Staro 31.05.2016., 18:09   #1
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Intel "Skylake-E" LGA-3647 Info Thread
Taman izašao Broadwell-E, a već postoje neke naznake za nasljednika.
Opet memorija u višekratnicima broja 3 i 1636 dodatnih pinova za skenjati kod montaže.
Intel Skylake-E will use new LGA 3647 socket and use 6-channel DDR4 memory
In recent years, every series of Intel motherboards has supported two generations of CPUs, be it LGA 2011 (X79), LGA 1155, or LGA 1150. It is now expected that with Intel's upcoming Skylake generation of Xeon and Skylake-E series CPUs that Intel will be moving to a new, larger socket designs and will be upgrading several key parts of their server platform.
Below we can see a picture of what is thought to be Intel's upcoming Skylake-E socket LGA 3647, which will feature 6-channel/Hex-channel DDR4 memory and will feature a larger number of PCI lanes than the previous generation of Intel Xeon CPUs.
Right now it is believed that Intel's Skylake-E Xeon CPUs will feature 48 PCI 3.0 lanes, giving CPUs on this platform the ability to run with more PCI devices like GPUs, ultra-fast storage, and other PCI devices with the hex-channel memory providing the CPU with much more memory bandwidth and support for much higher amounts of onboard memory.
This new CPU socket is huge, with a total of 1636 more pins than Intel's current 2011-3 platform, making Intel's Skylake-E CPUs considerably larger than their current Generation Broadwell-E based chips.
http://www.overclock3d.net/articles/..._ddr4_memory/1
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen!
vedranzeman je offline   Reply With Quote
Staro 31.05.2016., 19:34   #2
Bariarnil
Autor vedranzeman Pregled postova
Ma moralo se brzo počet pricat o tome.
To znači(mnogo veći soket)mnogo više jezgara.ipak,canonlake bi trebao se maknut sa samo 4 jezgre na mainstreamu pa mi je jasno zasto ide tolki soket.A i AMD-ov Zen server ce imsti max 32 jezgre sa SMT.Voli i intel jezgrice.
Staro 01.06.2016., 08:59   #3
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,779
Drama drama drama. Power8 vec preko 2 godine ima 15k i jos kusur pinova/padova pa nitko ne kuka.
Programer
Staro 01.06.2016., 09:41   #4
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,313
Sad ce trebat pola sata za pregledat sve pinove u trgovini prije kuplje maticne .
Staro 04.07.2016., 00:18   #5
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,779
https://www.supermicro.com/manuals/s...r/MNL-1891.pdf
Izgleda da Xeon Phi ide na isti socket.
Programer
Staro 05.10.2016., 08:44   #6
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,313
Staro 22.10.2016., 17:54   #7
softwaremaniac
Datum registracije: Mar 2015
Lokacija: Doma
Postovi: 144
Izgleda da će novi procesori ipak biti na LGA 2066.
http://wccftech.com/intel-skylake-x-...m-launch-2017/
softwaremaniac je offline   Reply With Quote
Staro 22.10.2016., 18:09   #8
Bariarnil
Da,prije nešto tjedana se to ustanovilo,no serveri bu valjda bili 3647.Treba ipak nešto konkurirat Zen Naplesu sa 32 jezgre.
Staro 23.10.2016., 12:39   #9
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,779
Autor Bariarnil Pregled postova
Mora da je to, jer netko je previdio E7-8890v4 s 24 jezgre i S8S skalabilnoscu... Oh, wait, pa to vec postoji, za razliku od imaginarnih AMD procesora.
Programer
Staro 23.10.2016., 13:52   #10
Garro
Postovi: 2,394
Ne kužim koja je svrha Kaby Lake-X, odnosno što on radi u HEDT-u kad su mu specifikacije čisti mainstream, pa ako me netko može prosvijetliti...
Staro 23.10.2016., 16:02   #11
Bariarnil
Autor Garro Pregled postova
KabylakeX bi trebao doci iza Skylake X.Obicno nabacivanje jezgara kao dosad.
Staro 23.10.2016., 22:16   #12
Garro
Postovi: 2,394
Moguće da nisi primijetio, ali tvoj odgovor nema smisla s obzirom da Skylake ima više jezgara od Kabylake-a.
Staro 23.10.2016., 23:22   #13
Bariarnil
Kolega molio bih link gdje se potvrduje tocno o cem se radi.Do KBX ima vjerojatno godina dana i tesko da se zna tocan broj jezgara ��
Edit:http://wccftech.com/intel-skylake-x-...m-launch-2017/
Neznam,ili je ovo što oni kažu(112w tdp 4core???)ili rumori zasad ne štimaju.
Zadnje izmijenjeno od: Bariarnil. 23.10.2016. u 23:27.
