Further details can be found in topic number 737-33383 Connecting an HDTV using the HDMI port on a system containing an ATI Radeon™ HD 3100/3200 series of product no longer results the LCD display device failing when hot-unplugging the HDTV. Further details can be found in topic number 737-33384
Super Moderators
Postovi: 17,485
Resolved Issues for the Windows XP Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include: 3DMark05/06: A performance drop is no longer noticed when running the benchmark under Windows XP. Further details can be found in topic number 737-33497 Lost Planet: Setting AA to either 4x or 8x no longer results in the game failing to respond. Further details can be found in topic number 737-28492 Setting the language option to any supported language other than English no longer results in the Help file for Configure and Diagnostics failing to appear. Further details can be found in topic number 737-32605 Setting the language option to Russian for the Catalyst™ Control Center no longer results in some text being cropped for the secondary display device in the display properties. Further details can be found in topic number 737-32663 Setting the language option to German for the Catalyst™ Control Center no longer results in some translation errors being noticed through-out the Catalyst™ Control Center. Further details can be found in topic number 737-32664 Setting the language option to French for the Catalyst™ Control Center no longer results in some translation errors being noticed through-out the Catalyst™ Control Center. Further details can be found in topic number 737-32665 Connecting a CRT and TV and enabling either clone mode or extended desktop no longer results in Overlay Theater Mode failing on the secondary display device when attempting to change the TV format to D/PAL. Further details can be found in topic number 737-32606 Catalyst™ Control Center->3D: AA options are no longer missing on certain system configurations. This issue may also have been experienced under the Windows Vista and XP Professional x64 Edition operating systems. Further details can be found in topic number 737-33400 The Apply button no longer fails to become disabled when changing the display resolution on a system with extended desktop mode enabled and the secondary display device having a different color scheme. This issue may also have been experienced under the Windows Vista and XP Professional x64 Edition operating systems. Further details can be found in topic number 737-33401 Setting the language option to French for the Catalyst™ Control Center no longer results in cropped text being noticed within the Catalyst™ Control Center. This issue may also have been experienced under the Windows Vista and XP Professional x64 Edition operating systems. Further details can be found in topic number 737-33402 The display device no longer displays a green image when launching the Catalyst™ Control Center when PowerDVD is running. Further details can be found in topic number 737-33405 The Windows XP operating system no longer fails to respond when switching between user profiles. Further details can be found in topic number 737-33414
Varanje na tržnici
Lokacija: Zabok
Postovi: 214
Izbačen se steam. moglo bi se zaključiti da si više nisu dobri pa bi u buduće vrijeme moglo biti više problema s driverima i igrama koje radi valve,ali opet nemora biti... Ili još gore što bi se moglo događati je da više neće budnlirati igre od valve-a što se meni nikako ne sviđa.Ovo mi se nikako ne čini dobar potez. |
Postovi: 553
![]() meni nikad ne nudi catalys na updejtu. vistu koristim sad, al ni na xp-u nije nudio. jedino one updejtane hdmi drivere i takve stvari za ati, al catalyst nikad. imam jedno pitanje, malo je OT pa se ispričavam unaprijed, zašto u dxdiag-u piše dx 10 a ne 10.1 kod verzije dx-a? znači imam vistu, sp1 i drivere nove. nije da patim na to,tak mi je svejedno, al sam baš išo vidit kad sam sp1 intalirao. mislim da sam negdje našo članak da u biti ni sp1 ne koristi dx 10.1 neg da će kasnije tek dolazit updejtovi za dx koji će dić to onda na 10.1. možda lupam gluposti, al mislim da sam pročito to negdje tak, ili nešto slično. ak sam zabrijo, don't ![]() ![]() ![]() |
Varanje na tržnici
Lokacija: Zabok
Postovi: 214
Zabrijao si. http://ati.amd.com/developer/demos/rhd3000.html Samo malo prođi po stranici i može se dosta toga zaključiti.(netreba biti lumen) |
#12 | |
Postovi: 553
![]() Citiraj:
![]() my bad ![]() |
opet sam sjebo kompjuter
Datum registracije: Apr 2008
Lokacija: Dubrovnik
Postovi: 30
ej ljudi, ja imam Ati radeonku HD 3870x2 i catalyst 08.1 što se dobije na cd-u s njome. Hoću li dobiti što na preformansama ili čemu korisnome ako instaliram noviji catalyst? kao ovaj 8.4, a neki mi preporučuju 8.3. što vi mislite? naravno Windows XP professional imam. |
#14 | |
Super Moderators
Postovi: 17,485
![]() Ako ti nisu dobri uvjek se možeš vratiti na stare... Instalirao si ove: http://game.amd.com/us-en/drivers_ca.../integrated-xp i ovo: http://game.amd.com/us-en/drivers_ca...adeonxavivo-xp
Zadnje izmijenjeno od: Jelc. 19.04.2008. u 23:39. |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Instalirao sam maloprije upravo..čisto neka glupa navika da uvijek stavim up-to-date drivere..igram Crysis dosta online,pa čisto nekih sitnica radi..textura,pucanja itd.. Sve štima odlično zasad na CoD4,Crysis SP,MP..NFS Carbon,NBA08,FiFa08..tako da mogu samo preporučiti vlasnicima 3870tki.. Što se tiče nekog konkretnog bencha,dobio sam na moj komp 11379 marka06, što je nekakav pomak od 70tak markova naspram 8.3 drivere,znači zanemarivo ali čini mi se čisto subjektivno,da je frame-rate nešto stabilniji..odnosno da dropovi više nisu tako česti.. Zasad sve štima..više bi trebalo zabrinjavati AGP usere njihova situacija,tj. da li su sredili stabilnost..nego nas na PCI-E..mali su pomaci..ovo je stvar čisto neke glupe navike..imho,nema od 8.1 - 8.4 neke razlike..pa čak i od 7.9... Al eto..up-to-date.. ![]() ![]() |
#16 | |
#17 |
Lokacija: Sl.Brod
Postovi: 270
Imam velikih problema što se tiče 8.4 u Crysisu na visti 64. Čim krenem igrati slika samo stanre zvuk ide dalje. Probao sam staviti 8.2 i onda mogu igrati jedno 15-30 min, ali se isto dogodi. 8.1 mi ne želi instalirati kao ni 8.3. Što još da pokušam? HELP! Grafa je 3870 peak.
Who is General Failure and why is he reading my disk? |
#18 | |
Postovi: 33,921
2. maknut Vistu
#20 |
Datum registracije: Feb 2003
Lokacija: Zaprešić/Laduč
Postovi: 460
Već sa 8.3 nisam imao nikakvih problema, ostao sam na XP-u, fala bogu. 8.4 mi se stvarno čini nekako fluidniji, nema nekih pomaka u špicama fps-a, ali su zato padovi čini mi se manji. Ono kaj meni nije jasno je da mikromekani može cijeli svijet karat sa tim poluproizvodom od Viste. Imaš hardver za dx 10.1 a moraš ostat na 9.0!
Member of PCE 100+kg demolition squad |
#21 |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
a ne znam, vista je u kurcu zbog vise stvari ali evo neki dan je stavio (SP1 naravno) i jos je nisam maknio. to nesto govori jer prije SP1 nikada nije izdrzala na stroju vise od 12 sati ![]() konacno radi vidljivo brze, fluidnije. sucelje vise nije onako sporo i sredili su one idiotarije da ponekad moram vijati pixel da bi stisnio 'beno dugme, kao da igram neku staru avanturu. driveri su ok za sve koliko sam vidio do sada. naravno morao sam ugasiti UAC i te budalastine, izludile su me ![]() da se razumijemo, ne propagiram je. vjerovatno ce opet uskoro odletjeti s kante. ali ocito je da se ipak trude nesto popraviti. to sto ce biti potreban jos jedan SP2 da bude upotrebljiva kao i XP...to je druga stvar ![]() |
#22 | |
JDM
Datum registracije: Sep 2004
Postovi: 6,137
![]() Ha gle. Vista je bolja sa SP1, al jos je to debelo lose, da bi opravdalo prelazak. EDIT: sad tek skuzio da je 8.4 tema, a ne vista review. Neka ostane reply, a modovi neka pobrisu ako misle da nije uredu. |
#24 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,000
#25 |
Lokacija: NA
Postovi: 2,620
@sagregator - nemoj biti tako povrsan, moramo se SVI fizicki i spiritualno posvetiti tom nasemu konacnom zivotnom cilju - ujeravanju gospodina manowar3 da updejta drivere. |
#26 |
Postovi: 12,600
Eo i ja se pridruzujem uvjeravanju. ![]()
#27 |
JDM
Postovi: 6,137
#28 |
Datum registracije: Mar 2008
Lokacija: SAS
Postovi: 20
nije mi jasno zašto svi ovde moraju doslovno shvatit sve što napišem i zašto nitko na forumu nezna za nimalo zajebancije. Sa catalistima sam uvik ima problema, od 7.1-8.3, kao što su promjenute boje u firefoxu i nekakvi erori od ccc-a,nemogućnost otvaranja ccc-a...itd. i još jedna stvar. ja sam pitao za hd2600xt a ti pričaš kako na tvojoj 3870 nema nikakvih problema |
#29 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,000
#30 |
Lokacija: Hrvatistan
Postovi: 4,164
ma lik se gubi ![]() btw. ako ti sad sve radi...nema bas potrebe da updejtas drajvere...uostalom, ak bi ih htel updejtat, nebi nas spitaval ![]() |
