Staro 02.05.2019., 16:01   #61
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,717
Ma super je žica. Došao sam sa žice na zrak, pa sam svijestan toga. Ali samo kad je postavljena, ili kad je nije velika tlaka postaviti.
Ne treba mi VoIP ni IPTV. To me ni ne zanima, pa nisam ni razmišljao o tome. Ne namjeravam zadržavati ISP router, ako uzmem novi.
Uglavnom, odlučio sam.
Po kući definitivno idem sa UTP-om. Problem je što sam sve bužire zapunio, pa će biti povuci potegni.
Za radnu sobu idem sa powerline-om.
Pa ću vidjeti kako se bude ponašalo.
Hvala.
It just works. Except when it doesn't.
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
VGA: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: Dell U2715h + U2407WFP
Audio: Asus Xonar U7 MK2 + Logitech Z-5500 5.1
Input: Logitech G915 + Logitech G602
OS: Windows 10 Pro x64
Asus N76VZ
CPU: 7-3610QM @ 2.30GHz
RAM: 2x8GB DDR3 HyperX 1600
VGA: NVIDIA GeForce GT 650m 2GB
SSD: Crucial MX100 256 GB
HDD: WD Scorpio Black 750GB @ 7200
Audio: Fiio Q1 DAC + AudioTechnica M50x
Input: Logitech G915 + Logitech MX Master 2S
In progress...
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
VGA: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
VGA: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3
2016: FX-8320E, Asus M5A97 PRO
2015: i7 6700k, Asus Z170-A
2014: FX-8350, ASRock 990FX Extreme3
2012: i7 3610QM, Asus N76VZ
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4
2009: Intel C2Q Q6600, GIGABYTE EP31
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x
2008: Intel Core2Duo T7200, Toshiba A100-847
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110
2002: AMD Duron 1200, Matsonic MS8127C
2001: AMD Duron 800, Matsonic MS8127C
1998: Intel Pentium II 300 Klamath
1996: Intel Pentium 120
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 02.05.2019., 16:07   #62
dadoremix
dadoremix's Avatar
Postovi: 4,518
e to nikky .. meni se nije dalo pisat, pa sam preskočio
isto kao i u jednoj temi sugeriram da rebuta modem i vidi šta se dešava, ali user i dalje trubi po svojem
barem nije napomenuo da je to učinio i da ne pomaže
al evo.. ovo mi se sad dalo pisat, ipak je jučer bio praznik rada i več sam se naradio
Staro 02.05.2019., 19:19   #63
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,717
Kakve veze ovo moje ima s rebootanjem "modema"? Ne kužim...
Sent from my SM-N950F using Tapatalk
HDD: Toshiba 3TB
PSU: Corsair CX650M
Asus N76VZ
In progress...
VGA: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 02.05.2019., 19:29   #64
dadoremix
dadoremix's Avatar
Postovi: 4,518
nema veze u temi .. napisao sam da u jednoj temi
ajmo dalje.. powerline kod tebe u akciju i povuci lan kabel
Staro 02.05.2019., 19:53   #65
lobo64
lobo64's Avatar
Postovi: 1,327
Staro 06.05.2019., 10:56   #66
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,717
E imam još jedno amateur pitanje. S obzirom da moj šroteks innbox router ima 1 gigabitni lan port i 3 100mbit-na, a uzeo sam gigabitni powerline, ima li smisla staviti na taj jedan gigabitni switch, pa iz njega izvlačiti i za powerline, i za druge uređaje po kući?
HDD: Toshiba 3TB
PSU: Corsair CX650M
Asus N76VZ
In progress...
VGA: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 06.05.2019., 11:25   #67
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,448
Ima smisla ako ti treba gigabitni prijenos podataka preko mreže, inače nema iako je to relativno mala investicija. Po meni ti je bolje uložiti u kvalitetniji router s više gigabitnih portova
Staro 06.05.2019., 11:30   #68
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,717
Npr.koji?
S obzirom da su me ovdje odgovorili od fancy wifi router pristupa...
HDD: Toshiba 3TB
PSU: Corsair CX650M
Asus N76VZ
In progress...
VGA: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 06.05.2019., 11:38   #69
Alister
Alister's Avatar
Postovi: 1,448
Ne mora biti fancy router, ali meni je osobno bezveze imati switch pored routera, onda bi radije postavio svoj router koji je neovisan od providera.
https://www.protis.hr/products/detai...ste-psu/132865
https://www.protis.hr/products/detai...e-antene/89601
https://www.protis.hr/products/detai...-rtac53/117155
Ili ako želiš više novaca potrošiti jer ti je potrebno radi nečega onda gledaj klase iznad toga.
Nikky ti je to lijepo objasnio:
Autor Nikky Pregled postova
Zato se napravi:
- ostaviš VoIp i IpTv na njihovom uređaju
- gasiš WiFi na njihovom uređaju
- sam ili preko SZK prebaciš Internet konekciju u Bridge mode i dobiješ (tražiš) podatke za PPPoE konekciju
- iza njega stavljaš svoj router, podesiš PPPoE konekciju
- vozi Miško
Eto, zato
Staro 09.05.2019., 21:07   #70
inaki
inaki's Avatar
Lokacija: Zgb
Postovi: 237
mislim se ovo uzeti Router MIFI Alcatel MW40V, u Iskonu je 390kn
jel se isplati ili mozda imate preporuku za nešto drugo u tom cjenovnom rangu...
hvala
inaki je offline   Reply With Quote
Staro 09.05.2019., 21:49   #71
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,010
koristio biš ga za iskon mobile wifi, već kad gledaš iskon? jer ako da - ta usluga radi najnormalnije u mobitelu, pa da ne bacaš pare ako ti treba samo za to...
Staro 09.05.2019., 23:03   #72
inaki
inaki's Avatar
Lokacija: Zgb
Postovi: 237
Autor jp_rv Pregled postova
da isao sam u tom smjeru...ma problem je sto na moru gdje khetuhen i nije bas neki signal na iskonu vise je E nego G pa sam mislio da su ti ruteri bolji za primanje signala a i prenosni su...
Staro 10.05.2019., 09:34   #73
jp_rv
Lokacija: istra
Postovi: 3,010
ako ti na mobu ne ide, ti mali prenosni nisu nešto naročito bolji, kad imaju majne-više antene istih dimenzija. naravno, neznam za navedeni alcatel.
ako ti iskon šteka, ili si kupi pravi router na kojeg možeš montirati vanjske antene, ili promijeni providera koji na tvom području ima bolju pokrivenost.
Staro 11.05.2019., 10:31   #74
inaki
inaki's Avatar
Lokacija: Zgb
Postovi: 237
zahvaljujem @jp_rv...
Staro 16.05.2019., 00:11   #75
lokoloko
Datum registracije: Jun 2012
Lokacija: worldwide
Postovi: 57
Upadam u temu, al je slično pitanje:
Imam tcomv ovaj "hibridni" ruter pošto je na bakru katastrofa. Kontam pogasit sve što se da na njemu i iza stavit Switch/AP da mogu pratit promet po mreži.
telefon se inaoko ne koristi, jedino za maxtv i dalje sav internet preko switcha.
Što uzet? (nemojte mikrotik molim vas)
lokoloko je offline   Reply With Quote
Staro 16.05.2019., 09:08   #76
Postovi: 16,104
Ja sam uzeo Xiaomi Mi 3 router, 239kn kod nas, vjeruj mi, odličan je.
Kontroler je jednostavan, ima sve što treba. Whitelist, blacklist, block MAC adrese, dual-band wifi, 1Gb brzina itd.
Instalacija i setup traje točno 3 minute.
Staro 16.05.2019., 09:32   #77
alengrosevic
alengrosevic's Avatar
Postovi: 3,742
dali si probao koliko je lan to wlan brzina? odnosno npr ako imaš neki NAS spojen žicom, koliko ti preko wirelessa vuče?
thnx!
Staro 16.05.2019., 09:36   #78
Postovi: 16,104
Nemam NAS doma na žalost, no mogu ti reći ovako.
Imam doma brzinu 200/100, na žici dobivam oko 180/100 bez brige.
Na wifi-u oko 120/80 po cijelom stanu, što na laptopu, što na mobitelima.
Imao sam Unifi AP-LR prije toga, on mi je davao oko 150/90, znači tu je unifi jači, ali je zato 3x skuplji.
Kada se spojim kablom direktno u Mi Router, dobivam lockano 200/100, ide i više, samo ga profil ograničava.
Staro 16.05.2019., 09:49   #79
jp_rv
Lokacija: istra
Postovi: 3,010
nije li 120mbita malo MALO za 5ghz wifi? meni i tp-link archer i speedport od t-come daju 300mbit dok sam dovoljno blizu njih, a onda pada na 100-150mbit kako idem iza zidova
Staro 16.05.2019., 10:03   #80
Postovi: 16,104
Pa imam brzinu 200, kak će mi dati 300?
Imao sam ja i 600mbit download na wifi-u, ali je bio giga uplink.
Zadnje izmijenjeno od: Mommistake. 16.05.2019. u 10:38.
Staro 16.05.2019., 10:09   #81
Alister
Alister's Avatar
Postovi: 1,448
ne treba brkati brzinu Wi-Fi-a i brzinu interneta.
Staro 16.05.2019., 14:37   #82
skalar
skalar's Avatar
Datum registracije: Apr 2015
Postovi: 1,535
brzina Wi-Fi-a na 5ghz ti u pravilu ovisi o mrežnoj (usb stick) na kompu, na routerima su u pravilu "ac 1200" pa naviše, mrežne pak "ac 300, 600, 1200, 1900" realna brzina ti je otprilike nešto više od pola deklarirane,
što se NAS-a tiće -ako hočeš najbržu vezu trebaš nabavit NAS koji ima dvije mrežne i router koji podržava "link aggregation",
dok NAS možeš naći nešto skuplje od ovih sa jednom mrežnom sa istim harwareom,
routeri sa "link aggregation" spadaju u gornju klasu u pravilu preko 1k kn,
razlika u brzini prenosa je bar kod mene 40-50MB/s sa jednom mrežnom sa "link aggregation" 110-130 MB/s, sa AC 1200 mrežnom što se tiće prenosa unutar mreže sa NAS-a nebi trebalo biti razlike žično - bežično imaš i switcheve koji podržavaju "link aggregation" koji isto nisu baš jeftini.
Zadnje izmijenjeno od: Nikky. 16.05.2019. u 14:45.
Staro 16.05.2019., 16:57   #83
alengrosevic
Postovi: 3,742
Hvala na infu! Za tih 230 kn je odličan router. I ako je samo malo slabiji od Unifi-a, izvrsna kupnja.
Meni HAP AC2 gura 170/100 preko wirelessa (profil je 200/100), sad sam naručio malo bolji USB adapter pa ću vidjeti da li mogu još malo podignuti brzinu.
Kako je s pokrivenosti naspram Unifia?
Staro 16.05.2019., 20:17   #84
RainZG
Postovi: 524
Autor skalar Pregled postova
Kod tebe ocito nesto ne stima jer pravi NAS koji ima brze diskove sa 1x gigabitnom mreznom karticom gura 110 MB/s bez problema. Igracke od Western digitala i slicnih to nece postici.
Isto tako, managed switch koji podrzava link aggregation kosta oko 400kn 8portni(dlink, ne znam koji model tocno)
RainZG je offline   Reply With Quote
Staro 16.05.2019., 23:39   #85
float
Datum registracije: Jun 2017
Postovi: 47
Kako je moguće dobiti više od 100Mb/s ako specifikacije uređaja navode:
Code:
2x LAN port, 10/100Mbps (Auto MDI/MDIX)
1x RJ45 WAN port, 10/100Mbps (Auto MDI/MDIX)
Source: https://www.mi.com/my/mi-router-3/specs/
Čini mi se da se misli na Mi Router 4 koji ima gigabitne portove, ova trica navodno nema.
Kod mene hAP ac2 na wifi vuče oko 300 Mb/s.
float je offline   Reply With Quote
Staro 19.05.2019., 12:53   #86
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,717
Autor estugarda Pregled postova
Hvala.
Operacija uspjela. LAN po kući. Powerline do radne sobe. Sve složeno na gigabit, a žice i konektori spremni za 10Gb (cat.6) ako mi bude trebalo. Zadovoljan sam mrežom. Posebno me oduševio Powerline. 0 problema. Uštekano i otprve radi na maksimalnom signalu, makar imam 3-faznu struju povučenu, tko zna kako i kada, do radne sobe. Brzina ista kao na žici.
ISP za sada ostaje.
Ne vidim razlog da ga mijenjam trenutno. S obzirom da sam na većini uređaja prešao na LAN, sad i WiFi bolje radi na mobilnim uređajima.
Što se Powerline tiče, imam i dilemu oko zaštite od u groma/munje. No neću spamati ovdje. Stavio sam post u "Powerline" temu. Pa ako tko ima savjet...
HDD: Toshiba 3TB
PSU: Corsair CX650M
Asus N76VZ
In progress...
VGA: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 19.05.2019. u 12:59.
Staro 20.05.2019., 15:16   #87
Postovi: 22,506
TP-Link Archer A serija WiFi routera
Pošto se često pita šta uzeti, kakve su katakteristike, ...
Evo najave TP-Linka za novu "jeftiniju" Archer A seriju > https://www.snbforums.com/threads/tp...routers.55682/
pa se informirajte
Staro 20.05.2019., 16:05   #88
Postovi: 16,104
Autor float Pregled postova
Code:
https://www.wowshop.hr/xiaomi-router3.html
5G WiFi: 2X2 (support IEEE 802.11AC, 867Mbps max)
EDIT: Ti pričaš o kablu, ne?
Da i ja sad gledam. Moguće da imam četvorku, ali kupio sam toga sa slike, nisam ni gledao koji mi je došao.
Mada, nekako brijem da krivo piše, iskreno. Ja sam ga platio 239kn, a brzina je svakako išla preko 100mbit/s.
Zadnje izmijenjeno od: Mommistake. 20.05.2019. u 16:20.
Staro 20.05.2019., 17:47   #89
Overclock_freak
Datum registracije: Dec 2012
Lokacija: Rijeka-Zagreb
Postovi: 1,206
pa se informirajte
Offtopic..
Koliko vidim iz postova dosta radiš sa mrežom pa si upoznat.
Stavljao sam bio prije svih brandova i svašta, što za upotrebu u stanu, kući, apartmani, point to point i slično
Kad sagledam 5 godina i nekakvu statistiku problema i kako to sve radi
Dolaziš do rješenja da UBNT, Tik je oprema koja radi no matter what
TP Link je inače bio bestbuy ali zblesirat se zna, point to point nekad kod njih zajebava za usrat se pa dok dobiješ neki beta fw kod njih koji to ispravlja se načekaš itd
Da bi u konačnici došao da dodam 200kn više za tika i zaboraviš ikada da nešto neradi
Staro 20.05.2019., 20:59   #90
Postovi: 22,506
A čuj, svaka roba ima svog kupca, ... Tik treba znati složit (za goli AP malo manje), ove jednostavne SOHO ljudi ipak mogu podesiti sami (uglavnom).
Da ne spominjemo sad PortForward / Firewall koji na Tiku treba "kukičati" a kod ovih ga već imaš (kakav - takav),
ili još zeznutiji detalj šta Tik - ove vole "napadat".
Ovaj gornji post je samo informativnog karaktera a ne "morate uzeti to"
