Staro 01.11.2006., 20:07   #1
Mikeyy
Postovi: 2,078
Pomoć oko HTPC kućišta + prijedlog HTCP kučišta
Odlučio sam se na ovo kučište:
http://www.thermaltake.com/product/C...tsx_vc7000.asp
Problem je što ako se stavlja full ATX ploča u kučište onda moram koristiti Build-in Riser Card.
http://www.thermaltake.com/product/C...artsx_View.htm
Mene pati ova rečenica:
If you are using a full size ATX motherboard, please make sure the PCI-E card is on the 6th slot of the PCI slot in order to install the riser card correctly.
Jel to MORA biti? Ima neko iskustva? Neznam zbog čeka baš 6-ti slot mora biti od PCI-E grafičke. Ono ubijam se da nađem matičnu kojoj je 6-ti slot PCI-E i ništa, a onih kojim je 4ti slot PCI-E ko pljeve.
I svakako ako imate prijedlog boljeg kučišta za HTPC računalo (al da ipak bude slim ili blizu slim, bit će slab comp unutra tako da netreba neko hlađenje, a želim da izgleda ok) bacite link i gdje se može kod nas kupiti. Thx unaprijed.
Staro 02.11.2006., 11:03   #2
sick_boy
sick_boy's Avatar
Postovi: 680
I ja sam u sličnoj dilemi, pa ću se vjerojatno odlučiti za ovo:
Mozart V4000sns
Ve-Mulj cca 750kn
Nije slim, pa stane u njega sve normalno. Ako ti baš treba slim - imaš peh.
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 02.11.2006., 13:39   #3
Mikeyy
Postovi: 2,078
Ma već sam počeo tražiti ne-SLIM kućišta pošto na ovo nitko nezna odgovor. Ako naiđe netko tko zna, nek pomaže.
Nego imam JOŠ jednu dilemu oko kućišta!
Kako sastaviti infrared za kučište? Znači moja TV kartica će biti MCE ready neka, al nema infrared na sebi. Pošto hoću složiti konfu da bude što uzer friendly, nema miša i tastature osim u krajnjoj nuždi. Vidio sam ona kučišta sa iMON-om i njhovim daljince, al sam procitao da nerade baš najbolje sa Win MCE.
Jel bi bilo problem nadograditi taj iMON na kučište koje ga nema?
Ima li neka druga opcija za ugradnju irda na htpc?
Da li bi Logitech Harmony 525 (ili bilokoji drugi univerzalac) radio na iMON shemi ili sa nekom drugom irda shemom?
Zadnje izmijenjeno od: Mikeyy. 02.11.2006. u 13:42. Razlog: Još pitanja :)
Staro 02.11.2006., 18:24   #4
newalss
Raindrops keep fallin'...
newalss's Avatar
Lokacija: Đakovo
Postovi: 826
Jel' si možda vidio po trgovinama ovo... http://www.hothardware.com/viewartic...leid=672&cid=8
Asus S-presso Deluxe. Imam ga nekih godinu dana i prilično sam zadovoljan s njim. Kupljen u diskont24. Za moj ukus definitivno najljepši HTPC koji se tad mogao kupiti. . Tko god mi dođe u kuću zbunjeno gleda i traži gdje mi je kučište od kompa. Izgled kao nekakva mikro linija a uživo izgleda još ljepše i kompaktnije nego na slikama.
Ima svoj OS tako da možeš gledati TV, DVD, slušati muziku i gledati slike bez pokretanja Windowsa. I to sve preko daljinskog.
Je da je stari socket, da nema PCI-e slota i ostalih điđa miđa ali za nekog tko koristi komp za internet, glazbu i TV, a Playstation2 i fotelju za igranje, ovo je i više nego dovoljno. Veliki plus je i što je praktički nečujan.
Nekima bi minus mogao biti to što stane samo jedan hard, što moraš koristiti integriranu grafu i zvuk da bi mogao koristiti Instant On al' ni jedan proizvod nije savršen pa tako ni ovaj.
Ovaj post je trebao biti puno duži i informativniji ali se netko u HEP-u igrao manja-veća i ugasio mi struju taman kad sam trebao postati. Prelijen sam pisati dva puta pa pitaj ako te nešto zanima. Ionako gore imaš cijeli review.
"I told my parents that when I grew up I wanted to be a musician.They said it had to be one or the other"
newalss je offline   Reply With Quote
Staro 02.11.2006., 18:27   #5
newalss
newalss's Avatar
Lokacija: Đakovo
Postovi: 826
Dupli post. Pozdrav serveru koji je izgleda u drugoj galaksiji. : baad :
