04.08.2018., 19:50 | #4621 |
Postovi: 14,575
BusMaster nije to za 16 jezgri. Vjerojatno za jednu ili dvije boost Nego ovo je možda natruha od čega će biti jače sljedeće konzole: AMD Unveils its Most Powerful Semi-custom SoC for a Chinese OEM |
04.08.2018., 21:45 | #4622 | |
Datum registracije: Apr 2017
Postovi: 343
RE: AMD Ryzen Threadripper 2000 Series Specifications and Prices Revealed
04.08.2018., 22:05 | #4623 |
Postovi: 14,575
Ma nije kod ryzena/threadrippera uopće problem hlađenje kod max overclocka, nego silikon tj. node udari u svoj zid i to je to, pa makar imao 20C headrooma 32 core će navodno boostati do 4ghz na svim jezgrama sa stock coolerom, vjerojatno je max OC onda tu negdje još bar 100-200mhz worst case scenario |
05.08.2018., 00:06 | #4625 | |
..starija garda
Postovi: 3,168
"The CPU runs at up to 3.00 GHz of clocks, and has 4 MB of L3 cache. The GPU is equally impressive: based on "Vega," it packs 24 NGCUs, translating to 1,536 stream processors, and the latest feature-set, including DirectX 12 and Vulkan. The GPU engine ticks at up to 1.30 GHz. 8 GB of GDDR5 memory across a 256-bit wide interface, is hardwired to the SoC (no memory expansion)." nekako 3,9 svi do sada su mogli pa racunam da bi to cak i mogao
izgleda skroz odlican --> "The CPU runs at up to 3.00 GHz of clocks, and has 4 MB of L3 cache. The GPU is equally impressive: based on "Vega," it packs 24 NGCUs, translating to 1,536 stream processors, and the latest feature-set, including DirectX 12 and Vulkan. The GPU engine ticks at up to 1.30 GHz. 8 GB of GDDR5 memory across a 256-bit wide interface, is hardwired to the SoC (no memory expansion)."
__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 05.08.2018. u 00:11. |
05.08.2018., 01:35 | #4626 | |
Postovi: 2,138
Meni je isto na prvu zvucalo too much onda se sjetio da 2700x treba 1165 mV za 4GHz tako da nije nemoguce 32core na 4GHz sa zracnim hladjenjem i da bude s nekom razumnom potrosnjom recimo 350W
Zadnje izmijenjeno od: Gigi1. 05.08.2018. u 01:45. |
05.08.2018., 01:54 | #4627 | ||
Postovi: 14,575
Nemojte zaboravit da je 1950x imao 27C offset Stock: Citiraj:
Zadnje izmijenjeno od: Manuel Calavera. 05.08.2018. u 02:05. |
05.08.2018., 21:22 | #4628 |
Postovi: 6,773
NDA za Threadripper 2 seriju istječe sutra, bar kad su u pitanju službene specifikacije nadolazećih modela. Mada, po svemu sudeći to je samo potvrda većine informacija koje proteklih mjesec dana kruže Internetima. |
06.08.2018., 00:11 | #4630 |
Postovi: 14,575
Izlazak je navodno 13.08. |
06.08.2018., 11:08 | #4632 |
Postovi: 343
AMD Ryzen Threadripper 2990WX 32 Core CPU Is 53% Faster Than Intel’s Core i9-7980XE 1
https://wccftech.com/amd-ryzen-threa...nch-benchmark/ Hehehe..... AMD Ryzen Threadripper 2990WX TDP 250W Cinebench R15: 5099.3 Points stock Intel Core i9-7980XE TDP 180W Cinebench R15: 3335.2 Points stock Intel Core i9-7980XE OC 4.9Ghz TDP 900W Cinebench R15: 5049.7 Points max OC with Delid |
06.08.2018., 14:35 | #4633 |
Postovi: 343
AMD Ryzen Threadripper 2990WX Now Available For Pre-Order
07.08.2018., 12:20 | #4636 |
Postovi: 14,575
Moguće je svaša. Nisam vjerovao da mogu ponuditi više od 8c16t na AM4, no 12 i 16c je izgleda tehnološki moguće (što ne znači da će i ponuditi.). IMO sve iznad 8c16t na AM4 će biti tough sell gamerima, streamerima i sl. Naravno ne koriste svi pc za zajebanciju (znam jednog koji bi jedva dočekao više jezgri), ali većina da |
