28.07.2017., 13:32 | #391 | ||
Postovi: 535
Code:
1 1049kB 256MB 255MB primary ext2 boot 2 257MB 21.0GB 20.7GB extended 5 257MB 21.0GB 20.7GB logical lvm Code:
udev 2.0G 4.0K 2.0G 1% /dev tmpfs 396M 628K 395M 1% /run /dev/dm-0 15G 3.0G 12G 21% / none 4.0K 0 4.0K 0% /sys/fs/cgroup none 5.0M 0 5.0M 0% /run/lock none 2.0G 0 2.0G 0% /run/shm none 100M 0 100M 0% /run/user /dev/sda1 236M 74M 150M 34% /boot Citiraj:
Code:
Information: You may need to update /etc/fstab. Code:
# /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> /dev/mapper/graylog--vg-root / ext4 errors=remount-ro 0 1 # /boot was on /dev/sda1 during installation UUID=f3c82967-d226-4c5a-99bd-2ecb6a31adfc /boot ext2 defaults $ /dev/mapper/graylog--vg-swap_1 none swap sw 0 0 Code:
fd0 2:0 1 4K 0 disk sda 8:0 0 19.5G 0 disk ├─sda1 8:1 0 243M 0 part /boot ├─sda2 8:2 0 1K 0 part └─sda5 8:5 0 19.3G 0 part ├─graylog--vg-root (dm-0) 252:0 0 15.3G 0 lvm / └─graylog--vg-swap_1 (dm-1) 252:1 0 4G 0 lvm [SWAP] sdb 8:16 0 100G 0 disk loop0 7:0 0 0 loop loop1 7:1 0 0 loop loop2 7:2 0 0 loop loop3 7:3 0 0 loop loop4 7:4 0 0 loop loop5 7:5 0 0 loop loop6 7:6 0 0 loop loop7 7:7 0 0 loop Zadnje izmijenjeno od: Wuchko. 29.07.2017. u 11:44. |
28.07.2017., 13:45 | #392 |
Datum registracije: Feb 2004
Postovi: 1,030
Bilo bi lakse citati da je u CODE tagovima. Po meni samo trebas nastaviti. Disk je tu, ali nema particije i filesystem. Code:
#kreiras particiju $ sudo parted -a optimal -- /dev/sdb unit compact mkpart primary ext3 "1" "-1" #kreiras fs $ sudo mkfs.ext4 /dev/sdb1 |
29.07.2017., 11:41 | #393 |
Postovi: 535
Puno hvala na odgovoru! Ispravio sam prijašnji post. U međuvremenu sam uspio, no na nešto drugačiji način (logiran sam kao root user): Code:
$parted /dev/sdb (parted) -a optimal /dev/sdb mklabel gpt (parted) -a optimal -- /dev/sdb unit compact mkpart primary ext3 "1" "-1" (parted) quit $mkfs.ext4 /dev/sdb1 .... |
31.07.2017., 14:49 | #395 |
Postovi: 535
Evo mene opet. Dakle, sada bih na radne stanice trebao instalirati Graylog Collector Sidecar da bi Graylog mogao prikupljati logove. I sve to uredno radi dok je GCS upaljen i vidljiv na radnoj površini, no ono što me muči je - kako ga dodati kao Windows service, znači da se vrti neprimjetno u pozadini? Na ovom linku postoje upute no uopće ne kužim na koji način ovo riješiti, posebno ove dijelove: Code:
$ C:\Program Files (x86)\nxlog\nxlog -u $ collector_sidecar_installer.exe Code:
$ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service install $ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service start Puno hvala! |
31.07.2017., 15:56 | #396 | |
Postovi: 1,030
Skini NXLog i instaliraj. Ugasi servis koji se automatski pokrece Code:
$ C:\Program Files (x86)\nxlog\nxlog -u Code:
$ putanja/do/datoteke/collector_sidecar_installer.exe Code:
$ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service install $ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service start |
31.07.2017., 18:37 | #397 |
Postovi: 535
Uspio sam pokrenuti, no sada dobivam poruku "Access denied". Ništa, prespavat' pa sutra isprobavat ponovno EDIT: šugavi AV je blokirao pokretanje, sad je sve ok (bar mislim). Zadnje izmijenjeno od: Wuchko. 31.07.2017. u 18:51. |
31.07.2017., 22:59 | #398 |
..starija garda
Postovi: 3,168
Pitanje je možda više za neki drugi dio podforuma, VM i slično, ali da probam tu. Kupio sam 250hdd i stavio linux tek toliko da s vremena na vrijeme mogu ga malo probati. Stavio sam ZORIN OS u dual boot, i za sad sam zadovoljan. Pitanje je, s obzirom da mi se neda izlaziti iz windowsa, da li se može iskoristi ta instalacija linuxa da se pokrene virtualna mašina pa da iz windowsa vrtim linux?
31.07.2017., 23:44 | #399 | |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,544
Vjerojatno ima neki export u OVF pa ga mozes vrtiti u bilo kojoj virtualki poslje.
Programer
Rok od dva mjeseca u stvari znači četiri, ali nikako ispod šest. |
31.07.2017., 23:45 | #400 | |
Lokacija: München/Varaždin
Postovi: 3,352
https://www.google.hr/search?q=conve...hrome&ie=UTF-8 |
12.08.2017., 21:44 | #401 |
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,481
Od kada sam prešao s Linux Mint 17.3 na 18.2 (čista instalacija, nije nadogradnja), ne radi mi VPN. Znači uredno, s istim openvpn datotekama napravim import openVPN veze kroz GUI. Sve prođe bez greške, uredno se spoji na VPN server, ali internet ne radi, tj. niti jedna stranica se ne može učitati. Ima li tko ideju kako riješiti? VPN server 100% radi, ako se spajam preko mobitela ili drugih računala radi bez greške. |
27.08.2017., 18:52 | #402 |
Postovi: 635
"Niti jedna stranica se ne moze ucitati" nije bas neki podatak. Koji error dobijes? Jel ti resolva DNS ime u adresu? Jel imas spojivost kad pingas neku IP adresu npr. 8.8.8.8? Kad si spojen na VPN pogledaj si rute (netstat -r) i napravi ping pa traceroute na neku IP adresu za koju znas da bi trebala ici preko VPN-a. Moguce da je nesto s firewallom isto, mozda drugacija defaultna pravila na 18.2. |
27.08.2017., 21:16 | #403 | |
Lokacija: Ramura
Postovi: 2,481
