Staro 23.11.2023., 20:31   #1
santos
santos's Avatar
Lokacija: Čakovec / AT
Postovi: 1,782
(riješeno) RAW copy tool kloniranje diska - HELP
Pozdrav!
znaci u kompu imam 1 TB samsungov NVME (970 evo) na kojem su izmedju ostalog i windowsi 10.
htio bi klonirati komlpetan disk na novi , 2 TB samsungov NVME (970 evo plus),
dakle podatke, windowse, master boot record, settingse , sve, tak da poslje ovaj od 1 tb mogu stavit u nvme enclosure i koristit ko prijenosni disk.
problem je sljedeci (sto kaze raw copy tool)
23-Nov-23 20:25:10 Locking device...
23-Nov-23 20:25:10 Unable to lock source device. Make sure you do not have open files on this device and try again.
23-Nov-23 20:25:10 NOTE: This tool will NOT copy your boot (OS system) hard drive. The tool requires absolutely exclusive access to the source media.
23-Nov-23 20:25:10 If you want to copy/image your boot hard drive, then you would need to attach it temporarily to another PC and perform the task on that PC.
da li se ovo ikak da zaobici / dati permissione da kopira disk na zivo dok se windowsi vrte ili moram s bootabilnog sticka pokrenut drugu verziju windowsa, pa onda u njima sklonirat jedan disk na drugi?
slow is smooth, smooth is fast...
santos je offline   Reply With Quote
Staro 23.11.2023., 20:35   #2
BinaryJesus
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 273
Macrium Reflect može clonat live windows.
https://pureinfotech.com/clone-windo...crium-reflect/
BinaryJesus je offline   Reply With Quote
Staro 23.11.2023., 21:05   #3
driftwood
driftwood's Avatar
Datum registracije: Jan 2010
Lokacija: .
Postovi: 680
Meni je DiskGenius sve riješio. I "live" kloniranje.
Autor driftwood Pregled postova
Samo bih preporučio program koji sam koristio za kloniranje diskova - DiskGenius. Program je besplatan i radi odlično, bar je meni odradio sva kloniranja nedavno.
Prebacivao sam win10 (500gb HDD na 240gb SSD). I win7 (640gb HDD na 480gb SSD) iz samih windowsa (potrebno instalirati Windows AIK /ADK), reboot i odradi sve. I još neke HDD na HDD sa podacima, ali kako nisu sistemski diskovi nije vrijedno spomena.
Isprobao sam par drugih programa i uvijek je bio problem što su "target" diskovi bili manjeg kapaciteta, ili nakon kloniranja nije htio bootat... Sa diskgenius nije bilo problema. Ima opcija "keep size..." što sam čekirao da boot particije ostanu netaknute, a ostalu particiju (npr. C) samo smanji. Naravno, nisam isprobavao sa punim diskom, bilo je mjesta da sve sjedne na svoje mjesto. Meni je program top. Možda nekom pomogne.
Dazed and confused
driftwood je offline   Reply With Quote
Staro 23.11.2023., 21:07   #4
santos
santos's Avatar
Postovi: 1,782
meni disk size nije problem, jer je source 1 TB a target 2TB
bitno mi je da doslovce sklonira cijeli disk, tako da dok ovaj od 1 TB izvadim, dize OS sa 2 TB i imam sve gore kak sam imao na prvom.
dok idem na clone disk, kaze mi da je preporucen da idem na OS migration.
kenslao, isao ponovno.
nudi mi 3 opcije za kloniranje:
copy all sectors
copy valid data sectors only
copy all files
kaj odaberem?
Zadnje izmijenjeno od: domy_os. 23.11.2023. u 22:09. Razlog: spojeni postovi
Staro 23.11.2023., 21:30   #5
Postovi: 23,484
Prva opcija je najsigurnija ali traje najduže.
Staro 23.11.2023., 21:32   #6
strikoo
strikoo's Avatar
Postovi: 942
Acronis Cyber Protect Bootable ISO
strikoo je offline   Reply With Quote
Staro 23.11.2023., 22:08   #7
santos
santos's Avatar
Postovi: 1,782
Rjesio na kraju AOMEI-jem, najjednostavniji je za koristenje, bez gro opcija koje ne znas koje treba odabrat a koje ne
hvala svima!
