Staro 18.04.2004., 12:55   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi Omega Drivers v2.5.36b
Evo-došli smo i do b verzije drivera
To je kompletni set novih drivera (nije patch).
Kad je već išao dodati gama fix, usput ih je još malo popravio i dodao neke stvari.
A novo je:
* Based on the Official Catalyst 4.4 drivers.
* Updated the Omega version of RadLinker (1007). Many thanks to ChrisW!
* FastWrites is now an option when installing.
* Fixed support for Mobility 9700.
* Fixed support for 9800SE cards flashed with 9800XT bios.
* Removed some old tweaks that are no longer necessary, this should give
a small speed boost to some games and applications.
UPDATE!!! (2.5.36b)
* Included the ATI hotfix to solve Gamma problems with applications and games.
* Added a possible fix for 9700M cards that are being detected as 9600M.
* Added a few new settings for Mobility cards that should fix a few things, for
example, the hibernation issue.
* Added new Large Desktop modes and refresh rates.
A za one koji nisu nikad koristili Omegu, još i:
REMINDERS:
1- If you have the normal ATI drivers installed, uninstall the ATI Control Panel
BEFORE upgrading to these drivers, the Omega Drivers already have the CP integrated
and another CP will cause conflicts or other problems.
2- There is no need to uninstall ANY previous drivers (ATI or OMEGA) when
installing these, they will override any previous settings.
3- In Windows 2k/XP, ALWAYS disable DDC in the ATI "Displays/Monitor" CP after
installing drivers to be able to use ALL the refresh rates and resolutions
your monitor supports, also this is the best way to avoid the 60Hz RR bug.
4- The WDM drivers for VIVO and AIW cards are not included, but they can be
downloaded separately from a link in my drivers page.
5- The Radeon cards do support FastWrites and they will work with it on
(on some machines), but it is not recommended, there is NO SPEED gain
when using FW, and this option will affect your PC's stability a LOT,
most game crashes and problems are because FW is enabled.
I don't recomend the use of ANY external tweakers with my drivers (specially Rage3D
tweaker), as they override my special settings and will make my work useless. The only
time I recommend a tweaker is when you have a specific problem with a specific tweak
and need to change it in order to make the drivers work correctly. Also if you use
a tweaker for overclocking, FSAA, Gamma or Aniso settings, is just fine, but you'll
be better off using the integrated ATI CP for that (which is ok by me if you change
any setting in it).
If you have any problems with this drivers please go to my webpage
and look in the ATI help section for answers. If still have problems
look for the drivers thread in www.driverheaven.net forums and let me know
what is going on.
If you happen to find a new tweak or fix for a specific game or many games
and it proves that it works then drop me an E-Mail (don't post it in the
forums), I'll make sure credit will be granted to that person in this INFO file.
IMPORTANT: Don't bother ATI about this drivers as they are unsupported by them!
http://www.omegacorner.com/index_ati.html
