| #1 | |
| Moderator | Uputstva i linkovi Upute za SIEMENS C-010I aDSL modem – Carnet – Router mode (496 KB) Upute za ELCON 2253 EU aDSL modem – Carnet – Router mode (2.66 MB) Upute za ZyXEL P-660 RU aDSL modem – Carnet – Router mode (1.53 MB) Upute za KASDA KD318-MUI aDSL modem – Carnet – Router mode (363 KB) Driver (USB) za KASDA KD318-MUI aDSL modem (72 KB) T-Com upute i drajveri za ADSL žičane uređaje T-Com upute i drajveri za ADSL Wlan uređaje RASPPPOE za 32-bit release for x86 machines (Win9x/NT/2000/XP) Gigaset_SE555 T-Com IPTV firmware 1.30K-9 Gigaset_SE555 non-IPTV firmware 1.30L-9 (Beta) Gigaset_SE555 non-IPTV firmware 1.30n-9 IP routera: 192.168.2.1, Password:admin Službeni Siemensov zadnji firmware za SE555 (izdan 01/07.) Nakon nadogradnje firmware - a napraviti factory reset kroz WEB sučelje pa tek onda punu konfiguraciju uređaja Gigaset SE555 WLAN dsl User guide (full version) English International PDF, 2231 Kb DSL-G684T Kratke upute za uporabu HR (1,7 Mb) Kratke upute za uporabu ENG (3 Mb) Full manual (9,5 Mb) Upute za postavljanje firmware-a DSL-G684T_Firmware_HR_IPTV (2,7 Mb) (DLinkEU-A_DSL-G684T_singleimage_kernel_fs_V3.00B01T01.HR-A.20061110) IP adresa routera: 192.168.1.1 Username: admin Password: 0000 Original firmware (DSL-G684T_fw_reva_300B01T02EUA20060717) IP adresa routera: 192.168.1.1 Username: admin Password: admin Nova verzija firmware - a (DSL-G684T_fw_reva_302B01T02EUA20070413) IP adresa routera: 192.168.1.1 Username: admin Password: admin Goli drajveri za D-Link DWL-G122 rev C1 rev C1 driver 1.0.1 rev C1 driver 1.0.3 Zadnje izmijenjeno od: Nikky. 22.07.2009. u 10:41. Razlog: Nadopuna |
| #2 | |
| Moderator | Upute KASDA KD318-MUI aDSL modem – Router mode – Nova verzija Kasda KD318-MUI ADSL router, postavljanje router moda, T-Comova "MaxTV" edicija 1. dio Autor: vsurlan sa http://www.forum.hr/ Napomena: ovo je prva verzija ovog tutoriala. Niti jedan od koraka nije testiran već sam čitav tutorial sastavio na temelju sjećanja i patnji od prethodnih 10tak sati. Moje iskustvo s mrežama je jako ograničeno. Jedini razlozi mog uspjeha su molitva i upornost. Vjerujem da ćete cijeniti moj uloženi trud. Uživajte! Ciljevi: #1 Razvaliti T-Com postavke kako bi se oslobodila dva ethernet konektora rezervirana za MaxTV. Ovo omogućuje spajanje do 4 nezavisna računala (svako računalo može zasebno biti spojeno dok su ostala 3 ugašena, za razliku od connection sharinga) umjesto po defaultu omogućena 2. #2 Podesiti uređaj da se ponaša kao router. Kao što je mnogima poznato, nekima iz T-Com-a je bilo logičnije da podese uređaj tako da je moguće ostvariti samo jednu konekciju. #3 Podesiti WinXP i Linux/Debian mašine da koriste uređaj kao router. Hardware: 1x CoreLogic ADSL splitter CLSI-018A 1x KD318-MUI ADSL router (T-Com edicija sa USB konektorom, dva "Ethernet" konektora i dva konektora "za MaxTV", tako se barem izrazio tehničar) 1x laptop/WinXP, 1x desktop/WinXP, 1x desktop/Linux (Debian) pripadajuće kablovinje (3x patch, 3x telefonski) Fizičko umreženje: svi PC-i: PC (konektor mrežne kartice) <-> patch kabl <-> Kasda Kasda <-> telefonski kabl <-> splitter (konektor označen natpisom modem) telefonski uređaj <-> telefonski kabl <-> splitter (konektor označen natpisom phone) splitter (konektor označen natpisom line) <-> telefonski kabl <-> telefonska linija Provjerite da li su sve konekcije kako treba i da li je Kasda upaljena! Obzirom da imam dva sjajna cimera očito je da je jedan stroj morao biti piknut u "MaxTV" Ethernet konektor. "MaxTV" Ethernet konektore prepoznat ćete po crvenom obrubu na Kasda routeru (ostala dva "obična" konektora obrubljena su zeleno). Dakle slijedeći korak je postavljanje postavki koje omogućuju da se "MaxTV konektori" koriste za spajanje računala na ADSL. Da bih skratio priču prilažem u privitku datoteku Kasda KD318-MUI settings.txt koju je potrebno učitati u Kasda router da bi se postavile sve potrebne postavke za ADSL konekciju sa 4 nezavisna računala. Sam router originalno sprema konfiguracijske datoteke sa ekstenzijom .conf međutim na ovom forumu nije moguće uploadati datoteke sa tom ekstenzijom (barem koliko sam ja primjetio). Ukoliko bude problema sa učitavanjem datoteke pokušajte ju preimenovati u backupsettings.conf. Upozorenje: Ukoliko dođe do problema nakon učitavanja postavki router je moguće resetirati na tvorničke postavke hard resetom koji se radi na slijedeći način: #1 Locirajte hard reset prekidač koji se kod mene nalazi između on/off prekidača i LAN konektora sa stražnje strane routera. Hard reset prekidač nalazi se unutar routera i moguće ga je pritisnuti nečim dugačkim i uskim poput uloška za kemijsku olovku. #2 Dok je router upaljen pritisnite i držite prekidač za hard reset. Dok držite prekidač ugasite router, nakon par sekundi ga upalite i ne puštajte prekidač hard reseta još desetak sekundi. Nakon ovog postupka router će se vratiti na tvorničke postavke. Prije učitavanja postavki iz datoteke koju sam priložio obavezno si spremite T-Com postavke koje su Vam došle sa routerom: #1 Usmjerite browser na: 192.168.1.1 #2 Birajte: Managment -> Settings -> Backup -> Backup settings Ukoliko nakon učitavanja priloženih postavki dođe do problema možete se vratiti na T-Com postavke tako što ćete izvršiti hard reset a zatim učitati datoteku sa T-Com postavkama na slijedeći način: #1 Birajte: Managment -> Settings -> Update -> Browse, birajte datoteku sa T-Com postavkama i Update Settings. Učitavanje postavki iz datoteke: Napomena: kod mene je često dolazilo do grešaka kod rada u Kasda konfiguratoru. Kad se desi greška jednostavno kliknite na 'Back' u pregledniku i ponovite zadnji korak. Ako vam je sav hardver korektno spojen i Kasda upaljena slijedite upute: #1 pokrenite svoj internet preglednik i idite na slijedeću adresu: 192.168.1.1 Ako je konekcija između Kasda-e i vašeg računala valjana preglednik će vam ponuditi login dijalog. #2 Unesite korisničko ime admin i lozinku 0000. #3 Birajte: Managment -> Settings -> Update -> Browse, izaberite datoteku sa postavkama i birajte 'Update Settings' #4 Birajte: Managment -> Save/Reboot i pričekajte da Kasda dođe sebi (ponekad joj stvarno treba podosta, čak do minute) Ako je sve do sada išlo kako treba posao sa podešavanjem Kasda-e je skoro gotov. "Oslobodili" ste "MaxTV konektore" i imate podešene sve potrebne postavke osim korisničkog imena i lozinke. Podešavanje korisničkog imena/lozinke: #1 Birajte: Advanced Setup -> Wan. Ako su se postavke ispravno učitale trebali bi vidjeti tablicu sa jednim retkom slijedećeg sadržaja: Kod: 0/33 1 UBR T-com dsl ppp_0_33_1 PPPoE Disabled Disabled N/A Enabled #2 Birajte: Edit -> Next (preskačemo stranicu) -> Next (isto) -> Unesite PPP Username (ne smije se izostaviti '@htnet-dsl') i PPP Password -> Next -> Next -> Save -> Save/Reboot Ovime je konfiguracija same Kasda-e završena. Potrebno je još konfigurirati same strojeve: |
Oglas | Oglasni prostor |
| #3 | |
| Moderator | Kasda KD318-MUI ADSL router, postavljanje router moda, T-Comova "MaxTV" edicija 2. dio Autor: vsurlan sa http://www.forum.hr/ Konfiguracija WinXP: #1 Birajte: Control Panel -> Network Connections -> Local Area Connection (desni klik Properties) Kod mene je tu slijedeća situacija: - Client for Microsoft Networks označeno - File and Printer Sharing for Microsoft Networks označeno - QoS Packet Scheduler nije označeno - PPP over Ethernet Protocol označeno - Internet Protocol (TCP/IP) označeno #2 Birajte: Internet Protocol (TCP/IP) -> Properties - označiti Use the following IP address IP address: 192.168.1.(broj od 2 do 254, paziti da se ne kosi sa drugim strojevima) Subnet mask: 255.255.255.0 Default gateway: 192.168.1.1 - označiti Use the following DNS server addresses Preferred DNS server: 192.168.1.1 Alternate DNS server: prazno Napomena: U ovim uputstvima gornja postavka (Alternate DNS server) je ostavljena prazna ali smatram da treba unjeti DNS server provajdera kojeg koristite: T-Com: 195.29.150.3 i 195.29.150.4 Iskon: 213.191.128.8 i 213.191.128.9 Nakon što ste sve podesili pričekajte neko vrijeme. Meni je umalo promaklo da sam sve podesio kako treba. Već sam počeo mijenjati postavke na routeru kad mi je cimerov laptop iz sobe viknuo: 'The virus database has been updated!. Konfiguracija Linuxa (Debian): #1 u /etc/resolv.conf dodati: nameserver 192.168.1.1 #2 u /etc/network/interfaces dodati: # The primary network interface auto eth0 iface eth0 inet static address 192.168.1.(broj od 2 do 254, paziti da se ne kosi sa drugim strojevima) gateway 192.168.1.1 netmask 255.255.255.0 #3 izvršiti kao root: /etc/init.d/networking restart Dodatak: uradio update kasde i gle sad ![]() ne mogu ici dalje namjestat sifru ak neko to uradio i ne zna sta ce treba stisnut onaj reset dok je upaljen, drzat ga, ugasit pa ponovo upalit kasdu (cijelo vrijeme drzat reset). |
| #4 | |
| Moderator | File & Printer share 1. Postavi na sva računala isti workgroup (Control Panel - System - Computer name - Change) Napomena za korisnike 9x sustava (Win95/98/98SE/ME) ime maksimalno 8 slova (i bez posebnih karaktera kao /()&%$#"!:;<>). 2. Uključi NetBIOS over TCP/IP ako već nije (Control Panel - Network Connections - Aktivna mrežna - Properties - Internet Protokol TCP/IP - Properties - Advanced - WINS tab - Klikni [selektiraj] Enable NetBIOS over TCP/IP) 3. Dozvoli share nekog direktorija (preporuka koristiti simple share). (npr. New folder [Mreza] - Properties - Sharing - Klikni Share this folder on network - Stavi ime pod kojim će se taj folder vidit na mreži, npr. Mreza isto - Klikni Allow network users to change my files, da omogučiš međusobno brisanje i čitanje). Napomena iz 1. točke vrijedi i ovdje. |
| #5 | |
| Moderator | Organiziranje mreže (definiranje IP adresa) Organizirati mrežu (definiranje IP adresa) može se napraviti na dva načina: 1. Auto - Na modemu/routeru se uključuje DHCP, definira u kom rangu će biti adrese dodjeljivane (preporuka 192.168.1.2 - 192.168.1.255). - Na svakom računalu na properties - ima od mrežne se bira Obtain IP address automatically - Svakako unesite Default gateway (192.168.1.1 na svim "novijim" modemima/routerima je ta - provjerite koja je def. u vašem slučaju - Unesite u Use the following DNS server address T-Com 195.29.150.3 i 195.29.150.4 ili Iskon 213.191.128.8 i 213.191.128.9 ovisno koji je vaš ISP. Mala napomena vezana za ovo gornje, naime kod smotanih (čitaj loše napravljenih) modema/routera pomaže da njihovu adresu (najčešće 192.168.1.1 isto doda na gornju listu DNS servera i to na prvo mjesto. Netko će reći nemože, ima samo dva polja. Krivo, (Control Panel - Network Connections - Aktivna mrežna - Properties - Internet Protokol TCP/IP - Properties - Advanced - DNS tab). Tu sa strelicama mijenjate prioritet (raspored) DNS servera. 2. Manual - Na modemu/routeru se gasi DHCP - Na svakom računalu na properties - ima od mrežne se bira Use following IP address i unosite 192.168.1.5 za prvo, 192.168.1.6 za drugo računalo i tako redom, Subnet mask svima isti 255.255.255.0 - Svakako unesite Default gateway (192.168.1.1 na svim "novijim" modemima/routerima je ta - provjerite koja je def. u vašem slučaju - Unesite u Use the following DNS server address T-Com 195.29.150.3 i 195.29.150.4 ili Iskon 213.191.128.8 i 213.191.128.9 ovisno koji je vaš ISP. Mala napomena vezana za ovo gornje, naime kod smotanih (čitaj loše napravljenih) modema/routera pomaže da njihovu adresu (najčešće 192.168.1.1 isto doda na gornju listu DNS servera i to na prvo mjesto. Ukoliko se konfigurira mreža sa modemom/routerom i ako je isti u router modu rada sa unesenim vašim podacima (User i Password za konekciju, tip konekcije Allways On ili Connection On Demand) onda vam dial-up više netreba. Dobro bi bilo na svim računalima u mreži definirati isti WORKGROUP i uključiti Enable NetBIOS over TCP/IP (Control Panel - Network Connections - Aktivna mrežna - Properties - Internet Protokol TCP/IP - Properties - Advanced - WINS tab - Klikni [selektiraj] Enable NetBIOS over TCP/IP) kako bi omogućili "prebacivanje fajlova" preko mreže. |
| #6 | |
| Moderator | Detekcija "nepoznatog" harware - a Detekcija "nepoznatog" harware - a Da bi detektirali i uredno instalirali nepoznati hardware možete koristiti slijedeće programe: PCI32 - Home page Download pcidevs.txt - aktualna lista poznatih pci kartica / devices, dodaje se u isti folder od PCI32 UnknownDevices - Home page Download ili na stranici UnknownDeviceIdentifier Download Ovi programi nam otkrivaju "ime" i PNP ID (Plug&Play Identification) pomoću kojih možemo "lakše" pronaći odgovarajući driver / software. |
