Staro 03.01.2007., 22:59   #91
Tetedeiench
Lokacija: Lille, France
Postovi: 44
Just a small post to keep you guys updated
OCCT PT is right now at 1.1.0.b09 , and will soon be released as... 1.0.3. I've delayed 1.1.0, and want to release an intermediate version, because the changes needed for 1.1.0 would take too long.
This version brings many new features :
*New, more effective Error detection algorithm
*Multi-CPU temperature support
*Custom temperature and voltages support
*Modified graphic design
*Maximum CPU Temperature
*Hyperthreading as Dual-core Option ( i.e. treat a P4 HT as if it was a Dual-Core Pentium 4 ==> launch 2 threads )
It corrects some bugs, including the "Allendale" => "Conroe" one
I've sent a mail to domy_os with the new translation to do (language files to update can be found in the latest beta zipfile, in the locale subdir). About 15 new strings
Just feel free to tell me if you found any bugs
http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b09.zip
Tetedeiench je offline   Reply With Quote
Staro 03.01.2007., 23:02   #92
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,912
Downloading: boxers :
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 03.01.2007., 23:12   #93
Tetedeiench
Postovi: 44
Let me know how things are going for you
Staro 04.01.2007., 05:11   #94
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,500
Samo da napišem što je Tetedeiench napisao na XS-u :
Autor Tetedeiench at XS forums
And keep in mind that we are dealing with a random thing : sometimes an error will be generated, sometimes not. OCCT just stresses your CPU to make an error likely to happen... but the time it is detected and produced may vary. But you can be sure of one thing : you should always trust the program detecting an error. OCCT, SP2004, Prime95 can be trusted Others too, probably. That's up to your own judgement !
i
OCCT is a bit more demanding and stresses the CPU a bit more, from testing results, as the other CPU stability program with error checking.
I'll never be on par with TAT on C2duos
Priznaje da nikada neće moći biti u rangu Intelova TAT-a ali da je u rangu ostalih programa za testiranje stabilnosti, ako ne i bolji
@ Tetedeiench
The 30 minute (auto)test isn`t best at generating errors because of instability, can you improve it somehow? Or is it just simpy made for getting those nice graphs under load ?
EDIT:
Can you make a plug-in for Core Temp, as it is the best programme for temperature measuring of K8 and C2D?
Nice job on Everest plug-in
Zadnje izmijenjeno od: Vuco. 04.01.2007. u 05:22.
Staro 04.01.2007., 05:35   #95
domy_os
domy_os's Avatar
Postovi: 18,395
Tetedeiench, you've got a mail...
Za ostale: promijenio sam "prava brzina" u "originalni takt" i još neke sitnice...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 04.01.2007., 16:26   #96
Mr.Ex.President
Torrent freek
Postovi: 3,912
Autor Vuco Pregled postova
Meni ne radi... napiše:
Ako odaberen ''Yes'' smrzne se
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 04.01.2007., 16:33   #97
Vuco
Vuco's Avatar
Postovi: 9,500
Ja ga nisam probao
Samo sa vidio da je tamo...
Ali bilo je riječi o tome što ne? Čini mi se kao da sam vidio taj error već negdje?
Staro 04.01.2007., 16:53   #98
Tetedeiench
Postovi: 44
i
@ Tetedeiench
EDIT:
Hey vuco Thanks for your message on xtreme
The Auto test will be revamped soon (in 1.1.0). It'll include 1 hour of CPU&RAM, as well as 2 or 3 passes of the new memory checking algorithm.
As for Core temp, i'll look into it, but there isn't any Shared memory or any way to get the readings out of the program... i can't promise you anything. i'll check !
1.1.0 should bring :[*]New memory checking algorithm ( memtest-like, probably less effective though )[*]Revamped graphs ( especially the scales, probably unified )[*]New auto-test (at least one hour + memory checking algorithm)
and more on the way...
I'll try to look into Vista compatibility... as soon as i get my hands on a copy of Vista I'm waiting for one at my work.
Staro 04.01.2007., 16:57   #99
Vuco
Vuco's Avatar
Postovi: 9,500
No problem
Do what you can...
Staro 04.01.2007., 17:03   #100
Mr.Ex.President
Torrent freek
Postovi: 3,912
Ja ga nisam probao
Ma nije mi ni bitno... al
mbm 5 mi je nije baš točan
Speedfan neman
Everest ne radi
Al nema veze, u pozadini otvorin ITE Smart Guardiana
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 04.01.2007., 17:14   #101
Vuco
Vuco's Avatar
Postovi: 9,500
Stari, evo sada probao, stavio čistu instalaciju Everesta (Ultimate V3.50 nešto), pisalo mi je ono da je disejblano, pita dal oću enable-at, roknem OK i sve dela.
Staro 04.01.2007., 17:59   #102
Mr.Ex.President
Torrent freek
Postovi: 3,912
Znači Everest sere... ok, promjenim ga
U mene je bija Ultimate v3.01
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 04.01.2007., 18:33   #103
Tetedeiench
Postovi: 44
I don't quite understand what you guys are saying, but only Everest Ultimate 3.50 and above is supported
Staro 04.01.2007., 18:37   #104
Mr.Ex.President
Torrent freek
Postovi: 3,912
Autor Tetedeiench Pregled postova
I didn´t know that. it`s OK now.:burn:
Periferija
LCD
