15.04.2017., 16:49 | #3721 |
Datum registracije: Mar 2011
Postovi: 2,705
1 x Gigabyte AB350M-Gaming 3 Socket AM4 (AMD RYZEN™ processor), 4*DDR4 3200, USB3.1/USB 2.0, DVI-D, VGA, HDMI, M.2, SATA III, RAID, GLAN, mATX 1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler 1 x Corsair 2x8GB DDR4 2666 C16 LP 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Toshiba SSD A100, R550/W480, 120GB,7mm,2.5" 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x Fortron Hyper 500W, 80+ - 60mj. 1 x GIGABYTE GeForce GTX 1050 GDDR5 2GB/128bit Ukupno: 6.222kn s forumskim popustom(2%) Zadnje izmijenjeno od: coconut. 15.04.2017. u 19:48. |
16.04.2017., 19:03 | #3722 |
Lokacija: /dev/random
Postovi: 42
Kolega mi predložio ovu konfu: Code:
Procesor AMD Ryzen 5 1600 BOX, s. AM4, 3.4GHz, 19MB cache, Six Core, Wraith Spire Cooler Matična ploča MSI B350 PC Mate, AMD B350, DDR4, zvuk, G-LAN, SATA, M.2, PCI-E 3.0, CrossFire, D-Sub, HDMI, USB 3.1-C, ATX, s. AM4 Memorija PC-21300, 8GB, KINGSTON HyperX Fury HX426C15FB/8 DDR4 2666Mhz SSD 256.0 GB INTEL Series 600p SSDPEKKW256G7X1, M.2, 80mm, PCIe NVMe 3.0 x4, 1570/540 MB/s Grafička kartica PCI-E GAINWARD GeForce GTX 1060, 3GB, DDR5, DVI, HDMI, DP Napajanje 600W, CHIEFTEC Smart Series GPE-600S, ATX v2.3, 120mm vent, PFC Kućište ANTEC NSK4100, MIDI, ATX, crno, USB 3.0, bez napajanja Ukupno: 6.902,48 kn (links.hr) |
16.04.2017., 19:30 | #3723 |
Postovi: 14,575
Izbacio bi msi ploču i ubacio asus b350 prime plus, ili gaming 3 (bilo matx ili atx) od gigabytea Možeš uštediti još na SATA SSD-u, rx 470 4gb (ne referentnu sa blower coolerom). Napajanje recimo hyper 500w ili 600w (5 god. garancije, a jeftino i pristojno), no nemaš ga u linksu. Case zalman z3, z1 neo (dosta gratis ventova) |
17.04.2017., 22:25 | #3724 |
Datum registracije: Apr 2011
Postovi: 1,408
Pozdrav društvo, Trebao bih komentare za kantu, frend mi uzima novo a namjena je office, multimedija i gaming (full HD rezolucija). S tim da za gaming nije siguran koliko će imati vremena ali volio bi da može vrtit nove naslove (kontam da bude 50-60 FPS-a). AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler Gigabyte Main Board Desktop AB350M-Gaming 3 Kingston 8GB 2666MHz DDR4 CL15 DIMM HyperX FURY Black XFX AMD Radeon RX 480 RS GDDR5 4GB Intel® SSD 600p Series (256GB, M.2 80mm PCIe 3.0 x4, 3D1, TLC) HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance Napajanje Seasonic SS-520GB, 520W Fractal Define S, crno s prozorom, bez napajanja To je nekih 7,7 tisuća. Moglo bi jeftinije za cca 500 kn uz običan SSD i npr. Zalman z3+ kućište. Može li se tu složiti nešto bolje za te pare ili jeftinije a da ne gubi na performansama? Razmišljam i o intel + nvidia opciji, tamo je sigurno "plug and play" i može se jeftinije uz i5 i matičnu (ne bih volio neka iznenađenja s kompatibilnošću, BIOS-om, driverima itd., ako je to moguće u AMD slučaju). thx |
17.04.2017., 22:36 | #3725 |
MiningMod
Postovi: 8,682
1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler 1 x Gigabyte AB350-Gaming 3, Socket AM4 (AMD RYZEN™ ), 4*DDR4 3200, RAID, LAN, ATX 1 x Kingston 8GB 2666MHz DDR4 CL15 DIMM HyperX FURY Black, EAN: 740617244397 1 x XFX AMD Radeon RX 480 RS GDDR5 4GB/256bit, HDMI, DVI, 3xDP, DD 2X, Backplate, Retail 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x SSD Patriot Hellfire R3000/W2200, 240GB, M.2 NVMe 1 x Kućište DeepCool Dukase V2, USB3.0, plexy, black 1 x Fortron Hyper 600W, 80+ - 60mj. Ukupno: 7836,40 kn -2% = cca 7650kn *Iako za takav gaming je dosta RX470/570 |
17.04.2017., 22:52 | #3726 |
Postovi: 1,408
Uzeo bih 470 grafu ali zanemariva je razlika u cijeni jer ta 480 je 1,8 tisuća, a ne nađem značajno jeftiniju 470. Izgleda dosta slično mojoj kanti a i cijena je skoro ista. Tih 2% jel to kod uzija? Zadnje izmijenjeno od: coconut. 18.04.2017. u 06:49. |
19.04.2017., 12:30 | #3727 |
Postovi: 560
Bok, tražim novu kantu (nije potrebno da lijepo izgleda) kojoj je primarni zadatak poslovna namjena (2D autocad, i kojekakvi programi za poračune). Proračun mi iznosi cca 6300 kn s PDV-om (trebam R1 račun). U početku sam mislio da neću preživjeti bez i7 procesora, no nakon nešto istraživanja sam shvatio (moguće krivo?) da vjerojatno može koristiti i jača verzija i5 (7500?). OC i pojačano hlađenje me ne zanima. O AMD-ovim procesorima ne znam mnogo. Ostali uvjeti bi bili min 8 Gb RAM-a (za sada, jasno je da će ovo uskoro postati premalo) i 120-240 Gb SSD + HDD (moguće 1 Tb). Moguće da me uhvati kakvo igranje, pa bi bio sretan kada bi u konfiguraciju upala grafička kartica, tako da integrirana ne krade sistemski RAM. Kratica bi trebala izdignuti performanse kante iz područja integriranih kartica u područje „ide igranje, ali ne na nekim visokim rezolucijama/bijesnim detaljima/visokim FPS-ovima“. Svojedobno sam negdje pročitao da je i slabija kratica mnogo bolja od bilo koje integrirane (jesam li u krivu?). Sve je na kraju potrebno zalijepiti na primjerenu ploču i napajanje. Kopanje po trgovinama je došlo do približnih rezultata tipa (potrebne manje izmjene): https://www.centro.hr/extro-havocpro...freedos-1.aspx https://www.instar-informatika.hr/ra...99901/product/ https://www.futura-it.hr/katalog/got...la/futura-037/ Imate li kakvo mišljenje/prijedlog?
19.04.2017., 12:43 | #3728 |
Postovi: 33,326
Gotove kante u pravilu treba izbjegavati. Dečki će ti uvijek složiti nešto bolje za tu lovu. btw, vidim da govoriš o R1. Da li to znači da ti trebaju i Winsi (firma mora imati legalno kupljene winse)?
19.04.2017., 13:42 | #3729 |
Postovi: 560
Nije mi potreban operacijski sustav.
19.04.2017., 13:58 | #3730 |
Postovi: 2,705
AMD Ryzen R5 1600 Asus Prime B350M-A 2x DDR4 8GB (1x8) PC4-19200 2400MHz CL15 G.Skill, F4-2400C15S-8GNT Grafička kartica MSI RX460 2G OC, 2GB GDDR5, 1210/1750MHz Napajanje 500W FSP Fortron/Source Hyper M Toshiba P300 1TB HDD SSD 128GB Samsung PM961, M.2 2280 PCIe Kućište Zalman Z1 ~6000kn |
19.04.2017., 14:06 | #3731 |
Postovi: 430
1 x AMD CPU Desktop Ryzen 5 1600 (6C/12T, 3.4/3.6GHz Boost,19MB,65W,AM4) box, with Wraith Spire 95W cooler 1 x Patriot Viper4, 2800Mhz, 16GB (2x8GB), CL16 1 x Asrock Fatal1ty AB350 Gaming K4, Ryzen, S.AM4 1 x GIGABYTE GeForce GTX 1050 OC GDDR5 2GB/128bit, WINDFORCE 2X 1 x Toshiba SSD A100, R550/W480, 120GB,7mm,2.5" 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x GIGABYTE Pulse 450W, Modular, 80+ Bronze Ukupno: 6552,00 kn -2% popusta = 6420kn. Slaganje i dostava u cijeni. |
19.04.2017., 15:40 | #3732 |
Postovi: 560
