Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 03.03.2011., 22:19   #1
Botlorn
Lokacija: rijeka
Postovi: 543
Folder hyperlink
Poz ljudi,
evo jedno ludo pitanje, možda će netko znati.
Naime, postoji li ikakva mogućnost u Windowsima (bilo XP, bila Sedmica) napraviti neki hyperlink od foldera (ili filea)? Znaci, recimo da u exploreru tražim po datoteci "filmovi" i naiđem na film "13th floor", kliknem alt+lijevi mouse klik i automatski mi pokreće google search u internet browseru s imenom datoteke (govorim o hipotetskoj situaciji, ali razumijete).
Pretpostavljam da takve opcije nema, ali samo sam htio provjeriti
Znači, dedicated tipka ili naredba koja će automatski pokrenuti google search s imenom selektirane datoteke.
Uostalom, ako sam upravo nekom dao ideju i baci se na programiranja, te proda riješenje Microsoftu, molim lijepo
In Construction...
Botlorn je offline   Reply With Quote
Staro 05.03.2011., 22:51   #2
iwwwek
xampp rulez
iwwwek's Avatar
Datum registracije: May 2009
Postovi: 90
Sve se može kad se hoće.
AutoHotkey
Features
AutoHotkey scripts can be used to launch programs, open documents, send keystrokes and send mouse clicks and movements.[2] AutoHotkey scripts can also assign, retrieve, and manipulate variables, run loops and manipulate windows, files, and folders. These commands can be triggered by a hotkey, such as a script that would open an internet browser whenever the user presses Ctrl+Alt+i on the keyboard. Keyboard keys can also be remapped or disabled, such that pressing the letter q, for example, might result in the computer receiving a letter r, or nothing at all.[3] AutoHotkey also allows for 'hotstrings' that will automatically replace certain text as it is typed; the most typical use for hotstrings is expanding abbreviations, such as assigning the string "btw" to send the text "by the way" when typed, or the text "%o" to send "percentage of".[4]
iwwwek je offline   Reply With Quote
Staro 06.03.2011., 21:27   #3
Botlorn
Lokacija: rijeka
Postovi: 543
Hvala na sugestiji, istražiti ću!
In Construction...
