Recorder: Version: P1.0 - HA 1 TA 0 - 8.3.6.0
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: Version: P1.0 - HA 1 TA 0 - 8.3.6.0
=== Scsi-Device-Map ===
CdRomPeripheral : SBU 4H6VS96J 1.03 aa8dsno0 Port 6 ID 0 DMA: Off
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4094MB (4192724kB)
Free physical memory: 2329MB (2385152kB)
Memory in use : 43 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
27.8.2008
ISO compilation
12:03:21 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
12:03:21 #2 Text 0 File Isodoc.cpp, Line 6713
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
12:03:21 #3 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
12:03:22 #4 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
12:03:22 #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorDVD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
12:03:22 #6 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2283615 (507:28.15, 4460MB)
12:03:22 #7 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
12:03:22 #8 Text 0 File DlgWaitCD.cpp, Line 2948
Recorder: PHILIPS SPD2414T, Media type: DVD+R
Disc Manufacturer ID: , Media Type ID: <004>, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
12:03:22 #9 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
12:03:22 #10 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2283616 (2283616) = #2283616/507:28.16
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2283616 blocks [E: PHILIPS SPD2414T]
12:03:22 #12 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
12:03:22 #13 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
12:03:22 #14 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
12:03:22 #15 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
12:03:22 #16 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
12:03:22 #17 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11.080 KB/s)
12:03:22 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
Vec mi je druga Philips DVD przilica riknula ove godine. Prva je izdrzala 4 mj, druga cak 5. mj. Ni prije nisam imao previse srece sa DVD prziliciama i rijetko koja mi izdrzi vise od 1g. i mozda nekih 200/300 sprzenih medija. Jedina koja se vec godinama drzi je neka prastara BTC.
Kupih u Feniksu prvu 2412T przilicu i nakon 100tinjak sprzenih DVDa vise ne przi. Cita DVD-e i CD normalno. CD-e przi normalno DVD nece. Pocelo je sa par losih sektora pri kraju DVDa, a onda je prestalo snimati. U 90% slucajeva dodje do 2% i onda za par min Nero 8 iznaci CD van uz "Write error". Takav DVD medij zatim mogu bez problema zaprziti na drugom racunalu u drugoj przilici (Pioneer/BTC). U 10% slucajeva DVD se pocne przit i stane negdje izmedju 3-100%. Takav medij je onda za smece. Ako se sprzi 100%, onda je pun gresaka.
Tu prvu sam u 5 mj. vratio i dobio (jedva) novu 2414T u zamjenu, posto 2412T vise nije bilo. Mislim da ova 2414T przi na 20X, a ova 2412T na 16 ili 18X...uglavnom izgleda sve isto. E i sad nakon 4 mj. i max 100 sprzenih DVDa i ova 2414t radi ista sranja kao i ona prije.
S obje przilice sam probao snimati na Verbatim, Traxdata pa cak i Philips medije. Uvijek ista stvar. Onu 2412 sam i selio na razlicita racunala i uvijek je radila iste probleme. S ovom mi se sad ne zajebava.
Sad vise ni sam nisam siguran zasto mi prze tako cesto umiru. Prije sam mislio; OK crkla prza jer je losa i gotovo. Ali sad me vec stvarno muci...
I ne znam dal' da sad vracam to opet u Feniks, ili da ju rastavim i probam cistit? I prvi put su mi prek qrca dali ovu 2414, pa imam osjecaj da drugu necu dobit...
Bus Type : default
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Use Inquiry : 1
27.8.2008
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
wow..svjetlo siva slova na bijeloj podlozi..divno.
Imaš garanciju? Imaš. Nemaju ti oni šta ne dat.
“Free software” is a matter of liberty, not price. To understand the concept, you should think of “free” as in “free speech,” not as in “free dinner.”
Nisam htio da nero report upadne u prvi plan i napravi vizualnu zbrku i time odvrati ljude od odgovaranja. (Profesionalna deformacija). A racunao sam na dosjetljivost, tj. mogucnost selektiranja teksta...
Ipak, u pravu si; slabo se vidi, pa ide nijansa tamnije sive.
Autor Brown Acid
Imam garanciju. jos 15 mj. ako se racuna i ona prva przilica. Znam da sam u pravu, ali mislim da je konflikt zagarantiran, s obzirom da je i kod zamjene prve prze bilo natezanja. Samo sam u posljednje vrijeme psihicki labilan pa se bojim da ne pocnem bacati sjebane medije ko shurikene tam po ducanu.
__________________ It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64 HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64 CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 23.09.2008. u 21:49.
Nemaš se ti kaj bojat. Jel imaš garanciju? Imaš? Dal proizvod radi? Ne radi. Dalje nije tvoj problem. Ak te budu zajebavali, samo reci da ti daju napismeno zašto ti ne žele zamjenit proizvod. I reci im da s tim ideš u neznam, novine, radio, tv, društvo za zaštitu potrošača.... Očito je da je proizvod nekvalitetan. A zašto philips radi nekvalitetne proizvode, nije tvoj problem.
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Ustanovili su u Feniksu da ova druga stvarno ne radi. I, dobio sam treću pržilicu. SPD2514T. Philips naravno. Drugu ne daju. I ova prži, ali zato ne čita. I to na skroz čudan način. Ovako, ako idem kopirati jedan file sa DVDa (bilo kojeg, sprženog na bilo čemu), ili par njih - iskopira se bez problema. Ali ako selektiram više fileova ili jedan veliki i drag&dropam to u windows exploreru u neki folder na HDDu (bilo kojem), počne kopirati i stane negdje random. Jednostavno se medij u driveu prestane vrtjeti i LEDica na driveu više ne svjetli. I jednostavno tako stoji. Ništa se ne dogodi. Nikakvu grešku ne prijavi Vista. Ništa. Osim što se Windows Explorer smrzne na 5-15min. I onda se "odmrzne" i sve OK dalje. I sad ako krenem snimati tu hrpu fileova jedan po jedan, svi se normalno snime na HDD.
Također svaka radnja koja obuhvaća pristup cijelom kapacitetu DVDa na toj pržilici, kao recimo Nero DriveSpeed, DiscSpeed ili Drive Benchmark prouzroči već opisan problem. Samo što se osim Explorera smrzne i ta Nero aplikacija.
Ništa mi nije jasno. Nešto tu smrdi. Osjećam se kao zadnja budala da nakon što si sam slažem konfe od 1993., 2008. moram pisati ovakve poruke po forumima. Ali jednostavno nemam pojma u čemu je stvar. Zar je stvarno moguće da baš nijedna Philips pržilica ne valja. U Feniksu me uvjeravaju da ih rijetko vraćaju.
OS je Vista x64. Osim s Philips pržilicama nikad nikakvih problema.
DMA uključen.
Mediji Verbatim/Traxdata.
Računala redovito održavam; virus i addware free, registry čist...
Druga pržilica (neka stara BTC) u istom računalu radi...
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
thopok, hvala, ali prvo sam pogledao na philipsovom supportu naravno i isključio sve što stoji u linku kojeg si dao gore. Da nisam, ne bih ovdje ni pisao. Ove prethodne dvije pržilice s kojima sam imao probleme su štekale na Vista X64, XP 32/64 Pro. Ovu koja dobro piše, a ne čita još nisam isprobao na drugim računalima. Ali sam zato na ovom računalu isprobao drugu DVD pržilicu i jedan Combo uredjaj i oba su bez problema kopirala.
Što bi mogao biti problem u BIOSu?
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
I ove imaju 2 ili 3 godine garancije.
Ali sumnjam da je problem u pržilici. Mislim da nije bio ni problem ni s ove dvije pržilice prije...Nešto drugo ne valja...
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
kvaliteta izrade današnjih dvd-prža je blago rečeno loša...nije ništa čudno da nakon par mjeseci intezivnijeg korištenja nešto ne radi, neovisno o proizvođaču
SATA ili AHCi svejedno mora radit bar osnovne radnje a kopiranje to je
Jes, ali ova zadnja koja ne čita je par dana stara i nije ni očitala ni spržila pošteno dvd. A postoji mogućnost da su i ove dvije prije isto tako zezale zbog nečega od početka, a ja nisam primjetio.
Još uvijek bih volio znati koja to točno razlika SATA-AHCI može utjecati na rad DVD-RW drivea.
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Koji s q mučiš s tim Philips pržama? Probaj u nekom drugom kompu i ako i tamo ima problema, opet je zamijeni. Ali, traži neku drugu firmu (LG/Samsung/Pioneer).
Skinuo sam DaemonTools (4.301 lite) i Nero8, te stavio Nero9 i sada izgleda sve radi. Nisam siguran koje od to dvoje je bilo problematično. Pretpostavljam DaemonTools. Sada u retrospektivi mi se čini da su ti problemi i počeli sa instalacijom DeamonTools. Ali nisam 100% siguran. BTW, mrzim takve stvari, kad ne znam u čemu je točno problem.
Spržio sam i prekopirao na HDD nekoliko DVDa i CDa. Bez greške za sada. I druge apllikacije koje su do sada štekale, kao npr. Nero DiscSpeed i CDCheck također rade bez greške...nadam se da će tako i ostati.
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
znam da je vec rjeseno ali moram dodati - nije li glupo da ljudi uporno covjeku preporucuju da ne uzme Philips i kupi samsung kad Philips ionako uopce ne pravi te przilice i iza njihove maske su iste przilice koje samsung i jos par brandova prodaje pod svojim imenom?
Dobro sto mu jos niste rekli da obavezno kupi fortrona 350W, samsung 2232BW, 8800GT....jesam li zaboravio nesto od toga sto svaki forumas mora kupiti bez obzira kakvih i s cime problema imao?
