Staro 17.11.2004., 01:00   #1
Black Dragon
Black Dragon's Avatar
Lokacija: Agram
Postovi: 2,982
Half Life 2 Error
Tolko čekali a ono nema igranja
Eto kako riješiti problem i koji je ako ga imate ...
Map Version is 0, expecting 19 Half-Life 2 Error
November 16, 2004 - There's a nasty Half-Life 2 bug out there that is stopping people from playing this seminal shooter. Valve's Erik Johnson sent out this to help those folks:
For people that are running into the bug on startup that looks like:
"Map Version is 0, expecting 19"
Try this to see if it works:
1. Go into your \Steam\SteamApps folder.
2. Rename the file called sourcemodels.gcf to something else.
3. Relaunch the game.
This is going to require a redownload of this file, but if you want to get playing tonight it's probably the best path. There are a couple of people now that were in this situation that were fixed this way.
As soon as we possible we'll release a fix for this that will not require this workaround.
Please let me know if this does or does not fix this specific problem for you. Just shoot me an e-mail at erik@valvesoftware.com. If this does fix it, it would be useful to get copies of a couple of the renamed (bad) cache files.
I BTW ATi melje nVidiu u HL2 vidi
http://theinquirer.net/?article=19707
Staro 17.11.2004., 01:44   #2
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,629
cini se da ATi ima ruke u HL2 enginu, isto kao sto je nVidia "sponzorirala" doom3 engine (sponzorirala = ucinila tu igru neigrivom na bilo cemu osim novijih nvidia kartica, dakako)
bilo kako bilo, kada izadje Counter Strike mod za HL2 i kada ljudi diljem svijeta krenu igrati CS (baziran na HL2) doom3 ce sluziti samo kao jedan od benchmarkova, kao sto je recimo bio max payne ili far cry danas
Drinking Rum before 10am makes you a Pirate, not an Alcoholic.
MasterX je offline   Reply With Quote
Staro 17.11.2004., 03:00   #3
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ne baš u tolikoj mjeri koliko Nvidia u Doomu.
Ti iz Valvea su malo veće lopine, oženili su oni za finu lovu i ATI i Nvidiu
Staro 17.11.2004., 06:19   #4
ozren
PC Ekspert
ozren's Avatar
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
NV i Doom III = nema lopovluka
stvar je tu cista, jednostavno ATi kao prvo nemre slozit dobar OpenGL shader2.0 driver opcenito - nema tu 2.0b patha i takvih sranja. a onda plus kaj za OGL nemre napravit sve one optimizacije za AF kao sto moze za DX - OGL ne ferma bilo sto takvog. rezultat je takav kakav je - sramota za ATi i samo to, nema tu varanja. i svi oni koji se nadaju da ce ATi sredit drivere - nece.
sto se tice HL2 i ATi = ima lopovluka, nazalost
a u cemu? pa npr. Valve uopce jos NV-i nije dao finalnu verziju dok je ATi vec ima dugo. ATi je zato lijepo izoptimizirao drivere, a NV ce to tek moci sada.
mene to nis ne cudi - kad pocnes tolko kasnit sa releasom, kada ti ukradu code jer si budala... na neki nacin moras spasit firmu. Carmacku se to nemre desit.
a sto se bencheva tice, to je iz ATi prezentacije - takvim stvarima se nikad nemre vjerovat. nagledao sam se takvih.....
Nissan GT-R Black Edition
ozren je offline   Reply With Quote
Staro 17.11.2004., 11:27   #5
darth_maul
Lich
darth_maul's Avatar
Datum registracije: Jul 2004
Postovi: 201
A i ako nece raditi 60 fps-a nego 40-ak, ja sigurno necu biti previse razocaran
Athlon64 3400+ 512kb/ABIT K8V MAX3
2x WD RAPTOR 36gb@RAID 0
Pioneer DVD+RW d.l. + Lg DVD-rom
Leadtek 6800gt@400\1100
2x 512 ddr Kingmax, 433Mhz
Chieftec,Midi DRAGON+Antec 550w
Samsung 19" Dynaflat SM997DF
SB Live! 5.1 + Creative 5.1 P580
2001:22,236/2003:12,429/2005:5,344
darth_maul je offline   Reply With Quote
Staro 17.11.2004., 13:49   #6
ozren
PC Ekspert
ozren's Avatar
Postovi: 1,214
Nisam jos puno isprobavao ali u CS: Source video stress testu na 10x7 4x/8x dobim 117fpsa sto mi se cini ok
Staro 17.11.2004., 14:23   #7
Jelc
Super Moderators
Postovi: 17,485
Niko ne spori da je Nvidia brža u OGL-u od ATI-ja.
Ali to da nema lopovluka kaj se tiče DOOM3 i Nvidie ne stoji.
Carmack je igru napravio tako da se shader instrukcije moraju izvršavati isključivo preko look-up texturne tablice, a isti posao ATI izvodi brže na drugačiji način.
Način izvršavanja tih shader instrukcija paše kaj se tiče brzine ISKLJUČIVO Nvidii...
Ati isti posao izvršava sirovom kalkulacijom brže nego kako je to Carmack napravio u engineu igre...
Kad su ga pitali za to rekao je da je on napravio igru takvu kakva je, da to sve stoji ali da je gotovo i da mu ne pada na pamet ništa mjenjati jer bi to predstavljalo "preveliki i preskup" posao koji mu se ne isplati delati...i bla, bla...
I nitko ne spori da je i sa takvim izvođenjem ATI u DOOM3 iza Nvidie, ali ni približno toliko koliko su pokazivali prvi rezultati kad je igra tek izašla.
Ovako kad čitam kaj si napisao čovjek stekne dojam da je u svemu u čemu je ATI brži od Nvidie kumovala hrpa razno-raznih optimizacija i ništa drugo...
Staro 17.11.2004., 14:47   #8
Mailman
Mailman's Avatar
Postovi: 1,606
Mailman je offline   Reply With Quote
Staro 17.11.2004., 16:25   #9
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
ati će biti bolja u hl2, nvidia u doom3 i bok...tako je napravljeno i tako će i biti
ali za ove rezultate mi nitko nemože reći da su vjerodostojni jer ati svoje drajvere optimizira (ne mislim na ništa loše,varanje i slično) za hl2 već dugo vremena ,a nvidia je tek na početku prilagođavanja svojih
IMO prerano je za ikakve zaključke o tome kako će se 6800 serija ponašati u hl2
Staro 17.11.2004., 18:35   #10
ozren
PC Ekspert
ozren's Avatar
Postovi: 1,214
da, samo kaj je tu jos jedan MALI detalj - ATi je znao tocno kako ce Doom III biti koncipiran odpocetka...
I performanse nisu tak-tak, vec ocaj.
Staro 18.11.2004., 02:43   #11
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
e jebiga jelc kak mi se vidi bumo se morali pak najti s berenom i po mogućnosti s ozrenom vu pivnici da im objasnimo neke stvari
pinsla je offline   Reply With Quote
Staro 18.11.2004., 02:45   #12
pinsla
pinsla's Avatar
Postovi: 1,860
oćeš doć do mene da vidiš kak mi grafa očajno vrti almighty Doom 3
Staro 18.11.2004., 05:44   #13
ozren
PC Ekspert
ozren's Avatar
Postovi: 1,214
Staro 18.11.2004., 15:02   #14
Jelc
Super Moderators
Postovi: 17,485
Je...sam je Carmack to tak napravio da se nije moglo tek tak ispraviti, moje osobno mišljenje je da je ATI ipak lagano dobio po njonji zbog onog curenja bete
A i taj timedemo je živi očaj i nema ni najblaže veze sa perfomansama u igri.
Na mom krampu taj demo veli 50, a igra ide glatko, sve high meni dosta
A to je ipak samo jedna igra i za ne faliti jedina u GL-u u kojoj Nvidia tako izrazito dere ATI, malo sam gledao neke nove custom bencheve i razlika je puno manja kaj je jako zanimljivo
Staro 18.11.2004., 15:14   #15
Jelc
Super Moderators
Postovi: 17,485
Samo ne tamo gdje smo bili zadnji put, pivo im i nije bog zna kaj...
Mada nekaj sumnjam da bu Ozren pored dvije žene tek tak zapalil
Staro 19.11.2004., 02:18   #16
Darth Revan
Darth Revan's Avatar
Lokacija: Ireland
Postovi: 1,565
ATI ne melje nVidiu jer po svim novim testovima i iskustvima ljudi koji su igru i prešli i onih koji su je igrali sa 6800 i X800 nvidia skoro ništa ne zaostaje za Ati-em u Halfu 2 naravno s 66.93 vezijom drivera.
Darth Revan je offline   Reply With Quote
