Staro 29.10.2019., 13:08   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Gigabyte Aorus Pro x399 tr4 i kompatibilnost DDR4
Pozdrav,
Slažem TR 2950X radnu stanicu, a baza je Gigabyte Aorus Pro x399. E sad, za to trebam hrpu rama. Maksimum zapravo, što bi trebalo biti 128GB. Gledao sam HyperX 2x16 3466 MHz kitove, ali na službenoj listi podržanih modula nema niša više od modula od 8GB iznad 2400 MHz.
Ima li tko iskustva s tom pločom i modulima od 16GB?
Ispalo je da o RAM-ima znam puno manje nego što sam mislio. Jel može možda netko pojasniti što Gigabyte-u znači ovo;
1. 8 x DDR4 DIMM sockets supporting up to 128 GB of system memory - jasno
2. Quad channel memory architecture - jasno
3. Support for DDR4 3600+*(O.C.)/ 3466(O.C.)/ 3333(O.C.)/ 3200(O.C.)/ 2933(O.C.)/ 2800(O.C)/ 2667/ 2400/ 2133 MHz memory modules
* Recommend to use a 1st Gen. Ryzen™ Threadripper™ processor to achieve 3600MHz (O.C.) speed. - Znači li to da za više od 2667 MHz treba "ručni" overclock?
4. Support for ECC Un-buffered DIMM 1Rx8/2Rx8 memory modules - - jasno
5. Support for non-ECC Un-buffered DIMM 1Rx8/2Rx8/1Rx16 memory modules Je li navedeni HyperX buffered ili nije? I znači li to da idu 16GB moduli, ali samo u "single channelu"?
6. Support for Extreme Memory Profile (XMP) memory modules
- jasno
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 29.10.2019. u 13:15.
estugarda je offline   Reply With Quote
Staro 29.10.2019., 14:24   #2
jjd37
jjd37's Avatar
Postovi: 245
Autor estugarda Pregled postova
Pozdrav,
- jasno
Za 3 - uključivanje XMP - samo po sebi je OC memorije
Za 5 - verificirani moduli s XMP za 4 slota: HX434C19FB2K4/64 ; HX434C19FW2K4/64 ; HX434C19FR2K4/64 - znači da nema garancije da će kombiniranje 2 kita (2x64GB) raditi u svih 8 slotova (i da će uopće raditi zajedno) a da će podržavati i XMP; prvi verificirani kit za svih 8 utora je HX430C15PB3K8/128 (sam po sebi 128GB kit). (https://download.gigabyte.com/FileLi...s-pro_180W.pdf )
Ova oznaka 1R i 2R znači da se čipovi na pojedinom modulu fizički nalaze samo s jedne strane ili s obadvije i nema veze dali je određeni tip memorije "buffered" ili nije.
| MSI Z97 MPOWER (MS-7915) | Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz - Noctua NH-D14 | Coolermaster Stacker | 4x G.Skill F3-10666CL7-2GBRH | OCT Vector 180 240GB, Hitachi HDS721010CLA332,ST3250410AS,ST3250410AS | GAINWARD GeForce GTX 980Ti Phoenix GS | Corsair HX 850W | LG L1919S |UPS CyberPower 2200VA |
| ASRock EX58 Extreme | CPU Intel i7 920 | Corsair 3x2GB | WDC WD5001AALS,WDC WD6400AAKS,SAMSUNG HD322HJ,ST3160813AS,,ST3300622AS,WDC WD800JB-00JJC0 | CrossFire Sapphire ATI Radeon HD4890 Vapor-X | Corsair HX850W | CIBOX 22" | UPS Trust PW4105 |
| Spectrum 48K | Comodore 128 | PC 386 |
| Dell Latitude D820 |
jjd37 je offline   Reply With Quote
Staro 29.10.2019., 19:02   #3
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,585
Pisao sam u threadripper/epyc temi (btw mogao si i ti tamo postat) o tipu koji je uzeo taj cpu i 128gb ram za x399 gigabyte designare (mogao je uzeti i bolju, msi megica je bila best buy), ram je uzeo hyper x 3600mhz (koji nije b-die) i zadnje što sam čuo je da rade na 3000mhz, ništa tada nisu twekali i pokušavali.
No bitno je reći da brzina rama kod workstationa ne znači aposolutno ništa, to ima utjecaj na performanse samo kod high end gaming konfe i naravno memory benčmarcima
Staro 29.10.2019., 23:18   #4
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor jjd37 Pregled postova
OK. Get it. Hvala.
Kako točno znati koji su b-die? Znam da su u pitanju Samsung i Hynix, ali nisu svi, zar ne?
Ovo je sve manje točno. Recimo cca 25% svojeg posla odrađujem u Unreal engine-u, i vjerujem da će taj postotak rasti. Tako da je meni i to bitno.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 29.10.2019. u 23:26.
Staro 30.10.2019., 10:20   #5
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
Imam x399 aorus gaming 7 i 128 gb ove memorije, i imam 1950x
https://www.uzishop.hr/ddr4-memorije...2F64&results=1
iako memorija nije na listi podrzanih za 1st gen, a za 2nd gen je, radi mi sve osim xmp profila.
Manualni overclock nisam probao jos
Staro 30.10.2019., 11:00   #6
Gigi1
Postovi: 2,138
nije bas tako, ovisi o useru kako ce upogoniti mašinu, odnosno za što.
npr.na novinarskoj prezentaciji 1st gen epyc, amd je vrtio neke rudarske simalacije za naftu i plin te pregazio intela zbog veceg mem.bandwitha, kao što je bitan br.kanala tako je bitna i brzina rama za bandwidth.
Staro 30.10.2019., 11:38   #7
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Da da. CAD više nije samo vektorsko crtanje/modeliranje i onda render. Sad to sliči gejmerskom setupu više nego ikad.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 30.10.2019. u 13:15. Razlog: tipfeler
Staro 30.10.2019., 15:12   #8
Manuel Calavera
Postovi: 14,585
Autor Gigi1 Pregled postova
OK, ne znam za unity i rudarske simulacije, no klasični workstation programi ne pokazuju nikakvo skaliranje ili je jako maleno od 2133 do 3200mhz (blender, cinebench tj. cinema4d, simulacijski euler3d itd.)
Staro 15.01.2020., 21:44   #9
mzex
Lokacija: Varazdin
Postovi: 72
Imam 2990wx i memorija je po defaultu radila na 2133 MHz.
Rezultat u Vray benchmarku je bil 23000. Kad sam memoriju digel na deklariranih 3000 MHz rezultat je skočil na 27000.
Druga konfiguracija je s 3970x i kod njega nema razlike s različitim klokovima memorije.
mzex je offline   Reply With Quote
