Staro 01.01.2013., 15:30   #1
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,025
ATI Catalyst 12.11 Beta 11 Modded driver For Legacy GPU
Evo veselja za nas koji vozimo HD2,3,4xxx seriju
Hey guys, I have finally completed the ATI Catalyst 12.11 Beta 11 driver for HD2000-HD4000 GPU. I modded this driver mainly to gain performance in Dx9 games and also to unlock hidden features within ATI Catalyst Software.
Source
Driveri su za Vista / 7 / 8
Instalacija za 64bit OS je malo drugačija i treba se uključiti Test Mode da se eliminira driver sign check:
1. Download The Driver
2. Enable Test-Mode so you can freely install and use the driver.
You can do so by running Command prompt as an Administrator then
type or copy and paste this: bcdedit -set TESTSIGNING ON
3. Press Enter when your done and wait until it says Completed Successfully
4. Restart your Operating System
5. Extract the 64 Bit Modded driver that you downloaded
6. Run Setup.exe
7. Uninstall your Current Driver
8. Install Modded Driver
Malo proučavam i čitam reakcije ostalih pa još neću stavljati. Ako ima neki kamikaza ovdje nek stavi drivere i javi kako je prošlo
EDIT: Dok su neki dobili nešto fps-ova u igrama u nekim slučajevima dolazi do BSOD-a, trzuckanja i slično. Testirajte na vlastitu odgovornost, dobro proučite kaj radite i na koji način da ne bi bilo nismo znali
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Zadnje izmijenjeno od: Mario92. 01.01.2013. u 15:41. Razlog: Dopuna
Staro 01.01.2013., 19:47   #2
klem
Postovi: 591
Autor Mario92 Pregled postova
Source
nemam potrebe testirat ovakve delance...12.6 legacy offical radi sasvim uredno.
klem je offline   Reply With Quote
Staro 21.01.2013., 02:34   #3
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,025
Evo znači lik kontantno radi na driverima, uskoro se prebacuje na 13.1 pa ćemo onda vidjeti. Komentari su sada dosta pozitivniji pa mislim da ću ubrzo probati i ja
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
