02.10.2009., 09:15 | #601 |
Lokacija: VG
Postovi: 1,756
ASUS HD 5870 Overclocks to 1035/1290 MHz on Air, Aces 3DMark Vantage in CrossFireX 'Here is what four AMD Cypress GPUs can achieve with some careful overclocking, without needing any third-party cooling. Renowned overclocker Kinc sent us details of his latest achievement using four ASUS Radeon HD 5870 1 GB cards installed in a 4-way CrossFireX setup, all overclocked, and cooled by AMD's reference cooler, taking a shot at 3DMark Vantage (Extreme Preset). The four cards returned a score of X26,332 points, with an average frame-rate of 79.49 fps in GT1, and 74.83 fps in GT2. To begin with the cards were overclocked to 1035/1290 MHz, up from reference speeds of 850/1200 MHz (core/memory). This was supported by raising the vGPU to 1.330V using GPUTool, from 1.015V. The platform to drive this feat comprised of an Intel Core i7 965 XE processor, cooled by Intel's reference (boxed) cooler, clocked at 4257 MHz. To seat them all was an ASUS P6T7 WS SuperComputer motherboard. The feat serves as a prelude to what the future holds in two "Hemlock" accelerators, which make use of two Radeon HD 5870 GPUs each.' |
02.10.2009., 09:42 | #602 |
Postovi: 679
Eto i HD5850 uskoro u obliznjem ducanu http://tinyurl.com/ydcux8x |
02.10.2009., 10:09 | #603 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,469
Držite se teme, Furmark to nije
02.10.2009., 10:24 | #604 | |
02.10.2009., 10:30 | #605 | |
muimerP
Lokacija: VG
Postovi: 3,333
2iljade, nije loše. ali mi je simpatično kako se lagano isprse, a nemaju ih na skladištu...
02.10.2009., 11:40 | #607 |
Lokacija: Miami, 1984, Ferrari F40
Postovi: 902
Evo i za ljude plićeg džepa. On par with HD 4870, GTS 250 cards A forum member on mymypc.com posted several images and benches of AMD's upcoming HD 5750, and the new cards looks pretty nice. The HD 5750 reportedly has 1120 stream processors and 56 texture units. Like the 5800 series, it packs GDDR5 memory, but on a 128-bit bus. Two 5700 cards are expected to appear, the $199 HD 5770 and the $149 HD 5750. They should replace current generation HD 4890 and HD 4870 cards, and they should compete with Nvidia's GTS250, GTX260 cards, as well as upcoming DX11 Nvidia hardware. Anyway, in synthetic tests the HD 5750 manages to beat both the HD 4850 and the GTS 250, although by a rather tight margin. According to GPU-Z, the HD 5750's core clock is 625MHz, while memory is clocked at a surprisingly high 1150MHz, offering 73.6GB/s of bandwidth. We're really not sure about the memory spec, so take these numbers with a grain of salt. Ovdje je link na temu na nekom forumu gdje benchano.
02.10.2009., 11:55 | #608 |
Postovi: 936
02.10.2009., 12:02 | #609 |
Postovi: 33,316
Cijene već padaju, ali su još uvijek visoke u odnosu na vani. 5850 bez poreza dođe u Trstu 207€, a ovdje 1.700kn što je 200kn više.
02.10.2009., 14:03 | #610 | |
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,706
S tim da ciljam na 5850,omjere cijene/perf. ne pridonosi ništa na stranu 5870. A i CF ce u prvom kvartalu 2010. bit jeftiniji |
02.10.2009., 15:01 | #611 |
Premija
Datum registracije: Mar 2009
Postovi: 1,631
02.10.2009., 16:12 | #612 | |
Postovi: 12,411
Sapphire HD5870
02.10.2009., 17:37 | #614 |
Postovi: 679
Dok iscekujemo smanjenje cijena 5xxx serije u lokalnim ducanima i uopce izlazak naslova vrijednih kupovine takve grafe, jedno pitanje. Da li je Q6600 na recimo 3.5Ghz dovoljan da hd5870 ili hd5850 zasjaje u punom svijetlu? |
02.10.2009., 17:45 | #615 | |
The Last Akkadian
Datum registracije: Apr 2008
Postovi: 194
Radeon HD 5750
Ako ne volite Googleove prijevode... Ma nije ruzna... Mada, ako je ovo bas za kinesko trziste, ne cudi me. Ugl, nisam ocekivao power connector. Mozda pogresno, no whatever. Za 100€ dusu dala i nije neka prevruca pecnica...
02.10.2009., 18:02 | #616 |
Ovo samo zakopava nvidiju dulje i dublje u drek. Neznam kakve uopce ima šanse taj njihov mrcinski GT3xx ako Ati zasiti tržište od glave do pete sa svim mogućim modelima dok će se oni trgati da naštancaju 1 ili 2 u startu. |
02.10.2009., 18:13 | #617 |
Lokacija: Zd
Postovi: 4,680
Ja bi reka da jest... Don't get me wrong , sigurno da ce biti razlika u odnosu na npr. i5 na 3.5Ghz ali mislim da nece biti znacajna.. |
02.10.2009., 18:36 | #618 |
Postovi: 33,316
Mene ova 5770 po izgledu (cooler) i karakteristikama (128-bitna sabirnica na GDDR5) strašno podsjeća na 4770. A ona je bila preskupa za ono što je pružala pa se bojim da bi se to moglo i sada desiti.
02.10.2009., 18:41 | #619 |
Postovi: 5,887
02.10.2009., 18:46 | #620 | |
The Last Akkadian
Postovi: 194
Ne zna je li cjenovna politika sa 4770 imala veze sa prelaskom na 40nm niti kako se to tocno moglo/trebalo odraziti/opravdati, ali su naznacili na tom kineskom sajtu da bi ova trebala fakat i biti top ponuda za cjenovni razred do 150$. Valjda ce i biti tako. Sto znaci da bi cijene cijele 5xxx serije mogle i jos brze padati (osobito 58xx) nego sto ocekujemo, s obzirom na omjer performansi i (zasada) preporucene cijene ove kartice u odnosu na 58xx kartushe. Osim ako kod nas ne bude oko 1500kn s PDVom, zbog cega bi se konkretno mogli nacekati na povoljnija vremena. Kako to inace biva kod nas... BTW, vele na TPU forumu, kako su na neweggu dobili i rasprodali sve primjerke 5850 u manje od dva sata. Nadam se da ce ATI moci dostici potraznju...inace bi cijene u retailu mogle i rasti, ha?
02.10.2009., 18:46 | #621 |
02.10.2009., 18:50 | #622 |
Super Moderators
Postovi: 17,469
02.10.2009., 19:23 | #623 |
Postovi: 2,112
Došla je, evo sada skidam drivere, i idem instalirati, ćim sve osposobim bacim par fotki kako izgleda u kućištu, i da uz nju se dobiju dvije igere, Dirt2 i Battlestations Pacific ! Idem
RedGreenBlue |
02.10.2009., 19:41 | #624 | |
Postovi: 33,316
Baš sada gledam 5870 'preko bare' i vidim da se kreće oko 380$ http://www.newegg.com/Product/Produc...ption=5870+ati
02.10.2009., 20:08 | #626 | ||
The Last Akkadian
Postovi: 194
Naravno, ovo ovisi i o razvoju price oko GT300. To ne bi bilo lose. Samo da je 5870X2 i da je imamo svi. Zivio tehnoloski komunizam!
02.10.2009., 20:17 | #627 |
Propali User
Postovi: 221
02.10.2009., 20:26 | #629 |
Postovi: 902
Da kupon se dobije, a igricu dobiješ kada pokažeš kupon(u trgovini gdje si je kupio valjda) za koji mjesec.
02.10.2009., 20:29 | #630 |
Lokacija: NaN
Postovi: 3,438
Mislim da je samo CD-Key na njoj koji se zgrebe. |
