Staro 18.12.2006., 18:20   #1
Facelessone
Facelessone's Avatar
Postovi: 4,204
Problem s mreŽom
Umrežena 2 kompa preko kasde, oba2 se vide u LAN-u, obojica mogu na net itd sve super OSIM, kaj kad napravim igru u LAN-u ili na Battlenetu u warcraft 3 drugi komp mi se nemre joinat....dal zna neko neko riješenje na brzinu?
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 20.12.2006., 20:30   #2
Facelessone
Postovi: 4,204
kaj niko nezna??
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 31.12.2006., 19:05   #3
Facelessone
Postovi: 4,204
Ajde ljudi veČ peeZdeem zbog ovog, LAN je čudesno proradil al mi se buraz još uvijek nemože joinat kad napravim igruna bnetu
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 31.12.2006., 19:26   #4
shobru
Postovi: 127
mozda zato sto imate isti cdkey, a mozda vas i firewall blocka, probaj stavit gamemode ili tak nesto, zavisi koji firewall imas.
shobru je offline   Reply With Quote
Staro 31.12.2006., 19:35   #5
Facelessone
Postovi: 4,204
windows firewall svi mi se mogu joinat u igru osim buraza znaci firewall nije kriv, nema nikakav gamemode.....hmm serial, idem probat kupit neki drugi pa javim
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 31.12.2006., 19:36   #6
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Firewall bez greške. Moraš u postavkama firewalla dozvolit igri da ima pristup lan-u i da se ponaša ko server, inaće niš od toga. Dok nisam znao riješio bi problema sa konzolom od recimo cod2, stisneš tildu i upišeš "connect 192.168.x.x" ili koja je već ip adresa od servera...
BTW, mislim da nema šanse da je cd-key u pitanju , isprobao.
Staro 31.12.2006., 19:43   #7
Facelessone
Postovi: 4,204
Da je firewall niko mi se nebi mogo joinat, al meni se samo buraz nemre joinat koji je pod istim routerom
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 31.12.2006., 19:57   #8
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
A nije ti palo na pamet da burazov firewall radi probleme, a ne tvoj?
Gle, već godinu dana redovito radim lan-ove za ekipu, i ja sam taj koji slaže mrežu. Koja god igra da je u pitanju, kad mi dođe netko novi i nemre se joinat UVIJEK je u pitanju firewall, sad dal je to zid od winbloza, ZA ili neko treće riješenje, nije bitno. Na bratovom kompu moraš igri dozvolit pristup lan-u.
Staro 31.12.2006., 20:16   #9
Facelessone
Postovi: 4,204
nije firewall, ugasil sam oba firewalla i opet ista stvar. nisam ja njub kaj se toga tiče al ovo fakat ne kužim. meni se čini da nekej kasda k@k@ al neznam kaj...
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 31.12.2006., 20:31   #10
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Čekaj, ako je kasda u router modu, onda moraš riješit portforward za svoj i bratov komp. Kod mog gigaseta se515 je portforward vezan na mac adresu mrežne kartice.
BTW, ako koristite i ti i brat firewall od win XP SP2, to što si ga ugasio, ne znači da su portovi za igru otvoreni. Firewall od win je malo žešće sr...e. Na win XP SP2 koliko je meni poznato visoki portovi ostaju zatvoreni i kad se ugasi firewall, možda griješim, ali takvo je moje iskustvo s tim firewallom.
Posjeti http://www.portforward.com/ i podesi portove za igre na routeru i firewallu od brata i problem bi trebao nestat.
Staro 31.12.2006., 20:38   #11
Facelessone
Postovi: 4,204
Autor Pomo Pregled postova
Otvoren je port u windowsima od prije več, e sad če kasda nastradat. ovo čebit još zanimljivije radit ujutro oko 5 kad dođem doma
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 16.01.2007., 01:51   #12
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
A kako otkljucati portove u slucaju kada ne idem preko routera nego direktno na internet?
Problem mi je sigurno u portovima, a ne u firewallu. Da li treba da zovem providera ili mogu to kod sebe podesiti? BTW potrebni su portovi od 6112 do 6119.
Ajde molim vas pomozite, treba mi da igram AT sa frendom.
Staro 16.01.2007., 01:58   #13
Facelessone
Postovi: 4,204
ovo gore nije riješenje mog problema.... tu je riješenje KliK
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 16.01.2007., 02:34   #14
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Ovo meni i dalje nista ne znaci. Ja ne koristim router.
BTW Facelessone, koji ti je ingame nick u W3?
Staro 16.01.2007., 02:49   #15
Facelessone
Postovi: 4,204
Nick mi je isti.Cek da ti nacrtam kak ovo napravit s portovima
EDIT:
valja buš skužil
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 16.01.2007., 02:55   #16
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Ladno bi mi mogo nacrtat. (najozbiljinije ti govorim) jer ne mogu vise na oci gledati. Zadnja 2 dana sam bio na LAN-u tako da nisam spavao bas puno, pa mi je sada mrsko citati sve ove postove. Ako ikako moze daj mi reci u dvije-tri rijeci sta i kako, pa da idem spavati. Skonto sam da treba nesto podesavatati u NAT-u ali.....
CRTAJ
EDIT:
Probavo sam to ali ne radi.
Hvala na pomoci i dobroj volji, a i na crtezima . Odo sad spavati.
Staro 16.01.2007., 03:04   #17
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Da li je moguce da se nesto slicno ovome mora podesiti i na serverima mog internet providera???
EDIT: Problem rjesen. : goood :
Kod mene je Thompson ADSL modem, pa ako neko ima istih problema neka mi se javi na pm.
Zadnje izmijenjeno od: Milentije. 16.01.2007. u 23:53.
Staro 18.01.2007., 00:09   #18
celduce
celduce's Avatar
Lokacija: Dimension 8
Postovi: 785
Da ne otvaram novi topic pitati chu ovdje.
Racunalo iz siga sam spojio preko Kasde u lan sa drugim racunalom (Celer 667, 256MB ram, 40GB, 3Com 3C905-TX 10/100).
Ovo drugo racunalo je office konfa + kao "mini file server" i sluzi za odlaganje podataka.
Racunala su spojena straight kabelom preko Kasde, namjestena je IP adresa i racunala se vide u mrezi i mogu pristupiti podacima.
Problem je u tome sto je brzina prijenosa podataka brzine 1% od 100mbita, dakle 10MB mi kopira i do 5 minuta.
Mozda je problem i u kablovima ali ajd mozda je i do Kasde pa da prvo pitam prije nego sto kupim 2 * 10m novog kabela.
Fujitsu C710 • i5 3470 • 8GB DDR3 • Crucial 512GB • nVIDIA Quadro K620 • iiyama 24" ProLite • Win 10
celduce je offline   Reply With Quote
Staro 18.01.2007., 10:48   #19
Postovi: 23,566
Da bi eliminirao potencijalni blem sa Kadom (i trenutnim kabelima), posudi crossower mrežni kabel i spoji dva kompa međusobno. Ako je i u toj kombinaciji file transfer spor ko puž onda je blem u samim kompovima, odnosno mrežne, driver - i od istih, . . .
Ako "stvar" poleti onda te zezaju kabeli il "prijateljica" Kasda.
Staro 18.01.2007., 18:56   #20
celduce
celduce's Avatar
Postovi: 785
Ipak je bio problem u kablovima, tocnije, u kabelu od Kasde do Celer konfe.
Danas sam posudio druge kablove, spojio i sve radi normalno.
Pozdrav!
